Official ZT60 Owners Thread - Page 208 - AVS Forum | Home Theater Discussions And Reviews
 532Likes
post #6211 of 14732 Old 01-07-2014, 09:00 AM
colnago's Avatar
Quoted: 70 Post(s)
Liked: 53
Originally Posted by Yeti1234 View Post
Do all the VT and ZT do this too? All complicated by the fact that I don't have much time left if I want to step up to the ZT. It would be well worth the money to me if it solved this problem but would totally bum me if I paid the premium for a ZT and it did the same thing.
I'm going to post this in the other thread too as I am looking for as much feedback as I can get. Thanks in advance!
Most, if not all image related issues posted here can be resolved by settings adjustments. Most pig the complaints regarding image quality are about the default presets...factor in that people are using varying sources/material as well.
You're using a few different sources and inputs, and their respective set of settings will most likely differ. You may even have to use differing "color gamut", and "HDMI color" settings on each input. Also, the set may need about 300 hrs to "normalize". It took closer to 400 for my reds and blues to be "not a overly vibrant...YMMV.
colnago is offline
post #6212 of 14732 Old 01-07-2014, 09:50 AM
Inseconds99's Avatar
Originally Posted by Axxion View Post
Wait longer, then unbox it and give it an hour or two to dry out with your heat running
They unbixed the tv put it in the stand then put it on the tv stand. Then I manually checked with a flashlight for imperfections. I didn't want them to leave without it being lifted onto my tv stand and me performing a manual inspection.
Inseconds99 is offline
post #6213 of 14732 Old 01-07-2014, 10:15 AM
AVKIK's Avatar
Quoted: 22 Post(s)
Liked: 24
I just received my zt60! Unfortunately it's a June build date. So no fan fix. I'm a bit concerned because when I got my vt60 the front panel had stickers with all the features and a protective plastic strip on the bottom. This zt60 has none of that. Only a energy rating sticker like you would see on display. Is This how your tvs looked when it arrived? Can someone please tell me again how to check the hours and should be all zeros? Waiting to fire it up because it's cold! Thanks guys.
AVKIK is offline
post #6214 of 14732 Old 01-07-2014, 10:31 AM
Terebi's Avatar
Yes, just energy rating sticker. Status 4 is the easiest way to check hours.
Terebi is offline
post #6215 of 14732 Old 01-07-2014, 10:31 AM
bvader's Avatar
Mine had energy rating sticker, and I thought a small panny sticker, no film or protector other than the nice plastic / soft "envelope. I had Zero hours.
Menu - Help - Version - Status 4
BTW I have a May build date and my fans are pretty quiet...
Long Live The Gorn!
bvader is offline
post #6216 of 14732 Old 01-07-2014, 11:01 AM
chillspace's Avatar
Just the energy rating sticker for me, too. Zero hours.
Eric
My Stuff: Panasonic TC-P65ZT60 w/  Ideal-Lume Bias Lighting, Yamaha RX-V3800, Oppo BDP-103D
chillspace is offline
post #6217 of 14732 Old 01-07-2014, 11:06 AM
changboy's Avatar
Liked: 53
The tech just leave my house and i got the fan fix : just 4 small slice of foam, 3 under the left fan and just 1 under the right fan, cost of this service and bill will be send to panasonic is : $ 263.22 !!!!!
changboy is offline
post #6218 of 14732 Old 01-07-2014, 11:26 AM
bvader's Avatar
No Panny Master Panel Sticker?... maybe I am remembering wrong...super minor but as long as we are all group OCDing... wink.gif
Long Live The Gorn!
bvader is offline
post #6219 of 14732 Old 01-07-2014, 11:31 AM
repete66211's Avatar
Quoted: 130 Post(s)
Liked: 287
Originally Posted by Saevio View Post
A couple questions if you all dont mind.
I've read many discrepancies as to slide or no slides,
personally for the first 100 hours i plan on not watching anything with bars or logos
and when not actively watching, i want to use the slides (via PS3)
any other methods preferred i've missed?
also, does anyone have experience with the Android ZT App for day to day use?
going to pick up Logitech Harmony Ultimate Hub this or next week.. does anyone have any experience with this?
Wii, PS3, XBox 360, DirecTV Genie, and soon Denon 1713(i believe)
and one last question, I have two fresh water fishtanks in the room that the ZT is going in, while they do not in anyway offer a lot of humidity,
how much is too much for day to day use?
Regarding slides, full screen content (16:9, no logos or tickers) effectively accomplishes the same thing as running slides so if you want to actually watch your TV you shouldn't worry about that.
I had a Harmony One for years until I stepped on it a couple of months ago. I replaced it with an Ultimate. It's expensive but I really like it. It's definitely an upgrade from the One, especially the RF functionality and no-delay buttons. I've used the app (iPhone) and it also works well, especially if you don't like the position of the FF/REW buttons at the top of the remote. However, the remote is easier to use so I wouldn't rely solely on the app, but it may be something you can get used to. However, if that's your plan, you may want to consider the Harmony Smart Control instead. (I have a ZT60, Denon AVR, PS3, Xbox 360 & AT&T cable.)
Saevio likes this.
repete66211 is offline
post #6220 of 14732 Old 01-07-2014, 11:38 AM
AVKIK's Avatar
Quoted: 22 Post(s)
Liked: 24
OCD?? What's that? :-) thanks for the help guys. Odd that the vt60 had more protection than the zt60. All is well. I will fire it up in about 30 min. That makes 2 hours. It came out if a van. A tad nervous because my room is looking awefully bright right now and the panel looks crazy reflective with it turned off. Fingers crossed!
AVKIK is offline
post #6221 of 14732 Old 01-07-2014, 11:38 AM
Axxion's Avatar
Liked: 89
Originally Posted by myared View Post
OK then Axxion, I need your help. My wife put a stop to my dilemma of how to move my TV and lift it up on top of the drawer chest with one strike: she tried lifting one corner of the TV off the floor and couldn't even move it. She imediately said: Nope, no can do! So there. Back to square one. My TV is still sitting on the floor running slides even though I'm now past 100 hours (which is probably not a bad thing). I need to find me a strong friend to help me with this TV. Axxion, how would you like to visit Little Rock?
Lol not for free, im in houston. It would be much more cost effective give a random person around your street 20 bucks to help. Or put a ad in craigslist. Maybe a family memeber? If none of that works, have pizza delivered to your house and bribe the pizza man with cash lol. Good luck, just dont let anyone try to pick it up who isnt comfortable doing so.
Axxion is offline
post #6222 of 14732 Old 01-07-2014, 11:40 AM
changboy's Avatar
Liked: 53
OMG look this video at CES las vegas 2014 of the director of samsung can't believe what happen there :
https://www.youtube.com/watch?v=R4rMy1iA268
changboy is offline
post #6223 of 14732 Old 01-07-2014, 11:41 AM
Axxion's Avatar
Liked: 89
ok. Let it sit for a while still. Better safe than not.
Axxion is offline
post #6224 of 14732 Old 01-07-2014, 11:48 AM
Jason626's Avatar
Quoted: 157 Post(s)
Liked: 152
He is a movie director Michael bay. You know the director of transformers movies smile.gif
His TelePrompTer he was reading from wasn't working correctly. I guess he got nervous and left stage lol.
Jason626 is offline
post #6225 of 14732 Old 01-07-2014, 11:51 AM
Quoted: 130 Post(s)
Liked: 287
Haha hilarious! Michael Bay chokes on stage. I can't believe this guy is a paid shill. Like he doesn't make enough money off those ****** Transformer movies.
When Samsung asks for its endorsement money back he should do what Samsung service did to me when I called about the strip of dead pixels on my plasma panel.
post #6226 of 14732 Old 01-07-2014, 11:53 AM
AVKIK's Avatar
Quoted: 22 Post(s)
Liked: 24
On another note, Long story short, I'm coming from a samsung f8500 and I think panasonic needs to take a lesson or two from samsung on how to package their tvs. The f8500 was packed way better than this zt60.
AVKIK is offline
post #6227 of 14732 Old 01-07-2014, 11:59 AM
chunon's Avatar
Quoted: 2061 Post(s)
Liked: 1804
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #6228 of 14732 Old 01-07-2014, 12:00 PM
ab2ab's Avatar
+10!!
I've had all of the top 2013 models and the Panasonic packaging is a little more than wrapping in a paper towel!
ab2ab is offline
post #6229 of 14732 Old 01-07-2014, 12:24 PM
changboy's Avatar
Liked: 53
hehehe funny, samsung will not introduce a new high end plasma this year but later they will produce a lower model from F8500 without the feature as built-in camera and metal curve stand for a lower price, and panasonic claim there new LED 2014 will give the same accurate picture from plasma model and this i not believe it.
So new tv is all around OLED and giant 105 inch curved LED from sammy and lg all at high price so i still happy with the ZT.
I'ts a shame to see a few months later they show you a new panel better of the one you just buy and this will not happen this year and maybe for a few years to come, all in all this was a good move bought one of those 2013 panel.
changboy is offline
post #6230 of 14732 Old 01-07-2014, 12:34 PM
Quoted: 130 Post(s)
Liked: 287
I certainly hope that's the case. If only my woman shared my enthusiasm for getting one of the last great TVs (for a while anyway). She still makes fun of me commenting on how black it gets.
post #6231 of 14732 Old 01-07-2014, 12:55 PM
My ZT is up and running, NO buzzing, No humming from the fans (October 2013 build) unless you put your ear behind the TV!! The picture is perfect, works well in a bright room. Sound and vision settings are in and I'm watching the Avengers in 1080p from my Apple TV and it looks amazing even in my bright room!!!. I have full control over the lighting as it is in a basement so the TV looks even more amazing with the lights off. I am finally happy with a purchase of a TV.
vinnie97 likes this.
post #6232 of 14732 Old 01-07-2014, 12:56 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
vinnie97 is offline
post #6233 of 14732 Old 01-07-2014, 01:14 PM
myared's Avatar
Liked: 26
And... did it work; is the fan noise gone?
myared is offline
post #6234 of 14732 Old 01-07-2014, 01:20 PM
myared's Avatar
Liked: 26
OK then you're off the hook but only for 6 months or so until we will have moved to... you guessed it, Houston! If I need any heavy lifting then I'll have to find you.
myared is offline
post #6235 of 14732 Old 01-07-2014, 01:26 PM
myared's Avatar
Liked: 26
I would like to turn the pixel orbiter off but it's grayed out no matter what picture mode I'm in (manual says it's grayed out in THX and EBU default). I've tried all picture modes, no luck. Anyone knows how to fix that? Thanks.
myared is offline
post #6236 of 14732 Old 01-07-2014, 01:36 PM
AVKIK's Avatar
Quoted: 22 Post(s)
Liked: 24
Picture looks great so far. I would have to say the samsung f8500 reflects less light. Also the fans on this thing are cranking pretty loud def more than the vt60 I had. Also the buzz is louder. Didn't seem bad at first, but the buzz is worse than the samsung and the vt60. Gonna run slides for a couple hours, grab a workout and come back home to tinker with it. The colors have so much saturation to them which I love!
AVKIK is offline
post #6237 of 14732 Old 01-07-2014, 01:46 PM
changboy's Avatar
Liked: 53
I'ts seam to be more silent but not just that , the airflow will be oriented more at the right place for a better cooling of the 2 inside board.
I also draw a lil shéma with the electronic touchpen (funny) for show you how this can give a better cooling of the inside board.
bvader likes this.
changboy is offline
post #6238 of 14732 Old 01-07-2014, 01:50 PM
Ronald Epstein's Avatar
Quoted: 103 Post(s)
Liked: 92
AVKIK,
Think you are more susceptible to panel buzzing than perhaps others as this is
the second display that you have had problems with.  Not criticism, mind you,
but just odd.  My ZT60 has no buzzing whatsoever.
Better saturation than the Samsung F8500?
When you get better acquainted with your new display I would love to know
which picture you prefer better.
Best of luck with your new display.
Ronald Epstein is offline
post #6239 of 14732 Old 01-07-2014, 02:10 PM
Originally Posted by Ronald Epstein View Post
AVKIK,
Possibly but I owned a VT60, and 2 f8500's and now a ZT60. The ZT does not buzz, the 2 f8500's were so annoying I couldn't take it. I have very good hearing and can pick out all types of different high pitch noises. He has just been unlucky just like me when it comes to panels having louder then normal buzzing.
post #6240 of 14732 Old 01-07-2014, 02:31 PM
Axxion's Avatar
Liked: 89
No problem get ahold of me then.
Axxion is offline
Panasonic Viera Tc P65zt60 65 Inch Plasma Hdtv , Panasonic Viera Tc P60zt60 60 Inch Plasma Tv
