Official ZT60 Owners Thread - Page 244 - AVS Forum | Home Theater Discussions And Reviews
 532Likes
post #7291 of 14727 Old 01-21-2014, 12:24 PM
repete66211's Avatar
Quoted: 130 Post(s)
Liked: 287
Originally Posted by Axxion View Post
depends on your settings, you can have anywhere from 10 posts to 100 posts per page. I use a cell so i put it at 10, for some reason my phones browser will jump to the top for no reason other to be obnoxious, thats why i set it to 10 because trying to find where i left off is a pain if its set any higher.
Mine does the same thing. Why does it do that? Thanks for the tip, I think I'll change my settings.
repete66211 is offline
post #7292 of 14727 Old 01-21-2014, 12:37 PM
larrygeary's Avatar
Liked: 46
Originally Posted by derekarita View Post
I have a 151FD Pioneer that has great front firing speakers attached at the sides of the display.  The rear firing speakers of the ZT are lacking.  Short of a full on sound system or sound bar, are there any passive speakers that would simply plug into the speaker outs that would sound better, but be discrete in appearance?  At the very least, is there a sound bar without sub, that would still sound good?
The ZT60 has no speaker outputs.
larrygeary is offline
post #7293 of 14727 Old 01-21-2014, 12:38 PM
Inseconds99's Avatar
Originally Posted by Cleveland Plasma View Post
Some feel you would have been fine from hour 1 wink.gif You are good .
I have an old 42" 720p Panasonic plasma from 2006, that has clear discoloration from 4:3 content from the plasmas infancy. You can clearly see that the picture is darker where the black bars would be on the left and right of the screen. You have to really look for it but it's def there.
It's def burn in from years ago when hd content was not so prevalent. That's why I'm being extra careful with this plasma. I don't want long darker color areas on the top and bottom of my ZT from letterbox format.
Inseconds99 is offline
post #7294 of 14727 Old 01-21-2014, 12:40 PM
*UFO*'s Avatar
Quoted: 465 Post(s)
Liked: 362
The ZT allows you to change the bars from black, to white, to shades of gray in-between black and white.
*UFO* is offline
post #7295 of 14727 Old 01-21-2014, 12:42 PM
cheridave's Avatar
I just received my 60ZT60 from Best Buy.
Serial # MJ3303xxxx
Build: October 2013
A16422
Inspected For Fan Fix and Back Cover Alignment...Completed at factory!!!!
Happy to report that I found no issues.
Plasma is completely silent.
Wishing good luck to those who are waiting for their Plasmas.
Dave.
"Appeasment only makes the Aggressor more Aggressive"
cheridave is offline
post #7296 of 14727 Old 01-21-2014, 12:47 PM
ClemsonChad's Avatar
Serial # MJ3303xxxx
Build: October 2013
A16422
Dave.
Congrats! I should get my 65ZT60 from VE in about a week, and I'm hoping that mine has a later build date. Enjoy!
amercnchopz34 likes this.
Panasonic TC-P65T60
Oppo BDP-103D
Pioneer VSX-1120-K
Monitor Audio RS6 Silver F, R, C, Surrounds
HSU VTF-1 MK2
PS3
CinemaQuest Ideal-Lume
Harmony Remote
ClemsonChad is offline
post #7297 of 14727 Old 01-21-2014, 12:54 PM
UniversalGC's Avatar
As to the Netflix discussion, I almost never achieve better than 720p, and most commonly receive 480 SD. I'm using my blu ray as the Netflix source and have an excellent wired and wireless connection (50+ mbps).
My settings are to use HD as default, but I still don't have good luck at all. Every once in a blue moon I'll achieve 1080p but it's almost always short lived. Drives me crazy.
My components:
Panasonic TC-P65ZT60 TV
Yamaha RX-V673 Receiver
Sony BDP-S590 Blu-ray
Definitive Tech Speakers 7.1
UniversalGC is offline
post #7298 of 14727 Old 01-21-2014, 12:59 PM
derekarita's Avatar
I take it then, that this is all due to our internet connection speed?
derekarita is offline
post #7299 of 14727 Old 01-21-2014, 01:00 PM
derekarita's Avatar
Oops...guess that's out then...
post #7300 of 14727 Old 01-21-2014, 01:02 PM
amercnchopz34's Avatar
Quoted: 61 Post(s)
Liked: 31
What is the build date im looking for to have fan issue taken care of from factory??
amercnchopz34 is offline
post #7301 of 14727 Old 01-21-2014, 01:02 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2008 Post(s)
Liked: 2169
Does not mean breaking it is is going to help an issue like that. To each his own though... You would have to test like ten panels on every model to boot, for years, to figure out if break would really helps a situation like that or not.
Cleveland Plasma is online now
post #7302 of 14727 Old 01-21-2014, 01:09 PM
whoaru99's Avatar
Liked: 69
Maybe I'm missing your point, but at the rate things are going you may well be out of luck to get one at all, trying to cherry pick for that.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #7303 of 14727 Old 01-21-2014, 01:09 PM
rjchyzy's Avatar
Is there a certain month build I should be hoping to get? Any way to tell before I take delivery? If it has not been modified is this something they will let me do myself if they send me the parts? I work on electromechanical things for a living. Are the cracks that have been found due to someone performing the mod wrong? Ex: geek squad. Lol
I'm leaning towards getting one ordered today. Rick
rjchyzy is offline
post #7304 of 14727 Old 01-21-2014, 01:26 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
August is the bare minimum you want for more silent operation. Yes, based on the evidence we've seen so far, incorrect re-installation of the back panel is the catalyst for the microcracks. Said microfracture discussion was actually augmented by those who had the problem, and having a discussion about it is certainly germane to the topic of this thread.
Inseconds99, what you're describing sounds more like uneven wear from which no plasma is immune no matter how many hours of break-in you employ.
vinnie97 is offline
post #7305 of 14727 Old 01-21-2014, 01:30 PM
That is a factor for some but shouldn't be for me. I have the fastest plan my ISP offers and it consistently tests very well on speedtest.net, etc...
Trying to watch something on Netflix during prime time hours is an issue too because so many users are doing the same doing those times.
But at 2:00 in the afternoon, HD/Super HD should be no problem for me, yet it is.
My components:
post #7306 of 14727 Old 01-21-2014, 01:34 PM
derekarita's Avatar
Hmmm....what now?  Well, best that Netflix shows for me is 720P and that takes about a minute to get there, starting with SD.
post #7307 of 14727 Old 01-21-2014, 01:40 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Slightly OT question, does Netflix Super HD compare favorably with the quality of Vudu HDX?
vinnie97 is offline
post #7308 of 14727 Old 01-21-2014, 01:41 PM
larrygeary's Avatar
Liked: 46
If you get a July build or earlier, it won't have the fan fix. September and later, it will already have the fan fix installed. August - maybe, maybe not. The build date is on the back of the set in the center. You can get the foam from Panasonic for about $3 and install it yourself, just taking care to put the rear panel on properly. But some people have excessive buzzing that may be caused by a bad circuit board, or by loose screws. This may or may not need to be replaced by a Panasonic repair facility.
ClemsonChad likes this.
post #7309 of 14727 Old 01-21-2014, 01:56 PM
colnago's Avatar
Quoted: 70 Post(s)
Liked: 53
Is it?
colnago is offline
post #7310 of 14727 Old 01-21-2014, 01:58 PM
colnago's Avatar
Quoted: 70 Post(s)
Liked: 53
Wait longer...it took 3-4 minutes of "negotiating", with the ZT on WiFi, until I was able to take the pic of "SuperHD". If still no joy (again, 6th season of Lost was the only show I could get to play in SuperHD with my limited time) then you need to upgrade your network, or provider.
colnago is offline
post #7311 of 14727 Old 01-21-2014, 02:00 PM
larrygeary's Avatar
Liked: 46
Originally Posted by colnago View Post
Is it?
That's a line-level output, not a speaker output. He would need powered speakers or an amplifier. There is also some question about whether he would have lip-sync issues with the Toslink output and these converters. (Not all these converters are the same.)
I'm going through similar searches myself. Most of my audio equipment is going on 30 years old.
post #7312 of 14727 Old 01-21-2014, 02:01 PM
drewTT's Avatar
Quoted: 574 Post(s)
Liked: 602
I prefer Vudu HDX. I think that is the best quality streaming service.
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is online now
post #7313 of 14727 Old 01-21-2014, 02:03 PM
Rudy1's Avatar
Quoted: 966 Post(s)
Liked: 1280
I agree...Vudu is clearly superior in terms of picture quality.
ASKHOLE: (n.) A person who constantly asks for your advice, yet always does the opposite of what you told them.
Rudy1 is online now
post #7314 of 14727 Old 01-21-2014, 02:04 PM
colnago's Avatar
Quoted: 70 Post(s)
Liked: 53
Right...but sometimes, "you gotta do what you gotta do"...my ZT will be eventually connected to my "all tube system"...no optical in on my preamp.
colnago is offline
post #7315 of 14727 Old 01-21-2014, 02:04 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
That's how I've always felt, but I haven't yet seen Netflix in Super HD (not all that super apparently).
vinnie97 is offline
post #7316 of 14727 Old 01-21-2014, 02:06 PM
drewTT's Avatar
Quoted: 574 Post(s)
Liked: 602
It's really not. Even on Super HD, you can easily notice compression in dark scenes. Sometimes downright ugly.
post #7317 of 14727 Old 01-21-2014, 02:08 PM
puch96's Avatar
Yes. Especially when Netflix accounts for about 33% of North America internet traffic!!!....
puch96 is offline
post #7318 of 14727 Old 01-21-2014, 02:10 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
I watched an HDX recently (Fast & Furious 6) and noticed some artifacts in the content with low light, so I can only imagine how much worse it would've looked on Netflix.
vinnie97 is offline
post #7319 of 14727 Old 01-21-2014, 02:41 PM
larrygeary's Avatar
Liked: 46
Vudu will give you 5 HXD movies for signing up, so you can try it out for yourself.
post #7320 of 14727 Old 01-21-2014, 03:09 PM
humanvr4's Avatar
Can you explain this a little bit more, or what setting it is called?
humanvr4 is offline
Panasonic Viera Tc P65zt60 65 Inch Plasma Hdtv , Panasonic Viera Tc P60zt60 60 Inch Plasma Tv
