Official ZT60 Owners Thread - Page 277 - AVS Forum | Home Theater Discussions And Reviews
 545Likes
post #8281 of 14799 Old 02-03-2014, 08:27 AM
bob brennan's Avatar
Quoted: 105 Post(s)
Liked: 148
Originally Posted by whoaru99 View Post
I believe it was set to 1080p but was even worse then. I'll definitely play around with the settings more though. PITA because I have to disconnect it from AVR, reconnect to the TV, then change it back to the AVR connection These are on opposite ends of my room.
Like you, what I don't fathom is why it works through the AVR with the older TV but only direct to the newer TV, yet other things work just fine both ways. And why it's just the OSD....weird stuff, man.
If you can watch the blu-ray movie A-OK & only have a problem with the OSD - appears it is the OSD - borrow a newer player - ones you have are older models! AND remember what Sherlock Holmes said ""Once you eliminate the impossible, whatever remains, no matter how improbable, must be the truth."
Panasonic TC-P65ZT60 - Oppo BDP-103D - Panasonic DMP-BDT220 - Toshiba HD-DVD-3A - OPPO DV-981HD - Harmony ONE
Onkyo TX-NR809 --- Definitive Technology - Studio Monitor 65 (2) - CS8040HD - Studio Monitor 45 (2) - Super Cube 6000
bob brennan is offline
post #8282 of 14799 Old 02-03-2014, 08:31 AM
whoaru99's Avatar
Liked: 69
I managed to wade through the flashing OSD to change the player's resolution. Forcing 1080p had no effect; not better, not worse, the same.
But, when I changed to 720p or 1080i, then the OSD worked fine. This is interesting because I think my Roku is just 720p. Not sure about the WDTV though, I'll have to check.
Looks like I'll have to swing by the local big box store to see if a newer player is the answer. Any suggestions for a decent cheap BD player? Not ready to spend another $500 right now to give the Oppo a try.
Still don't understand why it works direct but not through the AVR. That doesn't seem to indicate a problem with the player, although maybe that would be the easiest "fix".
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #8283 of 14799 Old 02-03-2014, 09:07 AM
Quoted: 105 Post(s)
Liked: 148
look here at Sound&Vision - the top pick http://www.soundandvision.com/content/panasonic-dmp-bdt220-blu-ray-3d-player
You can get the update model Model: DMP-BDT230 from BB for $80 - can't beat that with a stick!
http://www.bestbuy.com/site/smart-3d-wi-fi-built-in-blu-ray-player/8343057.p?id=1218874431837&skuId=8343057&st=categoryid$pcmcat205900050012&cp=1&lp=3
post #8284 of 14799 Old 02-03-2014, 09:09 AM
rifleman69's Avatar
Liked: 51
Originally Posted by LeKnobber View Post
I know you were kidding, but humans are way too quick to draw conclusions about their environment based on limited and insufficient amounts of data. This was a positive for not stepping on snakes more than once (all holes under trees are likely to have snakes since I saw one once), but not so good for dealing with large data sets.
For example, Panasonic has sold somewhere between 20,000 and 50,000 ZTs according to the insider. We have seen independent reports of 3 or 4 cracked ones. That is a 99.9% + rate of not having the crack. Yet accordingly on here, the sky is failing and now folks are afraid to get their TV repaired because it may crack.
As another data point, I had the fan repair done on my ZT and I asked the tech (who also repairs Samsung and other brands) how many he had repaired for the fan issue. He said around 20-25. I asked if he had ever seen any cracked ones, and he said no, and had never heard of the issue either, even though he had been doing fan noise repairs for many months.
I am not advising anyone to do anything, but just pointing out the facts as I know them, vs the scare mongering going on.
The repairman wouldn't see the micro fractures as many of them didn't become noticeable or even appear until after the fan fix was applied (and the back was improperly reinstalled). Otherwise, you're dead on.
rifleman69 is offline
post #8285 of 14799 Old 02-03-2014, 09:14 AM
puch96's Avatar
Why not get this one.  It is previous year model, so price is cheap. You can even watch streamed content movies in 24p!!!
http://www.amazon.com/Panasonic-DMP-BDT500P-Integrated-Blu-ray-Player/dp/B00752R4QO/ref=sr_1_3?ie=UTF8&qid=1391447556&sr=8-3&keywords=panasonic+blu+ray+player
puch96 is offline
post #8286 of 14799 Old 02-03-2014, 09:25 AM
Quoted: 105 Post(s)
Liked: 148
It's only a bargain if you need the analog outputs & 2 HDMI outputs - http://www.trustedreviews.com/panasonic-dmp-bdt500_Blu-ray-Player_photos_7
This is an upscale model with no improvement in the blu-ray performance - most folks connect with HDMI and have no need for these outputs so why pay for something you don't need - your call!
post #8287 of 14799 Old 02-03-2014, 09:28 AM
whoaru99's Avatar
Liked: 69
Thanks. Looks like they have one at the closest store, and I have a $15 gift card from BB.
whoaru99 is offline
post #8288 of 14799 Old 02-03-2014, 09:33 AM
amercnchopz34's Avatar
Quoted: 61 Post(s)
Liked: 31
Freight company just called...del my zt60 in 30 min.....
I just got a 60.00 bestbuy certificate....going to put 2 yr protection plan on it.......
modeboy, ClemsonChad and j-rod21 like this.
amercnchopz34 is offline
post #8289 of 14799 Old 02-03-2014, 09:38 AM
ClemsonChad's Avatar
Speaking of BD players, do you guys prefer the Panny 230 over the Sony s5100? I just purchased the s5100 on a dime from Best Buy but can swap at BB if you think the Panasonic or perhaps similar Samsung is better? Thanks guys.
ClemsonChad is offline
post #8290 of 14799 Old 02-03-2014, 09:44 AM
rifleman69's Avatar
Liked: 51
I like my Sony s5100. Works well and was really cheap before Christmas...probably still is.
post #8291 of 14799 Old 02-03-2014, 09:46 AM
That's good to hear. I wanted to get something to use primarily for blu ray to take the load off of the PS3 (and due to the loud noise of the PS3), so I grabbed the Sony at BB the other day for a great deal. I've watched two movies on it so far and everything appears to be okay. I know most of these players should produce essentially the same quality of image from blu ray, but I am willing to swap it if there is a compelling reason to grab the Panny or Samsung instead.
post #8292 of 14799 Old 02-03-2014, 09:51 AM
rifleman69's Avatar
Liked: 51
My in-law's got us whatever model of the Panasonic that looks like it would go with the ZT60 (never opened it and returned it since it was more expensive than the Sony). The Sony works and you're right that they all should produce essentially the same quality of image from blu ray. I'm more of a streaming guy myself so besides the James Bond collection and a few random discs here and there throughout the year, I probably won't be using my Sony that much. I guess if you weren't happy with the picture, I'd take it back and try something new. I don't really care how "ugly" or "beautiful" all of my tv electronic components go with each other...the Sony is black and that's fine with me.
ClemsonChad likes this.
post #8293 of 14799 Old 02-03-2014, 10:41 AM
cxr369's Avatar
Quoted: 20 Post(s)
Originally Posted by Playdrv4me View Post
If the TV doesn't have any IR/burn in and is in otherwise excellent shape I wouldn't worry about it. They could possible replace it with another open box one from your region, but then you'd have to worry about whether it had image retention or other problems. IF they can find a brand new one, that would be the best deal on a 65 inch and much like the way I got the deal on my 60 inch (started out as a open box and was replaced with a brand new in the box one).
Yea that's what happened, I bought an open box it had burn in and they replaced it with a new one, that's why it bugs me because aside from that it's perfect. I was reading that Vaseline would fill in the light scratch and make it disappear, is that true? Also, which camera is the best for the TV and u know the VT has an app called red karaoke, does the zt have the same ability to play karaoke?
cxr369 is offline
post #8294 of 14799 Old 02-03-2014, 11:06 AM
Playdrv4me's Avatar
Quoted: 56 Post(s)
Liked: 94
I've heard the vaseline thing also, but I'd be worried about rubbing anything on the panel that might affect the anti-glare coating. Don't know about the camera or the karaoke question but I'm sure someone else can answer to that.
Playdrv4me is offline
post #8295 of 14799 Old 02-03-2014, 11:16 AM
Quoted: 61 Post(s)
Liked: 31
Just came.......all I can say is wow.......trying to get slides for dnice....Where are they???
October build.....fan fix already installed. .....
modeboy likes this.
post #8296 of 14799 Old 02-03-2014, 11:29 AM
colnago's Avatar
Quoted: 70 Post(s)
Liked: 53
Check the settings thread created by D-Nice...quicker to google "D-Nice zt60 settings" or "D-Nice zt60 slides"
colnago is offline
post #8297 of 14799 Old 02-03-2014, 11:34 AM
eric3316's Avatar
Quoted: 842 Post(s)
Liked: 959
I have a VT and cannot find that app on my TV. There was another one app that was brought up at the Shootout, some kind of running game where you pick where you want to run and I cannot find that one either on my VT60.
I believe both of these apps use the camera with the built in mic so not sure of they would be on the ZT60, but like I said I can't even find them on my VT60.
eric3316 is offline
post #8298 of 14799 Old 02-03-2014, 11:50 AM
Congrats! Here you go: http://www.controlcal.com/forum/showthread.php?t=1006. You have to register with the site before you can download the slides.
post #8299 of 14799 Old 02-03-2014, 12:23 PM
larrygeary's Avatar
Liked: 46
Just became a proud owner of this set. I got an amazing deal on one from my local best buy, got the 65 inch for $2100 after taxes and two year geek squad protection. Only one problem, the delivery guys put a scratch in the top right corner, it looks like a smudge on the bezel but it's actually a fine scratch. I contacted geek squad but they dong fix cosmetic damage, my guy at BB was cool enough to say he would replace it with a new one but there aren't any available anywhere. Does anyone know of any other options? It's in the black border and not the screen but it still bugs me.
65" ZT60 for $2100 ? That's $700 off the lowest new price. Was this an open box? Maybe it was returned because of the scratch.
larrygeary is offline
post #8300 of 14799 Old 02-03-2014, 12:32 PM
Quoted: 61 Post(s)
Liked: 31
How do I look up hours on set.....also on dnice slides. ..it says custom settings on 100 hr panel prep slides. ..custom...seems bright 100contrast is that right
post #8301 of 14799 Old 02-03-2014, 01:07 PM
El Valluco's Avatar
Any Best Buy dead pixel exchange luck?
Finally got my NIB 60" ZT60 delivered this morning aaand it has a dead pixel :( Noticeable on the grey, green (though sometimes it turns on with the green slide) & white slides.  After debating whether or not I could live with it, I called BB just to check my options.  They said that was not a problem and to call back after 24hrs and they would send me another NIB ZT60 to replace this one.
My question is has anyone successfully done a NIB exchange with these guys in the last week or two?  With dwindling stock, I'd be surprised if they could actually pull it off.
Also, are dead pixels on this model common?  I searched "ZT60 dead pixel" and didn't mind much, so just wondering if I just had bad luck or not.
El Valluco is offline
post #8302 of 14799 Old 02-03-2014, 01:08 PM
rezalon's Avatar
So set up the ZT60 using cnet settings to watch the Denver blowout yesterday and then watched some regular tv afteward. Picture sharp but when I look at the colors on the Kuro there is a huge difference. The reds and greens seem much more rich with the Kuro. Pinkness of faces nice and realistic with Kuro but dull with ZT60; not sure which settings to change to get better color rendition? Help!!!
rezalon is offline
post #8303 of 14799 Old 02-03-2014, 01:13 PM
bvader's Avatar
Looks like it's time to post this again
2013 Panny FAQ ... mostly applies to ZTs: Thanks to eric3316
http://www.avsforum.com/t/1513205/plasma-help-guide-with-focus-on-panasonic-vt60-most-common-plasma-questions-answered-here
And my one for the settings etc...
http://www.avsforum.com/t/1474480/official-zt60-owners-thread/6000#post_24154216
oldsteve likes this.
Long Live The Gorn!
bvader is offline
post #8304 of 14799 Old 02-03-2014, 01:14 PM
bvader's Avatar
Besides setting... let it age a bit...common experience as the PQ really picks up couple hundred hours in.
Check the settings faq above try the CNET (Edit : oops duh on me!) to start...
Long Live The Gorn!
bvader is offline
post #8305 of 14799 Old 02-03-2014, 01:29 PM
rifleman69's Avatar
Liked: 51
How many hours on the set? I noticed a difference between brand new and 100 hours, and from 100 to about 275-350. It gets better, trust me!
post #8306 of 14799 Old 02-03-2014, 01:35 PM
whoaru99's Avatar
Liked: 69
Well, that's a bust. Same damn thing....
whoaru99 is offline
post #8307 of 14799 Old 02-03-2014, 01:57 PM
rezalon's Avatar
Thank you gentlemen - Superbowl was basically hours 1-3 - so we're talking brand new out of the box. Will take yours and Bvader's advise and look forward to improvemen. Appreciate the help.
rezalon is offline
post #8308 of 14799 Old 02-03-2014, 02:01 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Finally got my NIB 60" ZT60 delivered this morning aaand it has a dead pixel frown.gif Noticeable on the grey, green (though sometimes it turns on with the green slide) & white slides.  After debating whether or not I could live with it, I called BB just to check my options.  They said that was not a problem and to call back after 24hrs and they would send me another NIB ZT60 to replace this one.
As with every plasma that's ever been manufactured, it's known to happen (unfortunately, I didn't notice the defective subpixel on mine until 3 months into ownership). Try searching for "stuck pixel" within this thread, or even "subpixel" for more discussion. If the pixel was truly dead, you would be seeing it on every slide and color rendition. Since you only see it on certain colors, it's most probably a case of a dead subpixel.
vinnie97 is offline
post #8309 of 14799 Old 02-03-2014, 02:02 PM
GC3
GC3's Avatar
Liked: 49
I've tried the CNET settings just for comparison purposes until I get calibrated, but on my display the CNET settings came across as dull and greenish in comparison to THX Cinema..
GC3 is offline
post #8310 of 14799 Old 02-03-2014, 02:03 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
No wonder. smile.gif The panel goes through the most significant change in the first 300 or so hours.
vinnie97 is offline
Panasonic Viera Tc P65zt60 65 Inch Plasma Hdtv , Panasonic Viera Tc P60zt60 60 Inch Plasma Tv
