Official ZT60 Owners Thread - Page 382 - AVS Forum | Home Theater Discussions And Reviews
 545Likes
post #11431 of 14797 Old 04-19-2014, 10:22 AM
Denniswrly's Avatar
Liked: 38
Originally Posted by eaayoung View Post
If you only hear the buzz with the white slide then stop with the slides and just watch the TV. Problem solved. You may have to wait a little longer before getting the set calibrated, but at least you'll be able to enjoy you set. I've had my ZT for maybe 3 months and I've never heard it buzz. But I don't run the slides either.
64f8500
oppo bdp-103
Denon avr 1803
Energy speakers
Energy sub
Dual recliner lazyboy
xbox 360
Denniswrly is offline
post #11432 of 14797 Old 04-19-2014, 11:36 AM
GC3
GC3's Avatar
Liked: 49
A few pages back, I thought y'all made a consensus vow to ignore self's postings...but here we are again....there must be an extreme lack of other activity in this thread...(not that I'm helping)....I guess everything that can be said has been said.
andrewread likes this.
GC3 is offline
post #11433 of 14797 Old 04-19-2014, 12:48 PM
mjodotcom's Avatar
Quoted: 14 Post(s)
Originally Posted by vinnie97 View Post
I can't say the same in the case of the cooling mechanism. Movies tend to have dynamic content, and I can assure you my roaring, pulsating air noise is audible with such content (and at low volumes, audible nearly 100% of the time, save for the hum of the fridge or the whirring of the climate control). I'll be thankful to get a 50% reduction in perception of the sound and hope the tech doesn't damage the front glass in the process and also re-applies the panel correctly. smile.gif
Vinnie,
My fan noise was just as bad so I took the plunge and did the fix. Good news is it did reduce mine by at least 50%. Just give the tech tip to the people who come do the work. I made sure they read it first and the front panel was reapplied correctly.
mjodotcom is offline
post #11434 of 14797 Old 04-19-2014, 12:54 PM
mjodotcom's Avatar
Quoted: 14 Post(s)
Originally Posted by SeLfMaDe111985 View Post
Fans aren't even an issue compared to the buzz. Just put some slides up (I'm at 85 hours) and the buzz on the white slide is super loud and the buzz on a dark grey slide is not even present. Is that normal?? Goes from super loud on white to nothing on grey dark grey. Then nothing during regular scenes but once bright scenes come
On it buzzes. Heard up to 7-8 ft away. I don't understand. Am I the only one experiencing this? I don't see how anyone in here deals with this buzz if it's normal. I know white slides are the loudest but this is like absurd. It seriously sound like a bug zapper on full blast when those whites hit or like a taser.
Self,
I observed similar behavior on my set and previous plasma. What I found was room acoustics also play a big part in the buzz that can be heard. If I moved my TV further away from my back wall the noise got better. What made the biggest improvement was hanging a blanket on the wall behind the TV - to the point that I almost didn't notice it anymore (still need a more permanent solution wink.gif ). It was obvious that for my situation the sound was being enhanced by where the TV was in the room!
Bunga99 likes this.
post #11435 of 14797 Old 04-19-2014, 02:57 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Originally Posted by mjodotcom View Post
Vinnie,
The local tech is on the case. wink.gif He just replaced the panel on my LG OLED and said he'd be ordering the foam kit to do the Panasonic fix after it arrives. I also reiterated to him about the likelihood of microfracture should the back end not be properly aligned into the groove before screwing, and he was already ahead of me on that front. Very wise technicians who have apparently seen it all (even OLED now, this being their first servicing wink.gif) having been in business for at least 30 years.
vinnie97 is offline
post #11436 of 14797 Old 04-19-2014, 03:14 PM
jasjw's Avatar
Quoted: 42 Post(s)
Does anyone has a diagram of the foam fix? I think mine may have had the fix but not too sure.
LG 65C6 OLED
Onkyo HT-R390
Dune Solo 4K
SKY Q
Xbox One
jasjw is offline
post #11437 of 14797 Old 04-19-2014, 03:44 PM
repete66211's Avatar
Quoted: 131 Post(s)
Liked: 288
This post covers it.
jasjw likes this.
repete66211 is offline
post #11438 of 14797 Old 04-19-2014, 03:58 PM
jasjw's Avatar
Quoted: 42 Post(s)
Thanks, mine has had the fix.
LG 65C6 OLED
Onkyo HT-R390
Dune Solo 4K
SKY Q
Xbox One
jasjw is offline
post #11439 of 14797 Old 04-19-2014, 04:49 PM
rifleman69's Avatar
Liked: 51
It's like a car wreck...you slow down to look just because you can.
fmalczewski and CrazyNurse like this.
rifleman69 is offline
post #11440 of 14797 Old 04-19-2014, 07:08 PM
SeLfMaDe111985's Avatar
Liked: 99
Buzz is heard with white scenes as well not just slides. Anything that's bright colored is a loud buzz...idk whatever I'm all done with it. Bout to put a bat through it. If Panasonic can't fix it I'm all done..moving on
SeLfMaDe111985 is offline
post #11441 of 14797 Old 04-19-2014, 08:04 PM
Quoted: 131 Post(s)
Liked: 288
Self, you can't really complain about a defective set when you refuse to get it fixed. You've blown the micro-fracture issue WAY out of proportion. It only happened a few times when no one was aware of the potential problem. Now that the cause is known, and therefore how to prevent it, micro-fractures are no longer a legitimate concern.
rifleman69 and CrazyNurse like this.
post #11442 of 14797 Old 04-19-2014, 08:27 PM
Liked: 99
Ha..., made my day with that comment!
That's sad...but everyone has things that make them happy.
post #11443 of 14797 Old 04-19-2014, 08:29 PM
Super Moderator
DrDon's Avatar
Quoted: 1178 Post(s)
Liked: 2292
Enough with the bickering. Discuss the topic and not each other.
Further off-topic bickering could result in loss of access to this thread.
Keep it ....clinical.
rifleman69 and andrewread like this.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #11444 of 14797 Old 04-20-2014, 12:15 AM
music_to_my_ear's Avatar
Quoted: 185 Post(s)
Liked: 90
Yo Vinnie what's up with your zt now? What happened after you ran the standard setting over night?
And what's up with your OLED? Did the panel break or something?
music_to_my_ear is offline
post #11445 of 14797 Old 04-20-2014, 02:28 AM
jasjw's Avatar
Quoted: 42 Post(s)
All this forum seems to be about is Buzzing.
Yeah Plasma's buzz, more so on white screens. Jesus!
LG 65C6 OLED
Onkyo HT-R390
Dune Solo 4K
SKY Q
Xbox One
jasjw is offline
post #11446 of 14797 Old 04-20-2014, 07:32 AM
AVKIK's Avatar
Quoted: 22 Post(s)
Liked: 24
Self, If I remember correctly your tv is positioned close to the corner of your room. I honestly think the buzz is bouncing off of the corner which is amplifying the noise. I'm sure most of your buzz comes from the board on the left side (like mine) which is where the corner in your room is closest to the tv. Therefore, I don't think your buzz will go away. Unless you have the buzz I had every once in a while before my fan fix. Just get the fan fix done and go from there. Don't sweat the whole micro fracture issue. Or try to move your set to a different location. If not for good at least try it out to experiment and find out wether or not it's the acoustics of your room more so than the tv. Good luck.
AVKIK is offline
post #11447 of 14797 Old 04-20-2014, 09:35 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
The unevenness of the screen is still there. I'm done wasting electricity trying to resolve it. I just won't be using the set for Netflix anymore, because it seems like the navigation bar has resulted in some kind of burn-in. OLED won't be much, if any, better in this regard.
4 dead subpixels...of course, the new one has 3 now, but at least that's an improvement. wink.gif
vinnie97 is offline
post #11448 of 14797 Old 04-20-2014, 12:26 PM
Calilife17's Avatar
Quoted: 21 Post(s)
Hey guys quick question on Firmware 2.873. i know this firmware came out end of last year, but I never hooked up my TV to the internet till now (always have used Apple TV, Chromecast, Oppo, etc.). Is there any negative picture impacts of this firmware? lighter black level, or drop in brightness, color shift, image softening?
Just seeing if there is any negative to upgrading the firmware. Dont want to DL something and have it negatively impact the picture.
Theater Room: 65ZT60, Denon AVR-X6300H, Oppo 103D, Apple TV4, Harmony Elite
Bedroom: 65VT50, Sony S790, Roku 4, Apple TV4, Harmony Ultimate
Man Cave: Vizio P75, Harmony Elite, Apple TV4, Shield, Roku Ultra, ChromeCast Ultra, Xbox One S, PS4 Pro, Wii U,Intel Skull Canyon & about 20 more game consoles
Calilife17 is offline
post #11449 of 14797 Old 04-20-2014, 01:14 PM
Denniswrly's Avatar
Liked: 38
I seen nothing all is good.Usally updates are for other things than PQ...imo smile.gif
64f8500
oppo bdp-103
Denon avr 1803
Energy speakers
Energy sub
xbox 360
post #11450 of 14797 Old 04-20-2014, 01:20 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
vinnie97 is offline
post #11451 of 14797 Old 04-20-2014, 01:34 PM
rifleman69's Avatar
Liked: 51
It just updates a few apps and some other mumble jumble. It's not going to affect the PQ.
post #11452 of 14797 Old 04-20-2014, 02:32 PM
Denniswrly's Avatar
Liked: 38
OMG Dennis lay off the wine!!! i thought i was over at f8500 thread..... Delete my post WOW....Ty vinnie:)
64f8500
oppo bdp-103
Denon avr 1803
Energy speakers
Energy sub
xbox 360
post #11453 of 14797 Old 04-20-2014, 03:35 PM
Thxtheater's Avatar
Quoted: 152 Post(s)
Liked: 114
In any setups like this that accentuate noise, get a 2" sound absorber panel and it will do wonders to kill sound that is being amplified and reflected off a wall.
Thxtheater is offline
post #11454 of 14797 Old 04-20-2014, 04:49 PM
RoyMacDonald's Avatar
Quoted: 56 Post(s)
Liked: 47
I've just bought a ZT60, but on the cinema pre-sets skin tones have an unnatural green tone. Only the "Normal" present has skin tones that look OK. It also appears to suffer from black crush on the "Normal" setting. My wife wants me to go back to the old set as she doesn't like the picture quality as much as that of the old set.
Am I right in saying that when it's run in an calibrated it will match our old 7 year old calibrated 9G Kuro?
Thank for any advice.
Roy
RoyMacDonald is offline
post #11455 of 14797 Old 04-20-2014, 06:35 PM
Calilife17's Avatar
Quoted: 21 Post(s)
Thanks for the info.
Reason I ask is because Firmware can most definitely affect PQ. Just look at the VT50's 1.190 Firmware Last year. The are reports that it rose Peak luminance but at the sacrifice of the MLL rising as well. Also there were some reports of a color shift, with a little more red push. That is why i never upgraded my VT50 in my bedroom to it, i would rather take the lower MLL since i don't need higher luminance in that setup.
So i always check before a firmware to make sure it doesn't change anything on the PQ side.
post #11456 of 14797 Old 04-20-2014, 06:37 PM
slimoli's Avatar
Quoted: 645 Post(s)
Liked: 299
Originally Posted by slimoli View Post
I like to watch the CNET using the app on my ZT60 but the last time it was updated with new videos was March 20. On my Ipad it is updated every day. Does anybody know if there is anything I can do to make it more up to date ? Thanks.
I hate to do this but...bump
I was so happy without HDR...
slimoli is offline
post #11457 of 14797 Old 04-20-2014, 07:05 PM
Jason626's Avatar
Quoted: 170 Post(s)
Liked: 170
Roy
Give cnets settings a try and dnices from Panasonic 2013 settings thread. They work well on my set. Thx settings does have a green tinge and yellowish blotchy skin tone sometimes. My thx looks alittle better after 500 hours though.
CrazyNurse and RoyMacDonald like this.
Jason626 is online now
post #11458 of 14797 Old 04-20-2014, 08:25 PM
DrJayDub's Avatar
Quoted: 47 Post(s)
Liked: 59
Roy
I agree with the poster above, try out some settings from Cnet or Dnice to start. Calibration will make it near the equal of a Kuro. Definitely worth it to get it calibrated. Also, as for black crush, play around with the gamma settings i found this helped quite a bit on mine prior to calibration, especially if you watch with some ambient light in the room.
RoyMacDonald likes this.
Yup, I got stuff...
Panasonic 60ZT60, LG 55EG9100
Pioneer Elite SC-87, Oppo BDP-103D, PSB Synchrony two mains, center and surrounds.
XBox One
DrJayDub is offline
post #11459 of 14797 Old 04-20-2014, 09:19 PM
rifleman69's Avatar
Liked: 51
Worst case, leave it alone. The tv is still going to work with or without it. smile.gifsmile.gif
post #11460 of 14797 Old 04-21-2014, 06:28 AM
Quoted: 56 Post(s)
Liked: 47
Thanks Guys.
I am looking for it to have equal picture quality to my Kuro though. Will it be OK once I get it professionally calibrated?
I'll use the same guy who did my Kuro. He got mine better than any other Kuro I've ever seen.
The ZT does do motion very well and cartoons look superb, but obviously correct skin tones are a must. I have noticed some improvement in the picture now it's done about 45 hours. Myself and the family aren't liking it as much as the Kuro at the moment though so I'm having to resist going back to the Kuro with the promise things will improve.
One odd thing I've noticed about my panel is that if you stand up and look down on it from the top, it behaves like an LCD and the picture loses quality, becoming very dark to the point you can hardly see an image. OK from any other angle though. Not an issue with normal seated viewing, but do they all do that?
All the best.
Roy
Panasonic Viera Tc P65zt60 65 Inch Plasma Hdtv , Panasonic Viera Tc P60zt60 60 Inch Plasma Tv
