Official ZT60 Owners Thread - Page 414 - AVS Forum | Home Theater Discussions And Reviews
 528Likes
Old 07-23-2014, 09:21 PM
B T C's Avatar
Location: Lansing, MI via Kentucky, Georgia & Tennessee
Quoted: 304 Post(s)
Liked: 87
Originally Posted by repete66211 View Post
If I could get a 65" ZT60 for $1,700 I'd take my chances with the IR, especially if they threw in a warranty or some extras.
It still amazes me that in this day and age TV stores don't take better care of their floor models. I mean, everyone knows about IR. How can a manager not make the effort to ensure 16:9 content is run on all TVs--even the LCDs--7all the time? This just boggles the mind.
I pretty much agree with everything you said. How do the people running these stores take no precautions? I think the risk becomes worth it at some point. I guess that point is what I'm trying to identify.
B T C is offline
Old 07-24-2014, 12:29 AM
fmalczewski's Avatar
Quoted: 86 Post(s)
Liked: 38
Originally Posted by music_to_my_ear View Post
You can't eyeball greyscale. its impossible for a human to do it. D-nice has said this many many times ( I'm guessing he tried to do it himself and couldn't get anything out of it by eye )
A meter is a must to get any positive adjustment of the greyscale otherwise you can't see what ur adjusting good or bad
Pretty sure we've already had this discussion. Not talking a full blown calibration, just picking a Color Temp setting from a pulldown of maybe a handful of options. I can eyeball when grey has the least amount of coloration to it. Be happy to show you.
fmalczewski is offline
Old 07-24-2014, 12:35 AM
Quoted: 86 Post(s)
Liked: 38
I agree. I think voltages may have been set higher than normal causing IR to be more prone on the 2013 sets. Probably the best guess I've read on this forum of why IR is soo common on 2013
Also, my set before it hit 1500 hours was very very resistant to IR for any content....now its nearing 1600 hours and I can make out IR from just the menu after I switch to a white slide but it fades away after content is displayed. Im guessing at 1500 hours the voltage levels jumped keep up with aging phosphours or something...sorta like what happened with the VT25 black level rise when the word was some Panasonic engineer goofed on the voltage algorithm too early and too aggressively
That wouldn't surprise me at all. Seems to be the case for me too, with possibly a bump (or two) prior to that. Pretty easy to get anything with bright lettering to stick relatively easily as of late, particularly towards the bottom of the screen.
But... even when the set was practically brand new I ran into some of the same IR early on when I thought I'd run slides for 100 hours or so. Right off the bat, I think just from running the application to get them to play. (Not really sure it's just IR, so much motion involved in the (video) noise that goes along with it; towards the top I've seen some IR too, but none of the video noise.)
Old 07-24-2014, 05:54 AM
B T C's Avatar
Quoted: 304 Post(s)
Liked: 87
I saw some mild IR on my VT60 from the application to play video and it could not have been on the screen for more than a minute, probably closer to 30 seconds. This was with 1000+ hours on the set.
B T C is offline
Old 07-24-2014, 06:15 AM
repete66211's Avatar
Quoted: 130 Post(s)
Liked: 287
I see IR when I launch the PS3 Amazon Video app. It's up for just a few seconds and it fades pretty quickly. My old Samsung plasma did the same thing. I don't really consider short term IR like that a concern.
repete66211 is offline
Old 07-24-2014, 10:10 AM
Quoted: 86 Post(s)
Liked: 38
My IR still does seem to fade, but seems like it's there with the slightest provocation now, so as one bout is fading another comes along to take its place quite readily. Contemplating just making it a blu-ray/dvd only panel (but in the real world...)
At least it is still "only" visible/present with 16:9 mostly light/white content (black bars on the side, per 4:3 content, invisible; darker 16:9 content mostly always invisible, but sometimes if you look...).
Old 07-24-2014, 10:32 AM
garnettrules21's Avatar
I'm in the same boat with my plasma in regards to IR, its just an ST60. I have 2800 hours on it and run contrast on logo'd channels at a modest 60 and it will still generate IR no problem almost instantly. I also have line bleed pretty good on the low and mid brightness settings but when I put the panel brightness to high it diminishes it quite a bit but I normally run in mid or low cause of the image retention running in "high" seems like it sticks around longer. Sometimes even a persons eyes create slight line bleed.
I too was thinking maybe the voltage has become out of whack but is that normal? How does that even happen? I nervously went into the service menu to check my VSUS but it said it was set to low, was hoping it was set to high or something that would explain it. Not sure where to go from here. I'm passed my warranty and don't really want to pay for a tech to come out if its gonna cost over $50 or so. The only thing I could think of at this point though is that the voltages on the back of the panel are set too high or something. Not sure. It's aggravating.
I wrote panasonic on twitter about this and they told me its not normal (obviously). They want me to take a few picture examples and send them to them and they will share with their tech team. Gonna do that at lunch. I'm sure they will look at them and say its either "within normal operating guidelines" or something to that extent. Ideally I'd like for them to send a knowledgeable tech out for free to check the voltages.
Even as it stands its the best tv I've owned and don't plan on getting rid of it till it completely craps out.
garnettrules21 is offline
Old 07-24-2014, 04:46 PM
jliedeka's Avatar
Originally Posted by scott brown View Post
I'm moving and might have to mount the 65inch on a brick wall. I'd like a full motion mount that will extend up to 20 inches or so. What would you recommend? Sanus? Any particular model? Are all the mounts Sanus claims to be compatible with the TC-P65ZT60 actually compatible?
Any recommendations other than Sanus?
When I got my 65" ZT60, I gave my girlfriend my older 50" V10. That weighs 75 pounds and we used a Peerless fully articulated mount. The installation went smoothly but I was just installing into two studs behind standard drywall. The Peerless was a bit cheaper than the comparable Sanus model and was really well built.
Jim
jliedeka is offline
Old 07-25-2014, 05:47 AM
scott brown's Avatar
Jim
There's a friendly contractor working on the building next door who said he'd send a guy over to mount the zt on the brick wall next week. So that makes it easy. Now to decide if I want the dual arm mount or not. Amazon has the Sanus mounts for basically half of the retail price. My zt replaced my Kuro, which is now in the bedroom. Maybe I'll mount that on the wall, too
scott brown is offline
Old 07-25-2014, 06:36 AM
mohanman's Avatar
Quoted: 40 Post(s)
Liked: 33
You guys are all totally over reacting about this IR thing. I have a 55" VT30 that had the DISH logo from that hopper box on the screen everyday for days. I thought it was burned in and became very sad about the situation because it would never go away. It was there with white screens, grey screens... etc. The 55" VT30 went to storage because I then got a GT50 and now a ZT60. It was in storage for one year. I then took it out to put in one my bedrooms, and voila... the IR is gone completely. NO more dish logo.
Mo!
So if you are concerned about IR, just put it in storage for one year
mohanman is offline
Old 07-25-2014, 07:33 AM
HLdan's Avatar
Quoted: 494 Post(s)
Liked: 226
Talking
Panasonic said IR and Line Bleed were not normal? I understand about you saying your line bleed results are mixed based on screen brightness but these two things are typical "features" of a Plasma. IR and Line Bleed have been talked about for years on this forum.
Mo!
I don't think many of us are fortunate enough to have multiple TV's where we could put one in storage for an entire year. Also I thought the only way to remove IR is to watch mixed content. How does not watching any TV get rid of IR?
HLdan is offline
Old 07-25-2014, 07:49 AM
tgm1024's Avatar
Quoted: 2361 Post(s)
Liked: 2164
Mo!
LOL. So folks are overreacting when all they have to do for every IR they get is put the TV in the basement for a year? Well, >phew<, glad to hear it's such an easy solution.
antennahead and StinDaWg like this.
Thought #AYA: Porn gives young people an unhealthy and unrealistic idea of how quickly a plumber will come to your house.
tgm1024 is offline
Old 07-25-2014, 08:17 AM
They said getting instantaneous IR with low contrast after having 2800+ hours on the panel is not normal.
antennahead likes this.
Old 07-25-2014, 08:18 AM
B T C's Avatar
Quoted: 304 Post(s)
Liked: 87
Would unplugging the set for some period of time potentially have an impact on IR?
B T C is offline
Old 07-25-2014, 08:26 AM
HLdan's Avatar
Quoted: 494 Post(s)
Liked: 226
I have a Panny 55GT50 and a 64F8500 being delivered today in fact. I have the Panny set on Standard for most of my viewing since I watch TV late at night with the lights off and early in the morning before work. It keeps it cooler and it's easier on my eyes. Every day since day one, the second I turn on my Panny the "Smart Viera" logo pops up and leaves temporary IR. It seems ridiculous to me since there's no way to avoid that bright logo from popping up. After 5 minutes or less it goes away but it is instant IR. Although I have heard numerous times that the Samsung plasmas are much more immune to IR than the Panasonic TV's I'm already prepared for the same experience with IR on my Samsung being delivered today. If you're getting instant IR for example the CNN logo being on your screen for less than a minute but it stays for hours then there is something most likely wrong with your panel. Panasonic probably won't do a free or low priced service call but maybe you can find a local authorized Panasonic repair shop you can take it to who will do a free diagnostic.
HLdan is offline
Old 07-25-2014, 08:38 AM
Yea, its really annoying but I'm 100% ready to just live with it. Regardless of temporary IR and line bleed (which doesn't happen a ton), its by far the best tv I've owned.
Old 07-25-2014, 10:01 AM
Thxtheater's Avatar
Quoted: 80 Post(s)
Liked: 89
I suggest calling Panasonic. That sounds odd. I'm assuming contrast isn't set to 100%?
Thxtheater is offline
Old 07-25-2014, 10:44 AM
Quoted: 130 Post(s)
Liked: 287
It'd be nice if that worked, but I suspect you'd have as much luck fixing the problem just talking into an empty coffee can. I seriously doubt Panasonic will tell you anything beyond the regular script, "IR is not covered. What you're experiencing is normal. Plasma? We don't make plasmas."
Old 07-25-2014, 12:21 PM
antennahead's Avatar
Quoted: 231 Post(s)
Liked: 164
BTW, I too get the "instant IR" that goes away fast if I leave something static up for a few minutes, especially against a black screen. The IR I have been referencing in my previous posts is a long term one resulting from hours on the same channel day after day. I can report that it has further reduced itself down to a point where I would say it is about 95% gone. I have been running a lot more screen swipe, intermittently, than I did prior to the discovery. I have not watched that channel since this occurred.
I digress from the subject at hand a little, but doesn't it chap your a** that the major networks pretty much have a "screw you " attitude towards the consumer over these channel logos ............ forcing them down our throat whether we like it or not...... I mean we put our display on the channel.... we already know what channel we are watching, and when you first turn it on, if you didn't remember where you left it, one click of a button and the info pops right on the screen
antennahead is online now
Old 07-25-2014, 01:10 PM
Quoted: 130 Post(s)
Liked: 287
I always thought the logo was there for copyright reasons or something. You know, to prevent people from recording and selling a program/movie. Whatever the reason, there is no reason not to have the logo opaque rather than stark white.
Old 07-25-2014, 01:33 PM
Quoted: 231 Post(s)
Liked: 164
And to add to that, cycle it on and off with more "off" than on, in addition to the completely opaque design.
music_to_my_ear's Avatar
Quoted: 185 Post(s)
Liked: 90
VSUS was on low? What would happen if you changed it to mid or high? You said having brightness on high allowed the IR to disappear rather quickly
If you do change anything just be to write your original settings down!
ps: I know there was a thread on LG plasmas some folks were adjusting the pots on the back for some reason and it had a positive effect on the picture
Are there pots on the back on the 2014 plasmas that can be tweaked or something?
music_to_my_ear is offline
Old 07-25-2014, 01:41 PM
B T C's Avatar
Quoted: 304 Post(s)
Liked: 87
I'm going to be checking out another floor model ZT60 tomorrow that, according to the sales person, "looks good" with respect to IR.
B T C is offline
Old 07-25-2014, 02:30 PM
No, Panel Brightness High just helped line bleed diminish had no effect on IR other than probably making it stick longer. I believe there is only a VSUS Low and High. I'd be too nervous to go in changing that stuff around. I think I'm gonna try a factory reset and see if that does anything, doubtful but worth a shot. Like I said, these issues annoy me but I'm not going to any lengths like adjusting the pots and stuff on the back.
Old 07-25-2014, 07:33 PM
tgm1024's Avatar
Liked: 2164
Or as an embossed watermark, similar to this but with the light and dark regions more muted. The advantage of this is that the pixels involved in the creation of the logo are primarily outlines and are always composed of modifications of the underlying image data which is always changing. Further, because the bulk of it are outlines, it spreads the impact well when handed off to algorithms that move the image about:
tgm1024 is offline
Old 07-26-2014, 07:23 AM
Quoted: 185 Post(s)
Liked: 90
No
Old 07-27-2014, 09:57 PM
mohanman's Avatar
Quoted: 40 Post(s)
Liked: 33
No
I disagree, see my experience at the top of this page. Had a vt30 55" with dish logo practically burned in everyday .. it never went away. Didn't use TV for almost one year.. IR gone.
Mo
mohanman is offline
Old 07-28-2014, 11:23 AM
pdogg93's Avatar
Quoted: 79 Post(s)
Liked: 43
Hi there,
I just got my 65" ZT60 over the weekend to compare with my f8500 and keep whichever one is best. The screen on the ZT60 is near perfect with no visible dirty screen effect (which I have on the Samsung). But what I found when I plug in my ps4, is that it seems to be crushing blacks, leaving a lot of shadow detail non visible.
I have a kuro pro 101fd elite hooked up and the 8500 for reference, so I know that something is missing from the ZT. I've changed settings around as well (brightness, gamma, etc.) so I'm not sure what's going on.
thank you
pdogg93 is offline
Old 07-28-2014, 12:14 PM
Quoted: 185 Post(s)
Liked: 90
Originally Posted by pdogg93 View Post
Hi there,
thank you
Common mistake....turn rgb range from full to limited on the ps3 and the zt60. should be under the advanced picture settings
pdogg93 likes this.
Old 07-28-2014, 12:22 PM
pdogg93's Avatar
Quoted: 79 Post(s)
Liked: 43
Hi Music,
I thought that was a ps3 only issue. The ps4's rgb range is set to auto I believe, and it doesn't seem to give me trouble at that setting with the 8500 or the kuro. I'll try to change it around and see if that makes a difference though.
*Edit* RGB Limited fixed the issue. Looks like i'm gonna keep the ZT and return the 8500
I wish the 3D was better on the ZT, but oh well. Thanks Music
pdogg93 is offline
Panasonic Viera Tc P65zt60 65 Inch Plasma Hdtv , Panasonic Viera Tc P60zt60 60 Inch Plasma Tv
