Official ZT60 Owners Thread - Page 421 - AVS Forum | Home Theater Discussions And Reviews
 484Likes
post #12601 of 14362 Old 08-19-2014, 05:01 AM
repete66211's Avatar
Quoted: 129 Post(s)
Liked: 287
The ZT has 3 fans. I can't imagine adding additional exterior fans would do any harm, as long as airflow in & out isn't restricted.
repete66211 is offline
post #12602 of 14362 Old 08-19-2014, 06:36 AM
music_to_my_ear's Avatar
Quoted: 185 Post(s)
Liked: 90
Originally Posted by music_to_my_ear View Post
Hey Grendell.....got a thought to share with you
Notice the thermal infared pic you took? The brightest areas were ironically over the areas of the screen the were suffering the uniformity problem
High temps causing the uniformity issue?
Originally Posted by Grendell View Post
That was a thought. I noticed that people complained of noisy fans in the first shipped models, then later shipped models (which would be mine) had the fans quieted. I wonder if that is because they have reduced airflow?
I'm thinking about maybe buying larger case fans and mounting them on the *outside* of the set, on the bottom part, to boost flow.
I also notice a blotch that starts showing up after several hours now on the *right* side of the screen. It is *directly* over the hot spot. Running the screen wipe or alternating several red green and blue full screen IRE patterns seems to lower it some.
Any other way you can think to get cooler temps without opening the set?
Anyone hear of repair shops or techs putting in stronger fans? Two fans for a plasma seems not enough... my previous 2008 Panasonic had 4.
80mm usb fans. Place them directly over the vent holes. They will push in cool air.
They can be plugged into the tvs usb ports so they will shut off when the tv is off.
Coolerguys has some 80mm usb fans.
http://www.amazon.com/gp/product/B00...A2F13KK758WMXQ
music_to_my_ear is offline
post #12603 of 14362 Old 08-19-2014, 06:38 AM
Quoted: 185 Post(s)
Liked: 90
ps: Ive already had my zt60 shut off due to overheating. It happened once and it was random.
But i was in day mode ( with the contrast near 90 and panel bright at high ) so I know it mustive been overheating.
hasn't happened since but I've been looking into usb fans ever since to help cool it down
post #12604 of 14362 Old 08-19-2014, 06:42 AM
Quoted: 129 Post(s)
Liked: 287
You're probably better off sucking air out than pushing it in.
post #12605 of 14362 Old 08-19-2014, 07:25 AM
bob brennan's Avatar
Quoted: 90 Post(s)
Liked: 134
Correct
pdogg93 likes this.
Panasonic TC-P65ZT60 - Oppo BDP-103D - Panasonic DMP-BDT220 - Toshiba HD-DVD-3A - OPPO DV-981HD - Harmony 880
Onkyo TX-NR809 --- Definitive Technology - Studio Monitor 65 (2) - CS8040HD - Studio Monitor 45 (2) - Super Cube 6000
bob brennan is online now
post #12606 of 14362 Old 08-19-2014, 10:08 AM
mohanman's Avatar
Quoted: 40 Post(s)
Liked: 33
I stopped by best buy today to see what is new since I haven't been there in a while. Man its like a circus of tvs. Samsung has this new huge section with all sorts of sizes/curved/straight this and that. Although some of the 4ks did catch my eye, the motion was off to me, and the color was insane. Like almost made me blind insane. It gave me a headache! I'm so happy I got plasma, the picture is smoother, softer, natural like. Guess we will see what happens with 4k Oled
Mo!
repete66211 likes this.
mohanman is offline
post #12607 of 14362 Old 08-19-2014, 10:09 AM
Grendell's Avatar
Quoted: 41 Post(s)
Liked: 24
Where is the third fan? (With 1 and 2 being in the upper left and right corners.)
Grendell is offline
post #12608 of 14362 Old 08-19-2014, 10:32 AM
Quoted: 90 Post(s)
Liked: 134
Think there are two - see post 482 for photo
Panasonic ZT60 and VT60 Fan/Fridge Noise Production Numbers
post #12609 of 14362 Old 08-19-2014, 10:47 AM
mo949's Avatar
Liked: 1066
The ZT60 has a 3rd fan that the VT60 does not.
Its in the middle.
mo949 is offline
post #12610 of 14362 Old 08-19-2014, 11:04 AM
Quoted: 129 Post(s)
Liked: 287
The service bulletin shows a VT60, which has only two fans. (The webcam is at the center top.) The ZT60 has 3 fans, which can be seen in member goosesdizzel's post here and here:
This would lead one to believe that the VT60 might be more prone to damage caused by heat, no?
post #12611 of 14362 Old 08-19-2014, 11:06 AM
Grendell's Avatar
Quoted: 41 Post(s)
Liked: 24
Yeah, I see it now. In the middle.
Grendell is offline
post #12612 of 14362 Old 08-19-2014, 11:19 AM
Grendell's Avatar
Quoted: 41 Post(s)
Liked: 24
Thanks for that pic.
I'm looking at this:
http://www.newegg.com/Product/Produc...82E16811999130
And then using double sided tape to attach three of them to the following locations (on the outside), sucking air out:
Maybe only using one fan instead of two on the left (although that board seems to run hotter).
I'd probably rather use a USB hub with a swith on it rather than use the set's ports for power.
Does any of this sound ill advised?
Here's the thermograph again:
The two boards with the black heatsinks seem to be running the hottest.
That thermograph is taken from a distance to get the whole panel in, when moved closer to the set, the hot spots increase to a ~110°F - 115°F reading.
Grendell is offline
post #12613 of 14362 Old 08-19-2014, 11:26 AM
mo949's Avatar
Liked: 1066
Make sure your double sided tape is heat rated to about 130F.
Alternatively you can use what I did, which is real Duct (HVAC) tape and seal it around the sides to create the most static pressure.
mo949 is offline
post #12614 of 14362 Old 08-19-2014, 12:08 PM
B T C's Avatar
Location: Lansing, MI via Kentucky, Georgia & Tennessee
Quoted: 203 Post(s)
Liked: 58
So,the 65" VT60 only has 2 fans? I know that my 55" only has two.
B T C is offline
post #12615 of 14362 Old 08-19-2014, 12:13 PM
Quoted: 185 Post(s)
Liked: 90
Dont suck the air out if there are no vent to allow air in...you'll create a negative pressure environment and no cool air will be drawn in over the hot components
Use the screws that come with the fan. You can screw them into the grate like a pc case. Thats what I plan on doing I used double sided tape for my led strip and it kept coming off once the set heated up....
post #12616 of 14362 Old 08-19-2014, 02:10 PM
Grendell's Avatar
Quoted: 41 Post(s)
Liked: 24
It seems since there are three fans blowing out at the top, then the three fans I would add in the bottom/middle should probably blow air in.
Grendell is offline
post #12617 of 14362 Old 08-19-2014, 09:07 PM
rifleman69's Avatar
Liked: 51
Mine did that once back in Jan/Feb, I thought the power had blipped or something. This was before calibration with the contrast up pretty high.
rifleman69 is offline
post #12618 of 14362 Old 08-20-2014, 08:17 PM
Fete26's Avatar
Quoted: 45 Post(s)
I just got a PS4 that I have hooked up to my ZT. I was wondering what picture mode other people play their games in also what precautions should I take to avoid image retention. Thanks.
Fete26 is offline
post #12619 of 14362 Old 08-20-2014, 11:50 PM
AVS Club Gold
htwaits's Avatar
Quoted: 312 Post(s)
Liked: 830
I'm sure that there are people who use ZT60 displays for gaming, but I wouldn't.
htwaits is offline
post #12620 of 14362 Old 08-21-2014, 04:51 AM
Quoted: 129 Post(s)
Liked: 287
I game with a PS3 & Xbox 360 fairly regularly. You'll want to disable any unecessary HUDs (especially if they're white) and use a picture mode with Contrast set no higher than 70. Pixel orbiter can alleviate IR in some instances so the THX modes, which don't allow this feature, may not be the best modes to use when gaming. Also, if you are going to pause the game regularly you'll want to use the screen wipe while doing so.
I really wish the Panasonic remote had a hard button for the screen wipe. As it is, I programmed a macro on my remote to engage it, which I use all the time when pausing games or 4:3 content.
Devil Dan likes this.
post #12621 of 14362 Old 08-21-2014, 10:48 AM
mohanman's Avatar
Quoted: 40 Post(s)
Liked: 33
I game on ZT60 with THX bright mode all the time, no problems.
mohanman is offline
post #12622 of 14362 Old 08-21-2014, 10:57 AM
jliedeka's Avatar
I also play my Xbox 360 on the ZT. If I plan to be away from it for a while, I use the video mute feature on my AVR. I haven't had any retention issues.
Jim
jliedeka is offline
post #12623 of 14362 Old 08-21-2014, 12:38 PM
B T C's Avatar
Quoted: 203 Post(s)
Liked: 58
Is it true that, in comparison to the VT60, the ZT60 display contains no MgO, or magnesium oxide, making it less susceptible to burn in or IR? I remember reading that somewhere, but just wondered if anyone could confirm.
B T C is offline
post #12624 of 14362 Old 08-21-2014, 12:54 PM
Quoted: 129 Post(s)
Liked: 287
The ZT and VT panels are the same. Where they differ is the ZT's improved anti-glare coating.
post #12625 of 14362 Old 08-21-2014, 01:13 PM
B T C's Avatar
Quoted: 203 Post(s)
Liked: 58
That's what I thought, but I did read that somewhere on this forum I believe. If that's the case, it's obviously not true.
B T C is offline
post #12626 of 14362 Old 08-21-2014, 01:28 PM
Quoted: 90 Post(s)
Liked: 134
Panels are both are the same NeoPlasma Black 3000 - Filters are different Ultimate Black for ZT & Infinite Black Ultra for VT
Big difference is the way the screen is attached to the panel, the Filter is on the INSIDE glass surface, held there by the autoclave process.
Studio Master Panel
The ZT60 series features Panasonic’s Studio Master Panel for increased performance and superb contrast. By removing the pocket of air between the panel and the front glass, the Panasonic TV’s Studio Master Panel improves light transmission and minimizes reflections from external light.
"If you look at the Panasonic TX-P60ZT65 from an angle, you'll notice that its pictures don't suffer with the 'double imaging' issue you see with every other Panasonic plasma TV when viewing them off-axis. This is because Panasonic has managed to remove the usual air gap between the plasma panel and the front glass. It's something that's only been possible by manufacturing the ZT65 screens in autoclaves - rare, high-precision heated compression chambers required to make sure the panel layers bond together correctly."
JackDVD78 likes this.
post #12627 of 14362 Old 08-21-2014, 01:37 PM
B T C's Avatar
Quoted: 203 Post(s)
Liked: 58
Thanks, Bob. I knew about the different filter and no air gap on the ZT60, but was curious about the MgO comment I read.
This may be a bit off topic, but would you guys, or ya'll, have any reservations about buying either a VT60 or ZT60 with no warranty coverage?
B T C is offline
post #12628 of 14362 Old 08-21-2014, 01:44 PM
Quoted: 129 Post(s)
Liked: 287
I didn't buy a warranty for mine. Naturally it comes with one year of coverage, which is when any inherent issues usually appear anyway. I'm not sure if I'd buy used unless the price was nice. For example, ~$1,500 for a 65" ZT with no visible IR would be a compelling offer.
post #12629 of 14362 Old 08-21-2014, 01:51 PM
Quoted: 90 Post(s)
Liked: 134
Could this be it? Much to technical for me
http://www.google.com/patents/US8253333
The magnesium oxide crystal particles are arranged on the discharge space side of the metal oxide ... Original Assignee, Panasonic Corporation ... No. 12/662,768, filed on May 3, 2010 now U.S. Pat. No. 8,076,851 .
post #12630 of 14362 Old 08-21-2014, 01:56 PM
Quoted: 129 Post(s)
Liked: 287
Or is it related to magnesium sputtering as it relates to image retention? I remember talk about that from some time ago.
Panasonic Viera Tc P65zt60 65 Inch Plasma Hdtv , Panasonic Viera Tc P60zt60 60 Inch Plasma Tv
taboola here
