Official ZT60 Owners Thread - Page 425 - AVS Forum
post #12721 of 12744 Old 09-11-2014, 08:33 PM
eaayoung's Avatar
Quoted: 48 Post(s)
Liked: 54
Originally Posted by wse View Post
Thanks got one now the question is how do I wall mount it?
Here's how I mount my flat panels, and I have mounted 4 of them around 10+ times since 2005 and never had a problem:
For walls with wood studs: I use 3/4" furniture grade plywood to attach to the wall. Before install the plywood to the wall, I paint the plywood to match the color of the wall. I usually cut the plywood large enough to overlap three studs, say 30"x48". But, if you only cover two studs that shouldn't be a problem. Just make sure the plywood will be hidden behind the TV once it's mounted. Use a stud finder to mark the studs. Attach the plywood to the studs with 6-9 2.5" wood screws. For wood screws when mounting a TV, I like deck screws since they are very strong. I attach the mounting bracket to the plywood with 6 1.5" wood screws. Depending on where the studs are in the wall, you can move the mounting bracket to where it's centered on the on the wall. (Since the weight TV will be transfered to the studs, it doesn't matter where the mounting bracket is attached on the plywood. You made also need washers for the screws, depending on the gap on the bracket.) Important: after you install the bracket to the wall, test the weight by attaching a rope over the bracket and hanging your weight off the bracket. Whatever your weight is, the mount should hold that amount of weight. To attach the tv to the bracket and arm, following the instructions included with the mount.
For walls that are brick: I drill a hole in the brick and install 3/8" Red Heads anchor bolts. I then bolt the plywood to the wall via the Red Head anchor bolts. I then use 3/4" screws to attach the mounting bracket to the plywood. Once again, test the weight carrying ability of the mount by hanging your weight from the bracket. If the mount can hold your weight, they you should be good up to that weight. Attaching a TV to a brick wall seems more risky in my opinion. I've only mounted one TV to a brick wall. Although I never had a problem, I prefer attaching the bracket to studs.
For walls with metal studs: no clue. Let me know how you do it!
Making sure you hit the studs is the most important step. You can always pre-drill areas that will be covered by the plywood to make sure the studs are where you think they are.
Tip for lifting a heavy TV higher than your shoulders (ie: over a fireplace): My first Panasonic plasma is a 50" 500U. With my full motion Sanus mount attached, the combined weight is around 125 lbs. When I mount this TV high on the wall, I rent an AC lift from either HD or Lowes. I clamp a plywood base to the AC forks. I place the TV with stand still attached on the plywood. I then install the mount arms to the TV. I then crank the lift up and extend the mounting arm to where it attaches to the mounting bracket already attached on the wall. AC lifts can be transported in a van since they break down. Last time I rented one, it was around $100/day. If the lift won't go high enough, just build up the height with wood studs stacked up and screwed together and clamped to the AC lift forks.
Another suggestion, take off your rings/bracelets off when handling the TV, so you don't scratch the TV.
eaayoung is offline
post #12722 of 12744 Old 09-12-2014, 04:38 AM
Thxtheater's Avatar
Quoted: 36 Post(s)
Liked: 77
I need some help and advice with the ZT60. I was watching the movie All is Lost on Blu-ray and the color banding in a lot of scenes was terrible. I've also noticed slight banding on the Netflix House of Cards intro segment.
I've noticed the banding in my calibrated modes as well as the default THX and cinema modes.
I've calibrated my set with the Spears and Muncil disc in the pro modes.
My bottom line question is if this banding is a problem with the disc and netflix or if my set needs further calibration.
Thxtheater is online now
post #12723 of 12744 Old 09-13-2014, 01:51 PM
collinp's Avatar
Some heavily compressed source material may show banding. I wouldn't use Netflix to determine video quality, but most Blu-ray's should have very high quality video. I have not seen the All Is Lost Blu-ray personally, but Widescreen Review gave it high marks for video quality. I imagine it has a lot of dark scenes and blue water scenes both of which can really showcase banding issues.
Usually banding is introduced by the display. It is an extremely common problem in digital displays. It is due to not having a smooth grayscale. Color is effectively overlaid onto an underlying black and white image. As the display goes from black to white red, green, and blue must increase in same proportions. In almost all consumer displays this is not correct out of the box. For example at dark gray red may be too high then at light gray red is fine but blue is too low and so on as you get to white. Smooth gradients and fade ins/outs will make this sort of problem very visible.
Many displays do not have enough bit-depth in their processing engines to completely calibrate this sort of thing out, particularly in the shadows. Luckily the ZT60 grayscale can be made pretty darn smooth. It's quite a finicky set to calibrate, but it can get pretty smooth. I've calibrated mine and it is really close to flawless, with just a few small blips that are hardly noticeable. If I worked on it a bit more I think I might be able to work those out too but I'm content with what I've got. The default THX mode is okay on my set though it does exhibit some banding, over saturation, incorrect white point, etc. Most people wouldn't notice and be happy with THX mode but if you look at it critically there's definitely banding.
Someone with a lot of experience might be able to improve the grayscale by eye, but to get it correct you really need some sort of meter and software. That means paying a professional or investing in some HW & SW and teaching yourself. Calibrating by eye with a DVD really only gets the broadest of controls correct which on this set really aren't far off by default.
collinp is offline
post #12724 of 12744 Old 09-13-2014, 02:05 PM
kennyboy2's Avatar
All is Lost
My ZT60 is not calibrated but I seldom notice color banding. I rented All is Lost on blu-ray and caught segments on cable and noticed significant banding in certain scenes. The banding would come and go throughout the presentation. I suspect the banding may be inherent to the source. I doubt there is a problem with your set.
kennyboy2 is offline
post #12725 of 12744 Old 09-14-2014, 05:16 AM
Thxtheater's Avatar
Quoted: 36 Post(s)
Liked: 77
Thanks guys. My TV is fine. I'm not implying it's defective. I just didn't know if any of you with calibrated sets have experienced the banding in "All is Lost."
I mentioned "House of Cards" via AppleTV because that's an easy reference for comparison by others--even though it's compressed.
What I'm specifically wondering about is if the banding is due to some specific calibration setting. In other words, x y or z setting is usually where you go to fine time the set to address banding issues (assuming it's not the source).
Of all the movies I've watched I've never seen banding so frequent and so pronounced as I did with "All is Lost" on Blu-Ray. Therefore perhaps this disc is a reference torture test for banding??
post #12726 of 12744 Old 09-14-2014, 05:16 PM
jimshowalter's Avatar
Quoted: 24 Post(s)
Liked: 45
There is no perfect panel.
A long-time Kuro owner, I recently bought a TCP65ZT60 and a PN64F8500, before plasma is completely gone.
The Panasonic has the best picture I've ever seen: deepest blacks, most-lifelike colors. Just amazing.
But the Panasonic seems to have been slapped together. It's kind of a beta version. The fans are notorious for generating beat frequencies that are quite annoying, the thing gets incredibly hot, and at least in some cases it generates subwoofer hum. Owners have to basically finish the engineering that Panasonic should have done--adding diverter fans, measuring heat and sticking fans on the back to control it, and (in my case anyway), using an EMF meter and MuMetal shielding to try to knock down the hum.
Compared to the Pansonic, the Samsung is much much better engineered. No fan noise, runs much cooler, no subwoofer hum. Even the 3D glasses are better--light, comfortable, easier to replace the battery. And no distracting bright metal trim visible from the front. And you can still get insurance.
It's just that, well... the Samsung makes everything look like it's shot on video. Like daytime soaps. At first I thought it was the movie (which I hadn't seen before), so I switched to some Blu-rays I've seen multiple times, and they also looked like "All My Children". It's not the LCD "clay-face" problem. Instead, it's an utter lack of filmic quality. Things are too crisp, kind of fakey, like everything is CGI (even people). I fiddled around with various settings and got it to look better, but it still doesn't look realistic. Also the darks aren't quite as good.
Does anyone else have both panels? If so, do you have the same experience?
rifleman69 and Edllguy like this.
My system? Google for: Martin Logan 420 CLX Descent Stage Summit
jimshowalter is offline
post #12727 of 12744 Old 09-15-2014, 12:17 AM
fmalczewski's Avatar
Quoted: 17 Post(s)
^^ Crisp, Fakey - sounds like a contrast problem; did you try a calibration disc? A lot easier to get those settings in a reasonable ballpark than just by eyeballing it. Also, turn everything off... maybe some special processing on the Samsung is still on that's causing what you are seeing. Soap opera effect, isn't that usually tied to motion smoothing? Turn it off.
fmalczewski is online now
post #12728 of 12744 Old 09-15-2014, 06:41 AM
RoyMacDonald's Avatar
Quoted: 12 Post(s)
I've just ordered All is Lost so I can see how my ZT handles it. Will let you know.
RoyMacDonald is offline
post #12729 of 12744 Old 09-15-2014, 08:11 PM
Thxtheater's Avatar
Quoted: 36 Post(s)
Liked: 77
Roy, that's super! Thanks for letting me know your thoughts. You'll know right from the opening scene. The floating container and sky all had banding right away.
post #12730 of 12744 Old 09-16-2014, 04:09 AM
eric3316's Avatar
Quoted: 185 Post(s)
Liked: 644
Agree with this. Sounds like you have the motion smoother on if you are seeing the soap opera effect. The F8500 might not look as film like as the ZT60 but you can get it to look far from a soap opera once you turn off the settings that are causing this.
eric3316 is online now
post #12731 of 12744 Old 09-16-2014, 02:16 PM
bob brennan's Avatar
Quoted: 22 Post(s)
Liked: 97
Sad News - we might not own the best HDTV ever made - only 55" & has some issues but see the link and below - from CNET & David Katzmaier
"And about that picture quality. Last year I called the Panasonic ZT60 plasma TV "the best-performing TV we've ever reviewed." That's no longer the case, because the LG 55EC9300 is better"
http://www.cnet.com/products/lg-55ec9300/
Panasonic TC-P65ZT60 - Oppo BDP-103D - Panasonic DMP-BDT220 - Toshiba HD-DVD-3A - OPPO DV-981HD - Harmony 880
Onkyo TX-NR809 --- Definitive Technology - Studio Monitor 65 (2) - CS8040HD - Studio Monitor 45 (2) - Super Cube 6000
bob brennan is online now
post #12732 of 12744 Old 09-16-2014, 02:20 PM
Thxtheater's Avatar
Quoted: 36 Post(s)
Liked: 77
I've seen that TV and it's certainly impressive. Take heart that we still have the best 60" and 64" TVs ever made. ;-)
post #12733 of 12744 Old 09-16-2014, 02:31 PM
Quoted: 22 Post(s)
Liked: 97
totally agree - every time I watch something on my ZT I am still amazed and what an unbelievable picture it has - will be sometime before I consider anything else - if I did trade up it would have to be in the 70" to 75" range - I also subscribe to never being one of the first for anything - can wait and let them get the bugs out and bring the size up & price down
Edllguy likes this.
post #12734 of 12744 Old 09-16-2014, 02:33 PM
repete66211's Avatar
Quoted: 50 Post(s)
Liked: 209
And ours are flat.
The review isn't as glowing as you'd think given the quote above. For example, "Its video processing and color accuracy don't measure up to that of the best TVs, and the curved screen introduces some artifacts." And given that plasma died mainly (IMO) due to the public's perception of IR and burn in and this OLED shows signs of just that, I'm curious to see how the public reacts to the technology, especially at a price point that's higher than LED.
Edllguy likes this.
repete66211 is offline
post #12735 of 12744 Old 09-16-2014, 03:01 PM
mo949's Avatar
Liked: 401
Surprisingly the price is about the same as a 55" Vt50 cost on release, 2799 vs 2999 if memory serves.
mo949 is offline
post #12736 of 12744 Old 09-16-2014, 04:22 PM
eaayoung's Avatar
Quoted: 48 Post(s)
Liked: 54
Glad I won't feel pressured to buy the LG. Don't really care for LG products or a curved TV. My dream OLED TV is a flat 65" or bigger TV. I'm sure I could deal with any problems related to the picture. But, the curve is another issue I can't overlook.
Edllguy likes this.
eaayoung is offline
post #12737 of 12744 Old 09-17-2014, 01:08 AM
Famouss's Avatar
Liked: 47
Ya while the prices are getting better and better, I can't accept any tv smaller than my 65vt60 as my main viewing set. I upgraded from a 50" 2010 Panny and also currently have a Kuro in the bedroom, so I think I'll be just fine for a few more years.
Edllguy likes this.
Panasonic TC-P65VT60
Sony BDP-S5100
Elite PRO-101FD
Famouss is offline
post #12738 of 12744 Old 09-17-2014, 12:32 PM
mo949's Avatar
Liked: 401
I expect only people that care about a 55 inch sized screen will feel any pressure at this point.
mo949 is offline
post #12739 of 12744 Old 09-17-2014, 06:06 PM
discone's Avatar
Quoted: 48 Post(s)
Liked: 59
Not a bad review for an OLED being they are still in their infancy. If this tech is good now I will be watching to see how good they are in 5 years.
Even if they are saying it's better then a ZT I'm not ready to give mine up!!
Edllguy and eaayoung like this.
discone is offline
post #12740 of 12744 Old 09-17-2014, 06:30 PM
Quoted: 50 Post(s)
Liked: 209
I'm not sure if I'd say OLED is in its infancy given how long the tech has been around, but it's encouraging to see a larger unit going for a relatively modest price.
sooke and discone like this.
post #12741 of 12744 Old Yesterday, 07:07 AM
discone's Avatar
Quoted: 48 Post(s)
Liked: 59
Yes Thank You! I stand corrected.
I should have worded it better as OLED has been around for a little while. It's just now they are starting to push this tech more so then in the past. With price and other things the tech was not mass produced to reach a greater market. If it had been maybe I would not own a ZT right now. OLED is better now then in the past and they are doing different things to make them even better, but how it hold's up we will still have to wait and see. That is all I was saying about it is in it's infancy to become available for the mass market.
I should have said "in their infancy to reach a greater market share of home tv sales."
repete66211 likes this.
discone is offline
post #12742 of 12744 Old Yesterday, 07:59 AM
Cloverleaf's Avatar
Totally agree. While I am pleased that LG are carrying the OLED torch, when Panasonic, Sony et al seem to be happy to settle for an easy life and just bang out a load of pants UHD LEDs, I have always viewed LG as a bit of a "budget" brand, a bit below top tier in terms of quality. If they can produce such a good (albeit curved) OLED panel, I can't help wondering what Panasonic etc could come up with if they invested in and developed OLED as well ? How much better would a "ZT OLED" be for instance than an LG panel ?
I'm definitely keeping my ZT until a flat OLED screen from a premium manufacturer is avialable. If that ever happens, which it may well not sadly.
Panasonic ZT65 (isf calibrated) / Cambridge Audio 752BD / Pioneer LX55 / Dual CS506 / Sky + HD / Tannoy Arena 5.1 / Isotek Mira / QED Cables
Cloverleaf is offline
post #12743 of 12744 Old Yesterday, 12:23 PM
sooke's Avatar
Quoted: 26 Post(s)
Liked: 37
I look at this as good news. It means we have an upgrade path. The ZT60 won't be the last TV I buy, though I probably won't be in the market for another 5-7 years. I really wasn't looking forward to watching the display industry see how good they could make an edgelit LCD. OLED is much more exciting.
Panasonic TC-P60ZT60 plasma panel
Sony BDP-S5100 Blu-ray player
Samsung SMT-H3272 DVR
Yamaha RX-V650 AVR
XBOX 360
URC MX-780 remote control
sooke is offline
post #12744 of 12744 Old Today, 01:37 PM
Quoted: 24 Post(s)
Liked: 45
I feel exactly the same way. The reason I bought two plasmas was to have a backup. But it looks like LG has cracked the OLED puzzle, and we'll be able to get 80" 4k panels for a few thousand dollars in a couple of years. (Having a patent that gets them to high yields sure helps.)
Panasonic Viera Tc P65zt60 65 Inch Plasma Hdtv , Panasonic Viera Tc P60zt60 60 Inch Plasma Tv
