Official ZT60 Owners Thread - Page 464 - AVS Forum | Home Theater Discussions And Reviews
post #13891 of 13893 Unread Today, 05:13 AM
Jay AVF's Avatar
Quoted: 32 Post(s)
Liked: 30
Originally Posted by eaayoung View Post
Broke the Toslink flap on my ZT yesterday when moving equipment around. Found a suggestion of gluing a right angle Toslink adapter into the port. Hopefully it will work. Should work out better than what I was using since the Toslink port is on the side of the ZT.
Really dislike the Toslink connections. I've broken the flaps before and I'm sure this won't be the last Toslink flap that I break.
Are you able to take a picture of it please?
I'm curious as to what the damage looks like.
The reason I ask is I've come across a ZT60 for sale, very low hours but it has damage to the digital audio out (optical port).
The thing is it's not just the flap part, it's actually taken a chunk of the plastic away on the port (not just the flap). so I'm concerned that some force was used to do that damage.
Might sound silly but could that have any effect on the panel? I'm a little ocd and paranoid and I'd be worried about maybe some damage done internally due to the force or something.
I was hoping to see what your port looks like to get an idea of whether the damage is similar to the one I'm looking at purchasing to see if the damage is "normal" for simply removing the cable, or whether the one I'm potentially buying has been overly forced.
P.S as a general question to anyone reading, would a broken optical port put anyone off a potential purchase if everything else appears ok, no pane speration, low hours etc?
I checked uniformity and it was excellent, the VT60 I had suffered from vertical banding, and the LG 55EC9300 I have currently has awful uniformity. Also to be honest I think the ZT produces a better image than the LG so I'm super keen, just in two minds about the damaged port
Jay AVF is online now
post #13892 of 13893 Unread Today, 05:45 AM
eaayoung's Avatar
Quoted: 149 Post(s)
Liked: 106
Took a picture but you can't tell what's damaged unfortunately. Only damage on mine is to the flap. It broke off so the cable won't stay attached when plugged in. This is not the first flap I've broken either. Very common problem from what I've read. Currently have the cable taped in position. Optical connection works fine other than that problem.
Suggest you plug an optical cable into the connection. If the light travels the cable to the other end then it should be ok. You could always test the connection with equipment that can use the optical connection, like a soundbar.
I would be shocked if the damage is more than just the flap. The optical connection is pretty fragile. If you can tape the optical cable into the port to make it work, then you could glue a 90 degree optical plug into position. You can buy the 90 degree optical plugs on Amazon for cheap. I think mine was around $5.00.
eaayoung is online now
post #13893 of 13893 Unread Today, 06:38 AM
Jay AVF's Avatar
Quoted: 32 Post(s)
Liked: 30
Thanks for the reply,
here are images to show what sort of damage have been done. I can understand the flap being damaged under "normal" use, but this damage would require some serious force, and incorrect removal or have I got it wrong?? It's actually taken a chunk of the port away
[img]http://s18.postimg.org/8yz8h4005/IMG_0636.jpg[/img
Panasonic Viera Tc P65zt60 65 Inch Plasma Hdtv , Panasonic Viera Tc P60zt60 60 Inch Plasma Tv
