ISFccc Code to Unlock My Panasonic VT60 So I Can Calibrate With Calman5 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-29-2013, 08:23 PM - Thread Starter
VT604me's Avatar
Hello everyone!
just bought a panasonic 60vt60 i want to calibrate it after the initial breakin how can I get that ISFccc pin #?
thanks
Panasonic VT60
Onkyo NR 807
Denon BDP3800 Blu-ray
Bowers & Wilkins (fronts)
Bowers & Wilkins (rears)
Velodyne Ct120 sub
VT604me is offline
post #2 of 8 Old 05-30-2013, 05:46 AM
chunon's Avatar
Quoted: 2010 Post(s)
Liked: 1772
Originally Posted by VT604me View Post
Hello everyone!
thanks
If you own calman or control cal you do not need a pin to my knowledge just follow the ISF procedures, have you tried the Calman support forum >
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #3 of 8 Old 05-30-2013, 08:15 AM
TWD
TWD's Avatar
Quoted: 46 Post(s)
Liked: 36
There is an option in the display to set the Professional 1/2 picture modes to on. I think it is in the setup menu. Once you set it to on, the modes will show up in the main menu just like Custom , THX Cinema, etc.
TWD
TWD is offline
post #4 of 8 Old 05-31-2013, 03:37 AM - Thread Starter
VT604me's Avatar
I just bought the c3 meter and going to upgrade to control for the autocal feature. however if a pin# is needed to unlock in ISFccc mode and I have no resources to aquire then I am going to send Calman5 back for a refund.
Panasonic VT60
Onkyo NR 807
Velodyne Ct120 sub
VT604me is offline
post #5 of 8 Old 05-31-2013, 03:50 AM
chunon's Avatar
Liked: 1772
There are procedures for autocal on spectracals website
65C6 OLED
post #6 of 8 Old 06-29-2013, 10:34 AM
phibbus's Avatar
The code is "i085", "i" being the Info button on the remote.
The password is a bit confusing and not very well documented. It appears you can enter any 4-digit password the first time around, however you must then enter it again to confirm (including the "i085" code, above.) If you enter any password other than "i085", you will get the sub-menu item to turn the settings lock on or off, but not the additional one to connect to the ISFccc network required by CalMAN to access the settings.
phibbus is offline
post #7 of 8 Old 06-29-2013, 11:01 AM
Sammie2980's Avatar
Quoted: 201 Post(s)
Liked: 179
Your best bet is to get ControlCal. Honestly it's more then worth it. I don't think I would even touch a panasonic without it
turbe likes this.
LivingRoom: LG OLED65E6P / Oppo UDP-203 / Anthem MRX 1120 / SVS SB12 / M5300-PM / Def Tech BP-8060ST, Mythos Ones x 2, Eight, Gem XL x2 / PS4 Pro / Xbox One S / Wii U
Bedroom: Panasonic 65ZT60 / Oppo BDP103D / Apple TV / PS3
Office: Pioneer KRP-500M / Xbox 360
CalMan Enthusiast, ChromaPure, HCFR, i1D3 Pro, i1Pro, SpectraCal C6, MobileForge, Lightspace, Umik1
Sammie2980 is offline
post #8 of 8 Old 12-05-2013, 01:50 PM
nexusdoan's Avatar
I took a look at Calman. It's too expensive for me. Can't really pay more than $200 extra. I am thinking about getting ChromaPure since it seems easier as far as UI and I like the before/after reporting. Is this one "exactly" the same as far as functionally and feature set as the free one?
nexusdoan is offline
Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P55vt60 55 Inch 3d Smart Plasma Hdtv
