Official Samsung PNxxF8500 Owners Thread (No Street Price Talk) - Page 184 - AVS Forum | Home Theater Discussions And Reviews
 1235Likes
post #5491 of 13981 Old 04-09-2014, 02:30 PM
hove131's Avatar
Quoted: 36 Post(s)
Well when I turn on set it defaults to the smart hub....Picture is iimmediately bright and clear ...after a couple seconds screen dims and becomes yellow...assuming its adjusting to stored settings...maybe initially its in dynamic mode from factory before it makes its adjustment. I played with standard and movie mode ...both yellowish...standard not as much. Seems normal
hove131 is offline
post #5492 of 13981 Old 04-09-2014, 03:36 PM
xvfx's Avatar
Quoted: 410 Post(s)
Liked: 241
Originally Posted by pieandchips View Post
You may be used to things being too blue. Too many variables with your posts to be sure of anything.
Dwalin: What is this?
Balin: I don't know. I think it's supposed to be cheese, it's gone blue.
Bilbo: The thing is, um...
[Dwalin and Balin continue to ignore Bilbo]
Dwalin: It's riddled, but mold.
[Dwalin throws the cheese away]
xvfx is offline
post #5493 of 13981 Old 04-09-2014, 04:59 PM
CamaroDrvr's Avatar
Liked: 44
Originally Posted by hove131 View Post
Its pushed in all the way ...wiggles a bit. So if it possibly caused damage and still wiggles tiny bit ...return it?
You never had a short, you had an intermittent open circuit and while it caused the TV to go on and if it was going to do any damage it would be done and the TV broken. No doubt the power supply had to deal with it abruptly disconnecting and some electrical noise from the plug being loose but this did not change the voltage one bit and there is no need to return the TV. The power supply takes the exact same thing every time the TV is plugged in and unplugged and the power supply is designed to deal with that in spades, it has to or they would all break the first time they were plugged in.
The far more important reason you really want to make sure that plug is seated properly is the fire hazard, a loose plug can generate a LOT of heat, more than enough to catch the plug end and cord on fire, so find a skinny kid and boost them in place to make sure but it sounds like you have it now. Looking from the side, the plug should be sticking out 7/8" if it is sticking out over an inch it likely needs a little more push, that is if you are using the supplied right angle plug.
In any event there is no point in returning it, if it is working then it is fine as far an any impact from a loose plug. Virtually all things with a removable plug are designed to take a loose plug on occaision, it is something that happens all kinds of ways, so your TV is fine.
CamaroDrvr is offline
post #5494 of 13981 Old 04-09-2014, 05:07 PM
CamaroDrvr's Avatar
Liked: 44
I wonder if this is related to the "Notification" issue, I lost my picture completely after the .19 firmware upgrade and tried everything, the smarthub apps were the only thing that gave me a picture, as soon I went back to TV the screen blanked out after a few seconds. I am not sure what fixed it in the, I had reset through the user and maintenance menu's.
Then I stumbled on a work around, leaving my network disconnected, if you are wireless you need to go wipe out the network config and if you are wired pull the Ethernet connection. Once you have done this and are sure the network is not connected, turn it off, unplug it, wait a few minutes and plug it back in again, see if that changes your symptoms.
If it does the last thing I did when it magically started working right again was go to the Notifications screen and deal all and just pick anything you can click on, I had been doing that for a couple weeks and then last week, it just started to work properly again. Actually a couple of people had the same issue I did, some cleared up easier than others.
Worth a shot, if the picture is good in the apps hub is should be good in TV mode, now if you messed with all the settings I suggest you go into the menu and reset it all to factory, that eliminates a settings issue.
Good luck
post #5495 of 13981 Old 04-09-2014, 06:00 PM
hove131's Avatar
Quoted: 36 Post(s)
I did a reset for picture settings and it still does this. Its something in the program/firmware. Even on dynamic mode it slightly adjust...but barely. It dims and throws a slightly yellow filter over the picture. Pay attention next time you turn your set on ...wait about 3-4 seconds.
hove131 is offline
post #5496 of 13981 Old 04-09-2014, 06:03 PM
pieandchips's Avatar
Liked: 171
Mine does this too. They all do. It is not a defect.
On startup the TV logos are bright with a blue look to them.
hove131 likes this.
pieandchips is offline
post #5497 of 13981 Old 04-10-2014, 02:35 PM
tyler webb's Avatar
Quoted: 125 Post(s)
Liked: 41
How did everyone's update go? I can't tell any difernce in PQ.
tyler webb is offline
post #5498 of 13981 Old 04-10-2014, 02:43 PM
fierce_gt's Avatar
Quoted: 1650 Post(s)
Liked: 1588
I seriously don't think ANY of these updates have affected picture quality. some ppl may have had changes in pq due to errors during the update process, but that was always fixed with a reset.
the updates are more likely to focus on changing features, especially the smart features
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #5499 of 13981 Old 04-10-2014, 03:22 PM
caeguy's Avatar
I believe Samsung
"- Improves picture quality."
Samsung PN60F8500, Panasonic TH-42PD25U/P, Pioneer VSX-1018TXH-K, Oppo BDP-93, Aperion Audio 5T&5C, HSU STF-2, PS3, Wii, HTPC, SD Homerun Prime, Ceton Echo
caeguy is offline
post #5500 of 13981 Old 04-10-2014, 03:35 PM
wxman's Avatar
Quoted: 3853 Post(s)
Liked: 2738
As stated by others, if you had a bad picture, it was either a bad tv, or a poorly installed update, which a reset would fix. Several updates ago, they did fix the rising blacks with CS on, but since then, there has been no PQ improvement. What you have as a picture is as good as it's going to get, unless you do a professional calibration. 99% of the FW updates are generally useless, unless you use smarthub, and even then, most of those updates are useless too.
LG 65EF9500
LG 65E6P
wxman is online now
post #5501 of 13981 Old 04-10-2014, 04:57 PM
Liked: 171
+1. I love to keep seeing the placebo effect each release.
post #5502 of 13981 Old 04-10-2014, 05:32 PM
Denniswrly's Avatar
Liked: 38
pie did u update to latest FW? And whats correct way to do it now?
64f8500
oppo bdp-103
Denon avr 1803
Energy speakers
Energy sub
Dual recliner lazyboy
xbox 360
Denniswrly is offline
post #5503 of 13981 Old 04-10-2014, 05:35 PM
Liked: 171
I haven't sorry. I have always just updated with 3 HDMIs plugged in. Let it reboot then I shut down and pull the plug for 10 minutes.
This is by no means the recommended way but I seem to have been okay doing it.
post #5504 of 13981 Old 04-10-2014, 05:35 PM
hove131's Avatar
Quoted: 36 Post(s)
Couple flaws I've seen on my display...would like to see if anyone else has seen anything like it. If you're close to screen and turn TV on... On the "smart TV" splash screen...at the lower left portion of screen I can see a rectangle maybe 7" x5" outlined...also notice a slight grid pattern in screen. When running slides.... On a black slide or dark grey I see a vertical band splitting the screen right in half. There is also a big wide horizontal band when viewing solid white slides about halfway up screen. I think all tvs arent completely uniform ...but a lot dont run slides so they never see it. After watching a movie i also see image retention in the credits from the smart hub screen! Longest ive been on that screen at anytime is a couple of minutes. Anyone else have this?
hove131 is offline
post #5505 of 13981 Old 04-10-2014, 06:30 PM
thebigkahuna1's Avatar
Liked: 25
Is there a known issue with this TV turning itself off and back on again? This happened yesterday and again this evening.
PSN ID: thebigkahuna1
thebigkahuna1 is offline
post #5506 of 13981 Old 04-10-2014, 06:36 PM
hove131's Avatar
Quoted: 36 Post(s)
Check that your plug is seated all the way...push hard...I had same issue.
hove131 is offline
post #5507 of 13981 Old 04-10-2014, 06:43 PM
Liked: 25
Thank you, I hope that is the fix. I know Samsung TV's have had capacitor issues in the past but I don't recall anyone here having this issue.
post #5508 of 13981 Old 04-10-2014, 06:44 PM
CamaroDrvr's Avatar
Liked: 44
Unless you have a loose plug the most common cause if it getting turned on or off is CEC control, mine was acting up like that once and it turns out it was my receiver doing it, I had to pull the power plug from the receiver to reset it and then it was fine. You might try disabling all of the auto-control stuff like CEC and then see if it happens again.
post #5509 of 13981 Old 04-10-2014, 06:47 PM
Liked: 25
Well, since I don't know what cec control is it's probably not the problem. smile.gif
post #5510 of 13981 Old 04-10-2014, 08:13 PM
bboris77's Avatar
I have the exact same vertical band, but it is very very slight and only sometimes noticeable on light backgrounds when there is a very fast panning shot. You can make it out on light slides but only if you stare at it for a while smile.gif I also have the standard horizontal band which I almost never notice. The vertical grid pattern is there but it is almost invisible compared to the middle vertical band and horizontal band in the top third of the screen. I checked another PN60F8500 on display in my local store, and it had the exact same vertical and horizontal bands. I am fairly sure they are simply a side-effect of anti-glare filter. While they are annoying sometimes, I have come to the same conclusion as you that it is almost impossible to find a perfect display these days. These bands are not noticeable 99% of the time, so I am happy considering the fantastic overall picture quality. What I did notice is that, for some strange reason, these bands become much less noticeable when I am in Relax picture mode compared to Movie mode. I have no idea why this is the case, but it could be an option for cases where absolute screen uniformity is needed, like watching hockey for example.
Damien Inferno likes this.
bboris77 is offline
post #5511 of 13981 Old 04-10-2014, 08:33 PM
Plasmalvr60's Avatar
I'm watching my DVR recording of today's earlier coverage of The Masters golf tournament. The colors are spectacular on my new PN64F8500. smile.gif
Samsung PN64F8500 Smart TV (64" Plasma-2013); LG BD 390 Blu-ray Player; Denon AVR-1709; Nakamichi MB CD Player; Verizon FiOS Motorola 7 Series Cable Box (500GB Hard Drive).  Pioneer Elite 1120 (5th Generation Plasma- 2005); Denon AVR 2800 (2000); Oppo Blu-ray 103 w/Roku Stick; Sony Carousal CD;...
Plasmalvr60 is offline
post #5512 of 13981 Old 04-10-2014, 09:17 PM
Quoted: 1512 Post(s)
Liked: 626
Seems that the gamma changed.
Anyone else notice a little less black crush?
Klein K-10A, CR250, i1D3, i1Pro2, Calman Enthusiast, LG 65B6P, Panasonic 65VT50, and a great wife that puts up with all this.:)
JimP is online now
post #5513 of 13981 Old 04-11-2014, 03:13 AM
bob brennan's Avatar
Quoted: 101 Post(s)
Liked: 136
From CNET:by David Katzmaier
NO Plasma's
10 exciting new TVs coming this spring
http://www.cnet.com/pictures/most-anticipated-tvs-spring-2014/
Panasonic TC-P65ZT60 - Oppo BDP-103D - Panasonic DMP-BDT220 - Toshiba HD-DVD-3A - OPPO DV-981HD - Harmony ONE
Onkyo TX-NR809 --- Definitive Technology - Studio Monitor 65 (2) - CS8040HD - Studio Monitor 45 (2) - Super Cube 6000
bob brennan is offline
post #5514 of 13981 Old 04-11-2014, 05:42 AM
Liked: 171
Time to meter and let us know! I don't have it installed (yet).
post #5515 of 13981 Old 04-11-2014, 08:22 AM
leeuggy's Avatar
I believe im having issues upgrading the firmware on this set - I wasnt even aware I was having issues as auto updates is turned on I just presumed it was all done in the background but ive seen references in this thread to 1119 after just checking mine the firmware is 1115 ?
I went on software update double checked I was connected via wifi but it says ' There are no new updates for you at the moment '
So I downloaded the update from the Samsung website and put on a USB but it isnt recognizing that either or giving me the option to update - anyone have any ideas?
leeuggy is offline
post #5516 of 13981 Old 04-11-2014, 08:55 AM
WVZR1's Avatar
Quoted: 13 Post(s)
Liked: 29
I wouldn't think you would want to do it "wirelessly" anyway! Why you're having difficulties with the USB I certainly can't help you with, that's pretty straight forward. I believe I'd connect to the display with an Ethernet connection directly from your router and attempt it direct to the display.
Instructions and the 1119.1 update are here:
http://www.samsung.com/us/support/owners/product/PN64F8500AFXZA?CID=AFL-hq-mul-0813-11000279
In the past the .pdf for instructions have required a "reload" if the .pdf encountered an error. It worked OK today on the first attempt.
WVZR1 is offline
post #5517 of 13981 Old 04-11-2014, 09:16 AM
leeuggy's Avatar
Thanks for the reply - Yeah I followed those instructions to make sure the file was in the correct directory but it doesnt give me the option to update via USB when I select software update. The USB options do pop up as per normal when input (view videos / pictures ect) and I can manually navigate the contents so im pretty much stumped at the moment
EDIT- By putting the files on my external HDD as opposed to a USB thumb drive I am now getting the prompt to search the HDD for updates but it is saying there arent any available, Im quite savvy with computers and have made 100% sure the file is in the correct directory and file path.
For some reason my 51" F8500 will NOT update from version 1115 firmware no matter which way I try - Just attempted to connect the TV via ethernet cable like you suggested and still not working
leeuggy is offline
post #5518 of 13981 Old 04-11-2014, 10:21 AM
Denniswrly's Avatar
Liked: 38
<--- Me
64f8500
oppo bdp-103
Denon avr 1803
Energy speakers
Energy sub
xbox 360
post #5519 of 13981 Old 04-11-2014, 10:41 AM
hpp8140's Avatar
Quoted: 270 Post(s)
Liked: 82
A folder named ‘T-FXPAKUC’ is in the root directory?
LN55C630, PN64F8500, Definitive SSA-50, GE Supercinema 3D Array X, Paradigm Millenia CT
hpp8140 is offline
post #5520 of 13981 Old 04-11-2014, 01:25 PM
WantsNWarrants's Avatar
Quoted: 84 Post(s)
Liked: 50
Are you in USA | Canada | Mexico?
If not, 1115 is, I think, latest (for eu EG).
leeuggy likes this.
WantsNWarrants is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Samsung Pn60f8500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Pn64f8500 64 Inch 3d Smart Plasma Hdtv
