Official Samsung PNxxF8500 Owners Thread (No Street Price Talk) - Page 217 - AVS Forum | Home Theater Discussions And Reviews
 1230Likes
post #6481 of 13932 Old 07-09-2014, 12:02 PM
Stereodude's Avatar
Quoted: 3112 Post(s)
Liked: 2254
Originally Posted by whm01 View Post
The big one seemed to be judder with Blu-ray/24p mode on. I also read somewhere about a slight trade off in black levels with it on.
The rise in black levels when Cinema Smooth is turned on was fixed with a firmware update last last year. I addressed this in a post here. The motion "judder" with Cinema Smooth is inherent to 24p. It's the same thing you see in the theater. It does not have uneven 3:2 cadence judder with a 24p source and Cinema Smooth enabled. If you don't like the way 24p sources looked with Cinema Smooth enabled, but don't want 3:2 cadence judder, turn off Cinema Smooth and use Motion Judder Canceller instead.
KONICA TECH likes this.
Stereodude is offline
post #6482 of 13932 Old 07-09-2014, 12:02 PM
Ph8te's Avatar
Quoted: 4555 Post(s)
Liked: 3987
Originally Posted by Stereodude View Post
Wouldn't off be for video?
Further, in Auto1 when the TV is doing an IVTC on 1080i60 content don't you still get 3:2 cadence judder because the F8500 is updating the screen at 60Hz, not 96Hz? The manual says Cinema Smooth only works when the TV is given a 24Hz input and 1080i60 isn't 24Hz even though it ultimately becomes 24Hz after IVTC'ing.
Take a look at the shootout video they explain it there and demonstrate the difference.
Sent from my Flip Phone using DOS
Ph8te is online now
post #6483 of 13932 Old 07-09-2014, 05:46 PM
stile's Avatar
Quoted: 51 Post(s)
does anyone ever see a white flashing pixel for a split second once in a while when watching the f8500? like, on a dark background or something, sometimes i see a flashing white dot for a split second every once in a while in different places. my unit was made in Feb and i've had it for less than a week.
stile is offline
post #6484 of 13932 Old 07-09-2014, 06:16 PM
Stereodude's Avatar
Liked: 2254
Try another HDMI cable?
post #6485 of 13932 Old 07-09-2014, 06:32 PM
Ph8te's Avatar
Liked: 3987
Could be the source(does it happen on all sources) could be the HDMI cable as well. Without more information hard to say.
Ph8te is online now
post #6486 of 13932 Old 07-09-2014, 06:59 PM
clpetersen's Avatar
Quoted: 162 Post(s)
Liked: 53
[QUOTE=Ph8te;25620113]Could be the source(does it happen on all sources) could be the HDMI cable as well. Without more information hard to say.
I agree with previous posts. First make sure not the source; most likely the HDMI cable creating 'sparklies' due to dropped pixels/packets. We use Monoprice cables with 'Redmere' technology - thin, not very expensive, and no sparklies.
clpetersen is offline
post #6487 of 13932 Old 07-09-2014, 07:40 PM
stile's Avatar
Quoted: 51 Post(s)
[quote=clpetersen;25620769]
it happens on all sources. I did just change my hdmi cables... but they are rated for 10.2gbps so why would they be dropping packets?
stile is offline
post #6488 of 13932 Old 07-09-2014, 08:19 PM
Tandrin's Avatar
Randomly switching inputs?
For about a week now my 60f8500 has switched by itself from satellite input to broadcast tv a few minutes after turning on. A reviewer on Amazon noted the same behavior starting a couple of weeks back too. I thought it might something to do with my Harmony remote but this started out of the blue. I have FW 1120 which I updated back in May or early June.
Tandrin is offline
post #6489 of 13932 Old 07-09-2014, 08:24 PM
Ph8te's Avatar
Liked: 3987
[quote=stile;25621753]
Cables go "bad" just because it's it's a high speed cable doesn't mean much if a new cable fixes it then you know that was the issue. Also if you are feeding through AVR take AVR out of equation to make sure it isn't that.
Ph8te is online now
post #6490 of 13932 Old 07-09-2014, 09:19 PM
Stereodude's Avatar
Liked: 2254
Is voice control and gesture control turned off?
post #6491 of 13932 Old 07-09-2014, 09:36 PM
Tandrin's Avatar
Yes both are turned off ? Happens minutes after startup and once changed back it stays.
Tandrin is offline
post #6492 of 13932 Old 07-10-2014, 02:07 AM
Dianabol5mg's Avatar
Quoted: 309 Post(s)
Liked: 236
Factory Reset
Dianabol5mg is offline
post #6493 of 13932 Old 07-10-2014, 04:30 AM
Quoted: 1398 Post(s)
Liked: 590
Its probably something dealing with your HDMI cables. Just because they're new, doesn't mean they're right. They're 18 connections in an HDMI cable and you have to wonder if they're all sound. Also try hooking them directly to the display bypassing your receiver/preamp just in case it's something dealing with the receiver/preamp.
You also want to be sure its not this. http://www.webmd.com/eye-health/tc/r...-call-a-doctor
JimP is offline
post #6494 of 13932 Old 07-10-2014, 07:24 AM
redcrow100's Avatar
Liked: 24
its the AnyNet feature of the TV i believe. I replied to this in either this thread or the discussion thread. The tv will switch back to the "TV" mode of your receiver because it thinks thats the proper mode. I programmed an additional command on my Harmony one to switch it back to "Sat" on the receiver at the end of my watchTV activity.
redcrow100 is offline
post #6495 of 13932 Old 07-10-2014, 02:53 PM
chupra's Avatar
Quoted: 16 Post(s)
Originally Posted by Bobby244 View Post
I'm looking at the settings of my cable box and I have a choice of 720p, 1080i or native (seems to default to 1080i). Will I noticed a difference on this TV between 720p and 1080i?
depends on your eyesight and distance. That would go for all HD sets . I see a pretty big drop in detail when I change my cable box settings. That's from 6 feet away but I know some people who sit over 12 feet away and it would certainly not be notable from that far no matter how good your eyes. There's plenty of articles detailing the relationship between visual acuity,distance,screen size and resolution.
chupra is offline
post #6496 of 13932 Old 07-10-2014, 02:56 PM
JCBoomer's Avatar
My 60f5500 has started doing this as well, although it's within 30-60 seconds after turning the TV on. Interesting.
JCBoomer is offline
post #6497 of 13932 Old 07-11-2014, 05:31 AM
Bobby244's Avatar
Quoted: 24 Post(s)
I've had the cable box set to native the last few days with most channels coming in at 1080i and a handful in 720p, I'm not noticing much difference.
http://www.cnet.com/how-to/1080i-and...me-resolution/
I was kind of surprised at that article
http://www.cnet.com/how-to/set-top-b...ution-is-best/
This article makes some good points on why to have it on native so I'm going to keep it there.
Overall I'm really happy with this TV. Now that I've got all the settings the way I like them this is the best picture I ever imagined I could get on a 64 inch. Can't wait for nfl and nhl to start in the fall to see what they look like, World Cup games on here have looked incredible
adrock7309 likes this.
Bobby244 is offline
post #6498 of 13932 Old 07-11-2014, 10:36 AM
pdogg93's Avatar
Quoted: 79 Post(s)
Liked: 43
Well I pulled the trigger on the 64" set last night. One of two left in my province! I'm excited, but at the same time I'm a bit nervous for when I pull it out of the box and inspect the screen with a fine tooth comb.
I had a 50" Kuro Elite pro 111fd that had some DSE, and swapped it for a pro 101fd. I'm crossing my fingers that this set doesn't exhibit any obvious screen imperfections.
besides break in slides, do you guys recommend upgrading the firmware right out of the box as part of my initial setup?
thanks
pdogg93 is offline
post #6499 of 13932 Old 07-11-2014, 03:38 PM
box4m's Avatar
Hey ppl,
I had an unfortunate thing happend last night...
My girls f***ing cat scratched the panel of my 64" F8500. Im sure it hurts for you guys reading that so you can imagine my feelings.
I cant notice it even when i know it but there is quite a few scratches that i see good when the set is off.
Can i use some antiscratch thing do you think?
My homeinsurance covers it but i dont feel like thinking about the time it can take for them to replace the panel
Approciate answers, thanks guys.
box4m is offline
post #6500 of 13932 Old 07-11-2014, 03:44 PM
Glenee's Avatar
Quoted: 81 Post(s)
Liked: 76
Hey Buddy,
Don't use the antiscratch on the screen. You will mess the anti glare coating up and the screen will look like a REAL POS. No Chemicals, just distilled or filtered water and a micro fiber cloth.
Sorry My Friend
You need to think about the Home owners insurance policy for a moment. Around here if we have more than 3 claims they drop us.
Ph8te and KONICA TECH like this.
Nothing's Perfect So Stop Expecting It ! Glenee
Glenee is offline
post #6501 of 13932 Old 07-11-2014, 06:26 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2052 Post(s)
Liked: 2216
The panel will not be worth swapping, it will be a buy out situation I am sure. In most area's it is 3 strike's and you are out. Happy to hear you can not see the scratches when it is on.
Cleveland Plasma is online now
post #6502 of 13932 Old 07-12-2014, 03:10 AM
Macroblocker's Avatar
Quoted: 78 Post(s)
Liked: 35
well guys i spent the last few months saving up for the 64F8500 and yesterday i pulled the trigger on it!!! its here and its quite a amazing display, I'm coming from a pn63b5500 (2009) now begins the break in period
Bobby244 and adrock7309 like this.
Macroblocker is offline
post #6503 of 13932 Old 07-12-2014, 06:37 AM
Ahab's Avatar
Originally Posted by music_to_my_ear View Post
Grand Wega? Oh god...viewing angles on rear projection tvs were a nightmare.....never again
Didn't find it to be much of an issue since I normally sat directly in front and middle of screen. Haven't been able to reduce the rainbow effect on the F8500. Have already talked to Best Buy and will be taking it back for a replacement this weekend. Am hoping that will resolve the issue. If not, I'll have to go LED.
Ahab is offline
post #6504 of 13932 Old 07-12-2014, 03:19 PM
Monsterx's Avatar
I'm getting "No Cable Connected" on all of my HDMI ports. I've tested with all ports, multiple cables and devices. I guess my unit is out of warranty as I bought it when it first was released. Setup video looked fine after a factory reset, so hopefully this is a cheap repair, but I've never had a TV serviced before, any idea what could have caused this?
Monsterx is offline
post #6505 of 13932 Old 07-12-2014, 03:36 PM
cooknl's Avatar
Quoted: 23 Post(s)
Liked: 25
^^^^^check out tghe last 5 posts in the 8500 bugs thread might solve youre problem.
http://www.avsforum.com/forum/showth...9#post25685449
rob
cooknl is offline
post #6506 of 13932 Old 07-12-2014, 06:56 PM
jza80's Avatar
New owner - need HDMI recommendation!
Just took delivery of a PN64F8500 and I am really happy with the picture quality. Right now we have it on the stand (I wanted to make sure there was no excessive panel buzzing before wall mounting), and everything seems okay there - If you put your ear right next to the panel there is a very slight buzz but undetectable from a couple of feet away, about the same as my old Pioneer 50" plasma.
Anyway, I have encountered an issue with my HDMI cables. The connections on the 8500 are pretty close to the outer edge and the cables I bought are too stiff and can't make the tight turn and as a result will be visible from the left side once the TV is wall mounted. I am looking at the Monoprice RedMere cables and thinking that these may be a good solution. Any thoughts on these cables? The run would be about 12', so I would be using the 15' cables. Any other options for a flexible cable suitable for the 8500?
Thanks for any input!
jza80 is offline
post #6507 of 13932 Old 07-12-2014, 06:57 PM
wxman's Avatar
Quoted: 3605 Post(s)
Liked: 2605
I have the redmere cables and they work great. Very thin and flexible.
LG 65EF9500
LG 65E6P
wxman is online now
post #6508 of 13932 Old 07-12-2014, 07:24 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^^ If you want to keep your existing hdmi cables, you can buy these adapters from Monoprice. I have them. They work great.
Monoprice HDMI Port Saver - M to Female - 270 degrees.
wxman and KONICA TECH like this.
DanF8500 is offline
post #6509 of 13932 Old 07-13-2014, 08:55 AM
cblandin's Avatar
Quoted: 12 Post(s)
Haven't searched this entire thread yet, but does anyone have a different stand on their F8500 (not wall mounts) as opposed to the stylish, but furniture limiting, factory unit? Any pics?
cblandin is offline
post #6510 of 13932 Old 07-13-2014, 09:47 AM
Ph8te's Avatar
Liked: 3987
As far as I know there are no other "stands" available only the one that comes with the unit. People have used both the stand and wall minted however and been happy. Most decide to wall mount since the stand is wider than usual
Ph8te is online now
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Samsung Pn60f8500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Pn64f8500 64 Inch 3d Smart Plasma Hdtv
