Official Samsung PNxxF8500 Owners Thread (No Street Price Talk) - Page 227 - AVS Forum | Home Theater Discussions And Reviews
 1234Likes
post #6781 of 13973 Old 07-28-2014, 03:55 AM
ParityBit's Avatar
Quoted: 113 Post(s)
Originally Posted by NJPapi1977 View Post
Can anyone confirm if PC Mode reduces input lag more then what Game Mode offers for PS4 and XB1
Also is the pq the same in both?
I would like to know this also please.
ParityBit is offline
post #6782 of 13973 Old 07-28-2014, 05:39 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Originally Posted by stanjohn123 View Post
So I tried the anynet+HDMI-CEC option turned ON but still no sound was output from my tv to the receiver through hdmi.
I also tried searching for devices through that anynet option but it didn't find anything.
Any other idea to output sound from tv to receiv3r through hdmi.
Ok, now that you have anynet+HDMI-CEC turned on, you'll need to look at your receiver's connections/settings with regards to its ARC functionality. I brought up a SR6008 owners manual, and see that the hdmi output labeled, MONITOR, needs to be used, as that provides the ARC capability of the unit. Next, you'll need to enable your receiver's "hdmi Control" setting (pg. 155; default is OFF). Once you do this, you'll need to recycle power to your tv to create a new hdmi handshake, which lets your 8500 know of your receiver's new functionality. Refer to pg.120 of your 6008 owners manual for more info about your receiver's hdmi Control function. There are some footnotes about hdmi zone 2 functionality of your receiver not being compatible when the hdmi Control setting is ON. After doing the above, you should go back to your tv's speaker settings to see if more speaker options (i.e. "receiver") became available.
DanF8500 is offline
post #6783 of 13973 Old 07-28-2014, 07:05 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2247 Post(s)
Liked: 2437
Originally Posted by Ph8te View Post
Of you could go for the costco 99$ 4 year extended. It just about what you want out of it. There are many who have gone with the SquareTrade from Costco and been happy (saving that money doesn't hurt either). The markups on the warranty offered by BB are crazy. Btw yes you can purchase the Costco ST without being a Costco member and purchase the set elsewhere.
Only downside to there warranties, you can not get 5 years of total coverage and they have a max payout of $4000 on the warranty of $1000 and up. If these two cases are concerning, as they can be, Mack Warranty is there for you.
Cleveland Plasma is offline
post #6784 of 13973 Old 07-28-2014, 05:33 PM
max-n-tanner's Avatar
Fan for tv .3 amps?
Hello I was reading about the fan everyone is using for this tv. Isn't it rated .3 amps so it doesn't matter what USB you use?
P/N AF0007
Fan Dimension 120 x 120 x 25mm
Started Voltage ≦4V
Rated Voltage 5V
Rated Current Max. 0.3A
Power Input Max. 3.6W
Fan Speed 800~1500rpm±250rpm
Max. Air Flow 66.55CFM
Max. Air Pressure 1.42mmH2O
Noise 19bB(A) ~33.5dB(A)
Bearing Type Sleeve
Life Expectation 50,000hrs,25℃
Connector USB
Extension Cable Length 167cm
Weight 267g
* Specifications are subject to change without notice.
* The product picture(s) is only for your reference, it may differ from the actual product.
max-n-tanner is offline
post #6785 of 13973 Old 07-29-2014, 10:47 AM
shadowspawn's Avatar
Quoted: 83 Post(s)
Liked: 62
Rated Voltage 5V
I've been a little skittish about that.
Watts = Volts x Amps
So, I would have expected Max Watts to be 1.5W (5 x 0.3).
Or else, Max Amps to be 0.72 (3.6 / 5).
This inconsistency has made me nervous about using the 0.5A USB ports, us plugging two of these into the 1.0A USB port (using a splitter).
shadowspawn is offline
post #6786 of 13973 Old 07-29-2014, 01:46 PM
p5browne's Avatar
Quoted: 2873 Post(s)
Liked: 2193
As mentioned in a previous posting - most Forum Members will not be running the fan full tilt - a tad noisy. Mid point is about right, and your amperage will be less.
p5browne is offline
post #6787 of 13973 Old 07-29-2014, 02:43 PM
Quoted: 83 Post(s)
Liked: 62
^^^^^^^^^^I guess I worry about it not being fail-safe (which is why I used the term "skittish" rather than "totally opposed").I worry about things like relatives coming to visit, and a young nephew seeing the knob and going "What's this do?"... ZZZZZZT
post #6788 of 13973 Old 07-29-2014, 06:30 PM
MrPanther0's Avatar
Liked: 0
Ok guys, new Pn64F8500 owner here. At my wits end. I can NOT get the TV to sit on its base stand flush. the right side (if youre facing it) will sit flush but the other side has like a 3mm gap between the base stand and the bottom bezel of the tv. Any ideas?
MrPanther0 is offline
post #6789 of 13973 Old 07-29-2014, 07:10 PM
MrPanther0's Avatar
Liked: 0
Sorry for the double post. Here are some pictures of what I am talking about
ID:	186754   Click image for larger version
post #6790 of 13973 Old 07-29-2014, 07:16 PM
Stereodude's Avatar
Quoted: 3189 Post(s)
Liked: 2328
I didn't have that issue with mine. The base / stand sort of snapped in place. There were small locating pins in the corners though.
Stereodude is offline
post #6791 of 13973 Old 07-29-2014, 07:16 PM
KONICA TECH's Avatar
Quoted: 29 Post(s)
Liked: 55
You have the inserts backwards, one is for the left side, they have to be correct.
KONICA TECH is offline
post #6792 of 13973 Old 07-29-2014, 07:19 PM
cjpk248's Avatar
Quoted: 42 Post(s)
Liked: 24
As long as the mounting plate and screws are properly aligned and in place I wouldn't worry about it. Mine sits really tight on the right side (sitting in front of the screen) and the left side is a little displaced like yours. It's secured perfectly though so I'm good with it. Granted my left side isn't quite that bad.
cjpk248 is offline
post #6793 of 13973 Old 07-29-2014, 07:21 PM
cjpk248's Avatar
Quoted: 42 Post(s)
Liked: 24
I didn't think they would fit backwards.
cjpk248 is offline
post #6794 of 13973 Old 07-29-2014, 07:22 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^^ Your goal to mount the base stand to your tv should be *uniformity* on both sides. It's perfectly fine if you can't get the tv to sit flush with the stand. I have a few millimeter gap on both sides. It's been fine since I put it together in April of 2013. In fact, I like the visual effect of the tv seemingly "floating" in air off its base. Looks really cool!
DanF8500 is offline
post #6795 of 13973 Old 07-29-2014, 07:22 PM
cjpk248's Avatar
Quoted: 42 Post(s)
Liked: 24
I just used one of these plugged into the surge strip with the TV and called it a day.
http://www.ianker.com/product/71AN7105-W5A
cjpk248 is offline
post #6796 of 13973 Old 07-29-2014, 07:35 PM
MrPanther0's Avatar
Liked: 0
Do you think that is really the case? I can check here in a few minutes
EDIT: Yeah its not that. They wouldn't even fit into the opposite sides. For the life of me I cant figure it out. Only real problem is the screws wont go in to secure it to the base.
post #6797 of 13973 Old 07-30-2014, 06:38 AM
Quoted: 29 Post(s)
Liked: 55
I never said they were in the wrong end, they are facing the wrong way. At least the end that is giving you trouble by no fitting flush is. I was wrong to say left, maybe front side.
post #6798 of 13973 Old 07-30-2014, 08:43 AM
Stereodude's Avatar
Liked: 2328
Have you tried a little careful mechanical persuasion via the Fonz method?
post #6799 of 13973 Old 07-30-2014, 08:52 AM
pitchman's Avatar
Quoted: 22 Post(s)
Liked: 24
Make sure the insert is seated all the way down in the stand. Even if it's not properly seated, you can still screw it down. This is a bit of a design flaw IMO. This is what happened to me. I reseated the insert making sure it was totally flush, screwed it back in, and then the TV perfectly snapped into place on the stand.
KONICA TECH likes this.
pitchman is offline
post #6800 of 13973 Old 08-01-2014, 08:51 AM
jpdyson's Avatar
Quoted: 34 Post(s)
Liked: 51
I gave up.
Picking up my PN51F8500 today, replacing my (still good) PN50B860. Being at work today is like Christmas Eve.
gary777 likes this.
jpdyson is offline
post #6801 of 13973 Old 08-01-2014, 10:56 AM
HLdan's Avatar
Quoted: 497 Post(s)
Liked: 228
Originally Posted by jpdyson View Post
I gave up.
Awesome! But what do you mean when you say "I gave up"?
HLdan is offline
post #6802 of 13973 Old 08-01-2014, 11:19 AM
jpdyson's Avatar
Quoted: 34 Post(s)
Liked: 51
Willpower...
I was going to try and hold out for the Vizio P-series to see if I could make the, um, "transition" to LCD. I got worried I wouldn't have the option of the 8500 for long.
jpdyson is offline
post #6803 of 13973 Old 08-01-2014, 11:54 AM
Liked: 1
I had a similar problem and couldn't get the screws to align. The next day my son and lifted the set slightly, one on each side and it popped perfectly in place and the screws were perfectly aligned. I think the problem was when we original put the set on the stand that it went in on one side first. The stand is solid now.
Good luck
gary777 likes this.
whm01 is offline
post #6804 of 13973 Old 08-01-2014, 12:03 PM
HLdan's Avatar
Quoted: 497 Post(s)
Liked: 228
Willpower...
You did the right thing. Speaking from personal experience after my first flat screen TV being a Samsung LCD which I humbly returned within a week and bought a Panny Plasma and now I have a 64F8500, there's no way I could go back to LCD even if it was a FALD set.
venus933 likes this.
HLdan is offline
post #6805 of 13973 Old 08-01-2014, 06:07 PM
p5browne's Avatar
Liked: 2193
Stock dwindling in Ontario.
PN64F8500AFXZC - just checked FS - Out of stock in Ontario. BB - 9 left in stock. Oops, just dropped to 8!
p5browne is offline
post #6806 of 13973 Old 08-02-2014, 06:21 AM
stanjohn123's Avatar
Quoted: 22 Post(s)
Thanks a ton Dan. It's working fine now.
Lately I'm having lag issues as well with PC mode on and I have never updated my firmware yet.
stanjohn123 is offline
post #6807 of 13973 Old 08-02-2014, 08:24 AM
venus933's Avatar
Quoted: 1438 Post(s)
Liked: 1060
At this the only LCD I would look into would be the Vizio R series with its 384 zones. And that's post F8500 availability.
LG 55EG9100 (Bedroom TV but temporarily being used as my main TV)
OPPO BDP-103 Universal Disc Player - SOLD
Vizio SB4051-C0 Soundbar w/wireless Subwoofer
venus933 is offline
post #6808 of 13973 Old 08-02-2014, 05:28 PM
Mitch2025's Avatar
I recently bought this TV and have been loving it so far. I have one issue though. I have an HTPC and multiple game consoles (PS4, XBOne, etc) all plugged in VIA HDMI into my AV Receiver and output to a single HDMI cable into my TV. My issue is, I want to be able to just quickly turn on game mode (or PC mode. I am reading that PC mode has less lag). On my old Samsung plasma, I just had to go into the menu and enable it but it seems on this one, I have to rename the input to represent whatever mode I want by scrolling through a list. Now, while this isn't terrible, it is VERY annoying.
My initial plan was to hook my HTPC up to the TV and run optical to the receiver for audio and then just setup the input the receiver is going to as a permanent game/pc mode. Well, it works somewhat. It just doesn't transmit all 5.1 channels. It just transmits 2.0 channels. Netflix works fine though. I thought that maybe it was a limitation of optical so I decided to try ARC. I have never used it before but my receiver is compatible so I went through trying to set it up. However, the results are the same as the optical. Netflix gets 5.1 but my HTPC only gets 2.0. I did some more digging and it seems that when I plug my HTPC into the TV directly, it sees that it is only compatible of 2.0 channels so that is all it will output.
Does anyone know of a good solution to this?
Mitch2025 is offline
post #6809 of 13973 Old 08-02-2014, 07:44 PM
MrPanther0's Avatar
Liked: 0
Good luck
So I got the TV horizontal and upon taking the stand off i noticed that one of the TVs own little plastic tabs that slid into the grey metal brackets was flattened and was the reason TV wouldnt sit flat.
So far the set has been pretty nice, though I've been really limited in my content. Only been able to play some Wii u on it and stream HBO go off chromecast or Amazon prime on the TVs smart app list. Noticed a few things:
  • Noticeable input lag (was able to fix at least for mario kart on wii by changing input to be named game input and using warm2 and some offsets. The mode is clearly just a little off but it looks ok at least for gaming, lag is minimized though still there)
  • Pretty bad buzz. Its there for sure to my average hearing and randomly is worse with certain scenes. I can safely say that its worse than my 2010 Panny 54" S2 that its replacing.
  • Pretty good colors with movie and warm1 with a few adjustments. Pretty much everything off with black optimizer on darkest.
I'm waiting on an hdmi splitter to do my own little mini comparison between the old Panny and the new Sammy You would really, really expect the F8500 to just stand head and shoulders above it right?
I really look forward to testing out with some bluray content as soon as I'm moved back into my old apartment with all my gear. I'm considering having the set calibrated by a pro, how many people honestly have that done? Is it really worth the money?
post #6810 of 13973 Old 08-02-2014, 10:32 PM
Ronald Epstein's Avatar
Quoted: 103 Post(s)
Liked: 93
I think anyone who has had a calibration done will tell you it is absolutely worth the money.
I am so incredibly happy with mine. I had Gregg Loewen of LionAV do my display. He's one of the best in the business.
Ph8te likes this.
Ronald Epstein is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Samsung Pn60f8500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Pn64f8500 64 Inch 3d Smart Plasma Hdtv
