Official Samsung PNxxF8500 Owners Thread (No Street Price Talk) - Page 268 - AVS Forum | Home Theater Discussions And Reviews
 1234Likes
post #8011 of 13973 Old 10-11-2014, 10:53 AM
Cozmo85's Avatar
Quoted: 245 Post(s)
Liked: 92
Got my openbox set swapped with a brand new one and it came with the dumb remote! Im so happy.
Cozmo85 is offline
post #8012 of 13973 Old 10-11-2014, 11:28 AM
eelpout's Avatar
Quoted: 13 Post(s)
Originally Posted by Ph8te View Post
These are fairly basic browsers, not sure there is an official way to enable what you are looking for. All depends on the site and what they are using to stream the media to you.
The browser in this thing is atrocious. Tried several times to watch Bravo's "Top Chef Duels Knockout" web series to find the video frame not loading, the page hanging or the browser out-right crashing. Of course it doesn't help that these kind of websites overload their pages with animated ads that can wreak havoc on cheap ARM based devices.
eelpout is offline
post #8013 of 13973 Old 10-11-2014, 11:28 AM
eric3316's Avatar
Quoted: 841 Post(s)
Liked: 959
It is not dumb, it is mentally challenged.
eric3316 is offline
post #8014 of 13973 Old 10-11-2014, 11:40 AM
Cozmo85's Avatar
Quoted: 245 Post(s)
Liked: 92
Doing 10pt calibration is going to be so much easier with a remote with buttons.
Cozmo85 is offline
post #8015 of 13973 Old 10-11-2014, 11:46 AM
eric3316's Avatar
Quoted: 841 Post(s)
Liked: 959
There is software for your computer that allows you to make all the adjustment right from there, never touching any remotes in your TV.
I can't remember what the name of it is but a lot of guys here use it. It's not free but it isn't that expensive either.
You probably even know what I am talking about.
eric3316 is offline
post #8016 of 13973 Old 10-11-2014, 11:47 AM
Ph8te's Avatar
Quoted: 4588 Post(s)
Liked: 4047
If you're talking about CalMan and AutoCal I don't believe that is available for Samsung you'll need to use the remote. AutoCal only works with select TVs.
I'm lost in the blue nowhere.
Ph8te is online now
post #8017 of 13973 Old 10-11-2014, 11:57 AM
eric3316's Avatar
Quoted: 841 Post(s)
Liked: 959
Remembered, it is called ControlCal. It let's you bypass the remote and use your computer to enter in your settings.
I believe autocal with Calman that you are talking about actually calibrates the TV without you doing anything. Controlcal is different then that allowing you to bypass the user menu and control your settings from you PC.
Not sure if it supports Samsung's but it did support 2013 Panasonic's.
eric3316 is offline
post #8018 of 13973 Old 10-11-2014, 12:04 PM
Ph8te's Avatar
Liked: 4047
From the looks of it much like AutoCal there is no Samsung capability. turbe is a member of the forums here, but since it hasn't been done yet I doubt it ever will.
Ph8te is online now
post #8019 of 13973 Old 10-11-2014, 01:07 PM
Jnipz's Avatar
I'm looking to upgrade my Samsung PN63C8000 Plasma to this one due to the PN63C8000 ghosting and pink band issues. How does the picture quality compare between the two? Will I be getting a huge upgrade? Also, I will be mounting this, is the base removable?
Jnipz is offline
post #8020 of 13973 Old 10-11-2014, 02:11 PM
azcatsfan15's Avatar
Quoted: 43 Post(s)
Huge upgrade! And yes the base is removable. Very easy to unmounted it! Good decision.
azcatsfan15 is offline
post #8021 of 13973 Old 10-11-2014, 02:47 PM
ghulands's Avatar
Liked: 0
I mounted my 51" yesterday with a Sanus XF228. It is one solid mount. Took me about an hour to install it - including clean up time! There are a couple of caps that go on the tv where the stand mounts to the tv frame.
ghulands is offline
post #8022 of 13973 Old 10-11-2014, 04:07 PM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
user/owner update.........purchased April of last year, and zero issues other than updating fw. I also can confirm w/out meters that my BL's are still great if not better than the day I got it. I have about 4000hrs on her. I'm sick to my stomach that one day she'll be toast and I'll have to find some other tech that I won't be happy with. maybe I should stock up on another before they vanish forever.
Dianabol5mg and KONICA TECH like this.
Habit Forming....Wallet Burning Hobby....55" Oled Lg B6p 55" Samsung B8500 Fald Channel Master Dvr+ Onkyo RZ900 avr Samsung K8500 UBR player Svs Ultra Towers/Center, Svs Satellite Surrounds Svs Pb-13 Ultra Sub
airgas1998 is offline
post #8023 of 13973 Old 10-11-2014, 04:54 PM
Cozmo85's Avatar
Quoted: 245 Post(s)
Liked: 92
Anyone have problems with the tv reverting to speakers instead of receiver for sound output? Seems to happen after the tv is powered off and back on.
edit: ARC still seems to work, just turned built in speakers to zero. Weird it resets though.
Cozmo85 is offline
post #8024 of 13973 Old 10-11-2014, 05:15 PM
Sparhawk73's Avatar
PN64F8500 PC Driver
Sorry if this has been asked and answered but I couldn't find it.
I have hooked a home theater PC to my receiver and then to my Plasma via HDMI. Of course it only sees a generic pnp monitor. Are there any PC drivers for this set? Do I need them? The video card in this box seems to max out at 1920x1080. 1080p.
Sparhawk73 is offline
post #8025 of 13973 Old 10-11-2014, 07:05 PM
ozzfan84's Avatar
Quoted: 110 Post(s)
Where do you get the slides people are talking about to break in the tv? Keep in mind that I have no idea what any of this means so you'll have to treat me like an idiot! Thanks in advance.
ozzfan84 is offline
post #8026 of 13973 Old 10-11-2014, 07:25 PM
Ph8te's Avatar
Liked: 4047
You don't really need slides. Just watch varied content while avoiding static images for long periods of time. Unless you plan on watching nothing but slides for ten1st few hundred hours the varied content is the next best thing. The slide method stems from 1 calibrators method to quickly aging the plasmas phosphors to better prep for professional calibration. If you are not calibrating then there is no real point. There are millions of people who just watch tv and are OK b
Ph8te is online now
post #8027 of 13973 Old 10-11-2014, 08:34 PM
fierce_gt's Avatar
Quoted: 1644 Post(s)
Liked: 1585
shouldn't be needed, 1080p/60 is the best you'll get to the f8500 anyway
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #8028 of 13973 Old 10-11-2014, 11:47 PM
Quoted: 16 Post(s)
Liked: 0
So got the 60 inch delivered today (along with the Oppo). Picture looks fantastic, don't hear any buzz or anything that is noticeable at least. So thats good. No bands that I can see yet.
The only problem is (and its probably not a TV problem) that I don't get any sound through the receiver. I did connect HDMI1 of the Oppo to the TV and 2 to the receiver. Will post in the Oppo thread to see what response I get.
Samsung PN60F8500, Oppo BD-103, Pioneer Elite VSX-33, B&W 685B, B&W 686B, B&W HTM62, B&W ASW610
craygoose is offline
post #8029 of 13973 Old 10-12-2014, 02:27 AM
ozzfan84's Avatar
Quoted: 110 Post(s)
Great info here. Thank you very much for your explanation!
ozzfan84 is offline
post #8030 of 13973 Old 10-12-2014, 07:01 AM
Cozmo85's Avatar
Quoted: 245 Post(s)
Liked: 92
HDMI 3 is arc
Cozmo85 is offline
post #8031 of 13973 Old 10-12-2014, 07:51 AM
9179mhb's Avatar
Quoted: 148 Post(s)
Liked: 100
Can you tell me where in the owner's manual are the instruction for running the break in slides for a new PDP?
9179mhb is offline
post #8032 of 13973 Old 10-12-2014, 07:52 AM
Liked: 2
Hi,
We are thinking of buying the 64" f8500 but the only concern I have now is the audio out. I will try to explain my setup as easily as I can.
I have a 2 channel high end audio with a tube pre amp to do my audio switching, all analog inputs. On my existing Sony I plug my Blu Ray and DVR HDMI into my TV and do my video switching and use the analog out to my pre amp for audio.
I know the 8500 does not have an analog out and I am concerned about using a outboard DAC and audio lip sync issues, I know you can adjust it but I have an LG in the bedroom hooked up optically to a sound bar and I can never get it looking right.
Is anybody using the optical out to a D2A convertor and how is the audio sync?
Wyatt Earpe is offline
post #8033 of 13973 Old 10-12-2014, 07:56 AM
Ph8te's Avatar
Liked: 4047
There are none.
Ph8te is online now
post #8034 of 13973 Old 10-12-2014, 08:04 AM
Cozmo85's Avatar
Quoted: 245 Post(s)
Liked: 92
Are there any android apps that work on these tv's that dont require a samsung phone/tablet.
Cozmo85 is offline
post #8035 of 13973 Old 10-12-2014, 09:43 AM
mjnoles1's Avatar
Quoted: 22 Post(s)
Anyone close to Northern, VA area to check out a Samsung PN51F8500 tv for me?
I can buy one for $799. Can anyone check it out for me?
mjnoles1 is offline
post #8036 of 13973 Old 10-12-2014, 09:54 AM
WantsNWarrants's Avatar
Quoted: 84 Post(s)
Liked: 50
The slides are here:
http://www.eaprogramming.com/downloa...kIn_Images.zip
WantsNWarrants is offline
post #8037 of 13973 Old 10-12-2014, 10:11 AM
Quoted: 12 Post(s)
Liked: 3
YES! Best Buy just matched Abe's of Maine price on the 64" for me. They have it for $1959!!!! I take delivery Friday. I'm upgrading from my PN50C550 and had to get another before they stop making them!
DJPrelude likes this.
wfarrell4 is offline
post #8038 of 13973 Old 10-12-2014, 10:51 AM
EdL
EdL's Avatar
Thumbs up Simply Amazing!
I've been in Mitsubishi RPTV and DLP since the dawn of HDTV. Received my 64" F8500 yesterday and it feels like HD is new again!
Out the box in movie mode is amazing, whites are white and the black detail (wrinkles, creases, in clothes) is off the chain.
EdL
EdL is offline
post #8039 of 13973 Old 10-12-2014, 11:03 AM
MikeD2's Avatar
Quoted: 17 Post(s)
Wiring Devices Help !!
Looking for input on connecting my A/V components to the pn64f I ordered. My DVD was hopelessly out of date, so I have a new Sony S5200 coming as well.
Other gear is an old JVC VCR (still have a huge collection of tapes that get watched on occasion), TW HD DVR box (Scientific America 8300HD) & a JVC D412 AVR.
The goal is to maximize the features of the TV and allow for audio from both the TV and AVR for all 3 sources. Can't afford a new AVR for the near future, so I need to work around the D412 even tho I know it will not process anything beyond your basic 5.1 SS signal. It has 2 HDMI inputs (v1.1) and an HDMI output, but is not 3D or ARC compliant. It also has 2 optical & 1 coax digital input, 1 optical output (labeled PCM/Stream) + a ton of (useless these days) RCA component input/outputs).
Assuming the digital optical audio output on the TV switches when you switch the "source" you want to view (please says this is true, can't find anything in the manual that says how it works - LOL), and there is no disadvantage to passing the audio signal thru the TV, my thoughts were:
VCR to TV - old school 3 RCA jack component cable
DVR to TV - HDMI cable
S5200 to TV - HDMI cable
TV to AVR - digital optical cable
optionally (if there is an advantage to adding more cables):
DVR to AVR - run an optical cable or digital coax for audio
S5200 to AVR - run an optical cable for audio
Since there are only 2 optical inputs, I have to decide which 2 devices would be connected directly via optical. The TV seems mandatory and direct connecting the S5200 would allow me to play CD's without turning on the TV.
Comments, thoughts, suggestions ??
MikeD2 is offline
post #8040 of 13973 Old 10-12-2014, 11:42 AM
Dianabol5mg's Avatar
Quoted: 322 Post(s)
Liked: 248
Originally Posted by PathofNeo View Post
Forgive me if this has been brought up 1000 times.. but I'm seriously on the fence with a 51F8500. I currently have a D-Nice calibrated Pioneer 5020FD (tweaked for better blacks) and am thinking about picking up one of these to have as a backup for myself while the price is still good. I know it probably won't impress me as much as my Kuro but I'm really not interested in LCDs and from what I hear.. these and the last Panasonics are the best.
My concern however is this floating black issue. I had a Samsung C8000 plasma when it came out and to this day I still think that plasma had more natural sharpness and the smoothest (not frame interpolated) motion I'd ever seen on a plasma. However, the blacks would rise and drop constantly watching blu-rays and I just couldn't handle it. I believe we called it 'brightness pop' back then. I'd like to know if floating blacks are the same or different than brightness pops like I saw on my C8000. The single most irritating thing for me is the anamorphic bars not being consistent. For some reason my eyes are drawn to the black area in the bars during films (not all the time) and I notice these things and I'm hoping the F8500 doesn't have this problem. I'm reading now that after the update supposedly the floating blacks are fixed but the black level is raised? Okay I suppose I can handle this too as long as it doesn't 'pop'.
I really want to like this set but would like a current answer to this question before I spend the money. Thanks!!!
Buy from a place where there is free return shipping. As far as most of us actual owners are concerned, floating black is impossible to see unless you are running test patterns. Ive looking for them since day one and ive never seen them. My black bars never change. If there are floating blacks, which calibrators say is there, they are subtle and mostly unnoticeable. Brightness pops were fixed with update. Hockey looks great. The more hours put on the television, the better it looks, imo.
Dianabol5mg is online now
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Samsung Pn60f8500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Pn64f8500 64 Inch 3d Smart Plasma Hdtv
