Official Samsung PNxxF8500 Owners Thread (No Street Price Talk) - Page 295 - AVS Forum | Home Theater Discussions And Reviews
 1234Likes
post #8821 of 13973 Old 11-17-2014, 03:30 AM
patrick415's Avatar
Originally Posted by sdsvtdriver View Post
Local. Got BB to drop by 10% (matched mover's coupon). They delivered and set it up. It buzzed too much so they brought me another, set it up, and took away the old one. I'm sure if I needed them to, they'd find me another one if I had an issue (if it died this month, for instance). Online vendors not so much. Since it is the end of the line with these units, I wouldn't waste time with online and I'd have that TV delivered NOW in the event it is defective. In December you're stuck with it or you get your money back. No replacement option.
Good points. I may get BB to move the delivery up to the Monday after Thanksgiving (two weeks) since we''ll be gone before then. That should give me enough time to swap it out if necessary. I hate doing "early" Christmas gifts for the family – especially when they're really for me! – but...
How did you get BB to honor the Movers coupon. I thought it specifically excluded Samsung TVs?
patrick415 is offline
post #8822 of 13973 Old 11-17-2014, 08:10 AM
brambler's Avatar
Hi All,
I just received my brand new 51. Super happy with it and no problems except minimal buzzing from the back. I am having a problem with the standard remote though which I'm hoping someone might be able to help me out with. The smart remote controls my cable box no problem but the standard remote doesn't. Does it need to be paired? If so, how? Or do I need to set up the IR extender device? It just seems strange that one of the supplied remotes works and the other doesn't. I would simply get used to using the smart remote but it doesn't see to have power on off for the cable box (Time Warner) or be able to access the cable boxes DVR. Phew. I'm sorry if this is a total newb question. I spent an hour searching the forum with no luck.
brambler is offline
post #8823 of 13973 Old 11-17-2014, 08:21 AM
Breathing Borla's Avatar
Quoted: 119 Post(s)
Liked: 30
Is there a way to adjust the picture size while streaming movies from Amazon ? I start a hd movie and the black bars are on the top and bottom. I try to select picture size from the tv menu but it won't let you do anything.
I just want to zoom out of the black bars while this thing is breaking in
Or does watching a 3 hour movie with black bars not matter for ir burn in?
Breathing Borla is offline
post #8824 of 13973 Old 11-17-2014, 08:43 AM
MikeD2's Avatar
Quoted: 17 Post(s)
Anyone know if the US version of these TV's use a Power Factor Correction power supply ?? I believe they do in EU (due to energy regs over there), but not sure they do that here. Need to upgrade my UPS (this bad boy pulls 650W @ start-up !!!!) & was wondering if I can use just a standard one (simulated sine wave) or if I need to pop for a (much more expensive) pure sine wave unit.
MikeD2 is offline
post #8825 of 13973 Old 11-17-2014, 09:04 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^ I'm pretty sure over 99% of the F8500 owners don't have a UPS connected to their tv's. Why do you feel the need to have your tv on a UPS? I think a surge suppressor is recommended, but a UPS is overkill. A UPS is great for maintaining the integrity of critical/static data/memory on a computer/server, so it has its function in the electronics market. I just can't see the need for it on a tv.
DanF8500 is offline
post #8826 of 13973 Old 11-17-2014, 09:51 AM
p5browne's Avatar
Quoted: 2871 Post(s)
Liked: 2193
It's called insurance against possible On/Off scenarios that pops any weak capacitors when the unit is hot.
If you blew a couple thousand on buying a premium TV, then $79 for an APC 750VA UPS is a piddling amount to insure that there will be no down time, or blown TV!
UPSs on every one of my systems in my household!
I think that more than 1% of Members have some kind of protection:
Is Your Home Theater's AC Power Optimized?
p5browne is offline
post #8827 of 13973 Old 11-17-2014, 10:08 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Yes, I'd say over 95% of electronics owners have "some" kind of protection, but I still say under 1% own a battery backed up uninterruptible power supply for a tv.
DanF8500 is offline
post #8828 of 13973 Old 11-17-2014, 10:09 AM
paligap's Avatar
Quoted: 125 Post(s)
Liked: 43
Does anyone else have to turn off the 3D -> 2D option every time they play a 3D blu-ray? I don't understand why having that feature "on" would be the default.
paligap is online now
post #8829 of 13973 Old 11-17-2014, 11:32 AM
datbeme's Avatar
The F8500s seem to be completely gone from Amazon and Best Buy. Still appears on the BB site, but I couldn't get an order to complete yesterday. Not in stock at any of the BB stores and not available to ship. Is this finally it?
I did find it at B&H, and my order for a 51" (to complement the 64" I got in the spring) seems to have gone through. We will see.
datbeme is offline
post #8830 of 13973 Old 11-17-2014, 11:39 AM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
Try Value Electronics. They had some yesterday.
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #8831 of 13973 Old 11-17-2014, 11:58 AM
sdsvtdriver's Avatar
Quoted: 12 Post(s)
I simply asked if they'd take 10% off if I came and bought it. Mover's coupon won't scan but they manually over rode.
sdsvtdriver is offline
post #8832 of 13973 Old 11-17-2014, 01:17 PM
ccll0's Avatar
couple questions, if anyone might happen to know. does this tv have native, built in bluetooth connection, that would allow bluetooth headphones etc? Or if not, does this tv have dolby digital via tos, and/or an option in the tv menu to switch to PCM instead? If it does not have native bluetooth connection, then I would be forced to buy one of these Bluetooth transmitter with optical input? but last I checked they only support PCM, not DD.
Additionally, how is the gaming on this tv? I remember reading a couple years back that samsung lagged behind panasonic plasmas in gaming lag. Is this still true?
I am considering buying one of these but have been a panasonic fan. My current model is a Panasonic GT25
ccll0 is offline
post #8833 of 13973 Old 11-17-2014, 04:59 PM
Amped's Avatar
Originally Posted by Airmax View Post
Looks like Best Buy removed all 3 sizes of the F8500 on their website today. I'm glad I purchased mine last week. Can't wait for it to be delivered.
I purchased the 51F8500 online at BB on November 4 with a confirmed delivery of November 19. Received voicemails from corporate and a local BB store today telling me too bad, TV still not in stock and is "backordered". No ETA! Meanwhile, I notice the price has dropped again.
Amped is offline
post #8834 of 13973 Old 11-17-2014, 05:56 PM
walsey's Avatar
Hey amped, did they tell you they would get more in at some point. I was gonna get a 60 but of course they were out. If they were to get more in fairly soon I'd wait for one
walsey is offline
post #8835 of 13973 Old 11-17-2014, 06:03 PM
murphyb74's Avatar
I ordered the 51F8500 from Amazon on the 13th - should be here tomorrow. I saw the price drop today and Amazon is refunding the difference.
murphyb74 is offline
post #8836 of 13973 Old 11-17-2014, 06:08 PM
Amped's Avatar
Corporate told me to talk to the local store, but the local store seemed clueless. I'll have some time to raise hell tomorrow. This is the only TV I'm considering since I gave up on finding an affordable and low mileage Panny ST60 or VT60.
Amped is offline
post #8837 of 13973 Old 11-17-2014, 06:12 PM
walsey's Avatar
Hope everything works out for you! I've got the 51 inch and love it. Wanted to go bigger and get the 60 inch version but I was a little too late I guess.
walsey is offline
post #8838 of 13973 Old 11-17-2014, 06:16 PM
ppilot's Avatar
Quoted: 78 Post(s)
Liked: 41
There are still some new 51 inch models left in my area, but it looks like the 60's are completely out. The only option if I want the 60 is a floor model. Would purchasing a used plasma like this be a bad idea? What would be the things to look out for if I was going to do this?
ppilot is online now
post #8839 of 13973 Old 11-17-2014, 06:33 PM
p5browne's Avatar
Liked: 2193
NO F8500s listed for Black Friday
http://www.samsung.com/us/shop/black...COMMENDED/1/15
(Kudos to Konica Tech for the URL)
Will be interesting if any Members get a Made in December 2014 on their sets?
p5browne is offline
post #8840 of 13973 Old 11-17-2014, 07:20 PM
Airmax's Avatar
Originally Posted by LOWPRO24Z View Post
What size did you get? I got my 60' last week and this tv is an absolute BEAST, glad I was able to get one before they become extinct!
Pretty sure it's the end of the line especially since BB pulled the TV off their site. I think some retailers are getting their last allotments this week so if anybody wants one they should do it NOW.
I purchased the 60" but it won't be delivered until November 29.
That's weird, it no longer appears if you search TV's > Plasma but it does appear if you search "F8500".
That really sucks man. I haven't been contacted yet but now I'm worried about my order. Best Buy needs to figure this out because I'm not considering any other set right now since this is the last flagship plasma.
Airmax is offline
post #8841 of 13973 Old 11-17-2014, 07:22 PM
Airmax's Avatar
I just realized you purchased the 51" so hopefully I have better luck with the 60" but best of luck to you.
Airmax is offline
post #8842 of 13973 Old 11-17-2014, 07:39 PM
DRN94's Avatar
Quoted: 69 Post(s)
Liked: 99
I foolishly waited too late to buy the 51" and had to get it new through Beach Camera on Amazon. Beach Camera is a very reputable Samsung authorized seller but they do not have a price guarantee so I was stuck paying the old $1,200 price. I don't think the $200 is worth worrying over considering how hard these sets are to come by the last few days. I have the F8000 (superb LED set) and having never owned a plasma or seen one in ideal dark room conditions, the hype is quite high for me. I'm sure the F8500 will not disappoint!
DRN94 is offline
post #8843 of 13973 Old 11-17-2014, 08:06 PM
AMartin56's Avatar
Quoted: 1340 Post(s)
Liked: 652
Don't feel too bad. I wasn't willing to wait it out and paid $1300 for my 51 about 5-6 weeks ago.
AMartin56 is offline
post #8844 of 13973 Old 11-17-2014, 08:15 PM
Quoted: 12 Post(s)
Kinda OT. Does anyone know where I can order two of the black plastic clips that go in the box to hold the top on? I plan to move and am keeping the box but the delivery guys must have taken two of them as trash.
post #8845 of 13973 Old 11-18-2014, 03:17 AM
RobDMB's Avatar
Quoted: 91 Post(s)
Can anyone compare how glossy (i.e. glare) the screen of the F8500 is to the LG 55EA9800 OLED tv? I recently purchased the OLED but the glare is just too much in room. Not only does it reflect sunlight but it reflects a lamp in my room such that it will necessitate a return.
Also, is it an absolute no-no to transport this tv laying flat in the back of an SUV?
RobDMB is offline
post #8846 of 13973 Old 11-18-2014, 08:09 AM
stuart9682's Avatar
Liked: 1
Ordered my 51" from Value Electronics yesterday. Supposed to ship later this week.
Robert was very helpful.
What are your guys' opinion on the Evolution Kit for this set? Is the motion remote and faster processor worth the money? We do a lot of Netflix and HULU watching, some OTA and rarely watch a downloaded movie or program from a connected Mac Mini. Will the added features of the evo kit enhance my experience based on those watching habits?
dsskid likes this.
stuart9682 is offline
post #8847 of 13973 Old 11-18-2014, 09:36 AM
cblandin's Avatar
Quoted: 12 Post(s)
The F8500 is better for sure, but nothing is like an old matte screen display. Check out my post here: Forget 4K-All I want is 1080P with no glare
cblandin is offline
post #8848 of 13973 Old 11-18-2014, 10:08 AM
nbaj2k's Avatar
I received a defective 60F8500 from Best Buy, a replacement was ordered and scheduled to be delivered on Saturday. Just called and found out that it's 'backordered' and they aren't getting anymore in. Anyone else able to find one for order somewhere?
nbaj2k is offline
post #8849 of 13973 Old 11-18-2014, 11:17 AM
MikeD2's Avatar
Quoted: 17 Post(s)
We have VERY dirty power here, tons of brownouts, spikes & rapid on/off events that hit without warning. The AVR afforded by a UPS smooths out the dirty power issues & keep the set stable during the on/off events. I use surge suppressors for the cheaper bits, but for the expensive gear I use the UPS's.
Exactly, it's relatively inexpensive insurance if you have crappy power ! Can't use a 750VA for these TV's tho. I was using my 800VA (450W) from my old JVC IDLA for the F8500, but these bad boys pull 650W on start-up & it ate the battery in 3 weeks. Just ordered a 1325AV (810W) unit for the TV, still cheap ins. @ $120.
MikeD2 is offline
post #8850 of 13973 Old 11-18-2014, 11:22 AM
MikeD2's Avatar
Quoted: 17 Post(s)
MikeD2 is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Samsung Pn60f8500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Pn64f8500 64 Inch 3d Smart Plasma Hdtv
