Official Samsung PNxxF8500 Owners Thread (No Street Price Talk) - Page 332 - AVS Forum
post #9931 of 9957 Old 12-24-2014, 12:24 PM
venus933's Avatar
Quoted: 288 Post(s)
Liked: 214
My PN51F8500 was delivered Monday (a day early) and has a November 2014 Build date.
I have the A version and full whites have a slight pink push which I don't remember from my earlier PN51F8500 which was a B version. Other than that every thing seems A-OK, just the normal buzz hum which is only heard when head is tilted and it's quite unobtrusive. Overall PQ is spectacular and I'm amazed with how good SD looks on it.
Samsung PN60E7000
OPPO BDP-103 Universal Disc Player
MartinLogan Motion Vision Gloss Black 5-Channel Soundbar
MartinLogan Dynamo 700 10-inch Wireless Ready Subwoofer
venus933 is offline
post #9932 of 9957 Old 12-24-2014, 12:25 PM
hairy48's Avatar
Originally Posted by asere View Post
What is the bias light setting on the 8500?
It's not a setting on the 8500. A bias light illuminates the surrounding wall(s), slightly constricting your pupils to less than wide open in a dark room. It is positioned behind the set usually between it and the wall.
hairy48 is offline
post #9933 of 9957 Old 12-24-2014, 12:56 PM
sr
sr's Avatar
Quoted: 48 Post(s)
After reading about bias lighting, I installed it on my TV and love it. No more reflections from light sources in front of the panel and it shows off the TV! I even have a dimmer on the light so when its daylight I turn it down and at night I bring it up to a comfortable level.
sr is offline
post #9934 of 9957 Old 12-24-2014, 02:03 PM
twitchyzero's Avatar
Quoted: 27 Post(s)
Can someone confirm which port the PC renaming trick actually works? Is it strictly HDMI 2 DVI? Is it true it resets its effect when you restart the TV?
Also, is it normal for mkv files on the Smart TV to take a full minute? We're talking a full minute or two for x264/DD5.1 1080p ~15Mbps blu-ray rips...yet 720p mkvs loads instantly
twitchyzero is offline
post #9935 of 9957 Old 12-24-2014, 03:51 PM
fierce_gt's Avatar
Quoted: 1028 Post(s)
Liked: 1074
it works on all of them, and it does not reset
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1018AH, 5.1 audio
Sources: HTPC(Mediabrowser), PS3, XBOX360, Wii, Sony DVP-CX995V
Control: Harmony One
fierce_gt is online now
post #9936 of 9957 Old 12-24-2014, 04:32 PM
tomnan24's Avatar
Quoted: 52 Post(s)
I received my 51" yesterday. Almost everything has gone really smoothly so far, except:
This is my first smart tv. Whenever I have hooked up netflix to my tv before it has always been connecting my computer via hdmi. I had no trouble connecting to network wirelessly and internet during setup of my F8500. Since then, though, the tv keeps telling me I'm either not connected to the network or not connected to the internet. When I do get connected and watch Netflix it doesn't stay connected for long.
I have a 20 mbps connection about 30 ft from my tv. My computer and smartphone work from much farther than that. In fact, I can watch netflix from my smartphone at the same time that the tv says I'm no longer connected.
Is this unusual with smart tv's? Is there anything I can do?
tomnan24 is offline
post #9937 of 9957 Old 12-24-2014, 04:45 PM
tomnan24's Avatar
Quoted: 52 Post(s)
Originally Posted by tylerSC View Post
I was wondering what panel is used on the 51F8500, particularly the recent builds. I have a 51E7000 that has a TS02 panel and outstanding picture. Just wondering about the F8500.
My 51" is a uw01. I've heard of one other that was a uw01 and one that was a ts01.
I tried to read up on them but little is said about the panel lottery outside of LCD.
tomnan24 is offline
post #9938 of 9957 Old 12-24-2014, 05:22 PM
fierce_gt's Avatar
Liked: 1074
that's because it's not a 'lottery' like it is with lcd's. there's only one place that makes them, and they don't make different ones at the same time. so IF they change, it's a change with all of them made after that date.
it does appear as though something was tweaked to improve black levels in the 2014 f8500's, this is likely that different panel. but it's still not a 'lottery' in the same sense as with lcd's, because there's only one plant making them. if we found out the date they switched, the build date would tell you enough.
anyway, to help shed some light, cause i don't think this has been investigate too much, here's the stick from the back of mine:
INSIDE
OUTSIDE
post #9939 of 9957 Old 12-24-2014, 05:37 PM
asere's Avatar
Quoted: 148 Post(s)
Liked: 26
Mine says 11/14 for manufacturer date.
asere is online now
post #9940 of 9957 Old 12-24-2014, 06:50 PM
TheeeGod's Avatar
hey guys - officially checking into the F8500 owners thread! Got a 64" bad-boy a few days back, dialed in settings as per Fierce_gt and so far loving it.
This thing can do a lot of tricks, but I am not sure how useful they are on a daily basis. Anything you guys recommend as a must-use on this TV? I have the original remote that came with it and then another silver remote/game pad thingy that I have not yet touched.
I have Comcast and am debating if I should hook up the comcast remote to the TV or do vice versa with the IR thing that comes with TV. How do you have urs setup?
TheeeGod is offline
post #9941 of 9957 Old 12-24-2014, 09:14 PM
Tiki Steve's Avatar
Quoted: 12 Post(s)
Okay, this is stupid, so to save you time, stop reading.
So the other day I was looking at the screen on an angle, and saw a stuck pixle.
Was pretty bumbed out.
It was in the lower left of the screen, but no mater how hard I tried not to, I would spot it.
Then I noticed it was pretty large to be just a stuck pixle, it was a fricken group of stuck pixles!!!
Read a previous poster who said that touching the screen made it temporarily go away.
So what have I got to loose, so I touched it....
Turns it wasn't a stuck pixle or a group of pixles......
It was some sorta goo from my dog!!!
Cleaned right off, what a relief!!!
So now the dog isn't alowed to eat in the TV room.
I did warn you it was stupid!!!
Blue Rain and falconcry like this.
Tiki Steve is offline
post #9942 of 9957 Old 12-24-2014, 09:28 PM
wxman's Avatar
Quoted: 175 Post(s)
Liked: 258
LOL! Dogs can sneeze boogers too. So it might not have been food! Merry Christmas!
Tiki Steve likes this.
wxman is online now
post #9943 of 9957 Old 12-24-2014, 09:56 PM
sr
sr's Avatar
Quoted: 48 Post(s)
Poor Fido gets no respect
sr is offline
post #9944 of 9957 Old 12-24-2014, 11:47 PM
Liked: 1
I just ran the MENU --> SYSTEM --> SETUP with the IR blaster and an AT&T box. This also will set up your audio, and maybe more; if I remember correctly.
I have turned off motion and voice controls, as they were randomly popping up. (MENU --> SMART FEATURES) I don`t use Smart Apps, except for Netflix.
I don`t have the regular remote, as I have an older TV, but after 9 months of trying, I should receive one in January.
If you are a gamer, rename your inputs to either PC (least lag) or Game (slightly more lag, but better picture options and quality) by pressing the SOURCE button on the remote, highlight the HDMI port (don`t press OK), but press the up arrow. This should select TOOLS on the top right of the screen. Click OK, EDIT NAME, and choose PC or GAME from the list. You will have to reset the Picture settings, as only Standard and Entertain modes are available using the PC HDMI setting, so keep your settings handy.
MERRY CHRISTMAS ALL!
mome_rath is offline
post #9945 of 9957 Old Yesterday, 05:06 AM
tomnan24's Avatar
Quoted: 52 Post(s)
Bump. Is no one having difficulty with their wifi? I had another Samsung smart tv that I had no trouble with. Could my tv wifi antenna be bad? Anyone with any ideas?
tomnan24 is offline
post #9946 of 9957 Old Yesterday, 05:21 AM
tt300zx's Avatar
Liked: 0
So my 60" has a stuck sub pixel in the top right corner? This is the second one I received like this. The other was sent back. I guess this is something I will have to deal with? My 51" is perfect. Thoughts?
tt300zx is offline
post #9947 of 9957 Old Yesterday, 09:37 AM
Chili99's Avatar
Did the app list change? Looking for Crunchyroll.
Chili99 is offline
post #9948 of 9957 Old Yesterday, 09:43 AM
Chili99's Avatar
Never mind. It's hidden under Samsung Apps. I have been hitting the Netflix button so long that I've forgotten how to get around the list of apps.
Chili99 is offline
post #9949 of 9957 Old Yesterday, 11:44 AM
Blue Rain's Avatar
Quoted: 107 Post(s)
Liked: 32
Reason for Editing
Polk 7.1
Samsung PN60F8500
73" 73738 Mits DLP
Onkyo TX-NR3008
Panasonic AE4000 Projector
Blue Rain is offline
post #9950 of 9957 Old Yesterday, 12:19 PM
sr
sr's Avatar
Quoted: 48 Post(s)
If its not noticeable, I would live with it as a replacement TV may not be had this late in the game. I understand that a green stuck pixel is the most noticeable. I have a blue stuck pixel 1/3 the distance from the edge of the screen and do not see it at a 10 foot viewing distance from my 64" on a full white screen. If it's any consolation, you will not notice the pixel on a black screen or when the color of the stuck pixel actually matches or comes close to the color in the scene.
sr is offline
post #9951 of 9957 Old Yesterday, 06:47 PM
tt300zx's Avatar
Liked: 0
I will just live with it I suppose. It's about 3 inches down and 3 inches from the right towards the upper right hand corner. I have ran pixel flippers and color washes to no avail. I did not expect it to do much anyways...aside from a miracle. At least I can say I tried. I called Amazon and they knocked 15% off what I paid which makes it a little more tolerable!
tt300zx is offline
post #9952 of 9957 Old Yesterday, 09:56 PM
avfanatic1's Avatar
Quoted: 42 Post(s)
Liked: 25
I also have a stuck pixel with mine. Out of curiosity what did you say to Amazon when you called? 15% off would definitely help.
avfanatic1 is offline
post #9953 of 9957 Old Yesterday, 11:23 PM
IslandStyle's Avatar
fierce_gt & sr,
thanks for the replies/advice last month re: break-in, etc. I've got over 200 hrs after a marathon of continuous slideshow. My wife is sick of hearing me gush about the picture…..yet family and friends are enjoying GOTG at the moment. (I'm extremely late to the game on flat screens -- scary, I know. I waited too long and missed on Kuro, but glad I got my F8500.).
all,
Anyone have experience with BB certified calibration service? The price is nice ($250), but I'm leery. My challenge: I don't have a lot of options here in Vegas which is surprising.
While I'm figuring out the pro-calibration, any suggestions of settings in the interim? Apologies for the following two noob issues: I could use some advice on limiting soap-opera effect. Any way to configure/eliminate letterbox?
Thanks in advance!
Display: Samsung PN64F8500
Audio: Marantz SR6003 7.1, Klipsch Center/Front, OSD Kevlar ICE side/rears, Epik Phoenix 18" Ported Sub
Sources: Oppo 103D; Dune Smart D1, Xbox 360, Wii
IslandStyle is offline
post #9954 of 9957 Old Today, 12:10 AM
fierce_gt's Avatar
Liked: 1074
Originally Posted by IslandStyle View Post
fierce_gt & sr,
all,
Thanks in advance!
I'm skeptical of the BB calibration. the way I see it, you might get a decent calibrator that just happens to have a passion for it, but it's not assured. BB isn't training or certifying them to a high standard, so it could be good, it might not be. I opted to buy the meter for 200bux and do it myself.
if you wish, try some of the calibrations posted here, it might work out, no harm in trying anyway.
for SOE, turn off motion judder canceller
I don't believe you can zoom in to remove the letterbox bars if you're using HDMI. you'd have to figure out a way of zooming on your source instead.
post #9955 of 9957 Old Today, 08:03 AM
wmuller's Avatar
I got a 51 inch f8500 from amazon last week. Great picture.
An air bubble appeared at the edge of the screen about the size of half a quarter. I am able to squeeze it to the side of the screen and the tv looks great again. After TV watching, the next day bubble re- appears.
As it is it is easily tolerable and does not affect viewing.
Amazon does not have replacement. Gave 20% off.
I am concerned it will only grow over time and mar a great viewing experience. No buzz and no dead pixels.
Any history of this happening?
Will the bubble grow?
wmuller is offline
post #9956 of 9957 Old Today, 08:41 AM
HLdan's Avatar
Quoted: 252 Post(s)
Liked: 126
You have a warranty. Contact Samsung ASAP to have a tech come out and look at it.
HLdan is online now
post #9957 of 9957 Unread Today, 12:07 PM
wxman's Avatar
Quoted: 175 Post(s)
Liked: 258
Are the screws on the back of the tv all tight?
wxman is online now
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Samsung Pn60f8500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Pn64f8500 64 Inch 3d Smart Plasma Hdtv
