Official Samsung PNxxF8500 Owners Thread (No Street Price Talk) - Page 337 - AVS Forum | Home Theater Discussions And Reviews
 1254Likes
post #10081 of 14062 Old 12-31-2014, 11:20 AM
sr
sr's Avatar
Quoted: 85 Post(s)
Liked: 36
I have it in writing in a two independent chats from Samsung that they do not honor the warranty from purchases made from unauthorized dealers.
sr is offline
post #10082 of 14062 Old 12-31-2014, 11:30 AM
bmcn's Avatar
Quoted: 1864 Post(s)
Liked: 2743
Originally Posted by sr View Post
I have it in writing in a two independent chats from Samsung that they do not honor the warranty from purchases made from unauthorized dealers. I originally almost bought a TV from East Coast at a bargain price and then canceled the order after communicating with Samsung. I then received a call from a representative at East Coast all pissed off that I cancelled the order claiming that there were no warranty issues to worry about. East Coast may be 100% right, but I would hate to be in a position to have to debate that with Samsung after the fact.
Unfortunately, Samsung's warranty terms trumps the opinion of their chat reps. The warranty language for the 8500 is unambiguous.
bmcn is offline
post #10083 of 14062 Old 12-31-2014, 11:48 AM
kasedogg's Avatar
Does anyone know the difference between MRT and Panel Display Time? My MRT is 5194 and Panel Display Time is 1690 min.
Any advice whether I should keep this tv based on the number of hours in usage?
kasedogg is offline
post #10084 of 14062 Old 12-31-2014, 12:02 PM
asere's Avatar
Quoted: 1571 Post(s)
Liked: 322
I know the soap opera effect is not good to have on but I'm curious to see how it looks. When I set it to standard or smooth nothing happens.
Is there anything I'm missing?
asere is online now
post #10085 of 14062 Old 12-31-2014, 12:28 PM
elixxxer's Avatar
I haven't searched through this entire thread, but I have my 60" F8500 mounted to the wall with a Monoprice mount. Unfortunately it sticks out further from the wall at the base than the top and I am simply flummoxed as to why. The PN50C7000 replaced by the F8500 rested perfectly flat on the wall using the identical mounts. It's quite obnoxious as the screen is tilted slightly up while the center of the TV is mounted just above eye level.
elixxxer is offline
post #10086 of 14062 Old 12-31-2014, 12:41 PM
bmcn's Avatar
Liked: 2743
Bummer. You might have to take it off the wall and reset the vertical brackets, install spacers/washers along with the upper m screws, or just reseat the lower ones.
Last week I installed a smaller Sammy LCD using a monoprice wall mount. One end of the wall plate was curved or bent but not enough to return it.
Took pains to ensure the wall plate was level and yet the tv was slightly skewed left to right when mounted. After adjusting for some slop in the bracket holes it's now as level as the wall plate.
Can't wait for monoprice to begin production of TV's.
bmcn is offline
post #10087 of 14062 Old 12-31-2014, 01:13 PM
Tom Riddle's Avatar
Quoted: 515 Post(s)
Liked: 432
Originally Posted by kasedogg View Post
My Panasonic 50" VT20 has a much better antiglare filter. See attached photos. The VT20 is hooked up to the component input and the F8500 to HDMI. The VT20 is also brighter. I have them both set to David Katzmaier's recommended settings. I picked up the F8500 as an open box floor model at Best Buy and am undecided if I want to keep it. I was not able to find a new one. There is some image retention on the F8500 and it was manufactured in March 2013. The image retention seems to be fading after running the scrolling bars and can't really be seen with normal viewing. I haven't tested dark room performance to compare them.
Isn't the VT20 the European version of the VT25? If so, the overall peak brightness would not be higher than the F8500. My VT30 has a very similar peak brightness to the VT25 and in no way is as bright as my 8500. Maybe the VT20 is brighter in those particular CNET settings. I will say my VT30 does a better job with anti glare, but that's about the only way it bests the 8500.
Klipsch RF-7 II's, RC-64II, RS-62 II's, RS-52 II's
PSA V3600I
Marantz SR7008 with TK421 Modification
Emotiva XPA-5
Sony XBR-75x940c with Ideal-Lume Panelight
Oppo UDP-203
Tom Riddle is offline
post #10088 of 14062 Old 12-31-2014, 01:54 PM
kasedogg's Avatar
I believe it is the Best Buy version of the VT25 as I bought it at Best Buy. I am also in the greater Houston area.
kasedogg is offline
post #10089 of 14062 Old 12-31-2014, 02:04 PM
Tom Riddle's Avatar
Quoted: 515 Post(s)
Liked: 432
Are you sure it's a VT20 and not a VT25 then? All the info I can find lists the VT20 as the European version of the VT25.
PSA V3600I
Emotiva XPA-5
Oppo UDP-203
post #10090 of 14062 Old 12-31-2014, 02:29 PM
manhatton's Avatar
Quoted: 16 Post(s)
I've seen a few owners with higher than expected MRT numbers for a new set, had there been any attempt to question Samsung in this yet? Or any response?
The set delivered yesterday with an 11/14 build date lists ~190.
Best Buy thought this to be normal. I'm thinking Samsung refurbed this unit, the other 'tell' I believe is that the stand and bezel color do not match. (Anyone else experience that?)
Has the increase in demand caused them to just throw what they have at us?
manhatton is offline
post #10091 of 14062 Old 12-31-2014, 02:38 PM
Tom Riddle's Avatar
Quoted: 515 Post(s)
Liked: 432
Motion should seem incorrect, almost sped up. If you're watching sports, it will be mostly unoticable, if your watching regular content, like a movie, you should be able to quickly spot it. I leave judder off on all sources on the 8500.
PSA V3600I
Emotiva XPA-5
Oppo UDP-203
post #10092 of 14062 Old 12-31-2014, 03:03 PM
asere's Avatar
Liked: 322
Is soap opera effect animated like in a way like using a home video cam?
asere is online now
post #10093 of 14062 Old 12-31-2014, 03:23 PM
Quoted: 28 Post(s)
Originally Posted by cdepaola View Post
Thanks for that info, I'll have to look into SquareTrade but the whole think may be more hassle then it's worth. I really had high hopes that having the receipt would be enough.
Just as a heads up, Square Trade is great...the best possible way you can go. I sell them at my work. BUT....their service doesnt cover burn in. The only service that does is Best Buy, which you can only get if you buy there. Just wanted to throw that out there.
FloydTerminator is offline
post #10094 of 14062 Old 12-31-2014, 03:30 PM
Quoted: 28 Post(s)
I didnt like it at first. it made everything look cheesy and comical. Now however I have got used to having it on, and I think it makes things seem sharper and more real, I feel like things have more depth. Just my opinion after keeping it on for a week.
post #10095 of 14062 Old 12-31-2014, 03:34 PM
Quoted: 28 Post(s)
My MRT out of the box was 5 hours. My step dad has worked with tvs for 30 years. He said it can have any amount of time on it as select tvs are tested and adjusted, but not all, which would be why some peoples say 0. Probably a quality control issue.
post #10096 of 14062 Old 12-31-2014, 03:37 PM
Tom Riddle's Avatar
Quoted: 515 Post(s)
Liked: 432
Agreed. The two times I've filed a claim with square trade, they were quick and fixed the issue. Had a board replaced on my VT30 in about 20 minutes at my house. Highly recomended.
PSA V3600I
Emotiva XPA-5
Oppo UDP-203
post #10097 of 14062 Old 12-31-2014, 03:43 PM
Tom Riddle's Avatar
Quoted: 515 Post(s)
Liked: 432
It can look animated. Just play around with it and see if you like it or not. I use it on my LED set in my kids game area, and it is able to work without producing a vivid soap opera effect, so it's not distracting. The judder control on the F8500 I find too distracting, plus the motion is already really good - not like an LED that truly needs it.
FloydTerminator likes this.
PSA V3600I
Emotiva XPA-5
Oppo UDP-203
post #10098 of 14062 Old 12-31-2014, 04:11 PM
astrobuf's Avatar
My F8500 has a problem
So, my P51F8500 is 11 months old. It intermittently has a display problem. The top 4 inches or so of the screen gets very light, starts flashing etc. Trouble is, it is intermittant. Samsung service says they cant fix it if they cant see it. Will occur when the TV is in displsy diagnostics mode.
Seems more common when the set is in Dynamic mode, but will occur in Standard mode too.
I am worried this will croak and I'll be forced into an LCD as a warranty fix.
What is going on here?
astrobuf is offline
post #10099 of 14062 Old 12-31-2014, 04:41 PM
venus933's Avatar
Quoted: 1724 Post(s)
Liked: 1368
The side by side settings are quite interesting. Your right about the glare. I have both the F8500 and the Kuro and both are rather terrible at controlling glare. I had the Panasonic ZT for a short time and it may have handled the glare better, but no way did it produce a better picture in my opinion. The bottom line is you have to control reflections by using bias lighting, shades, etc. I also found that other calibrator's reference settings should only be used as a starting point and that you have to tweak those settings according to taste. I copied the Value Electronics calibration settings as an experiment and found that the picture looked like I was watching it through a fog. The CNET and Consumer Reports settings were a much better starting point.
My understanding of the panel filtering on the ZT60/VT60 and F8500 models is that they're more designed for blocking light from vertical angles such as an overhead light.
Indeed, when I turn on the overhead light in my bedroom my PN51F8500 is great at retaining black levels and the picture doesn't get washed out at all.
LG 65C7
LG 55EG9100 - Bedroom
Vizio SB4051-C0 Soundbar w/wireless Subwoofer
venus933 is offline
post #10100 of 14062 Old 12-31-2014, 05:37 PM
fierce_gt's Avatar
Quoted: 1752 Post(s)
Liked: 1675
Originally Posted by jk_bama View Post
is it 51 inch? depends on the settings also.. i believe cell light one
64 as per my sig. my range includes all the cell light settings I've used, so about 12-20. also eco on low or off. either way i've done it, peak luminance was always between 30-40ftl
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #10101 of 14062 Old 12-31-2014, 05:57 PM
Tom Riddle's Avatar
Quoted: 515 Post(s)
Liked: 432
Shoot a video of it and that should pacify them. It should also help them diagnose the issue.
PSA V3600I
Emotiva XPA-5
Oppo UDP-203
post #10102 of 14062 Old 12-31-2014, 06:06 PM
Quoted: 28 Post(s)
question for u guys....i see people say if theres a power problem when you turn the tv on the red light blinks. When I turn my tv on the red light blinks 5 times, takes about until the 5th blink for the cable to be going. Everything seems fine, but should the light blink 5 times? Is that how it normally starts?
post #10103 of 14062 Old 12-31-2014, 06:30 PM
Tom Riddle's Avatar
Quoted: 515 Post(s)
Liked: 432
Just purchased an Ideal-Lume bias light from Cinema Quest. Got the pro light and the IR remote to control it. I'm excited about the addition!
PSA V3600I
Emotiva XPA-5
Oppo UDP-203
post #10104 of 14062 Old 12-31-2014, 06:32 PM
Tom Riddle's Avatar
Quoted: 515 Post(s)
Liked: 432
Mine blinks exactly 5 time upon startup. Probably normal and something to do with startup. Interested to see other's comments.
PSA V3600I
Emotiva XPA-5
Oppo UDP-203
post #10105 of 14062 Old 12-31-2014, 07:22 PM
tompatrick's Avatar
I just picked up PN648500 from BestBuy. It was a return but came with no remotes. It seems one way of replacing the smart remote is to order a Samsung 2013 SEK-1000 Smart Evolution kit. Can anyone recommend a solution they have found more beneficial? I have read bad reviews on the functionality of the Samsung Smart remotes. Also, does anyone have the 2014 SEK-2000 Smart Evolution kit and is there an advantage to investing more money with that?
tompatrick is offline
post #10106 of 14062 Old 12-31-2014, 07:28 PM
HLdan's Avatar
Quoted: 497 Post(s)
Liked: 228
Samsung should be able to sell you a Smart Remote.
HLdan is offline
post #10107 of 14062 Old 12-31-2014, 07:28 PM
Chris Hansen's Avatar
Quoted: 127 Post(s)
Liked: 48
Can I connect Bluetooth headphones to the F8500? If so, how?
Chris Hansen is offline
post #10108 of 14062 Old 12-31-2014, 08:19 PM
Liked: 0
I just recently turned my HDMI port to PC mode and for some reason the tv keeps going into screen saver mode after a few minutes whether Im playing a game or navigating around on my XBox..... Is this a bug or do I have to completely turn off my screen saver?(which Im not overly comfortable with)
TVBUFF11 is offline
post #10109 of 14062 Old 12-31-2014, 08:19 PM
Tom Riddle's Avatar
Quoted: 515 Post(s)
Liked: 432
I like the smart remote, but to be fair, I mostly use my Harmony One. Really only use the smart remote to change picture settings. If you want the smart remote outside of the Smart Evolution Kit, go to Amazon.com and search for Samsung Smart Remote. They have some good options.
PSA V3600I
Emotiva XPA-5
Oppo UDP-203
post #10110 of 14062 Old 12-31-2014, 09:17 PM
wxman's Avatar
Quoted: 4474 Post(s)
Liked: 3084
You can buy a replacement remote for $10 on Amazon.
http://www.amazon.com/AA59-00784C-AA...-00784C+remote
wxman is online now
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Samsung Pn60f8500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Pn64f8500 64 Inch 3d Smart Plasma Hdtv
