Official Samsung PNxxF8500 Owners Thread (No Street Price Talk) - Page 362 - AVS | Home Theater Discussions And Reviews
post #10831 of 10847 Old Yesterday, 11:08 PM
DanF8500's Avatar
Quoted: 346 Post(s)
Liked: 227
Originally Posted by DanL0 View Post
Hello,
Finally, the volume from SmartHub's apps is really low and the voices are kind of muffled. When watching Netflix I have to crank up the volume to 30 in order to more or less hear. When watching movies through Amazon, voices are very low compared to background sound (e.g. Inception). I've tried "Clear Sound" and other options but they don't change much.
Again, any advice/suggestions will be very helpful.
When I set "Auto Volume" in the Speaker settings menu to "Normal", it really gives me a boost to the audio. 30 Volume would blow me out of the room in that mode. Try it out if you haven't already. I also use "Clear Voice".
DanF8500 is offline
post #10832 of 10847 Old Yesterday, 11:47 PM
hove131's Avatar
Quoted: 18 Post(s)
The uniformity on my brothers $800 Samsung 5300 plasma blows mine away .... His picture quality mirrors mine and balcks too.... His uniformity is perfect where mine has flaws.... What the hell Samsung ???
hove131 is offline
post #10833 of 10847 Old Today, 12:06 AM
Liked: 0
Is "Screen Fit" disabled when HDMI is named "PC" for you too? What settings do you use for gaming? I notice the lag on default settings, and also in game mode. "PC," which has the smallest delay, doesn't look good.
DanL0 is offline
post #10834 of 10847 Old Today, 12:07 AM
Liked: 0
It does help. Now I find the volume at 15 for Netflix to be comfortable, and 10-9 for TV channels from air antenna. Thanks for the tip.
DanL0 is offline
post #10835 of 10847 Old Today, 12:41 AM
wxman's Avatar
Quoted: 254 Post(s)
Liked: 280
Smaller plasma screens will have less flaws, or noticeable flaws. Making plasma screens 65 inches or larger have been a challenge for tv makers.
wxman is online now
post #10836 of 10847 Old Today, 12:43 AM
hove131's Avatar
Quoted: 18 Post(s)
His plasma is 60"
hove131 is offline
post #10837 of 10847 Old Today, 05:47 AM
AMartin56's Avatar
Quoted: 280 Post(s)
Liked: 99
His plasma is 60"
Frankly I'm surprised you found a F5300 with good uniformity. All the ones I've seen are worse than my F8500s.
Making a uniform panel would cut into their profit margins! You just have to find one you can live with. You probably just bucked the odds and saw a best in show F5300 while your F8500 might be a bit of a mutt.
I'm new to plasma but I'm finding that the uniformity issues bother me more than on LED because they include color variance. Side lit LED's backlight variance bothers me less. While it's sad it also makes sense that getting millions of plasma cells to react to voltages in the exact same way is more difficult than avoiding pixel element variance on LCD. Better manufacturers than Samsung do it better IMO so it's possible... Just not profitable.
AMartin56 is online now
post #10838 of 10847 Old Today, 07:34 AM
Kg810's Avatar
Liked: 0
Originally Posted by Nascar Dog View Post
Which city is this?
Funny you ask, I'm in Calgary as well.
I'm pretty sure the one I bought last night is the last one.
Were you looking for one too?
Kg810 is online now
post #10839 of 10847 Old Today, 07:39 AM
Nascar Dog's Avatar
Liked: 27
Memory Express?
Nascar Dog is online now
post #10840 of 10847 Old Today, 07:47 AM
Kg810's Avatar
Liked: 0
Memory Express?
Yeah the NE location.
Kg810 is online now
post #10841 of 10847 Unread Today, 11:51 AM
WantsNWarrants's Avatar
Quoted: 30 Post(s)
Liked: 38
Originally Posted by djbluemax1 View Post
One important thing to consider, ESPECIALLY if you are ONLY using fans for hot air extraction, vs blowers that blow air INTO the equipment:
adding foam or any other form of air filtration over the vent holes will severely restrict the airflow into and through the equipment. Using foam or pleated fiber or any other kind of filters over the intake vent holes while ONLY using heat extraction fans can potentially cause increased heat in components vs without any add-ons at all.
Max
That's not what my (mute737enter) panel temp indicates (32° C).
WantsNWarrants is online now
post #10842 of 10847 Unread Today, 12:01 PM
venus933's Avatar
Quoted: 314 Post(s)
Liked: 226
My observations between plasma and LCD displays are a polar opposite of yours. Not only is uniformity noticeably better but color luminance is MUCH better on a plasma IMO.
Since it's not probable that all the Samsung plasmas you have owned have had bad uniformity I'm wondering what the heck you're observing. Perhaps your power source fluctuates too much.
Samsung PN51F8500
Samsung PN60E7000
OPPO BDP-103 Universal Disc Player
MartinLogan Motion Vision Gloss Black 5-Channel Soundbar
MartinLogan Dynamo 700 10-inch Wireless Ready Subwoofer
venus933 is online now
post #10843 of 10847 Unread Today, 12:06 PM
JRWalker's Avatar
Quoted: 22 Post(s)
Liked: 44
JRWalker is online now
post #10844 of 10847 Unread Today, 12:56 PM
djbluemax1's Avatar
Quoted: 33 Post(s)
Liked: 289
That shows the temperature from a single sensor. To really see know what effect you're having, you would have to use a thermal imager. While covering the vents and holes with foam/filters and placing a vent fan at certain spots may reduce the temperature at specific locations, it will likely cause increased temperatures at others simply because you've impeded the airflow.
Max
djbluemax1 is online now
post #10845 of 10847 Unread Today, 01:22 PM
AMartin56's Avatar
Quoted: 280 Post(s)
Liked: 99
It's really not that complicated.
If I throw up a full screen white field on my Kuro 5020FD the screen appears to the eye to be the same uniform color. Certainly not as bright as the F8500 can reach due to ABL but the color appears uniform.
If I do the same on my F8500s I don't really see any obvious dimming from ABL (which is nice!) but areas of the screen (that vary from panel to panel) do not appear to be uniform in color. Most often one part of the screen will appear green or pinkish. My current panel appears a bit greenish in the center....my previous ones tended to be pinkish on the right side. This is also visible in grayscale fields that are less than peak white.
Since I think it's important to not entirely rely on my eyes alone I pull out my colorimeter and take readings on the same full screen white field using a meter positioning pattern similar to an ANSI checkerboard. Where I perceive color push the meter does as well. And where I think it's particularly bad the meter reports an error beyond dE 3.0 (which of course makes sense as that's supposed to be where you would start to notice it).
Now I know that test patterns aren't content so I've only replaced one panel for 'the issues' I describe above because the problem with this one WAS visible in normal content. I just get a bit offended when reviewers use the word 'perfect' to describe the uniformity of these sets because I've yet to see it.
I've never owned a F5300 so I can't say that I've measured one but to the eye the ones I've seen had areas of pinkish hue on white backgrounds that was much worse than I've personally seen on my F8500s. And all 3-4 I've seen have had it.
My side lit LED's uniformity is TOTALLY worse than my F8500. But the issues tend to be what you would expect...flashlighting, light bleed from the edges etc. To my eye there is no real color push involved with this, and because of that my eye isn't drawn to it as much. Others may certainly feel differently.
Hopefully the above adequately describes 'what the heck I'm observing'.
Living room: Sony KDL-60NX720, Yamaha RX-V673, NHT Super One/Super Zero w/ NHT Ten Subwoofer, Panasonic DMP-BDT230 Blu-ray.
Man Cave: Samsung PN51F8500, Vizio S4251w-B4 Sound Bar, Sony BDP-S5100 Blu-ray.
Displays calibrated with HCFR, i1DisplayPro, and Colormunki Photo.
post #10846 of 10847 Unread Today, 01:48 PM
mithrilG60's Avatar
This. Thermal management is a complex art, home made jury rigged cooling solutions rarely improve performance in these cases and often introduce more issues. These TV's were designed to utilize passive cooling via heat sinks, vents and natural air convection and no one here knows what temperature ranges Samsung designed the components to operate in. Adding additional cooling to a PC you're overclocking is easy, the case and applications are already designed for active cooling so more airflow = cooler temps. Passive cooling is a completely different animal and by introducing fans in the manner everyone is talking about in this thread you are changing/disrupting the designed airflow.
That may have positive effects, it may have negative effects... but all you really have no way of predicting it so you're just blindly "cooling" on the assumption that it will be "better". One effect you can guarantee it will have is voiding your warranty should a component fail due to heat stress. If you really feel the need to add cooling the best option is to use room fans to move the air behind the panel case, this will have less effect on the air current's over components and heat sinks inside the tv and promote passive heat exchange.
Samsung PN64F8500
Marantz SR5008
Jamo: S 40 centre channel, S 403 front satellites, and S 40 sub
OrbAudio: Mod1X rear satellites
Popcorn Hour A-200, AppleTV 2nd gen
2x Debian NAS/Media Servers - 28TB & growing
mithrilG60 is online now
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Samsung Pn60f8500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Pn64f8500 64 Inch 3d Smart Plasma Hdtv
