Official Samsung PNxxF8500 Owners Thread (No Street Price Talk) - Page 367 - AVS Forum | Home Theater Discussions And Reviews
 1235Likes
post #10981 of 13977 Old 02-06-2015, 01:01 PM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1055
Originally Posted by PaulF View Post
Can you explain further? Are you saying that when the signal reaches an AVR the HDCP is stripped off? If so, why would this only affect audio? How would the TV enforce HDCP?
No, you're right. You could strip it prior to or after the AVR it wouldn't matter but that's an unlikely set-up anyway. My point was that if you can't first route through an AVR for some reason and don't have ARC, then your only option is to defeat DHCP and use the TV's optical out. I have tested this configuration successfully.
zoyd is offline
post #10982 of 13977 Old 02-06-2015, 01:27 PM
sjm817's Avatar
Quoted: 243 Post(s)
Liked: 83
I neither have a source connected directly to the TV, nor an AV receiver that supports ARC like you, so I can't replicate your setup.
I tried Netflix via my Tivo which supports 1080p/24 (with DD+ audio) pass-through and content encoded as such, but it still did not enable a DD option for audio out. My receiver supports DD+ which according to Dolby makes use of the pass-through feature but no dice.
Whats is your receiver model??
sjm817 is offline
post #10983 of 13977 Old 02-06-2015, 02:03 PM
PaulF's Avatar
Yamaha RX-Z7.
PaulF is offline
post #10984 of 13977 Old 02-06-2015, 02:18 PM
WPWoodJr's Avatar
Quoted: 97 Post(s)
Are you saying that prior to the TV you defeat DHCP and then run audio/video over HDMI to the TV and get DD 5.1 from the optical out? How?
Samsung PN60F8500, TiVo Roamio, ASRock Vision 3D HTPC, Chromecast
WPWoodJr is offline
post #10985 of 13977 Old 02-06-2015, 02:35 PM
sjm817's Avatar
Quoted: 243 Post(s)
Liked: 83
Yamaha RX-Z7.
Ok, you have a Tivo that has Netflix and a receiver that supports DD+. It should work. you should be able to plug the Tivo into the Yamaha and get DD+ sound and send the video to the TV. That being said, there have been LOTS OF PROBLEMS with Netflix DD+ with many different vendors. Can you try Amazon Prime or VUDU?
Can you set the Tivo to output multichannel PCM?
sjm817 is offline
post #10986 of 13977 Old 02-06-2015, 02:42 PM
zoyd's Avatar
Liked: 1055
This did the trick.
zoyd is offline
post #10987 of 13977 Old 02-06-2015, 03:34 PM
PaulF's Avatar
I don't have any problem playing any multi-channel audio format through the AVR so long as I don't forward the digital audio signal onto the TV. If I enable the audio signal to be passed on, then I guess an HDMI handshake occurs which forces the AVR into 2.0 mode. This behavior occurs regardless of source.
The Tivo (Roamio) does not have an option for multi-channel PCM output even though it supports HDMI.
As an aside, I did try testing an HDMI multi-channel PCM source using my blu-ray player and the behavior is exactly the same. With the audio set the terminate in the AVR I got PCM listed as the input and indicators showing 5.1 channels. With the digital audio set to be passed onto the TV, the AVR reverts to PL II and I only get the L&R indicators light up. You can also clearly hear the difference.
PaulF is offline
post #10988 of 13977 Old 02-06-2015, 04:16 PM
sjm817's Avatar
Quoted: 243 Post(s)
Liked: 83
Maybe i'm missing what you are trying to do. You want to have 5.1 support using netflix right? That means sound from your 5.1 speakers connected to the AVR. Why do you (or do you) want to forward sound to the TV? HDMI to the AVR, sound from the AVR and video (only) to the TV.
sjm817 is offline
post #10989 of 13977 Old 02-06-2015, 04:44 PM
PaulF's Avatar
Absolutely, we're agreed. All works well for me. The only usage case that causes a problem is when I try to use Samsung's Smart View app on my phone. The only way to get sound is to first forward the digital audio signal to the TV, but that's a minor problem.
I chimed in because some suggested that they were able to get DD 5.1 audio on the TV's HDMI input passed-through over Toslink or ARC for output. However, all my testing suggests that any audio source connected to the TV over HDMI is forced to down-convert to 2.0.
Your configuration is different and I can't test that. Well I could connect a source directly to my TV but would not be able to confirm if ARC is outputting all 5.1 channels. Perhaps the mysterious pass-through setting on your STB is the basis for why it works for you.
PaulF is offline
post #10990 of 13977 Old 02-06-2015, 05:24 PM
HLdan's Avatar
Quoted: 497 Post(s)
Liked: 228
Originally Posted by mithrilG60 View Post
I can guarantee you it is. PCM is a format, it can be either 2 channel (ie. Linear) or multichannel (ie. bitstream). If your source is capable of outputting or down-sampling multichannel audio into raw format (ie. multichannel PCM) that's exactly what the receiver will receive from the TV. I'm not arguing that optical is better, frankly I'm tired of arguing this at all given that I can't imagine why you'd ever want to any TV as your primary source input if you've invested in a modern AVR, but it most definitely is possible in most cases for those who either don't have ARC as an available option or you want to use optical instead.
The reason for people wanting to output audio directly from the TV is for the SMART apps such as Netflix or any other app that streams video. The SMART apps only output audio from the TV's speakers or the TOSlink cable. Not everybody has or wants to invest in a Roku, Playstation, Xbox or AppleTV device to use the streaming apps.
HLdan is offline
post #10991 of 13977 Old 02-06-2015, 05:51 PM
Kurtz9's Avatar
Quoted: 219 Post(s)
Liked: 99
quick point of order.... the TV smart apps also output over HDMI via ARC if the receiver supports it.
Kurtz9 is offline
post #10992 of 13977 Old 02-06-2015, 06:43 PM
HLdan's Avatar
Quoted: 497 Post(s)
Liked: 228
Unfortunately my new audio system doesn't support ARC, but that's good to know.
HLdan is offline
post #10993 of 13977 Old 02-06-2015, 07:10 PM
HLdan's Avatar
Quoted: 497 Post(s)
Liked: 228
I do have a concern though. I've heard and read some conflicting messages about ARC. Even though the audio system supports it and even though the TV supports it I've understood that not all TV's that support ARC will output DD 5.1. through HDMI. Thoughts?
HLdan is offline
post #10994 of 13977 Old 02-06-2015, 08:41 PM
cyclones22's Avatar
Quoted: 123 Post(s)
Liked: 142
My 64F8500 is back in business after a power supply and board replacement. $350 is much less than I anticipated, so I'm happy. Now to get Chase Freedom to reimburse me 😊.
Denon X4200W, Emotiva XPA-5
Klipsch RF-7II Front Cherry (x2), RC-64II Center Cherry, RP-280FA Surround/Atmos (x2), RP-140SA Atmos (x2)
SVS SB-2000 Subwoofer (x2)
OPPO BDP-103D, Sony UBP-X800, Synology NAS
LG OLED65C6P
cyclones22 is offline
post #10995 of 13977 Old 02-06-2015, 09:05 PM
Kurtz9's Avatar
Quoted: 219 Post(s)
Liked: 99
I expect that's true... further I expect it depends on the source of the signal too....Many TVs likewise won't output 5.1 over optical with most external sources.
For the Samsung F8500 this thread is about I believe it works as follows-
The audio from the TV's tuner, smart tv apps, network connection, and USB port can pass as Dolby Digital or 2ch PCM- so you'll get lossy compressed 5.1 if the source provides it, or stereo if that's what the source content provides.
HDMI and analog connected devices (ie external devices going INTO the tv with an audio/video signal) will be output over ARC as 2ch PCM only... so no 5.1 there.
So as with most things you're best off never running sound "through" the TV if possible- go direct from source to receiver via HDMI so you can get HD audio and 7.1 (if the source provides it)... but if you have to (for smart tv apps for example) then ARC is the best option as it requires no extra cables and will give you DD5.1 if the source content is providing it.
As far as I know, I don't think anybody streams DTS-HD MA or Dolby TrueHD at all via smarttv apps anyway... at worst you're missing out on Dolby Digital Plus over ARC compared to "non-TV sourced" HDMI.
Kurtz9 is offline
post #10996 of 13977 Old 02-06-2015, 10:50 PM
wxman's Avatar
Quoted: 3826 Post(s)
Liked: 2724
Another way to get around the toslink limitation on the F8500 is to get a toslink hub that gets around this issue. Just hook all your devices via toslink to the hub, and then one toslink cable from the hub to your AVR. You will then have 5.1. This device will do the trick.
http://www.amazon.com/ViewHD-Audio-T...C+VHD-SM4X4%29
wxman is offline
post #10997 of 13977 Old 02-07-2015, 08:52 AM
Dirtold's Avatar
Good news, mine is still in diagnosis mode. I sure miss it.
Dirtold is offline
post #10998 of 13977 Old 02-07-2015, 10:26 AM
encendido5's Avatar
Quoted: 39 Post(s)
The tech came by yesterday and said the buzz is normal. I figured that's what he was going to say. On the bright side, he's ordering another stand for me since the original has a gap.
Edit: he also said he has these buzzing complaints every week. They used to replace panels but I guess Samsung told them to stop since it wasn't fixing anything. He also said people seemed to have good luck mounting the TV.
I told him I was thinking of returning it and he said I would be crazy to return it especially at the price I paid.
At this point, I'm going to keep it. Reading the LCD threads, it seems they come with their own set of issues and I will never match this set's PQ.
encendido5 is offline
post #10999 of 13977 Old 02-08-2015, 04:42 AM
sjm817's Avatar
Quoted: 243 Post(s)
Liked: 83
I did some more playing around with my setup this morning. The FiOS Motorola 7232 hidden setting for passthrough audio is a magic setting. If I turn that off, I no longer get Dolby 5.1 audio. I get PCM 2.0. Dolby is greyed out in the TV menu. When set to passthrough, the option is available and I get DD5.1. Here is the kicker. I get DD5.1 from the ARC or the Toslink! That confirms what I have thought about ARC. Its basically "toslink over HDMI" Has the same limitations/features. Just over a different physical connection.
DanF8500 likes this.
sjm817 is offline
post #11000 of 13977 Old 02-08-2015, 05:50 AM
yamvmax's Avatar
Quoted: 47 Post(s)
Liked: 33
Well yes, the latest update gives me DD out on optical now.
yamvmax is offline
post #11001 of 13977 Old 02-08-2015, 06:01 AM
sjm817's Avatar
Quoted: 243 Post(s)
Liked: 83
If you are referring to my post above, it is not the Netflix DD+ fix I'm posting about. It is the ability to have an HDMI input on the TV with DD and pass it back out the ARC or toslink port. In theory you can not do that. It is normally converted to PCM 2.0. Internal OTA or smart apps do not have this limitation.
sjm817 is offline
post #11002 of 13977 Old 02-08-2015, 06:03 AM
yamvmax's Avatar
Quoted: 47 Post(s)
Liked: 33
NO, just stating that DD out on optical on netflix does work with the latest update. The whole hdmi thing is a mess all across all platforms. Its a big fail imo.
yamvmax is offline
post #11003 of 13977 Old 02-08-2015, 06:13 AM
sjm817's Avatar
Quoted: 243 Post(s)
Liked: 83
It is complicated for certain. Netflix with their implementation of DD+ broke just about every piece of audio gear out there in some fashion. I'm OK with HDMI in general. It all depends on what you are tying to do. Using things like CEC, ARC, HDMI switched through a TV etc all have various nuances.
sjm817 is offline
post #11004 of 13977 Old 02-08-2015, 06:48 AM
PaulF's Avatar
I pulled up the Fios equipment manual for the VMS1100 yesterday and noticed that it has two pass-through settings. One for 1080p/24 video pass-through, the other for audio pass-through. Your Motorola box must be the same. Tivo supports the former but not the latter.
My guess is the pass-through setting locks the audio output to whatever the source signal provides and in the case of multi-channel does not allow the TV to negotiate a down-conversion.
PaulF is offline
post #11005 of 13977 Old 02-08-2015, 07:07 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Wow! I also have a QIP7232 DVR, and didn't know about the audio passthrough setting. I knew about the "Native" video passthrough in the secret menu. Thanks for sharing this info. I was always saying on this forum that DD5.1 optical out from an hdmi source was not possible due to HDCP, but I won't be saying that anymore.
DanF8500 is offline
post #11006 of 13977 Old 02-08-2015, 07:26 AM
sjm817's Avatar
Quoted: 243 Post(s)
Liked: 83
I would say its still generally true but with an * that it is possible under special circumstances.
sjm817 is offline
post #11007 of 13977 Old 02-08-2015, 09:18 AM
PaulF's Avatar
I did a little more testing.
Tivo Netflix (via HDMI) -- audio output is Dolby Digital Plus. No option to output DD from TV. No audio signal being sent to the TV anyway. Forwarding audio forces down-conversion to 2.0.
F8500 Netflix (via Toslink) -- audio output is Dolby Digital (not Plus). DD output option is enabled.
Audio output is always from my receiver.
BTW, full 5.1 DD audio output was fixed on my TV with the Netflix app update with a UI build date of Feb 3, 2015. This was before I updated the F8500 FW to 1206. Still don't know what that update fixed.
PaulF is offline
post #11008 of 13977 Old 02-08-2015, 09:35 AM
HLdan's Avatar
Quoted: 497 Post(s)
Liked: 228
Glad to know this, thanks for clarifying this. How did you get an F8500 with a February 2015 build date when it was discontinued in the end of November 2014?
HLdan is offline
post #11009 of 13977 Old 02-08-2015, 09:57 AM
PaulF's Avatar
I have had my TV for about a year. The date code I refer to is only for the Netflix app. The apps can be updated manually or automatically. App updates are also independent of which firmware the TV is running.
PaulF is offline
post #11010 of 13977 Old 02-09-2015, 10:59 AM
wxman's Avatar
Liked: 2724
Interesting article about Samsung collecting data via voice activation. I think I will keep mine turned off.
http://www.bbc.com/news/technology-31296188
wxman is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Samsung Pn60f8500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Pn64f8500 64 Inch 3d Smart Plasma Hdtv
