Official Samsung PNxxF8500 Owners Thread (No Street Price Talk) - Page 373 - AVS | Home Theater Discussions And Reviews
post #11161 of 11184 Old 02-20-2015, 04:17 PM
Dianabol5mg's Avatar
Quoted: 43 Post(s)
Liked: 29
Originally Posted by cyclones22 View Post
Through the 103D because it will get the benefit of Darbee. Plus, the 103D plays just about any high definition audio/video container without issue.
I really appreciate the response. Im supposed to pick it up from fed ex when the lady calls me back. They tried delivering it early this afternoon, but my wife and I were out to lunch. I thought it would arrive here on Monday. Oppo got it here pretty friggin fast.
Samsung 60F8500
Samsung 51F8500
LG 55LHX
LG BH200
2 PS3's
Dianabol5mg is offline
post #11162 of 11184 Old 02-20-2015, 04:21 PM
dhartst's Avatar
Thanks for the PM reply AMartin56. I don't have enough posts, otherwise I would have simply replied.
That's my spot too. Heading over there today to pick up some speakers. Why don't you name them publicly? They're great.
dhartst is offline
post #11163 of 11184 Old 02-20-2015, 04:57 PM
AMartin56's Avatar
Quoted: 313 Post(s)
Liked: 114
I'm a huge fan of them too. I've been shopping there for about twenty years now.
Living room: Sony KDL-60NX720, Yamaha RX-V673, NHT Super One/Super Zero w/ NHT Ten Subwoofer, Panasonic DMP-BDT230.
Man Cave: Samsung PN51F8500, Vizio S4251w-B4, Sony BDP-S5100, Darbee Darblet.
Displays calibrated with HCFR, i1DisplayPro, and Colormunki Photo.
AMartin56 is online now
post #11164 of 11184 Old 02-21-2015, 03:45 AM
hove131's Avatar
Quoted: 24 Post(s)
Last night for the first time... My 64f8500 turned off on its own. It had a countdown timer in lower left of screen inside a blue menu box. I only caught the last couple seconds of it. Sleep timer was off and cable box content was displayed When it happened. I've never seen this and I have 1500 hours on set. Ideas?
hove131 is offline
post #11165 of 11184 Old 02-21-2015, 10:49 AM
S_G7's Avatar
Quoted: 20 Post(s)
Originally Posted by S_G7 View Post
I recently purchased a 64 from Best Buy and I'm having an issue installing the stand. The holes for the right clip (labeled 'R') on the stand will not align with the screw holes on the back of the panel. I thought maybe the right clip was not fully attached to the stand, so I detached it from the stand and inserted it alone into the right clip slot of the panel and the holes will still not align. Checked the clip slot on the panel and it is free of any obstructions. I'm going to call Samsung to send me another right clip, but wanted to check here to see if anyone has come across this issue. The left clip screw holes align perfectly. Thanks for any assistance.
Thanks for the replies on this issue. In case anybody else runs into this same issue, Samsung sent me another clip and the new one slid in completely with minimal effort.
S_G7 is online now
post #11166 of 11184 Old 02-21-2015, 11:05 AM
wxman's Avatar
Quoted: 298 Post(s)
Liked: 301
Under System, then eco solution, make sure No Power OFF and Auto Power OFF are off. Then under Screen Burn In Protection make sure Auto Protection Time is off.
wxman is online now
post #11167 of 11184 Old 02-22-2015, 12:22 AM
hove131's Avatar
Quoted: 24 Post(s)
Thank you wxman
hove131 is offline
post #11168 of 11184 Old 02-23-2015, 06:31 AM
stanjohn123's Avatar
Quoted: 18 Post(s)
Guy's I have been away for a while and just come back on the grid. I have a doubt regarding the firmware update for our F8500.
I've never updated my firmware ever since my purchase since I read many owners complaining about reduction in brightness once the firmware is updated.
Is this still the case or is it safe for me to update to the latest firmware ?
stanjohn123 is offline
post #11169 of 11184 Old 02-23-2015, 08:41 AM
KONICA TECH's Avatar
Liked: 51
If you like what you see, and if it is calibrated, leave it alone. You may only be opening a new can of worms that may cause new problems. I do not use the web stuff with my set so there is nothing to be gained.
KONICA TECH is offline
post #11170 of 11184 Old 02-23-2015, 10:53 AM
High Gear's Avatar
Quoted: 27 Post(s)
You should have gotten the standard remote as well.
Originally Posted by V42 View Post
As stated, brackets cover opening where stand attaches which would otherwise be exposed when wall mounted. Per the Quick Start Guide, all the included accessories are shown below (including 4 pairs of 3D glasses):
High Gear is offline
post #11171 of 11184 Old 02-23-2015, 10:57 AM
High Gear's Avatar
Quoted: 27 Post(s)
Hell, I was blaming my older kids for changing the channel on my little guy. This was going on for a month, until I realized that the audio command was on.
wxman and tyler webb like this.
post #11172 of 11184 Old 02-23-2015, 12:12 PM
twitchyzero's Avatar
Quoted: 42 Post(s)
anyone here have exp with panel replacement for warranty?
is there a serial number and build date on the panel?
Does the total screen time in the service menu show the age of the new panel or does it retain the time logged on your old panel? Was your replacement panel 'new', ie. 0 or very little hours logged?
Display: 64" Samsung 3D Smart PDP F8500
Audio: 54" Vizio 5.1 Sound Bar System S5451w-C2
NAS: Seagate Backup Plus 5TB via Asus RT-AC56U Router
HTPC: C2D E8400/Passively-Cooled GeForce GT 730/4GB DDR2 Win 8.1 3D Blu-ray Limelight Steam Machine
twitchyzero is offline
post #11173 of 11184 Old 02-23-2015, 12:18 PM
AMartin56's Avatar
Quoted: 313 Post(s)
Liked: 114
Yes.
Yes.
New panel.
MRT was 2. With original panel it was 500ish.
twitchyzero likes this.
post #11174 of 11184 Old 02-23-2015, 03:18 PM
Ketro's Avatar
Liked: 0
Help !
I have a PS64F8500 , european model, living in Holland.
When I use my blu-ray player or pc throuhg any hdmi , I will get a black flicker every few seconds on the screen. Its only in te FILM mode and at a cellight of 16 and 17.
On the cable its working fine.
Any ideas wat is going on?
Thanks in advance !
Best regards
Ketro is offline
post #11175 of 11184 Old 02-23-2015, 03:21 PM
wxman's Avatar
Quoted: 298 Post(s)
Liked: 301
Originally Posted by Ketro View Post
Help !
Thanks in advance !
Best regards
Try setting the color space on your blu ray player to 4:2:2 instead of 4:4:4 and see if that solves the blu ray issue. Do you have the latest FW? If all fails try a factory reset.
KONICA TECH likes this.
wxman is online now
post #11176 of 11184 Old 02-23-2015, 03:28 PM
hove131's Avatar
Quoted: 24 Post(s)
I still notice brightness pops during content. I thought this was addressed in a FW update?
hove131 is offline
post #11177 of 11184 Old 02-24-2015, 02:52 AM
Ketro's Avatar
Liked: 0
Thanks for your reply, I will try to find the setting 4:2:2.
I have the latest FW update.
Just to be sure after a factory reset , my calibrated tv can be used with the same calibrated settings?
Keep you informed.
Ketro is offline
post #11178 of 11184 Old 02-24-2015, 08:49 AM
DanmanMan's Avatar
Liked: 1
Thanks for the help with my question on missing items everyone. Unfortunately, Best Buy couldn't find the missing accessories. I showed them that replacing the missing parts (and the broken Smart Touch remote) would cost $270 including shipping from Samsungparts.com and they offered me half the cost as a refund. So now I'm on a mission to try to acquire the missing items cheaper than that $135.
So if anyone has extra accessories/cables that they aren't using for their TV, please send me a message. I'm looking for any unneeded 3D glasses as well as the RCA and Component adapters as my main priorities. Thanks!
DanmanMan is online now
post #11179 of 11184 Old 02-24-2015, 09:00 AM
HLdan's Avatar
Quoted: 400 Post(s)
Liked: 178
Well I can't speak for the remote but you can get the compatible Samsung 3D glasses at Best Buy for about $19.99. And cables cost a dime a dozen.
HLdan is offline
post #11180 of 11184 Old 02-24-2015, 10:27 AM
wxman's Avatar
Quoted: 298 Post(s)
Liked: 301
Keep you informed.
Yes, your calibrated settings will work after reset. You will have to re enter them after reset, so write them down before you reset.
wxman is online now
post #11181 of 11184 Old 02-24-2015, 11:10 AM
Ketro's Avatar
Liked: 0
Unfortunately nothing worked. 4:2:2 setup didnt work and a complete reset neither. I guess something is wrong with the motherboard or the current supply, I am not sure.
Any suggestions?
Ketro is offline
post #11182 of 11184 Old 02-24-2015, 11:15 AM
wxman's Avatar
Quoted: 298 Post(s)
Liked: 301
Any suggestions?
Have you tried different HDMI cables? Can you turn deep color off on your blu ray player? The fact that you have no issues with your cable box makes me wonder if it is the tv. What type of blu ray player do you have?
I have re-read your previous posts. Cell light at 16 or 17 causes the issues. Yea, that's not normal. I remember reading some early posts that some had that same issue with cell light at 16 and 17. Not sure what their solution was, but i would think calling Samsung is all you can do for now.
wxman is online now
post #11183 of 11184 Unread Today, 12:38 PM
molfious's Avatar
Hi there, I have a PN60F8500 and had an issue while trying to reload my calibration settings. It ended up causing some default WB settings in the service menu to be reset and a factory reset is not fixing the issue. I was wonderig if anyone would be willing to help me by sending me pictures of the default service menu settings through a private message. To me it looks like only the ADC/WB settings were effected. The red, green and blue offset and gains have all been reset to 128 and I require the default values.
molfious is online now
post #11184 of 11184 Unread Today, 04:24 PM
Quoted: 577 Post(s)
Liked: 505
Those are the default values for ADC/WB, check also ADC Result - should be close to 130,130,130,69,69,69
zoyd is online now
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Samsung Pn60f8500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Pn64f8500 64 Inch 3d Smart Plasma Hdtv
