Official Samsung PNxxF8500 Owners Thread (No Street Price Talk) - Page 376 - AVS Forum | Home Theater Discussions And Reviews
 1266Likes
post #11251 of 14082 Old 03-04-2015, 08:43 AM
videoaddikt's Avatar
Quoted: 41 Post(s)
Originally Posted by pitviper33 View Post
What's going to be more complicated about it? Why would your macro strategy change with the new TV?
It should not, I agree.
One basic example is having 4 HDMI cables hooked up and doing all my switching with the 8500 and not my pre-pro.
Using the alternative method, I bypass many programming functions I have set up in my Harmony remote.
One downside to having the 8500 select sources is that I am using a Darbee enhancer that processes video from all my sources and outputs through one cable to the display.
I am thinking out loud right now, sorry for any incoherence. Just reviewing my options.
videoaddikt is offline
post #11252 of 14082 Old 03-04-2015, 08:54 AM
ChrisMc73's Avatar
Quoted: 208 Post(s)
I searched through this tread for the word "wall mount" and found a few mentions of a wall mount for the Samsung Plasma PNXXF8500, but I have some questions regarding those and any others that I might not have seen yet.
My situation is this, I have a brand new house, with a media room spot upstairs. The wall where the TV is to be mounted has an electrical outlet and right next to it a spot where the cables are run from what will be behind the TV to down in the bottom right corner of that same wall where the components hook up. They have HDMI, Coax and CAT5 ran up there behind the TV, the wires are not crimped yet, just hanging out of the hole in the wall, where they have it nicely covered with a hole plate.
So my question is, I need a wall mount that has the blank space to keep the electrical outlet and the other cables from being blocked. The wall mount needs to hold the PN64F8500, 64" Plasma TV, not sure the weight or what kind of stand plate it requires. I don't care if its one that comes out and can swing side to side or just tilts, either is fine, I know the more elaborate ones cost more and I was hoping not to spend too much, but if its a good one I'll consider it. I'm also not apposed to Cheetah quality, or whatever is lower, as long as it will hold my TV and do its job. I'm basically ok with mid-upper range priced stands.
So any suggestions on a stand that will fit my TV and allow my cables room is the advice I'm looking for. The stuff behind the TV is not recessed its flat on the wall.
ChrisMc73 is offline
post #11253 of 14082 Old 03-04-2015, 09:05 AM
Quoted: 41 Post(s)
I think this question has come up before, Likely more than once. Any difference between using the 8500 SMART TV for selecting apps vs Roku (etc.) or a high quality SMART BluRay player as far as A/V quality?
(audio processed through a pre pro in either case)
post #11254 of 14082 Old 03-04-2015, 09:09 AM
abouttreefitty's Avatar
Quoted: 161 Post(s)
Liked: 346
One difference I notice is that I'm unable to change the picture size when I use the Smart TV Netflix app. I'm able to change it when I use Netflix on my PS3 and PS4.
ChrisMc73 likes this.
abouttreefitty is offline
post #11255 of 14082 Old 03-04-2015, 09:17 AM
Quoted: 1704 Post(s)
Liked: 731
Since the firmware has shown up to activate PVR, how does it work?
JimP is offline
post #11256 of 14082 Old 03-04-2015, 09:22 AM
molfious's Avatar
Quoted: 33 Post(s)
Originally Posted by Ketro View Post
Hi Molfious,
It is not a continuous flickering actually like on the youtube. But more like pops every few seconds and indeed at cel light 16 and 17 as also mention in one of the replies on that whirpool forum.
But this should have been adressed in earlier FW updates?
Hi Ketro, the pops at cell light 16 and 17 should have already been addressed in a previous firmware release. I believe there is actually a setting in the advanced service menu of the TV that can be checked to validate this. You need a special factory remote or another process already posted in this thread to access this portion of the service menu, so only do so if you know what you are doing. I will check when I get home and post the specific setting.
molfious is offline
post #11257 of 14082 Old 03-04-2015, 09:27 AM
molfious's Avatar
Quoted: 33 Post(s)
Originally Posted by Prany View Post
No PVR function using base service menu in 1203. Yep, all the settings got messed up.
molfious, per your request:
Offset
R - 140
G - 128
B - 118
Gain
R - 147
G - 128
B - 114
Thanks Pranny you rule!
molfious is offline
post #11258 of 14082 Old 03-04-2015, 09:30 AM
molfious's Avatar
Quoted: 33 Post(s)
Interesting observation. If you look across many series of Samsung TV's; D series, F series etc. you will notice that when samsung sets the default white balance in the service menu they never adjust Green Offset and Gain. They always remain at the default setting which is 128.
molfious is offline
post #11259 of 14082 Old 03-04-2015, 09:31 AM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
Yes, please share. I've never seen any problems with unstable luminance in 2d mode but I do see it in 3d. Recently did a 3d calibration and some patterns levels would initially display at one luminance value and then a few seconds later increase significantly to a different level. I could see this in 3d playback occasionally as well. I did not try and figure out if cell light and/or any other settings influenced it.
zoyd is offline
post #11260 of 14082 Old 03-04-2015, 10:30 AM
ChrisMc73's Avatar
Quoted: 208 Post(s)
I don't think there is a A/V quality difference, but someone else might know the exacts of that, but as far as usability and the interface, I've never ever liked any of the apps written for the Smart TVs, they have always been a LOT clunkier and buggy when compared to Xbox, Roku, Apple TV, Amazon apps etc...in my opinion. The device specific apps are better written and flow better and over all perform and look better as far as the UI is concerned. This is my opinion.
Do they work, yes, sometimes just not as well as the apps on the 3rd party devices. But again I don't know the A/V quality differences, I don't think there is much if any.
post #11261 of 14082 Old 03-04-2015, 10:36 AM
molfious's Avatar
Quoted: 33 Post(s)
Your best bet if you use these features a lot it to build a custom Home Theater PC. I do this so I can control my codecs and I get much better picture and sound like this even when compared to my Xbox One and PS4. Really it's the only way to go if you are looking for the best quality.
molfious is offline
post #11262 of 14082 Old 03-04-2015, 10:37 AM
zoyd's Avatar
Liked: 1064
I've only tried a few minutes or recording OTA (just pressed the record button) but it worked fine. The recording shows up on one of the SmartHub pages for playback.
zoyd is offline
post #11263 of 14082 Old 03-04-2015, 10:47 AM
venus933's Avatar
Quoted: 1752 Post(s)
Liked: 1396
Originally Posted by Michael Vincent Praino View Post
I want to rent the new Hobbit movie now available through either Vudu or AIV apps built into the tv. Does anyone know which would provide a higher quality feed? My internet is fast enough for 1080p (50 mb/s) so it really comes down to the inherent differences between the two sources.
VUDU especially if you use external speakers
LG 65C7
LG 55EG9100 - Bedroom
Vizio SB4051-C0 Soundbar w/wireless Subwoofer
venus933 is offline
post #11264 of 14082 Old 03-04-2015, 10:51 AM
Quoted: 223 Post(s)
Liked: 39
Hmm, I came across this post that seems to think say otherwise (for PQ at least). The Grand Budapest Hotel: Blu-ray vs. Vudu vs. iTunes vs. Amazon
Michael Vincent Praino is offline
post #11265 of 14082 Old 03-04-2015, 11:00 AM
venus933's Avatar
Liked: 1396
I stand corrected, apparently Amazon has come a long ways. My apologies. Thanks for the link!
LG 65C7
venus933 is offline
post #11266 of 14082 Old 03-04-2015, 11:56 AM
bmcn's Avatar
Quoted: 1925 Post(s)
Liked: 2827
fwiw, when the 8500's Netflix app was unable to deliver Dolby 5.1, I purchased a Roku3 and the same programming (House of Cards) had better visual quality with the app, less banding, etc..
The difference was enough for me to return the Roku before NF/Sammy got their audio act together.
bmcn is offline
post #11267 of 14082 Old 03-04-2015, 12:16 PM
Quoted: 41 Post(s)
so you are saying the NF issue is resolved with the Samsung. As usual Roku sets the standard for others to follow. Good stuff!
post #11268 of 14082 Old 03-04-2015, 12:24 PM
ChrisMc73's Avatar
Quoted: 208 Post(s)
This is good to know, thanks for sharing, I don't have ROKU but this may be what I get now, which version of the ROKU is the one you have? Is it the top ROKU out now?
post #11269 of 14082 Old 03-04-2015, 12:51 PM
wxman's Avatar
Quoted: 4526 Post(s)
Liked: 3114
I have the ROKU 3 and it's PQ for Netflix is better than the Samsung Smarthub app, and better that my OPPO 103D Netflix app. Hands down.
wxman is online now
post #11270 of 14082 Old 03-04-2015, 01:02 PM
molfious's Avatar
Quoted: 33 Post(s)
Sorry Zoyd, the setting I was looking at isn't actually for this. It controls the pop-up message displayed by your TV.
molfious is offline
post #11271 of 14082 Old 03-04-2015, 01:07 PM
bmcn's Avatar
Liked: 2827
No, my experience is the opposite and opposite to wxman's.
For me, the 8500's NF Smartapp delivers noticeably better NF PQ compared to the Roku3, which I returned to the retailer.
bmcn is offline
post #11272 of 14082 Old 03-04-2015, 01:13 PM
bmcn's Avatar
Liked: 2827
Yes, the 8500's NF DD 5.1 audio issue was fixed in early February.
Netflix in stereo not 5.1
bmcn is offline
post #11273 of 14082 Old 03-04-2015, 01:18 PM
bmcn's Avatar
Liked: 2827
Interesting the Roku3 has better NF PQ than the 103D. You convinced me I need to test another Roku3, which I thought had inferior NF PQ to the 8500 app. Perhaps a cable issue, lol. Thanks.
bmcn is offline
post #11274 of 14082 Old 03-04-2015, 01:32 PM
bmcn's Avatar
Liked: 2827
Monoprice has a large selection of wallmounts and I believe they display the backplates for each wallmount.
bmcn is offline
post #11275 of 14082 Old 03-04-2015, 01:41 PM
ChrisMc73's Avatar
Quoted: 208 Post(s)
Thanks, I'll check those out. Was hoping someone with the PN64F8500 would chime in with what they purchased since its such a big TV, getting feedback from them on their experiences would be great, I'll report back with my findings from Monoprice!
Wondering if this TV warrants the use of a full motion range mount or just a tilt. I guess that depends on the space its in and where it needs to be seen. I think in my case a tilt would work, but not sure about the cables and power behind it fitting, so one that comes out a bit might help?
post #11276 of 14082 Old 03-04-2015, 01:56 PM
bmcn's Avatar
Liked: 2827
My 64 is mounted with a flat, low profile Sanus wallmount that held a 60" Sony LCD before it was replaced by the Sammy 64.
Bought a basic one from monoprice to remount the Sony.
bmcn is offline
post #11277 of 14082 Old 03-04-2015, 02:07 PM
ChrisMc73's Avatar
Quoted: 208 Post(s)
My 64 is mounted with a Sanus wallmount that held a 60" Sony LCD before it was replaced by the Sammy 64.
Sanus is the top of the line brand for wall mounts right? I may be wrong but I think that brand is the higher end?
What is the consensus of most people who own 64" or bigger TVs, do they usually just get a tilt mount or is it beneficial to have the ones that come out and move around? I don't know if I need it to do all that.
post #11278 of 14082 Old 03-04-2015, 02:16 PM
pitviper33's Avatar
Quoted: 267 Post(s)
Liked: 117
I'm using this one from Monoprice for my 64" set.
http://www.monoprice.com/Product?c_i...seq=1&format=2
The TV is on the wall, it does not fall off the wall, and I spent 14$.
The only way I can think of that my experience might have been better is if it cost 13$.
I honestly don't understand what specific cable clearance issues you're worried about. If you can explain, I'll do my best to tell you what I can about that mount.
pitviper33 is offline
post #11279 of 14082 Old 03-04-2015, 02:22 PM
ChrisMc73's Avatar
Quoted: 208 Post(s)
Oh I don't know if there are any clearance issues, just asking if there have been any, but I guess I'm talking about having the HDMI cable, power cable and CAT5e cable back there, and with the mount hung up does this specific mount sit above or below your power outlet? I have two outlets up on my wall, one is a standard power out let with two places to plug in power cables, next to that is the same sized plate, but its a hole where a lot of cables are coming out of that run down to a similar hole in the wall down in the bottom right of this wall. So the wall mount would need to either have space for those to things and still be centered on the wall, or sit above or below them. This link you shared has space but doesn't seem to fit the kind of outlets I have. Your space on the mount is more horizontal and I'd need more open space to mount next to. Does that make any sense? I think your stand would go great above or below my said outlets.
Here are some images of my space and the location where I want to hang this TV. I don't know yet if telescoping or tilting is important in this spot. It could be nice to have since the room expands off the the right of this photo, where the kids play, so maybe so they could watch from that area, but the majority of the time its a straight on viewing area.
post #11280 of 14082 Old 03-04-2015, 02:25 PM
bmcn's Avatar
Liked: 2827
The flat Sanus, with no tilt or telescope, is good quality but one from monoprice that suits your requirements should be good.
bmcn is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Samsung Pn60f8500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Pn64f8500 64 Inch 3d Smart Plasma Hdtv
