Official Samsung PNxxF8500 Owners Thread (No Street Price Talk) - Page 377 - AVS | Home Theater Discussions And Reviews
post #11281 of 11299 Old Yesterday, 03:30 PM
ChrisMc73's Avatar
Quoted: 22 Post(s)
Originally Posted by bmcn View Post
The flat Sanus, with no tilt or telescope, is good quality but one from monoprice that suits your requirements should be good.
I can see where tilting down would be nice for this spot, not sure telescoping is needed, but could come in handy. I think the tilting will be a lot closer to the wall vs. the telescoping ones right?
ChrisMc73 is online now
post #11282 of 11299 Old Yesterday, 03:32 PM
ChrisMc73's Avatar
Quoted: 22 Post(s)
This one appears to allow me to mount this bracket right on top of the two outlets I have on the wall, plenty of space in there, so I can center the TV right on top of those outlets...am I wrong with this mount? It does say its only up to 52" but the weight of this 64" is 73lbs so this mount can hold that, but maybe the size of the bracket is not going to fit on the back of the TV?
http://www.monoprice.com/Product?c_i...seq=1&format=2
So if that one wont fit my TV, this one is up to 63", thats pretty close to 64" wonder if it would fit?
again, what I'm worried about is these look really close to the wall, so will the power cable, HDMI and network cable fit back there between the wall and mount and TV?
post #11283 of 11299 Old Yesterday, 03:40 PM
mwl001's Avatar
Quoted: 12 Post(s)
You only need to worry about two things with TV mounts -- weight limit and VESA measurement. The "fits TV" measurement is only a suggestion. I don't know if you already have the TV, but on mine by far what stuck out the furthest was the power cable, right in the middle of the TV. I bought an ultra slim mount from monoprice and used the largest spacer without issue. Was able to mount my previous 65" Panasonic closer to the wall, but it was tight.
mwl001 is offline
post #11284 of 11299 Old Yesterday, 04:51 PM
sjm817's Avatar
Quoted: 96 Post(s)
Liked: 33
Originally Posted by videoaddikt View Post
so you are saying the NF issue is resolved with the Samsung. As usual Roku sets the standard for others to follow. Good stuff!
It the opposite. My friend has 2 Rokus. One is an HDMI only and one has toslink (I dont recall models). Toslink with Netflix gives him 2 Ch. The HDMI Roku does DD+. The HDMI Roku doesnt have to do anything but bitstream the signal through. A device that only has toslink or ARC HAS to convert DD+ to DD vanilla. Samsung TV does this and Roku does not. From what I understand, Roku has no plans to correct this.
EDIT: Dont think I explained that well
Device that only has to pass audio via HDMI has it easy (Roku, Chomecast stick as examples). Bitstream it through. Nothing to do.
DD+ cannot go over ARC or Toslink. It must be converted to DD vanilla. A Smart TV must convert the DD+ to DD to send it out via ARC or Toslink. It has more to do than just bitstream the DD+ through.
sjm817 is online now
post #11285 of 11299 Old Yesterday, 06:00 PM
DanF8500's Avatar
Quoted: 385 Post(s)
Liked: 233
I believe all ROKU devices output RGB Video Level too. No way to change the color space. Many other streaming devices output YCC color space. I don't think this is an issue though. The 8500 should be able to handle either RGB or YCbCr inputs.
DanF8500 is online now
post #11286 of 11299 Old Yesterday, 07:23 PM
Quoted: 247 Post(s)
Liked: 53
As pointed out by mwl, the power cable is the only one that protrudes from the back of the tv. The lan cable plugs into a recessed receptacle on the back and HDMI cables connect at the side. fwiw, my 64 is 1.25" from the wall with the Sanus mount.
There were several monoprice mounts recommended by others elsewhere in this thread.
ChrisMc73 likes this.
bmcn is offline
post #11287 of 11299 Old Yesterday, 07:27 PM
Quoted: 247 Post(s)
Liked: 53
Curious if you hear a difference between DD and DD+ when watching NF?
bmcn is offline
post #11288 of 11299 Old Yesterday, 07:29 PM
00Smurf's Avatar
I've had mine for 8 months now, Best Tv i've owned. Have a slight buzz, but it goes away once the tv volume is going.
00Smurf is offline
post #11289 of 11299 Old Yesterday, 08:33 PM
sjm817's Avatar
Quoted: 96 Post(s)
Liked: 33
Cant say that I have but I have not really done any purposeful testing either. If someone gave me a specific movie/scene to compare I'd be happy to try it. I can do DD from the TV, or DD+ from a Chromecast or BD player. Most of the time I use the TV since the NF interface is very fast and convenient.
post #11290 of 11299 Old Today, 04:13 AM
Quoted: 247 Post(s)
Liked: 53
Agree; I didn't hear a difference between DD and DD+ when casually watching NF.
bmcn is offline
post #11291 of 11299 Old Today, 09:22 AM
pitviper33's Avatar
Quoted: 165 Post(s)
Liked: 74
Here are some images of my space and the location where I want to hang this TV. I don't know yet if telescoping or tilting is important in this spot. It could be nice to have since the room expands off the the right of this photo, where the kids play, so maybe so they could watch from that area, but the majority of the time its a straight on viewing area.
Thanks for the picture. I understand much better what you're worried about now.
That conventional style outlet might create an issue with a mount like the one I linked. There really might not be enough room for the plug where it goes into the wall. I can't remember whether the wall end of the plug is straight or a 90. If you don't have a reason to keep it close to the wall, I'd recommend finding one that holds the TV farther out than the one I linked.
What you have can definitely be made to work just fine. But in case you aren't aware of it, I'll point this out. There are outlets that could be installed that are a much better fit behind a TV. Something like this would eliminate the issue of the plug sticking out from the wall.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Arguably more importantly, it lets you use a surge protector. How important that is to you is a personal decision. I'm just pointing it out to be sure you're aware and consciously making the decision.
pitviper33 is online now
post #11292 of 11299 Old Today, 09:43 AM
Quoted: 247 Post(s)
Liked: 53
Wall plug is a 90 and protrudes 3/4" when plugged in.
No doubt using a surge protector is wise on a >$2k item.
bmcn is offline
post #11293 of 11299 Old Today, 01:51 PM
ChrisMc73's Avatar
Quoted: 22 Post(s)
I had not thought about a surge protector for the TV, thanks for pointing that out. I don't see how this TV Bridge Kit you linked me allows for a surge protector? Where is that functionality in this item?
post #11294 of 11299 Old Today, 02:08 PM
pitviper33's Avatar
Quoted: 165 Post(s)
Liked: 74
The top box is just like a regular outlet. You plug the TV into it. It also provides a large recessed area for bundled cords to hide and some openings into the wall for your signal cables.
The bottom box has a cord coming out that you can plug into a regular outlet near the floor. The top box gets its power from the bottom box. If you want surge protection, you just plug the bottom box into a surge protector that is plugged into the wall.
I use the kit I linked. It was the slimmest option I could find. I was looking for something that came out of the wall very little AND went into the wall very little.
post #11295 of 11299 Old Today, 03:09 PM
ChrisMc73's Avatar
Quoted: 22 Post(s)
Ok I see now, wow, thats a cool thing to have not sure I have the skills to replace what I have with that though, would have been good to know before they installed what I have. Wished I was more handy with that kind of stuff.
post #11296 of 11299 Unread Today, 09:19 PM
ChrisMc73's Avatar
Quoted: 22 Post(s)
I have another question for you all who own the PN64F8500 or different size of the same model, which HDMI port do you use as your input if you do HDMI switching on your AVR? I know there are 4 back there, but I don't know what it matters if any on which one I use as the main input? I know some of you probably don't do HDMI switching on the AVR and go straight into the TV for each input component.
My Denon AVR has handled my HDMI switching fine since I got it a few years ago.
post #11297 of 11299 Unread Today, 10:06 PM
sjm817's Avatar
Quoted: 96 Post(s)
Liked: 33
HDMI3 has the ARC port.
post #11298 of 11299 Unread Today, 10:07 PM
ChrisMc73's Avatar
Quoted: 22 Post(s)
Ok I guess I haven't studied my TV enough, what's the ARC port? And what's it good for?
post #11299 of 11299 Unread Today, 10:28 PM
sjm817's Avatar
Quoted: 96 Post(s)
Liked: 33
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Samsung Pn60f8500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Pn64f8500 64 Inch 3d Smart Plasma Hdtv
