Official Samsung PNxxF8500 Owners Thread (No Street Price Talk) - Page 394 - AVS Forum | Home Theater Discussions And Reviews
 1230Likes
post #11791 of 13931 Old 04-16-2015, 07:39 AM
Quoted: 216 Post(s)
Liked: 38
Long lasting IR from short spurts of gaming
I have been experiencing some long lasting IR from gaming and it is starting to concern me. Last night I played about 45 minutes of SSB4 and it took a full hour and a half of screen wipe on dynamic for the static HUD IR to disappear. What is everyone else's experiences?
My gaming settings:
PC Mode
Cell Light: 8
Contrast: 100
Brightness: 48
Sharpness: 50
Color temperature: Warm 2
Gamma: 0
Michael Vincent Praino is offline
post #11792 of 13931 Old 04-16-2015, 09:22 AM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
My gaming settings:
PC Mode
Cell Light: 8
Contrast: 100
Brightness: 48
Sharpness: 50
Gamma: 0
I don't game, but it's not uncommon for me to watch sports with scrolling banners for a few hours. Granted, the banners aren't there during commercials, but I haven't experienced any image retention. I utilize Cell light of 16, with contrast set at 90.
My daughter uses the Wii for an hour at a clip, and no image retention afterwards as well.
How many hours on your display. If less than a few hundred hours, I'd hold off on gaming until you have around 400 hrs or so. Perhaps the phosphors haven't settled enough.
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #11793 of 13931 Old 04-16-2015, 09:50 AM
Quoted: 216 Post(s)
Liked: 38
Have well over 800 at this point. My set seems more prone than others in regards to IR.
post #11794 of 13931 Old 04-16-2015, 10:12 AM
ChrisMc73's Avatar
Quoted: 208 Post(s)
Originally Posted by DanF8500 View Post
You're having hdmi handshaking issues. When I hear A/V owners say, "Sometimes it works, sometime it doesn't", those are timing issues....If this was a problem with all 8500's, every owner would be experiencing what you and a few others have experienced, but this is not the case. To help alleviate this problem with your 8500 and other A/V equipment in your hdmi chain, the proper order which you turn on your equipment could make a big difference. It's a good idea to power your tv only "after" all the other components you want to use (avr, pre/pro, cable box, blu-ray players, gaming devices, etc) are fully powered up. Problems (hdmi handshake issues) arise when you try to bring up your tv before your other components have a chance to stabilize/boot up their firmware. Glitches in the hdmi lines during power up can lock up the hdmi handshake communications...some devices are more sensitive than others with regards to this. Your mix of audio/video gear seems to be more susceptible of these critical hdmi handshakes.
Also, make sure "all" your hdmi cabling is high speed....longer runs of cabling could also cause handshaking issues because signal/syncing time outs between when a receiving device gets the handshake from the sending device can be possible with longer runs. Longer runs (over 6 ft) of conventional/passive hdmi cabling can usually be resolved with an active hdmi cable, such as the monoprice redmere cables. Passive hdmi cables are spec'ed at 6 ft....anything longer (and sometimes even shorter length) can screw up signal timing of the hdmi spec, especially when the sending/receiving components aren't ready, for various reasons, to send/receive handhsakes in a given timeout duration.
Thanks Dan. I'm just now getting my HT setup in my new home to a point where I can test this more accurately. Before when I was seeing this problem I was running everything through my AVR and the STB was actually going through my Xbox One as well. I would use the Xbox One remote control to power on the Xbox which would in turn power on the AVR and TV as well. I think, if I remember right, it would seem to power on the TV possibly before or around the same time as the AVR and STB, I can't say for sure. I would guess the handshaking issues were probably the issue with that setup after reading your explanation. It seems very likely. And thats when I experienced the bulk of this issue and had my frustrations. It was an easy fix then as the TV was on the stand and I could easily reach behind it and unplug it. But it annoyed me and I wanted to get to bottom of it. I was lazy and didn't bother and then we found our house and packed it all up and moved.
Since we've moved to the new house and I've setup my components again, I decided not to run the STB through the Xbox One this time.
I have good HDMI high speed cables, monoprice as a matter of fact. I am just now starting to test powering on the TV last and have so far not had an issue. Once I get the universal remote setup I will also delay the TV power on till after all the other components are on. Right now I'm just manually powering on everything and the TV is last, and its been working. This is only a few days of testing though.
I will continue to test, leaving the TV as the last thing that powers up and see how this goes. So far its been working, this may be the answer and something I need to more diligently pay attention to going forward.
ChrisMc73 is online now
post #11795 of 13931 Old 04-16-2015, 10:20 AM
ChrisMc73's Avatar
Quoted: 208 Post(s)
Originally Posted by turnne1 View Post
any Samsung TV remote from the last decade will control any Samsung TV
There were differences in the feature sets on the newer TV's which could may help you save a few clicks of the remote
But $15.00( or less) on Ebay will buy you a remote that will control your TV
http://www.ebay.com/itm/NEW-OEM-Sams...item1c4f179a39
though it probably wont have the pretty touchpad....
Warren
Hey, I have the touchpad remote and a remote similar to the one linked here on eBay that were from my previous Samsung LED that was stolen from my house. The remotes are brand new, as the TV was brand new when stolen. I never used them. They do work on my plasma as stated, and should work on yours, even though they were for the LED TV that I used to have.
If you want to PM me, we can work out a good deal on these, as I don't ever use them. I've kept them as "backup" to my current ones but probably don't need to. If you want to work out a package deal on both I'd sell them to you so you don't have to pay the Samsung price and I don't have to list them on eBay.
Let me know.
post #11796 of 13931 Old 04-16-2015, 10:25 AM
ChrisMc73's Avatar
Quoted: 208 Post(s)
Warren
Originally Posted by bigjoexxl View Post
Does anybody know a good place to buy a trustworthy replacement remote? I contacted Samsung and they sent me here (link below). I just feel like a hundred dollars for a replacement is high. Does anybody else happen to know of a cheaper place to buy? I'm just worried about purchasing a knock off version on Amazon or somewhere else. Thanks
http://www.samsungparts.com/Products...59-00758A.aspx
PM me and we can discuss the two extra remotes I have from a previous stolen Samsung LED, not sure if you'd want both or just one.
post #11797 of 13931 Old 04-16-2015, 12:07 PM
turnne1's Avatar
Quoted: 1755 Post(s)
Liked: 410
I think I have two of those touchpad remotes
I dont even ever use them
I typically use the "simple" one if I am making adjustments to the TV
if I am turning it on and off I just use the Direct TV remote that is programmed for my TV
Warren
Rm 1 Samsung 64F8500 Marantz 8801 prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Hisense H50C Yamaha A2050 Celestion 305 speaker system
Rm 3 Panasonic 50ST50 Denon4520 Kef 2005.2 speaker system
Rm 4 Samsung 51E8000 Sony DA5400ES Mirage Omni sat speaker system
turnne1 is offline
post #11798 of 13931 Old 04-16-2015, 12:14 PM
Keenan's Avatar
Quoted: 2213 Post(s)
Liked: 2004
Originally Posted by zoepup View Post
I tried 2 from Monoprice hooked to a 2003 Pioneer PDP4340. The AppleTV would never properly sync with it, thus 9/10 times I had to cycle power to get it to display video from ATV. Monoprice "claims" ATV is slightly different. Plus, my point of view is the less in your path, the more reliable you will be. If the kids turn on the Xbox and it doesn't work 1/10 times, that is too much for me. I buy things to do as advertised 99% of the time. the switch did not. I wish it did. I would prefer an AVR that could do it all.
I have used, and still have in fact, the 5 port model of the Kinovo HDMI switch and it never failed to do what it was supposed to in the year and half I used it.
Keenan is offline
post #11799 of 13931 Old 04-16-2015, 01:23 PM
turnne1's Avatar
Liked: 410
I have heard many similar stories
Warren
turnne1 is offline
post #11800 of 13931 Old 04-16-2015, 01:29 PM
Byrdman10's Avatar
Quoted: 17 Post(s)
Can somebody direct me to an OFFICIAL SAMSUNG website that details what F8500 firmware updates offer? I have not been able to find an official site. I am not interested in guesses or opinions, please don't post.
Byrdman
Samsung PN64F8500
Denon AVR-2313CI
Oppo BDP-103
Panasonic TC-P65S60
Denon AVR-1911
Byrdman10 is offline
post #11801 of 13931 Old 04-16-2015, 02:39 PM
WantsNWarrants's Avatar
Quoted: 84 Post(s)
Liked: 50
Byrdman
What you seek does not exist.
WantsNWarrants is offline
post #11802 of 13931 Old 04-16-2015, 02:44 PM
turnne1's Avatar
Liked: 410
Byrdman
why dont you call Samsung?
Warren
turnne1 is offline
post #11803 of 13931 Old 04-16-2015, 06:10 PM
chunon's Avatar
Quoted: 2060 Post(s)
Liked: 1803
Originally Posted by chunon View Post
I recorded it on my dvr havent watched yet will report back
Same effect on Dish Network dvr green noise in catacombs scene, Game of Thrones
chunon is offline
post #11804 of 13931 Old 04-16-2015, 08:58 PM
hpp8140's Avatar
Quoted: 264 Post(s)
Liked: 79
Byrdman
haha...same generic info.
I wouldn't bother calling Samsung support...same old monkey response...."reset TV" "upgrade firmware"
LN55C630, PN64F8500, Definitive SSA-50, GE Supercinema 3D Array X, Paradigm Millenia CT
hpp8140 is offline
post #11805 of 13931 Old 04-17-2015, 01:01 AM
Byrdman10's Avatar
Quoted: 17 Post(s)
Hey, how did you get that pop-up window to display v1206 firmware information???
BTW, the latest firmware is now v1207. It's available on the TV itself, but not the Samsung support website.
Byrdman
Samsung PN64F8500
Denon AVR-2313CI
Oppo BDP-103
Panasonic TC-P65S60
Denon AVR-1911
post #11806 of 13931 Old 04-17-2015, 01:02 AM
breezy2012's Avatar
Quoted: 242 Post(s)
Liked: 97
Am I the only one here dorky enough to really enjoy drawing the channel numbers on the touchpad remote?
That's my preferred method of changing stations.
breezy2012 is offline
post #11807 of 13931 Old 04-17-2015, 06:54 AM
Quoted: 12 Post(s)
Liked: 4
I remember seeing some serious PQ issues a couple of seasons ago on The Walking Dead. I watched it on different hardware and it was always bad. I think maybe it was the AMC production that was the problem. Newer seasons have looked much better. I wonder if the HBO production is to blame on this one?
DJBoxBaba likes this.
TVs: PN64F8500, PN50B850
AVR: Denon AVR-X1000
Speakers: Cambridge Audio S30/S50
Sub: Klipsch SUB-12
Control: Savant
GTIFace is offline
post #11808 of 13931 Old 04-17-2015, 06:59 AM
chunon's Avatar
Liked: 1803
yeah could be, ill try to chrck it out on my St60, I doubt it is the F8500 itself
chunon is offline
post #11809 of 13931 Old 04-17-2015, 09:30 AM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1051
I rewatched this scene from the HBO fios feed and it was significantly better than either HBOGo or the fios OnDemand versions. The scene was grainy due to the very low light and some over-compression, but it was certainly more watchable than the streams.
zoyd is offline
post #11810 of 13931 Old 04-17-2015, 09:32 AM
chunon's Avatar
Liked: 1803
Did you see a green halo effect?
chunon is offline
post #11811 of 13931 Old 04-17-2015, 09:47 AM
zoyd's Avatar
Liked: 1051
zoyd is offline
post #11812 of 13931 Old 04-17-2015, 09:54 AM
chunon's Avatar
Liked: 1803
Hmmm Ill have to double check my calibration definitely see some green discoloration in that scene.
Do you use black optomizer set to auto ?
chunon is offline
post #11813 of 13931 Old 04-17-2015, 10:18 AM
Quoted: 216 Post(s)
Liked: 38
No, there was no haloing, contouring or discoloration.
Can a low contrast setting (in the 60's) create false contouring/posterization?
post #11814 of 13931 Old 04-17-2015, 10:20 AM
HLdan's Avatar
Quoted: 497 Post(s)
Liked: 228
No, not dorky at all. When using the SMART remote that's really the easiest way to do it. I actually think it's pretty impressive. The most effective way to do it is to not look at the TV while drawing the number on the touchpad. Just look directly at the touchpad while drawing it.
It's a whole lot less dorky than using the onscreen keypad.
HLdan is offline
post #11815 of 13931 Old 04-17-2015, 10:25 AM
zoyd's Avatar
Liked: 1051
dark room
Probably not, this type of problem is almost always source related. Everything on the panel side is done in 10 bits so where you set contrast is not going to create artifacts.
zoyd is offline
post #11816 of 13931 Old 04-17-2015, 10:31 AM
chunon's Avatar
Liked: 1803
dark room
Do you calibrate night mode with it set to dark room?
chunon is offline
post #11817 of 13931 Old 04-17-2015, 10:33 AM
zoyd's Avatar
Liked: 1051
zoyd is offline
post #11818 of 13931 Old 04-17-2015, 10:42 AM
arkinon's Avatar
one of my cats decided to finally get curious about the tv and left some good morning scratches on my screen today. I'm sad.
arkinon is offline
post #11819 of 13931 Old 04-17-2015, 11:26 AM
chunon's Avatar
Liked: 1803
yes and with 25% APL patterns.
day mode bright or auto?
chunon is offline
post #11820 of 13931 Old 04-17-2015, 11:32 AM
zoyd's Avatar
Liked: 1051
zoyd is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Samsung Pn60f8500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Pn64f8500 64 Inch 3d Smart Plasma Hdtv
