Official Samsung PNxxF8500 Owners Thread (No Street Price Talk) - Page 395 - AVS | Home Theater Discussions And Reviews
post #11821 of 11832 Unread 04-17-2015, 10:41 AM
chunon's Avatar
Quoted: 414 Post(s)
Liked: 598
Originally Posted by zoyd View Post
I calibrate using auto for the smarthub and bright for a day mode.
appreciate the tips as akways, why the diff for smarthub?
One other question do you recommend pixel shifter on for traditional cals or is that only for luts ?
chunon is online now
post #11822 of 11832 Unread 04-17-2015, 10:49 AM
zoyd's Avatar
Quoted: 721 Post(s)
Liked: 607
smarthub apps lock out the optimizer on auto, so if you want to calibrate with an hdmi source you can transfer over the settings obtained with it set to auto.
I don't think it's necessary to use the pixel shifter unless you do long LUT measurements.
zoyd is online now
post #11823 of 11832 Unread 04-17-2015, 11:10 AM
chunon's Avatar
Quoted: 414 Post(s)
Liked: 598
smarthub apps lock out the optimizer on auto, so if want to calibrate with an hdmi source transfer over the settings obtained with it set to auto.
Thanks again looks like Ill be busy tonight
post #11824 of 11832 Unread 04-17-2015, 01:52 PM
wxman's Avatar
Quoted: 359 Post(s)
Liked: 331
Black optimizer will work with the apps if you reset your tv and dont re-enable day/night cal modes.
wxman is offline
post #11825 of 11832 Unread 04-17-2015, 04:01 PM
Quoted: 437 Post(s)
Liked: 266
I'm amazed with you knowledge on this. How did you find this out?
Samsung 64F8500, Panasonic 65VT50, Oppo 95, Tivo Roamio for OTA, Dish VIP722, Marantz AV8801 preamp, Rotel Amps, Atlantic Tech 8200 speakers, Seaton Submersive HP, Calman 5, Chromapure, VideoForge HDMI II, Klein K10A, i1Display3pro, i1pro2, eecolor colorbox.
JimP is online now
post #11826 of 11832 Unread 04-17-2015, 04:39 PM
wxman's Avatar
Quoted: 359 Post(s)
Liked: 331
Someone else posted this awhile back. I tried it and sure enough it worked. However, I can't say it will work with the latest FW as I am still on an older version.
wxman is offline
post #11827 of 11832 Unread 04-17-2015, 04:52 PM
DanF8500's Avatar
Quoted: 434 Post(s)
Liked: 241
I have never activated the day/night modes on my 8500, and the black optimizer setting when I'm watching Netflix in the Smarthub is grayed out on "auto"...not selectable.
DanF8500 is online now
post #11828 of 11832 Unread 04-17-2015, 04:53 PM
zoyd's Avatar
Quoted: 721 Post(s)
Liked: 607
You don't sacrifice anything using auto mode so no worries.
DanF8500 likes this.
zoyd is online now
post #11829 of 11832 Unread 04-17-2015, 04:58 PM
wxman's Avatar
Quoted: 359 Post(s)
Liked: 331
That's bizarre because it worked the time I tried it. Perhaps it was a fluke. I always do a reset after a FW upgrade. I wonder if you have to first enable day/night and then after you do a reset and do not re-enable day/night it allows you to use set BO. I re-enabled day/night and the BO was greyed out again.
wxman is offline
post #11830 of 11832 Unread 04-17-2015, 05:01 PM
DanF8500's Avatar
Quoted: 434 Post(s)
Liked: 241
Was BO greyed out on "auto"? I have never manually reset my 8500.
post #11831 of 11832 Unread 04-17-2015, 05:26 PM
wxman's Avatar
Quoted: 359 Post(s)
Liked: 331
Yes, it was greyed out on auto.
wxman is offline
post #11832 of 11832 Unread Today, 06:57 AM
ChrisMc73's Avatar
Quoted: 81 Post(s)
Originally Posted by bigjoexxl View Post
Does anybody know a good place to buy a trustworthy replacement remote? I contacted Samsung and they sent me here (link below). I just feel like a hundred dollars for a replacement is high. Does anybody else happen to know of a cheaper place to buy? I'm just worried about purchasing a knock off version on Amazon or somewhere else. Thanks
http://www.samsungparts.com/Products...59-00758A.aspx
PM me.
ChrisMc73 is online now
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Samsung Pn60f8500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Pn64f8500 64 Inch 3d Smart Plasma Hdtv
