Official Samsung PNxxF8500 Owners Thread (No Street Price Talk) - Page 441 - AVS Forum | Home Theater Discussions And Reviews
 1067Likes
Old 02-04-2016, 09:21 AM
Breathing Borla's Avatar
Quoted: 107 Post(s)
Liked: 26
Originally Posted by Keenan View Post
So one or two? And are they exhausting air out or blowing air in?
Found this that looks like it would do the job nicely,
AC Infinity MULTIFAN S7, Quiet Dual 120mm USB Fan for Receiver DVR Playstation Xbox Computer Cabinet Cooling
these look nice, I bet two of these on the medium setting would do the job nicely.
how did you secure them to the back of the TV?
64PNF8500 Plasma, Yamama RX-V1900, BIC Acoustech 5.1
Breathing Borla is offline
Old 02-04-2016, 09:24 AM
p5browne's Avatar
Quoted: 1350 Post(s)
Liked: 1051
Checkout my picture on the previous page. Others may have other options.
UN65HU9000 with SEK-3500U - Mine
PN64F8500 / UN55HU7250 with SEK-3500U / UN32EH5300 / 2 X LG 55LHXs - wife's !
p5browne is online now
Old 02-04-2016, 10:17 AM
Quoted: 1060 Post(s)
Liked: 554
http://www.amazon.com/Plastic-Cable-.../dp/B002C0SKBW
bmcn is offline
Old 02-04-2016, 11:06 AM
Rojo_P's Avatar
Quoted: 16 Post(s)
There are postings in this thread and other PNxxF8500 threads about placement of fans and in particular this type which is speed adjustable:
http://smile.amazon.com/gp/product/B...ilpage_o00_s00
I put 4 of these USB fans (2 on each side) directly above the two heatsinks (no mistake where the heat is if you put your hand on the backside of the TV). They brought my temps from the 42-44 C range to 31-32.
Too, I have my PN60F8500 on a swivel mount and keep it 6” or so from the wall.
Rojo_P is offline
Old 02-04-2016, 01:19 PM
Quoted: 107 Post(s)
Liked: 26
http://www.coolerguys.com/840556090557.html
what do you guys think about these?
I used stuff from these guys for my media cabinet and they have been real good.
even though they are 80MM, I think with two it would do the trick, looks like they have low dB and move some decent mount of air
I think I'll give them a try and report back my findings of before and after panel temp
not bad 18.79 shipped for two fans wired together for 1 USB port.
Old 02-04-2016, 01:30 PM
DanF8500's Avatar
Quoted: 575 Post(s)
Liked: 281
I'd get a manual speed adjustment for those fans...at max power, you will hear those fans blowing....unless you want to hear fan noise.
DanF8500 is offline
Old 02-04-2016, 01:39 PM
Quoted: 107 Post(s)
Liked: 26
I think I'll be ok, I have 5 120 mm fans going in the media cabinet. I have my tv only going through my yamaha so with that on you don't hear anything that as low as 20 dB...
I went with these for more ease of set-up, cost, etc. I think they will move enough air, but I'll see what the panel temps have to say about that
I think two of them will move plenty of air from that small rear panel
I can always add the manual speed deal afterwards I suppose http://www.coolerguys.com/840556099116.html
I'll report back how they work out
Old 02-04-2016, 02:06 PM
xvfx's Avatar
Quoted: 382 Post(s)
Liked: 211
I have those Coolerguys 120MM USB fans on my VT50. Cannot hear them as they are 19.7dB.
xvfx is offline
Old 02-04-2016, 02:15 PM
skeeder's Avatar
Quoted: 85 Post(s)
Liked: 26
I bought these. They are surprisingly nice. I couldn't figure out a way to mount them without getting some humming sound (I'm surprisingly picky about sound). Then I sold my F8500 after having reoccuring issues. Frankly, I'm really bummed it is gone and hope I can snag a 1080p OLED before LG stops making them, (if it gets to 1k, I'm all in).
The are in a box downstairs--I'd gladly sell them to you. I'm not really sure what I'll use them for at this point.
<Shopping> | Sony BDPS5200 3D | Yamaha RX-V659 | B&W 601 S3
Past: Samsung 51 F8500 PDP
skeeder is offline
Old 02-04-2016, 04:48 PM
AVS Club Gold
Keenan's Avatar
Quoted: 1615 Post(s)
Liked: 1239
Originally Posted by bmcn View Post
Spring for two 120 fans, to exhaust from a larger surface area.
Tied two similar to this to the top back corner above the ports. Two 120's, adjacent to the bend, were a perfect fit on the 64". They're slim and come in different speed/noise ratings. Buy the fastest, then use a USB to 3-4 pin adapter/splitter for power. The adapter/splitter will slow the fans and cut the dba of each by approximately 50%.
http://www.amazon.com/Scythe-Slip-St.../dp/B002CYPWTG
http://www.frozencpu.com/products/16995/
The adapter example above has only one 3/4 pin plug; don't recall if i split that or found a USB adapter with two plugs.
I have an ac infinity 2 fan cooler placed on the top of my receiver and the fans were too loud for my taste, so I swapped the fans for Sythe's, iirc.
I like this, especially the low profile aspect. In fact, lots of good suggestions, thanks guys.
I'm thinking a couple of those thin fans with a speed controller to keep the noise down should do the job. I already some of those bits and pieces here so I'll be ordering the fans today. I also already have a package of 8 of these to keep the noise down(rattling against the display's back cover, though, that will likely reduce the excavation of air by setting the fans off of the cover a bit. I'll try it without first and see if there's any significant noise. 'll post up a pic or two when I get it running.
P.S. I'm also thinking about Noctua fans, a bit pricey but they are really quiet, I've used several in some server build I've done.
Keenan is offline
Old 02-04-2016, 07:38 PM
Quoted: 107 Post(s)
Liked: 26
Can someone give me a couple shots of where you mounted the fans?
Seems hottest point is on the left side if your facing the front of the tv, is that the most important area to cool?
Did you put the fans flat on the back or towards the top near the ledge?
Thanks for the help
Old 02-04-2016, 08:46 PM
Rojo_P's Avatar
Quoted: 16 Post(s)
Thanks for the help
Post 10707:
Rojo_P is offline
Old 02-04-2016, 08:56 PM
AVS Club Gold
Keenan's Avatar
Liked: 1239
Originally Posted by Rojo_P View Post
Do you know where the poster got those flanges?
Keenan is offline
Old 02-05-2016, 12:23 AM
Liked: 1
how many USB ports do we have on the TV, or if you get two fans do the chain from fan to fan so you only need 1 USB port?
there are two 0.5A and one 1A rated usb port. I only use two of them with single fan connected to each one
vavan is offline
Old 02-05-2016, 06:19 AM
fierce_gt's Avatar
Quoted: 1379 Post(s)
Liked: 1351
so, last week i did the update to fw 1211 which comes with the new os(i guess you'd call it?). update went fine, but i'm noticing now that i can only access the smart menu about 20-30seconds after the tv starts up. if i try any sooner than that i get a dialog box that reads 'the smart menu is updating, try again later'.
the only reason this is an issue for me, is that i have absolutely no cable. the only source i use now is a htpc and the smart features(most of my 'cable' channels are 'on the go apps'). so when i push 'watch tv' on my harmony, it's programmed to turn on the tv and go into the smart menu. that no longer works.
i've downloaded fw 1206 from the samsung canada site(kind of surprised to see it was available actually), but before i install that(hoping i can) i'm just curious if anybody else has experienced this, or if it's perhaps not related to the fw at all.
i have to say, overall that tizen os should be pretty nice, but i haven't figured out how to get rid of the 20 useless apps that pop up on the scroll bar. with those still there, it's much quicker to go into the full menu and use it like the old os. so right now, i'm not thrilled with it
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
Old 02-05-2016, 06:48 AM
zoyd's Avatar
Quoted: 1134 Post(s)
Liked: 886
You can't downgrade without first rooting and then using a downgrade technique available on the samygo.tv forums. I would be interested in whether you are able to root 1211.
zoyd is online now
Old 02-05-2016, 07:10 AM
Liked: 1
I thought it's not really tizen but just older os mimicking it
vavan is offline
Old 02-05-2016, 08:16 AM
Rojo_P's Avatar
Quoted: 16 Post(s)
Sorry I don't.
(I attached mine by simply looping twist ties through the vent holes of the TV and the fan screw holes).
Keenan likes this.
Rojo_P is offline
Old 02-05-2016, 08:19 AM
Liked: 554
Wire ties hold the fans flush against the back and don't introduce add'l resonance when used with plastic framed fans; those rubber mounts look OK if they'll securely fasten. Prefer the low profile fans for my app because tv is mounted only a couple of inches from the wall.
Nocturas are the ones I swapped in to replace ones that came with the ac coolers used on my amp and avr.
Keenan likes this.
bmcn is offline
Old 02-05-2016, 11:20 AM
sunlinger's Avatar
Quoted: 37 Post(s)
Liked: 30
I'm using 5 Thermaltake AF0007 120mm fans with USB connectors that have a fan speed adjustment dial. Mine are running at 1000 rpm and can barely hear them at very low (TV) volumes which is a rare occasion with my 5:2 GE HT. I believe it's best to connect fans flush with the back panel using zip-ties. Pulled tight you get a somewhat sealed connection with minimal vibration.
I posted earlier that I have 3 exhaust fans on top and 2 intake at panel bottom while achieving operating temps of 34-36C, which is pretty good living in Florida. Personally I wouldn't go with 80mm fans, they just don't move as much air as with 120mm, 33% percent less.
sunlinger is offline
Old 02-05-2016, 04:25 PM
fierce_gt's Avatar
Liked: 1351
i have no experience with tizen. all i know is there's a 'overlay' version of the apps now, and it's really not as useful as it should be because other than the 3 'last used' that pop up, i'm forced to scroll through dozens of unused apps to select anything else. it's quicker to go into the old menu and do it the old way. except now it's not a simple 1-button press to get into the old menu
Old 02-05-2016, 04:26 PM
fierce_gt's Avatar
Liked: 1351
too bad, i was kind of hoping i could just do a factory reset and then 'update' the fw to an older version. i was putting off this update, but had not heard any complaints so i went for it.
Old Today, 06:53 AM
Dan0780's Avatar
You are able to pin whatever apps you want to the locations on the button of the screen that pops up. Thats what I did for my plex app using the harmony remote. I do not have it boot up directly to an app right now but should work with a delay set in. I have it boot to antenna and then have a sequence set to a button to open specific apps.
Dan0780 is online now
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Samsung Pn60f8500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Pn64f8500 64 Inch 3d Smart Plasma Hdtv
