Official Samsung PNxxF8500 Owners Thread (No Street Price Talk) - Page 452 - AVS Forum | Home Theater Discussions And Reviews
 1169Likes
post #13531 of 13552 Old 06-30-2016, 10:27 AM
Quoted: 1079 Post(s)
Liked: 470
Originally Posted by mwl001 View Post
Can you see if you have the same issue? I'm really more shocked more people aren't reporting this, whether that's because they don't use it or can't reproduce it.
I'm down to Amazon now. Would that provide any useful information?
JimP is offline
post #13532 of 13552 Old 06-30-2016, 03:27 PM
mwl001's Avatar
Quoted: 25 Post(s)
No, fortunately I only experience the issue with HBO, I don't think anyone else has had issues with apps other than HBO.
mwl001 is online now
post #13533 of 13552 Old 07-03-2016, 06:07 PM
muffinmcfluffin's Avatar
Quoted: 132 Post(s)
Liked: 102
I believe I've mentioned this before, but I don't know if there have been any solutions found since.
I own an F8500 and D7000. When watching Blu-rays, I use Cinema Smooth for all 2D material (looks best and doesn't have an annoying flicker).
However, with 3D material, it's the exact opposite. Cinema Smooth causes headache-inducing flickering. It actually looks more like the pixels are rapidly shifting. The depth effect also isn't quite as sweet, and my white balance calibration tweaks would have to be rather extreme to work out right. But it's the headache-like motion that is most craptacular about Cinema Smooth with 3D material. Again, this is with both TV sets. I know other people have not reported noticing this same issue in the past.
So, I switch off Cinema Smooth for 3D content. With my D7000, this is no problem. However, it's not in the living room with the HT equipment and the picture (at least the black levels and peak whites) are not as good as the F8500, so I'm looking to get the most out of my F8500's 3D material instead. What happens when I switch it off though? I believe ABL kicks in. I don't know why, but it does and it does quite often. It will flutter in and out. I'm going to try and record a video of what I am experiencing.
I am on FW 1209 (in the US), and I have the ability to upgrade to FW 1214. I doubt this will remedy anything regarding ABL, but I was wondering if anybody knew for sure. Not only that, I'm also curious if there are any picture setting adjustments that will take this away. The one fix that won't apply here (although it technically is a fix for the issue) is "turn on Cinema Smooth." Sorry, I can't do it with 3D material. I just can't.
muffinmcfluffin is offline
post #13534 of 13552 Old 07-04-2016, 03:19 AM
Quoted: 132 Post(s)
Liked: 102
Fooling around a bit, it appears I made some headway by not using CAL-DAY or CAL-NIGHT. When I use Movie mode, even with the exact same picture settings, it's barely noticeable when something "changes."
I will still record this someday to show people the effect that I was referring to. I have to question how people can watch 3D with Cinema Smooth enabled, though. It acts nothing like the greatness that Cinema Smooth is for 2D Blu-ray films. It has a lot of flicker and back-and-forth juddering... not sure what to call it, but rapid pixel shifting. It's nauseating after just a few seconds.
post #13535 of 13552 Old 07-08-2016, 07:32 AM
Stereodude's Avatar
Quoted: 2645 Post(s)
Liked: 1808
CS with 3D gives you a effective 48Hz refresh rate in the glasses (as opposed to 96Hz for normal 2D CS). I can't watch that. It's too flickery for me. I turn Cinema Smooth off, which results in the Motion Judder Canceler (FI) being turned on, despite being set to off in the menu. So you have to go set it to off again in the menu. (known bug) The MJC/FI algorithm seems to really struggle with 3D content providing weird after images at scene changes. I'm okay with 60Hz on the glasses for 3D. I don't really notice the 3:2 cadence judder like I do with 2D content. To me it's the least objectionable setting for watching 3D.
I have noticed ABL is much more apparent in 3D mode as well. I can't speak to ABL with CS on vs. CS off for 3D since on is unwatchable.
Stereodude is online now
post #13536 of 13552 Old 07-08-2016, 12:18 PM
Liked: 3
Originally Posted by pdjmwj View Post
Think I made a mistake, purchased a demo model 64F8500. Having so many issues that I think I need to return. Love the pic on this TV, love it to death. But, it is not reliable.
When turned off I have to unplug for several minutes, plug back in, and it will then turn back on. HDMI-CEC is flaky when connected to my Sony DN1050. Forces a switch to TV when I want it to stay on SAT connection, that is minor. TV freezes when in menus. Does not respond to remote.
Not sue what to do at this point.
Mine switches to TV when I first turn everything on. I find that if I tell another component ,that's connected to the reciever, to turn on, the. It will go to that input.
davelrcenter is offline
post #13537 of 13552 Old 07-08-2016, 01:41 PM
pbenjamin's Avatar
Quoted: 45 Post(s)
Liked: 27
I have my Harmony Touch set up to pause a second or so, then switch the receiver's input from TV to TiVo as it insists on switching to TV if left to its own devices.
Paul
pbenjamin is offline
post #13538 of 13552 Old 07-08-2016, 01:56 PM
Quoted: 132 Post(s)
Liked: 102
I was reading this post and almost assumed that I had written it, since it's my writing style, my observations and my opinions haha.
So yes, I keep CS off with 3D content as well (and as you said, you have to switch the MJC from Off to Standard/Smooth then back to Off). As I said in my next post though, the bad ABL issue was mostly addressed once I went from CAL-DAY/CAL-NIGHT to Movie mode. I can see some changes, but it's not like it was before. It was an actual issue previously. Now it's just a "little thing" that I can look right past.
Thanks for letting me know it was doing 48Hz. Yeah, the flicker itself was bad, but take off the glasses, play your content, and watch the back-and-forth rapid movement that the pixels have. That combined with the flicker is just terrible. In 2D? Not a problem! I love CS enabled with 2D content, ha!
Cam1977 likes this.
post #13539 of 13552 Old 07-10-2016, 12:18 AM
Cam1977's Avatar
Quoted: 215 Post(s)
Liked: 114
When watching 3d content I always switched cinema smooth off, although I hate soa, it wasn't so bad and easier on the eyes☺
Cam1977 is online now
post #13540 of 13552 Old 07-10-2016, 08:49 AM
dandukem's Avatar
Sad day at my house
It was a sad day at my house after a lightning strike hit a tree in my yard and then seemed to have traveled through the irrigation system wiring into my house electrical system. It took out several low voltage items including the HDMI ports on three tv's which includes my PN51F8500.
Insurance will cover this (less the $1000 deductible) but here is my major concern. If I remember right, in 2013 and most of 2014, this tv sold for around $2800. I was very fortunate to be able to get it from Amazon.com in late 2014 for $1000. If my insurance company gives me only $1000 to replace it, there's no way that I'll get a suitable replacement for that price. Some of my other concerns are that this is a 51" tv and I think I'd need to go up to 55" to get a tv that's even close in PQ to the F8500 and I'm not sure if I have room for a 55". I do have replacement insurance coverage so they may allow me to get high-end tv like the Samsung KS9xxx or a LG OLED but either of those would be at least 55".
My other option would be to have the F8500 repaired. Everything seems to work fine on it except the HDMI ports so I'm thinking that it may be a fairly simple repair.
Any thoughts on a suitable replacement or repair of the F8500 would be appreciated.
dandukem is offline
post #13541 of 13552 Old 07-10-2016, 02:34 PM
Liked: 470
Sorry for the trouble you're going through.
Curious....how do you know its the HDMI board?
JimP is offline
post #13542 of 13552 Old 07-10-2016, 04:41 PM
Tiki Steve's Avatar
Quoted: 103 Post(s)
Liked: 84
That's How I got my 60" 8500, lightning took out two 60" LG's (and all the sat equipment and BD players)
If you have replacement insurance they may give you the extra cost to replace with something similar ?
Samsung 60" F8500
Samsung BD-F7500
Pioneer 1024K
PSB Image 8C,5T,2B,Alpha
Polk PSW10 (x 2)
Monster HTS5100mkII
Tiki Steve is offline
post #13543 of 13552 Old 07-10-2016, 07:08 PM
dandukem's Avatar
I don't think I said that it's the HDMI board, just that none of the HDMI ports are working. It would be nice if it were just a single board and an easy repair though.
dandukem is offline
post #13544 of 13552 Old 07-10-2016, 07:09 PM
dandukem's Avatar
I do have replacement insurance so there's a chance. What current 55" would you get to replace the F8500?
dandukem is offline
post #13545 of 13552 Old 07-10-2016, 07:35 PM
Tiki Steve's Avatar
Quoted: 103 Post(s)
Liked: 84
What to get??
That I can't help with, I have no idea what I would get to replace mine with.
From what I have heard the LG OLED (I think) are about the closest.
I have always been a plasma TV owner, lost when it comes to anything else.
My lightning strike hit the yard and must have come in through the Sat. cables, which were berried in the ground
That's what went on mine also, the HDMI inputs no longer would work.
Samsung 60" F8500
Samsung BD-F7500
Pioneer 1024K
Polk PSW10 (x 2)
Monster HTS5100mkII
post #13546 of 13552 Old 07-11-2016, 09:03 AM
hpp8140's Avatar
Quoted: 194 Post(s)
Liked: 63
HDMI ports are on the main board. Easy, problem is finding a replacement.
LN55C630
PN64F8500
Definitive SSA-50
GE Supercinema 3D Array X
Paradigm Millenia CT
hpp8140 is online now
post #13547 of 13552 Old 07-12-2016, 07:51 AM
brimorga's Avatar
What to get??
I have this TV in 65" and also the LG OLED 55EF9500. Got a deal through beach camera, ebay on the OLED since it's the 2015 model. If you can swing it, go with the OLED, it's amazing. The 3D is mesmerizing on that thing. I had bought a bunch of 3d discs to use with this tv but ended up not being that impressed, but with the OLED it is stunning. I put Frozen 3D on for the kids and found that I could not get up to leave, I was sucked in. That's really saying something cause I'm not a huge Frozen fan!
brimorga is online now
post #13548 of 13552 Old 07-12-2016, 01:31 PM
hpp8140's Avatar
Quoted: 194 Post(s)
Liked: 63
If only Samsung made on OLED these days. I'm used to their software.
LN55C630
PN64F8500
Definitive SSA-50
post #13549 of 13552 Old 07-15-2016, 07:55 AM
Stereodude's Avatar
Liked: 1808
So I think I finally found the infamous floating blacks people complain about. I was watching a poorly authored 2.35:1 Blu-ray that had the black levels mangled on the disc. I was playing it back from my HTPC which sends RGB 0-255, so I set the F8500's black levels to low instead of normal which fixed the washed out image, but sure enough I saw the black bars get noticeably bright several times during the movie. I've never seen that with the blacks set to normal or sending the F8500 YCbCr color space.
post #13550 of 13552 Old 07-15-2016, 11:00 AM
Liked: 470
....snip.... I set the F8500's black levels to low instead of normal ....snip....
...huh?....
Are your referring to dark room optimizer?
JimP is offline
post #13551 of 13552 Old 07-15-2016, 11:14 AM
Stereodude's Avatar
Liked: 1808
...huh?....
No the HDMI black level control that's only adjustable when sending a RGB signal to the set. It's in the Picture Options menu.
post #13552 of 13552 Old Today, 01:54 PM
Liked: 4
Has anyone tried watching a 4K blu-ray on your F8500? I'm wondering if you can get true 1080p, 4:4:4 out of a 4K blu-ray since it should have enough color information when downscaled. Also, if you have done it, was the difference between the 4:2:0 1080p content and the 4:4:4 1080p downscale noticeable?
TVs: PN64F8500, PN50B850
AVR: Denon AVR-X1000
Speakers: Cambridge Audio S30/S50
Sub: Klipsch SUB-12
Control: Savant
GTIFace is online now
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Samsung Pn60f8500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Pn64f8500 64 Inch 3d Smart Plasma Hdtv
