Official Samsung PNxxF8500 Owners Thread (No Street Price Talk) - Page 467 - AVS Forum | Home Theater Discussions And Reviews
 1240Likes
Old 05-16-2017, 10:01 AM
mwl001's Avatar
Quoted: 27 Post(s)
Hi - I have a Samsung 8500 and a Denon receiver that have worked together harmoniously for years but now I either get ARC with TV, or sound through other AVR inputs, but not both. When my TV sound is working, and I can control the receiver volume with the TV remote, and I switch to the HDMI on TV and try to select an AV input, the receiver flashes the desired input, then right back to TV. If I turn off HDMI CEC on the receiver I can get receiver inputs to work, but then I get no surround on my TV input. The TV also fails to recognize the receiver as an audio playback option. Has anyone had an issue like this? The only thing I've done recently was turn on the HDMI control feature on my Roku but turned that back off and things were fine until today. I can always hook up an optical cable but TV is wall mounted so I'd just like to avoid that if there's an easy solution.
mwl001 is offline
Old 05-21-2017, 10:36 AM
Supermans's Avatar
Liked: 36
i've also had this set now for years and it still works great too. i have used an optical cable for audio and haven't had any issues at all with sound. i would go that route and pipe the optical cable into the wall.
mwl001 likes this.
Supermans is online now
Old 06-01-2017, 07:57 AM
9179mhb's Avatar
Quoted: 159 Post(s)
Liked: 106
Does anyone know if it is possible to update the version of the Spotify app for this TV?
9179mhb is offline
Old 06-01-2017, 02:31 PM
mmatheny's Avatar
Originally Posted by decibels View Post
Yes, did do this and actually left it unplugged for 10 days before the tech came out and it made no difference. He took off the back cover, inspected it, put it back together and it has been working fine so far. Will keep praying that it stays this way until I am able to afford to move to OLED!
I have an issue where my PN64F8500 won't give a picture on power up. Red light flashes 6 times then stops. I took a chance and ordered a NEW Samsung power board and replaced it. It still does it, but not nearly as often .I have seen mention of the Y-board causing issues like this. Any input GREATLY appreciated.
Decibels - did the tech unplug any connectors while he had the back off? Maybe that's the solution, is reset all connectors.
Mike
Houston Comcast
mmatheny is offline
Old 06-01-2017, 08:02 PM
zaockle's Avatar
Quoted: 52 Post(s)
there's a new update for this set (1217). I'll report back any changes I find when it's done installing.
EDIT: Looks like Samsung finally fixed the silly boot logo glitch. option stays off between power cycles. hooray. otherwise everything appears to be the same.
zaockle is offline
Old 06-03-2017, 09:12 AM
9179mhb's Avatar
Quoted: 159 Post(s)
Liked: 106
I saw your post & checked for this update... sure enough software version: 1217 is available and is being applied to my PDP as I respond to your post.
If only I could update the Spotify app to match the version my aging PS3 supports.
9179mhb is offline
Old 06-03-2017, 02:13 PM
hpp8140's Avatar
Quoted: 274 Post(s)
Liked: 83
Sounds like Y board...simple cheap fix. Haven't really heard of any other major problems with this TV.
LN55C630, PN64F8500, Definitive SSA-50, GE Supercinema 3D Array X, Paradigm Millenia CT
hpp8140 is offline
Old 06-03-2017, 02:14 PM
hpp8140's Avatar
Quoted: 274 Post(s)
Liked: 83
Anything else?
hpp8140 is offline
Old 06-05-2017, 05:44 AM
Quoted: 222 Post(s)
Liked: 38
Originally Posted by hpp8140 View Post
Anything else?
I am seeing a setting under sound that either is new or I haven't noticed before. It's called 3D audit and its greyed out set to low.
Can anyone else confirm?
Michael Vincent Praino is online now
Old 06-05-2017, 04:09 PM
hpp8140's Avatar
Quoted: 274 Post(s)
Liked: 83
3D audio has been around for a while...looks like the bug is still there, set to low. I noticed it creates a reverb effect on the sound, until turned off.
hpp8140 is offline
Old 06-06-2017, 07:02 AM
Quoted: 222 Post(s)
Liked: 38
Do you know of any workaround to turn it off?
Old 06-06-2017, 07:46 AM
WVZR1's Avatar
Liked: 29
3D AUDIO being only available when 3D content is being displayed I'd think you load some 3D content and see if it's now available to be modified LOW/HIGH/OFF or whatever. I've got it on my very old firmware 1119 and I believe it was there long before that. Not sure but I'd think so. I've never attempted any tweaks of the "SOUND" - I believe that of the 11160 hours of use on the display there's very likely less than 25 hours of that using the SOUND. Much of that time was very likely just confirming the Y-sustain capacitor failures for "power on"!
WVZR1 is online now
Old 06-06-2017, 02:01 PM
Quoted: 222 Post(s)
Liked: 38
So does that mean 3D is not actually doing anything when content is 2D (even if set low/greyed out)?
Old 06-06-2017, 02:47 PM
hpp8140's Avatar
Quoted: 274 Post(s)
Liked: 83
It shouldn't, but I noticed that it did change the sound and I use external sound through optical.....not sure if Samsung has fixed it or not.
Enable 3d video mode, go to sound options to turn off 3d audio, then turn off 3d video mode.
hpp8140 is offline
Old 06-16-2017, 04:36 AM
Quoted: 52 Post(s)
some people suffered from vertical/horizontal lines and reported that here on avs
vavan is offline
Old 06-21-2017, 06:25 PM
fierce_gt's Avatar
Quoted: 1668 Post(s)
Liked: 1600
anybody have issues connecting their f8500 to their wired network? the wifi has been as stable as any wifi i've ever had(which is frustratingly close to good enough), but i plugged in a network cable and it won't connect. been trying to troubleshoot, but can't really figure out where to point the finger. The tv/router are in very different locations, so running a second cable to test is really not doable. i had some issues with a miniPC hooked up to this network cable, but i had issues with that device everywhere. Was actually trying to connect the tv to confirm the ethernet cable was good. it connects to some things, but not everything.
it kind of seems like my router is picky, and any device that isn't "perfect" doesn't work with it. so it's tough to figure out if the router is the issue, or the device that won't connect to it is.
if this is a known issue, i won't really worry about it. but if not, it may help me narrow down my problem.
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is online now
Old 06-23-2017, 07:45 PM
zaockle's Avatar
Quoted: 52 Post(s)
Spoiler!
hard to say. I've had issues with samsungs in the past when installing them for a client and switching between wireless/wired, or even from one wireless to another. but at the same time, my experience tells me it could ALWAYS be the cable.
Home Theater: Samsung PN51F8500|Samsung TW-J5500|Panasonic DMP-UB900|Custom W10 HTPC running MPC-HC w/ LAV+madVR|Panamax M5400-PM|URC MX990 (WIP)
Gaming: Asus VG248QE|Custom W10 6700K+980Ti|J-Tech 5x1 HDMI switch|PS3 Original 60GB|PS Vita TV|Wii U|Schiit Jotunheim w/DAC|Sennheiser HD600 w/XLR4
zaockle is offline
Old 06-23-2017, 10:28 PM
fierce_gt's Avatar
Liked: 1600
yeah it's been a little tough to pin down.
the miniPC has been sketchy everywhere, i know it's not great. but the wifi on it was basically non-functioning, so i got one of those powerline kits and hooked it up to the router that way. seemed to do the trick and worked well for several months. then one day, it says i have IP conflicts, then a couple days later it's working again(without be doing anything). another month goes by, and the IP message pops up again, connected by no internet. this time it doesn't fix itself, but resetting the router and leaving the pc off for a few minutes does. then like a week later it happens again, and i can't fix it.
it's at that point i try troubleshooting, tried changing cables where i could, plugging the powerline kit into different outlets, nothing made any difference. then by fluke, my router got soaked, and i had to replace it. everything worked again with the new one. then a month later, IP conflict message comes up again, and at that point i basically gave up on the PC. this was the first time i tried plugging in the network cable to the tv, and it didn't work.
i've tried different network cables on both ends of the powerline kit. the cables work when connected to other devices, and the cables from those other devices don't work when connected to the powerline kit. the powerline kit seems to work when connected to other devices(i don't have many to check with though that aren't right by my router anyway)
basically i don't think it's wires, since they work in other locations, and all wires don't work in this location(that i've tried)
it could be the router, but it does connect to other devices(two other devices are using a wired connection and have not had any of these issues) and will connect to the miniPC with a short, direct run
it could be the miniPC/TV, as i'm not able to check the tv in a different location, and the miniPC has always been poor, but does connect with a short, direct run
it could be the powerline kit since the miniPC will connect without it, but other devices will work with the powerline kit
so basically, the miniPC(and now TV) don't work with my router and powerline kit in my living room. but seems like everything else works with the powerline kit in the living room, and the miniPC at least works in other locations without the powerline kit. i'll have to investigate more with the powerline kit when i get the chance. seems to be the only link between TV and miniPC not working
Old 06-24-2017, 06:22 AM
Stereodude's Avatar
Quoted: 3248 Post(s)
Liked: 2367
Are you using a CAT7 cable like the manual says?
FWIW, I don't have mine connected to my network.
Stereodude is online now
Old 06-24-2017, 07:20 AM
9179mhb's Avatar
Quoted: 159 Post(s)
Liked: 106
If you're going to use the wireless connection you may have better luck connecting to the 2.4 GHz band, which provides a stronger signal than the 5.0 GHz band will.
If you want to switch to Ethernet, I recommend rebooting the router to clear it's arp cache then do a factory reset for the PDP and run through the set-up wizard selecting Ethernet for your network connection.
I'm assuming the cable & RJ-45 connectors are terminated properly & connectivity has been verified using a different device (e.g. laptop).
9179mhb is offline
Old 06-24-2017, 12:23 PM
bmcn's Avatar
Quoted: 1705 Post(s)
Liked: 2530
Other than the occasional greyed out update option, never.
bmcn is offline
Old 06-24-2017, 03:36 PM
fierce_gt's Avatar
Liked: 1600
cat6, but i'm assuming this isn't a serious issue...
was cat7 even available when the f8500 came out?
Old 06-24-2017, 04:21 PM
Stereodude's Avatar
Liked: 2367
Well, CAT7 is shielded, so maybe there's something to using a shielded Ethernet cable. No idea really.
Old 06-24-2017, 09:44 PM
fierce_gt's Avatar
Liked: 1600
unless the tv is the source of the interference, i don't know how this could possibly be the issue. i understand if it was missed in my long post, but the cables work with other components
Old 06-25-2017, 07:08 AM
bmcn's Avatar
Liked: 2530
Try assigning a fixed IP address for the 8500 on your router and leave the 8500's DHCP setting to its default.
bmcn is offline
Old 06-25-2017, 08:53 AM
fierce_gt's Avatar
Liked: 1600
tried. too dumb to get it to work
it's actually 'working' right now. at least it finally connected. we'll see if it lasts though.
Old 06-25-2017, 09:23 AM
shadowspawn's Avatar
Quoted: 84 Post(s)
Liked: 62
It's at least a possibility.
I have a Meridian 561 digital pre-pro that sits about 2 inches below the bottom of F8500 (Meridian on top of an entertainment console, F8500 on an articulating arm 12" - 15" out from the wall).
When I got the F8500, I had to wrap the Meridian in metal foil to shield it from the F8500. The F8500 was producing interference that made the Meridian turn itself on and off, change inputs, change settings, and eventually freeze up so I'd have to unplug and cold-boot it. Once I even had to connect it to the laptop PC and re-upload all the setup information. Wrapping it in metal foil fixed the issue.
That never happened with my Pioneer 5010 or with the Panasonic that preceded the Pioneer.
shadowspawn is offline
Old 06-25-2017, 09:57 AM
bmcn's Avatar
Liked: 2530
Presumably you rebooted router after assigning IP address to 8500. GL, you'll nail it.
bmcn is offline
Old 06-25-2017, 03:55 PM
9179mhb's Avatar
Quoted: 159 Post(s)
Liked: 106
I thought I said essentially the same about 8 posts ago...
37 years employed as an IT professional (1978 - 2015), but what do I know.
9179mhb is offline
Old Today, 11:55 AM
avsform1's Avatar
Quoted: 51 Post(s)
Liked: 32
To add to that, the CAT7 is only good if it is point to point (router to tv). If you home is pre-wired it will most likely not be shielded through out the house.
avsform1 is online now
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Samsung Pn60f8500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv , Samsung Pn64f8500 64 Inch 3d Smart Plasma Hdtv
