2013 TC-P60S60 ($1209) vs 2012 TC-P60ST50 ($1348)??? - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: 2013 TC-P60S60 ($1209) vs 2012 TC-P60ST50 ($1348)
S60 0 0%
ST50 0 0%
Voters: 0. You may not vote on this poll
post #1 of 9 Old 06-02-2013, 02:34 PM - Thread Starter
brdaaw's Avatar
I'm looking to get a new 60'' plasma. I"ve always been a fan of panasonic plasmas. My question is: should I get the 2013 TC-P60S60 ($1209) vs 2012 TC-P60ST50 ($1348)?
- I don't really care about 3D
- The price difference is negligible to me
- I'll be sitting ~10' from the TV
- I've get 2 Definitive Tech STS, Mythos 3 and Gems powered by a Marantz 6007
brdaaw is offline
post #2 of 9 Old 06-02-2013, 02:47 PM - Thread Starter
brdaaw's Avatar
I'm also not too interested in Smart TV features, as I have an Apple TV that I'm happy with.
brdaaw is offline
post #3 of 9 Old 06-02-2013, 04:09 PM
rahzel's Avatar
Liked: 148
Light controlled room: S60 (no screen filter)
Bright/Brighter room: ST50
rahzel is offline
post #4 of 9 Old 06-02-2013, 04:42 PM - Thread Starter
brdaaw's Avatar
There are only windows on the perpendicular walls. All of the windows will have window treatments.
brdaaw is offline
post #5 of 9 Old 06-02-2013, 05:51 PM
bamaboy1234's Avatar
Is there really only a 150$ difference between the 2 60" models? There is like an $800 difference between the 2 65" models when I was looking. That being the case, would definitely go with the ST60 for that small of an increase. The S60 is good, but the lack of filter kept me away from it. I really enjoy my 65S64 though, couldn't ask for a better TV for the price.
edit: ignore my ability to misread...
This is a tougher question. It basically comes down to the where it will be used since I believe both TV's are pretty similar.
bamaboy1234 is offline
post #6 of 9 Old 06-02-2013, 06:31 PM
rahzel's Avatar
Liked: 148
If glare/reflections won't bother you, then the S60 is a bit better.
rahzel is offline
post #7 of 9 Old 06-02-2013, 06:56 PM
Ahh...sneaky, I get so used to seeing the 60 series now.
post #8 of 9 Old 06-02-2013, 08:26 PM - Thread Starter
brdaaw's Avatar
My living room:
Found an almost identical fireplace that has exactly what I intend to do:
brdaaw is offline
post #9 of 9 Old 06-02-2013, 08:38 PM
rahzel's Avatar
Liked: 148
Even ambient light will wash out the picture faster having no filter vs having one. Those pot lights (unless they're dimmable) or having the window open during the day will be enough to make it look washed out compared to the ST50. In a dark or moderately lit room, the S60 will look a bit better. Depends on what conditions you do most of your viewing in.
rahzel is offline
Panasonic Viera Tc P60st50 Plasma Tv , Panasonic 60 Inch Plasma Hdtv Tc P60s60
