ST60 vs VT50 (similar size) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-03-2013, 01:50 PM - Thread Starter
Roy Warner's Avatar
I've seen very few of these comparisons, and even the ones I've seen have been comparing deals involving differently sized TV's.
Long story short, I had a hookup for a 55" ST60 for $800 plus tax/delivery from a friend, and now his chain has decided to not to stock ST's this year. I think the best I can do to match that is going to be around $950 for something comparable with the 55st60
BUT
There is a used 55vt50 available that I can get for 900 plus tax/delivery that is described as "pristine condition" all around, except for an L shaped scratch measuring about a quarter of an inch made up of three little pinprick type dots in the lower left part of the screen (within the black bars for 2:35 films, which will be the main function of this TV). If it's visible at all, it will bother the hell out of me, and there's a strong possibility it'd be visible in a dark room.
So I can't decide what to do frown.gif Anyone have any advice?
Roy Warner is offline
post #2 of 4 Old 06-03-2013, 02:37 PM
rahzel's Avatar
Liked: 148
I don't like buying used. Plus the ST60 is a hair better anyway. I would go with the ST60. Unless you're a hardcore gamer and input lag bothers you.
Roy Warner likes this.
rahzel is offline
post #3 of 4 Old 06-03-2013, 03:06 PM - Thread Starter
Roy Warner's Avatar
What if it were between a 50st60 and 55vt50? I've finally seen pictures of the scratches (the TV is 75 miles away, so I can't see it in person).
PQ is my absolute priority. It's a smaller room, so the size difference isn't too killer, and if I'm super bothered, I have a 58v10 in the next room, ha. I think I can get the 50st60 for 900 plus tax with delivery included
post #4 of 4 Old 06-03-2013, 04:43 PM
rahzel's Avatar
Liked: 148
I have a hard time recommending a used set. Even if it's still under warranty I'm not sure if it's transferable (I don't think that it is, you might want to check on that).
Just a straight comparison of the two, I would go with the larger VT50. Whether you want to buy used is up to you.
rahzel is offline
Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv , Panasonic Viera Tc P55vt50
