panasonic vt50 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-06-2013, 04:16 PM - Thread Starter
gonzosparky04's Avatar
I bought a panasonic 65vt50. Got it calibrated by Geek Squad since I had 1 free service from them. The question is, they did most of the calibration from the service menu, which I believe was grey scale adjusting, and used the cinema mode to tune in the color, sharpness, etc. Does that seem right? If so is the grey scale set for every input and every color mode ie cinema, vivid, etc.
gonzosparky04 is offline
post #2 of 10 Old 06-06-2013, 05:12 PM
chunon's Avatar
Quoted: 1148 Post(s)
Liked: 1156
Calibrating in the service menu is not necessary should has calibrated the ISF Day and NIght modes, can you post your before and after charts if you have them ?
Service menu calibration is on a color temperature basis for example warm, normal and cool so the grey scale adjustments affect all picture modes, my guess is they calibrated THX cinema ? Did they calibrate 3d ?
55EG9100 calibrated by Chad_B
55ST60
Time Warner Cable/Oppo 103d/ Sony XT1 Soundbase/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
My JS9500 Calibration review(CHADB)http://www.avsforum.com/forum/166-lc...l#post36534866
chunon is offline
post #3 of 10 Old 06-07-2013, 07:52 AM - Thread Starter
No before and after charts. Wasn't very happy about that. Whatever he did in the service menu did make a difference. It was all about getting the color temperature right. Other than that he just used a Joe Kane DVE disc to make the other adjustments. It was only cinema mode not thx cinema. I don't use 3d so he didn't calibrate it. I didn't expect a great calibration from them, but it was free so I had them do it. At least they didn't ruin the tv.
post #4 of 10 Old 06-07-2013, 07:55 AM
chunon's Avatar
Liked: 1156
Still you are not enjoying the full performance of your set imo, so much calibration horsepower in custom/isf modes can't belive how clueless these guys are
55ST60
chunon is offline
post #5 of 10 Old 06-07-2013, 10:17 AM - Thread Starter
So what would you suggest?
post #6 of 10 Old 06-07-2013, 10:21 AM
chunon's Avatar
Liked: 1156
The chances of them redoing the cal correctly are slim and none imo, a proper professional cal with cost you in the $400 to $500 range. If you're happy with your set now just go with that, I wasn't posting to try to sway you one way or another its just I own the same set(55") and know what it is capable of. Did you try DNice's setting or any of the other ones in the owners thread ? Might yield an improvement might not, do you feel the picture is bright enough for your needs ? That would be my main concern that and gamma might be off. What are your brightness and contrast color and tint settings out of curiosity ?
55ST60
chunon is offline
post #7 of 10 Old 06-07-2013, 11:13 AM - Thread Starter
picture 80
brightness 52
color 50
tint 0
color temp warm 2
black level light
What picture mode would you recommend? Custom has the most options but can you get good adjustments by eye?
post #8 of 10 Old 06-07-2013, 11:20 AM
chunon's Avatar
Liked: 1156
picture 80
brightness 52
color 50
tint 0
color temp warm 2
black level light
You can do the basics in custom but beyond that you need a meter and software, that brightness seems low to me do you see good shadow detail or do blacks seem crushed ? MIght be worth trying some settings in the owners thread jsut to see if it is an improvement
55ST60
chunon is offline
post #9 of 10 Old 06-07-2013, 11:37 AM - Thread Starter
I"m looking for some settings in the owners thread. Are there any? By the way GO BUCKS!!!
post #10 of 10 Old 06-07-2013, 11:55 AM
chunon's Avatar
Liked: 1156
Sorry try the Vt50 settings thread, yes "Urban" Renewal is in full swing smile.gif
55ST60
chunon is offline
Panasonic Viera Tc P55vt50 , Panasonic Viera Tc P65vt50 65 Inch Plasma Tv
