OFFICIAL LG 60PN5700 60" Class Thread - Page 24 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #691 of 708 Old 07-10-2015, 04:52 PM
OmegaStageThr33's Avatar
Quoted: 16 Post(s)
Originally Posted by empiretc View Post
yep.
have had this TV for just over a year. grabbed it for $699 last august and was pretty happy.
these days, image retention seems to be a real problem. it is on m-f for ~8 hours and the 2 channels it is one during that time have their logos visible on the screen at all time. not a real big deal, since they are only noticeable on light color and white backgrounds. however, white backgrounds also produce what this poster noticed.
over the weekend, though, we attached a pc to this television via hdmi2 to display some images. we were shocked when we immediately noticed after an image had been on screen for ~1 minute and we would switch to the next, lines from the previous were clearly visible.
there have been 2 updates in the past few weeks and it almost seems as if the image retention has gotten worse since.
when you are watching full color HD, the TV still has an outstanding picture. whenever you view something with a white (or light colored) background, all these imperfections and image retention spots steal the show.
it is clear this is the first and LAST plasma we will own. Will use this one until it dies (or screen becomes unbearable) and get another LED.
We have had the TV for ~ 1.5 years and I have noticed the same thing. For me its a white grid that has 3 vertical lines and 2 horizontal lines. Did you ever figure out the issue with yours?
OmegaStageThr33 is offline
post #692 of 708 Old 08-03-2015, 01:10 PM
No Look's Avatar
Blue Smart key on factory remote FAIL...
OK, all of a sudden the BLUE Smart key on my remote does not access the apps ?? Instead, I get a pop up window across the to of the screen letting me know I'm getting a 1080p signal, and the litttle red home icon appears..
Have tried powering down, removing the HDMI from the cable box (verizon fios), disconnecting the cable from the modem, and cursing.. But nothing has worked so far.. Nor have I been able to find any work thru's via google or you tube.. Surely I'm not the 1st with this issue? Help ? And thanks...
No Look is offline
post #693 of 708 Old 08-04-2015, 11:51 AM
sambou812's Avatar
Could you snap a pic of what your seeing when you press the blue button?
what happens if you press the my apps button to the right of the blue button?
i assume you have the standard remote and not a magic remote?
at this point it seems as if you have a damaged remote.
sambou812 is offline
post #694 of 708 Old 08-04-2015, 06:32 PM
No Look's Avatar
What I get is the image across the top of the screen:
HDMI1 16:9 1080i 60Hz (pink tv) On Now
Aside from that, all the other functions on the controller seem to be functioning...
What do you think ?
No Look is offline
post #695 of 708 Old 08-05-2015, 12:28 PM
sambou812's Avatar
What do you think ?
you may have a damaged remote.
if you can use the my apps function button and all works well,than its a remote mapping error .
did you use simplink to set up that input?i have seen remote mapping errors using simplink and magic remote but doing an initialization of the system app usually clears that up.
also its a good idea to keep the firmware updated.
my kids once spilled mountain dew on one of my ht remotes and cleaned it off so dad wouldn't know.
but the stuff got between the graphite pad and circuit board and corroded the contacts.
i used liquid flux cleaner to repair it.
post #696 of 708 Old 11-03-2015, 11:44 AM
jokerfish's Avatar
Anyone else just get an OTA update?
I wonder what this will do
jokerfish is offline
post #697 of 708 Old 11-03-2015, 07:50 PM
sambou812's Avatar
not me i'm @ software version 05.04.03 been there since august.
i know lg is killing there cloud service ,but i haven't seen anything new.
post #698 of 708 Old 11-04-2015, 12:51 AM
ChazzMatt's Avatar
Quoted: 17 Post(s)
I saw the notice about the cloud service, but I was hoping it was just for the 3D TV sets, not ours -- as the notice specifically mentioned 3D service. I thought perhaps it was only actual 3D apps (if any) that were going away, as 3D TV is now passe.
I know our plasmas are not 3D capable, but for some reason we share the same "3D Cinema" apps software. Yet, I was hoping stuff like Pandora and YouTube would stay. It's a pain to fire up the Blu-Ray just for a couple of apps when it's already built into the TV.
Do you think LG will replace the 3D Cinema software with some other apps software in an update?
Your creed may be interesting, but your deeds are much more convincing.
ChazzMatt is offline
post #699 of 708 Old 11-04-2015, 11:25 AM
sambou812's Avatar
i was referring to the lg cloud back up file service.
as far as 3d world, i just noticed the removal notification last night .
i doubt we'll get any new apps.
i have always liked this interface a whole lot better than the newer web os version.
i have a 2015 vizio 65" led so called smart tv. its yahoo interface is terrible and slow. they try'd to do an ota update, and it caused the tv to endlessly loop the update you couldn't even watch the thing. i had to disconnect the Ethernet cable then it try'd to connect to my wireless router which it couldn't because its password protected i was finally able to reset to defaults and lose all my calibration settings.
just another reason i love my lg.
post #700 of 708 Old 04-24-2016, 08:08 PM
No Look's Avatar
Alllllrighty then...
Will this model support HBO NOW ?
PS: As for the controller issues I asked about last year, I gave up.. Still unable to access the menu via the blue smart home key.. Just use my iphone app now..
No Look is offline
post #701 of 708 Old 08-31-2016, 07:51 PM
papitosabe's Avatar
so I heard about some secret menu for a samsung TV which allows you to turn on a wireless headphone function. Has anyone heard of something similar for this LG TV? There is no auxilary port for headphones, and it looks like we can't connect a wireless headphone thru the options menu. IIRC, there is an area for one, but its greyed out, and you can't choose it. Even the crappiest of tvs typically have an auxilary port. Anyone have a simple and very cheap solution. I'm really not wanting to spend bucks on some device/adapter unless its under like $10-$15
papitosabe is offline
post #702 of 708 Old 09-01-2016, 01:48 PM
sambou812's Avatar
post #703 of 708 Old 09-02-2016, 08:37 AM
ChazzMatt's Avatar
Quoted: 17 Post(s)
Thanks, that was a great find.
post #704 of 708 Old 09-03-2016, 12:03 PM
sambou812's Avatar
no problem..glad i could be of service.
post #705 of 708 Old 01-13-2017, 02:01 PM
vmalhotra's Avatar
Quoted: 26 Post(s)
Last night, while watching Charlie Rose, heard a loud pop and TV shutdown. Totally dead, no light in front, back and no response to power button.
Is it power supply? Any steps to diagnose it?
You got to be nuts; you want me to pay to watch commercials?
vmalhotra is online now
post #706 of 708 Old 01-13-2017, 02:31 PM
sambou812's Avatar
sounds like you blew a capacitor on the power supply board.
i have had extensive experience with that exact problem,while not with my lg's.
the Panasonic g10's were notorious for that,they would come out once every few months and replace the whole power supply module instead of beefing up a few capacitors.
well after my service contract ran out it happen'd again this time i repaired it my self.
i went out and bought slightly over sized Japanese cap's and heat dissipation covers for them.
a good tv repair shop could do this cheaply.
the Panasonic g10 i repaired is still in use today with no further repairs.
i hope this was helpful.
post #707 of 708 Old 01-13-2017, 08:27 PM
vmalhotra's Avatar
Quoted: 26 Post(s)
Really appreciate your response, replacing caps is something I can handle. Small price to try it out, I just hope it is not any other logic/control boards.
post #708 of 708 Old 02-23-2017, 02:22 PM
vmalhotra's Avatar
Quoted: 26 Post(s)
Finally opened up the TV, following dismounting.
Turns out power supply fuse (10amp) is blown. Caps look OK. Fuse is soldered to the PS Board.
Also, next to the fuse, the variaster, looks like has oozed out some yellowish goo. Not sure if it is some glue put at factory or some chemical spit out by failing component (very atypical of failed variaster).
Will replace both and report.
Lg 60 Inch Plasma 60pa550c
