Pioneer PDP RO3U - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-07-2013, 11:51 PM - Thread Starter
albertian's Avatar
I have a pioneer PDP R03U that I got from a friend it was always hooked up to a surround system and amp the provided sound, I want to hook up the pioneer speakers that came with the TV, I can not get any sound, is there something on the remote that I am missing? And yes I checked the mute, had my wife ask me too.
albertian is offline
post #2 of 6 Old 06-08-2013, 05:08 AM
Quoted: 1392 Post(s)
Liked: 587
That model number is for a Media Receiver that probably is hooked up to a PDP-5030HD panel.
Verify the panel model number.
Without looking at the model's pdf, I'd speculate that you have to be sure that the wires in the back are properly connected to the terminals based on my PDP-6070 which is long gone. It's also possible that in the menu, there is a setup option to turn on the TV's speakers rather than using an external surround sound system.
If that doesn't help, be sure to get us the model number and we'll see if we can figure it out.
JimP is offline
post #3 of 6 Old 06-08-2013, 10:24 AM - Thread Starter
albertian's Avatar
The model of the plasma display is PDP-503PU, I had the speaker wires in and out, and pretty confident they are connected properly, thanks and appreciate the help
post #4 of 6 Old 06-08-2013, 11:07 AM
Liked: 587
I entered this model number into the pioneer electronics website and it didn't find anything.
Is this a North American model? If not, which region.
JimP is offline
post #5 of 6 Old 06-08-2013, 10:18 PM - Thread Starter
albertian's Avatar
I double checked the model, the mfg date was 2002, I can only assume it is a North American model, I live and got the tv from a friend of mine who always lived in Canada
post #6 of 6 Old 06-09-2013, 07:04 AM
Liked: 587
According to this post 4 http://www.avsforum.com/t/1228888/pioneer-pdp503pu
We should be looking for a PDP-5030HD
Here's the PDF for it.
http://www.pioneerelectronics.com/pio/pe/vgn/images/portal/cit_11221/50019PDP5030_4330_2002411152202500.pdf
See if the instructions on page E-46 help. Sounds like variable is selected instead of fixed which sound wrong even as I type it. Whatever it is, try the other one.
JimP is offline
