Samsung PN60F5300 calibration settings? - AVS Forum | Home Theater Discussions And Reviews
 252Likes
post #1 of 1628 Old 06-09-2013, 06:31 AM - Thread Starter
LowerFE's Avatar
Liked: 41
Hi,
I recently bought a Samsung PN60F5300, and I find the factory default settings give terrible colors. Does anyone have a calibration setting for it?
LowerFE is offline
post #2 of 1628 Old 06-09-2013, 07:54 AM
will7046's Avatar
Liked: 34
My Samsung PNXXF5300 (Seperate Setting for Both 51inch and 60inch) Calibration Settings
Note: These calibrations were perfomed on the 2013 A Series. I'm unsure if they will work for the 2014 B Series
PN51F5300:
Notes: Because there were some significant shifts in greyscale and brightness when engaging Cinema Smooth, I calibrated two modes, Cinema for 24p Blu-Ray viewing, and Standard for everything else.
For 60 HZ inputs (Cable Box/Sat, Game Systems)
--Picture menu
Mode: Standard
Cell Light: 18
Contrast: 92
Brightness: 46
Sharpness: 0
Color: 41
Tint: G50/R50
Picture size submenu:
Picture Size: Screen Fit
PIP: Off
Advanced settings submenu:
Dynamic contrast: Off
Black tone: Off
Flesh tone: 0
RGB Only Mode: Off
Color space: Custom
White Balance: [see below]
10p White Balance: Greyed Out
Gamma: 0
Expert Pattern: Off
Motion Lighting: Off [grayed out]
Color Space submenu:
Color Space: Custom
Red: Red 49, Green 23, Blue 15
Green: Red 46, Green 49, Blue 16
Blue: Red 6, Green 14, Blue 53
Yellow: Red 50, Green 50, Blue 17
Cyan: Red 47, Green 49, Blue 50
Magenta: Red 51, Green 22, Blue 53
White balance submenu:
R-Offset: 18
G-Offset: 25
B-Offset: 24
R-Gain: 18
G-Gain: 25
B-Gain: 23
10p White Balance submenu:
10p White Balance: Not available
Picture options submenu
Color tone: Warm2
Digital Clean View: Off
MPEG Noise Filter: Off
HDMI black level: Normal [grayed out]
Film mode: Auto 1
Black optimizer: Dark room
For 24p inputs (Blu Ray)
--Picture menu
Mode: Movie
Cell Light: 17
Contrast: 100
Brightness: 44
Sharpness: 0
Color: 45
Tint: G50/R50
PIP: Off
Black tone: Off
Flesh tone: 0
RGB Only Mode: Off
Color space: Custom
10p White Balance: On
Gamma: 0 or -1 (Personal Preference, I calibrated at and used -1 and it didn't change the other measurements much for 0)
Expert Pattern: Off
Color Space: Custom
R-Offset: 18
G-Offset: 25
B-Offset: 23
R-Gain: 18
G-Gain: 25
B-Gain: 26
Interval Red Green Blue
1 0 0 -1
2 0 0 -2
3 0 0 0
4 -1 0 +1
5 +1 0 -3
6 +1 0 +1
7 +1 0 -2
8 0 0 0
9 +2 0 -6
10 +3 0 +6
Color tone: Warm2
Film mode: Cinema Smooth for 24p
PN60F5300:
Notes: These will be very innacurate if you use Cinema Smooth for 24p content, it caused an extremely large shift in greyscale so keep your Blu Ray player at 60hz or Film Mode to Off (Over 10 for some of the Delta E errors!!)
--Picture menu
Mode: Movie
Cell Light: 20
Contrast: 100
Brightness: 47
Sharpness: 0
Color: 46
Tint: G50/R50
PIP: Off
Black tone: Off
Flesh tone: 0
RGB Only Mode: Off
Color space: Custom
Gamma: -1
Expert Pattern: Off
Color Space: Custom
Red: Red 49, Green 19, Blue 16
Green: Red 55, Green 52, Blue 15
Blue: Red 9, Green 15, Blue 54
Yellow: Red 50, Green 51, Blue 19
Cyan: Red 50, Green 51, Blue 52
Magenta: Red 49, Green 24, Blue 53
R-Offset: 29
G-Offset: 25
B-Offset: 27
R-Gain: 24
G-Gain: 25
B-Gain: 22
1 0 0 +2
2 -1 0 +1
3 0 0 +1
4 +2 0 +2
5 0 0 0
6 +1 0 0
7 0 0 -4
8 0 0 0
9 -2 0 -6
10 -3 0 -1
Color tone: Warm2
Film mode: Auto1 of Off (Never use Cinema Smooth with these settings)
will7046 is offline
post #3 of 1628 Old 06-12-2013, 08:47 AM
snoopdogg's Avatar
Will, what did you use for calibration? DVD or professional? I bought the same set recently and tried calibration with the Disney WOW DVD. I purchased it because of the many positive reviews but I was hoping for a little more from it to help with the advanced settings.
snoopdogg is offline
post #4 of 1628 Old 06-12-2013, 09:45 AM
will7046's Avatar
Liked: 34
I'm not a professional, I self taught myself, but I have calibration meter (i1 Display Pro) and calibration software (Color HCFR) and use the AVS and other calibration discs found in the Display Calibration subforum for test patterns.
Disney WOW is great too, I also have this disc, it really is great for setting basic settings (Color, Contrast, Brightness, etc.)
Advanced settings (Gamma, White Balance, Color Management Systems) really can't be adjusted correctly without the benefit of a meter and software.
gnphiker likes this.
will7046 is offline
post #5 of 1628 Old 06-12-2013, 11:55 AM
signmastr's Avatar
Quoted: 12 Post(s)
Will, still plan on calibrating your "buddies" PN60F5300 in the near future?
signmastr is offline
post #6 of 1628 Old 06-12-2013, 01:00 PM
will7046's Avatar
Liked: 34
I will be doing it this weekend. I will be traveling over the weekend, so I will post the settings early next week.
signmastr likes this.
will7046 is offline
post #7 of 1628 Old 06-15-2013, 05:29 PM
snoopdogg's Avatar
Thanks for posting your settings Will smile.gif I'm liking how it looks and I'd like to see your charts you mentioned.
post #8 of 1628 Old 06-16-2013, 03:09 PM
will7046's Avatar
Liked: 34
Glad your liking them.
Please see the new comments I made above. I will be posting an additional set of settings with cinema smooth turned off and my charts for both sets this week sometime.
I will also try to post the calibrated settings from the 60 inch 5300 I calibrated over the weekend. I calibrated this one with cinema smooth off (it was horribly inaccurate with it turned on). It also came out very good.
will7046 is offline
post #9 of 1628 Old 06-16-2013, 08:55 PM
mattymaxima's Avatar
I calibrated my PN60F5300 using the Spears & Munsil calibration disk here: http://www.avsforum.com/t/1477056/samsung-pn60f5300-calibration-settings-using-ps3. I used the 10p, white balance and custom color settings as used by will7046 and the color bars came out almost perfect. My cell light, contrast and brightness settings were different though as my reds and blues were clipping above 91 contrast (whites never clipped even with contrast turned all the way to max though). I tried adjusting the color down to prevent clipping which worked but then the color bars were way out of whack. Increasing the color to 51 and decreasing the contrast to 90 seemed to be perfect. I am using Cinema Smooth as well. Thanks
mattymaxima is offline
post #10 of 1628 Old 06-17-2013, 06:21 AM
will7046's Avatar
Liked: 34
Sounds like you had great results, awesome.
I did see a bit of color clipping as well, but I made the trade off to get more light output from the set.
will7046 is offline
post #11 of 1628 Old 06-19-2013, 06:07 AM
will7046's Avatar
Liked: 34
Please see post 2 in this thread for my updated settings for the 51 inch 5300, I also posted my 60 inch settings
will7046 is offline
post #12 of 1628 Old 06-19-2013, 07:09 PM
karlpoe's Avatar
Will, thanks for posting the 60"F5300 settings! I have the same set and they came out beautiful! Nice work! I'm planning on getting an i1 Pro soon and am interested to see if there are any differences with my panel. . but I have to say. . the set looks incredible with your posted settings!
karlpoe is offline
post #13 of 1628 Old 06-20-2013, 08:26 AM
signmastr's Avatar
Quoted: 12 Post(s)
Thanks Will. I'll try these settings tonight...
post #14 of 1628 Old 06-21-2013, 08:53 AM
signmastr's Avatar
Quoted: 12 Post(s)
Looking great with your settings. Ever consider ISF certification? Thanks again...
post #15 of 1628 Old 06-21-2013, 10:12 AM
will7046's Avatar
Liked: 34
Glad you are enjoying them.
It's basically a hobby at this point. I wanted to be be able to calibrate my own equipment, and I get new TV's every couple of years. It would have been very expensive to keep hiring a professional calibrator. Now I also help out my freinds and family when I can. This site is great for finding resources on learning how to calibrate yourself.
Maybe someday though, I always keep it in the back of my mind
will7046 is offline
post #16 of 1628 Old 06-21-2013, 01:19 PM
karlpoe's Avatar
Have you updated your firmware to 1017? I'm curious if the update changes any of the calibration settings..the description on the Samsung site says: "Improved picture quality over HDMI"
karlpoe is offline
post #17 of 1628 Old 06-21-2013, 01:38 PM
will7046's Avatar
Liked: 34
Thanks for the heads up on the new firmware. I have been pretty good about checking on this, but haven't looked in the past week.
I will update my 51 and check it out sometime this weekend. I won't be able to check on the 60 inch version.
I can't imagine it would change things all that much though. Maybe it will help with the ABL pops (Hockey Pop's as some have dubbed them here) that I see from time to time.
will7046 is offline
post #18 of 1628 Old 06-22-2013, 10:16 AM
will7046's Avatar
Liked: 34
New firmware did not change any of my calibration settings. Not sure what it did honestly. Everything looks the same.
will7046 is offline
post #19 of 1628 Old 06-22-2013, 10:23 AM
karlpoe's Avatar
Thanks for checking! I didn't really notice a difference either...
karlpoe is offline
post #20 of 1628 Old 06-23-2013, 06:34 PM
snoopdogg's Avatar
I was going through and modifying my settings based on Will's recent edit to his original posting. I have a PS3 connection which I use for netflix, vudu, blu ray, gaming, etc. It is connected using an HDMI cable. I was wondering if anyone knew why I do not have the 'film mode' option available under 'Standard' or 'Movie' when playing 60hz content from netflix or vudu in particular. It is grayed out and set to off. This is really bugging me.
post #21 of 1628 Old 06-24-2013, 06:10 AM
will7046's Avatar
Liked: 34
Film mode will always be greyed out with a 60hz signal. It will be selectable with a 30 hz input (1080i or 480i) or a 24p input (Blu Ray can do this with the setting enabled on the player)
will7046 is offline
post #22 of 1628 Old 06-24-2013, 08:51 AM
signmastr's Avatar
Quoted: 12 Post(s)
Samsung support told me "firmware updates do not change calibration settings" that's a good thing.
post #23 of 1628 Old 08-08-2013, 07:28 AM
larlev's Avatar
Thanks for the settings that were posted. Works great. Are your 60" cable settings same as your 51"?
I cannot connect hdmi through my Time Warner cable dvr so I have component connected. Am I correct in that I have to set calibration for hdmi and component separately.
larlev is offline
post #24 of 1628 Old 08-08-2013, 01:17 PM
larlev's Avatar
Thanks, I think I saw your other post. I set my ps3 as you did. I ordered the disney wow disc to calibrate for regular cable watching.
Coming from a Mitsubishi wd-62327 DLP.....this plasma is really really good. I'm taking dvr back to TWC and get it exchanged, hopefully it will fix issue. Component isnt really that bad however, still looks great.
larlev is offline
post #25 of 1628 Old 08-08-2013, 11:26 PM
BenDB's Avatar
edit: I had a long question here, in regards to the CNet review. I decided it would be best in its own thread, so I moved it.
If you would like to coment, which I would appreciate, it is HERE.
BenDB is offline
post #26 of 1628 Old 08-09-2013, 02:01 PM
larlev's Avatar
Switched out dvrs...hdmi is working now. Much better actually, didnt think it would matter. Wills settings for blu-ray are spot on. Thanks again Will for taking the time to post. I feel like I owe you something.....I'm taking the easy way out instead of doing it myself.
I'm still working on settings for regular cable viewing. It's close, and is probably fine but I can't leave it alone. smile.gif
larlev is offline
post #27 of 1628 Old 08-09-2013, 02:16 PM
dannov's Avatar
Originally Posted by LowerFE View Post
Hi,
Works for the 32"???
dannov is offline
post #28 of 1628 Old 08-10-2013, 07:55 PM
afkingjay's Avatar
i followed wills settings and tweaked them just a little for my room settings. standard is my normal tv watching / ps3 gaming. movie is my dark room blu-ray viewing.
thanks
afkingjay is offline
post #29 of 1628 Old 08-11-2013, 11:41 AM
dannov's Avatar
thanks
Please post Wills again or include Link -
dannov is offline
post #30 of 1628 Old 10-20-2013, 09:28 PM
RicFlair's Avatar
Quoted: 488 Post(s)
Liked: 71
How is the lag on this TV?
RicFlair is offline
Samsung Pn60f5300 60 Inch 1080p 600hz Plasma Hdtv
