3 plasmas equal 3 times input lag? - AVS Forum | Home Theater Discussions And Reviews
Old 06-10-2013, 10:01 PM - Thread Starter
dextra's Avatar
If i had a 3 monitor setup or a 3 plasma set up for PC gaming and the plasma has 20ms input lag and i bought 3 of those and hooked them up as one huge screen, or 3 monitors with 20 ms input lag each and used it as one huge wide screen, would that mean the input lag is now 60ms or would it be 20ms? Input lag not response time.
dextra is offline
Old 06-10-2013, 11:46 PM
Sean Max's Avatar
Assuming that the processing required to send the signal to all three displays doesn't increase the input lag it would still be 20ms.
"Experience is the one thing you can't get for nothing." - Oscar Wilde
Sean Max is offline
