Samsung PN60F5300 calibration settings using PS3. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-12-2013, 06:23 PM - Thread Starter
mattymaxima's Avatar
I tested this TV using the “Spears and Munsil HD Benchmark Blu-disc” played through a PS3.
PN60F530 Settings:
-Picture Menu
Mode: Movie
Cell Light: 20
Contrast: 90
Brightness: 43
Sharpness: 0
Color: 51
Tint: G50/R50
Picture Size: Screen Fit
-Advanced Settings Menu
Dynamic Contrast: Off
Black Tone: Off
Flesh Tone: 0
RGB Only Mode: Off
Color Space: Custom (see below)
White Balance: (see below)
10p White Balance: On (see below)
Gamma: 0
Motion lighting: Off (grayed out)
Color Space submenu:
Red: Red 49, Green 23, Blue 15
Green: Red 46, Green 49, Blue 16
Blue: Red 6, Green 14, Blue 53
Yellow: Red 50, Green 50, Blue 17
Cyan: Red 47, Green 49, Blue 50
Magenta: Red 51, Green 22, Blue 53
White balance submenu:
R-Offset: 18
G-Offset: 25
B-Offset: 23
R-Gain: 18
G-Gain: 25
B-Gain: 26
10p White Balance submenu:
Interval Red Blue Green
1 0 0 -1
2 0 0 -1
3 0 0 0
4 -1 0 +1
5 +1 0 -3
6 +1 0 +1
7 +1 0 -2
8 0 0 0
9 +2 0 -6
10 +3 0 +6
-Picture Options Menu
Color Tone: Warm 2
Digital Clean View: Off
MPEG Noise Filter: Off
*HDMI Black Level: See Below
Film Mode: Cinema Smooth (I chose to use this feature with Blu-rays as I saw flickering with it OFF when the PS3 24p mode is set to Automatic. The Samsung's cinema smooth feature does a great job at 96hz)
Black Optimizer: Dark Room
*HDMI Black Level: There are 2 methods by which you can set this IF using a PS3.
1) You can set the RGB Full Range Mode option to "LIMITED" on the PS3 and use "Normal" (grayed out) for watching movies and "Low" while playing games or through a HTPC. This would also be the choice to use if NOT using the PS3 and its RGB Full Mode option.
2) You can set the RGB Full Range Mode option to "FULL" on the PS3 and leave the setting to "Normal" on the TV. This is the option I have chose so I do not have to ever switch the TV setting and instead let the PS3 control the proper spacing.
PS3 Settings
-BD/DVD Menu:
Cinema Conversion: Automatic
Upscale: Normal
BD/DVD Video Output Format (HDMI): Automatic
BD 1080p 24Hz output (HDMI): Automatic
-Display Settings Menu
RGB Full Range (HDMI): Full
Y Pb/Cb Pr/Cr Super-White (HDMI): On
snoopdogg likes this.
mattymaxima is offline
post #2 of 3 Old 06-08-2014, 07:16 PM
SoonerTheBetter's Avatar
Quoted: 21 Post(s)
Liked: 26
Thanks for these settings mattymaxima. I have been trying a few of the different settings from different posters and these have given me the best results for my pn60f5300. My picture is now phenomenal.
I can't believe you only have two posts.
SoonerTheBetter is offline
post #3 of 3 Unread Today, 04:31 PM
PhilipsPhanatic's Avatar
Quoted: 197 Post(s)
Liked: 32
Bumping this as an alternative 5300 Settings to utilize besides the others some of us use.
I'll compare the actual numbers here to the others on the Calibration Settings. For all I know, they could be 90% the same.
PhilipsPhanatic is online now
