Need Help Clearing out Viera App off VT - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-13-2013, 07:13 PM - Thread Starter
chefwong's Avatar
VT60 series.
Netflix acting up.
The unit is connected to the internet. Can browse Prime, etc.
Netflix would not autheticate.
When I do the deactive, it does not go through (I suspect cause it can't reach the server).
Call Netflix - they said their servers are good, and will need to call Panasonic.
Went into Viera Marketplace - no real option to uninstall/reinstall Netflix App.
Not sure what the problem is.
It's been 3 days in a row - I suspect it's the Netflix app not hitting a server.
Hence, when I choose deactivate, it says it does it, but then hangs.
I pulled the plug on the TV - let it sit for 3 hrs. Plugged it back in.
No dice.
Any other ideas...
chefwong is offline
Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv
