TC-P42S60 Firmware Update Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-19-2013, 04:03 PM - Thread Starter
Blokhead's Avatar
Hello,
I just picked up a 42" S60 that was on sale Father's day at Sears. I changed some of the settings to the ones found here, but some options are not listed. I checked my firmware, and its 2205-10201. So, its version 2.205 correct? After searching on this thread I see that 2.206 is the latest. I've tried to update it manually, but it says that I have the latest version?......And, yes I am connected to the internet. Is there any other way to update the firmware?
Dean
Panasonic's Chat was no help. They said there was no new firmware for this. I'm not happy with the picture, but don't really want to return it just yet.
Blokhead is offline
post #2 of 6 Old 06-19-2013, 09:10 PM
mrkdilkington's Avatar
Were the settings you found for the ST60 or S60?
mrkdilkington is offline
post #3 of 6 Old 06-20-2013, 05:46 AM - Thread Starter
Blokhead's Avatar
They were Fairchild's99's from the first page of the "Official Panasonic S60 Series Discussion Thread ".
On page 15 an 16 of the same thread people have posted that there versions are 2.206, even the S64 from Costco.
Is the 42" somehow different (other than size) from the other ones?
Blokhead is offline
post #4 of 6 Old 06-20-2013, 07:43 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 521 Post(s)
Liked: 776
Originally Posted by Blokhead View Post
Hello, I just picked up a 42" S60 that was on sale Father's day at Sears. I changed some of the settings to the ones found here, but some options are not listed. I checked my firmware, and its 2205-10201. So, its version 2.205 correct? After searching on this thread I see that 2.206 is the latest. I've tried to update it manually, but it says that I have the latest version?......And, yes I am connected to the internet. Is there any other way to update the firmware? Panasonic's Chat was no help. They said there was no new firmware for this. I'm not happy with the picture, but don't really want to return it just yet.
The firmware updates only pertain to the internet apps - they have nothing to do with picture settings or picture quality. When you check for updates, it will only update if there is a new version, otherwise it will just tell you you have the current version.
Whenever i set up a new Plasma the picture quality looks a bit "harsh" for the first several hours until the panel starts settling in. Give your panel about 300 hours to fully settle in then adjust the picture settings again and see how you like it. If you don't like the PQ of this S60, maybe you need to upgrade to a higher model that has better picture quality (ST60 or VT60)?
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #5 of 6 Old 06-22-2013, 09:11 AM - Thread Starter
Blokhead's Avatar
Are you sure about that?
Just a quick search, and I find this; "The new version 1017.1 firmware update is well worth it. It dramatically improved my PQ. Mainly much better white balance." here http://www.avsforum.com/t/1474305/samsung-pnxxf4500-owners-thread/0_50
Granted its for aPNxxF4500, but its still a Samsung plasma.
Anybody out there with a 42" care to tell me what their firmware number is?
Blokhead is offline
post #6 of 6 Old 06-23-2013, 02:58 PM
"Don't PM Me Bro"
Quoted: 521 Post(s)
Liked: 776
Yes, i'm positive.
Wait, you posted above that you have a Panasonic (S60) so i presumed that you have a Panasonic. My reply about the firmware pertains to the Panasonic S60, not any of the Samsungs.
Randy
Panasonic 42 Inch Plasma Hdtv Tc P42s60
