Panasonic ZT60 and VT60 Fan/Fridge Noise Production Numbers - Page 17 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #481 of 1544 Old 10-25-2013, 07:26 PM
merccrazy's Avatar
Quoted: 13 Post(s)
Originally Posted by Jeff_DML View Post
For those who had the fix installed
I have a tech coming out tomorrow morning. He has not installed a kit before, anything tricky on the install that I should watch out for? He says the kit comes with instructions.
TIA
jeff
Please copy the instructions and post. Thanks
Sammy2 likes this.
merccrazy is offline
post #482 of 1544 Old 10-25-2013, 08:46 PM
Bkultra's Avatar
roncruiser and merccrazy like this.
Bkultra is offline
post #483 of 1544 Old 10-25-2013, 09:09 PM
merccrazy's Avatar
Quoted: 13 Post(s)
Originally Posted by Bkultra View Post
Cool thanks
post #484 of 1544 Old 10-26-2013, 05:21 AM
guvadc's Avatar
Liked: 62
Originally Posted by mrajoel45 View Post
I am no longer positive that the noise that my set makes is the fans. The noise is louder when showing brighter content on the screen but even on bright screens it comes and goes. It is a buzz that seems to come from the lower right part of the screen and is relatively low in pitch.hCWpp
This is the "Plasma Buzz" that you hear about and not the fan noise. My set des the same thing.
guvadc is offline
post #485 of 1544 Old 10-26-2013, 06:24 AM
elitemikes's Avatar
I hear this as well, it doesn't really bother me as much as the constant fan noise
elitemikes is offline
post #486 of 1544 Old 10-26-2013, 06:31 AM
Sammy2's Avatar
Quoted: 558 Post(s)
Liked: 264
I guess you guys are unfortunate. I do not hear anything from across the room.
Maybe it was that Van Halen concert in 1980 and you guys are actually fortunate to have better hearing than I?
Sammy2 is offline
post #487 of 1544 Old 10-26-2013, 06:35 AM
Ronald Epstein's Avatar
Quoted: 104 Post(s)
Liked: 93
Is the fan problem solely related to the VT series or the ZT as well?
Ronald Epstein is offline
post #488 of 1544 Old 10-26-2013, 06:39 AM
Bkultra's Avatar
Both are affected as indicated by the picture of the instructions above (and title of this thread).
Bkultra is offline
post #489 of 1544 Old 10-26-2013, 08:42 AM
Jeff_DML's Avatar
TIA
jeff
Took him 30 minutes to install, seems like a pretty kludgy fix. Now I get to reinstall everything for my wall mount setup redface.gif
Jeff_DML is offline
post #490 of 1544 Old 10-26-2013, 08:55 AM
AVKIK's Avatar
Quoted: 22 Post(s)
Liked: 24
Let us know if it made a difference. Thanks.
AVKIK is offline
post #491 of 1544 Old 10-26-2013, 09:25 AM
Edllguy's Avatar
Quoted: 156 Post(s)
Liked: 69
Could someone please comment and describe the fan noise issue in terms of comparing it to other noisy devices? (Pre and Post foam fix)
For example, I still own the original 60gig PS3 and everyone knows how those fans turn on and can get loud. I got use too it and now it does not bother me as much. Any similarities?
Edllguy is online now
post #492 of 1544 Old 10-26-2013, 09:44 AM
Jeff_DML's Avatar
Definitely can still hear them from my 10 foot sitting position. I tried youtube via the smarttv which seems to bring out the worst of the fans. Initially I thought it at least reduced the noise but now I am not so sure mad.gif I have sound meter but it seems like it would be difficult to measure unless you are in a sound proof room.
Basically it doesn't make it worse getting the fix but not sure how much if any it actually reduces the noise level. My tv is in my family room which is open to the kitchen so I have a lot of various noises, fridge is worse. So the noise is ok with me in my environment but if I had a dedicated home theater room i would be tempted to return it.
I thought someone complained and got Panasonic to upgrade their VT to a ZT. Seems like for some people it would be worth to see if Panasonic will downgrade to the ST plus some money back to get away from the fans. I had my VT calibrated by D-Nice so I am sticking with it.
Jeff_DML is offline
post #493 of 1544 Old 10-26-2013, 11:30 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
I guess they went skimpy on thermal design. Your environment is just like mine, Jeff. I'd rather not fiddle with Panasonic support and have an unknown technician complete the "fix" and will instead just "suffer" through the noise until a 70" OLED for $3k arrives.
vinnie97 is offline
post #494 of 1544 Old 10-26-2013, 05:08 PM
ChuckAuger's Avatar
I think they just went with some crappy high RPM fans. Computer case fans come in a variety of fan blade style and RPMs, some can really move air silently with a lot less RPM than these fans.
If somebody could figure out what the fan voltage is - they look like like just 2 pin fans, not PWM - I bet a lower RPM yet similar (or even greater) CFM fan could be fitted.
Sammy2 likes this.
ChuckAuger is offline
post #495 of 1544 Old 10-26-2013, 05:21 PM
markjl's Avatar
Quoted: 18 Post(s)
Liked: 25
I wonder if the new units shipped from August on have different fans.
markjl is offline
post #496 of 1544 Old 10-26-2013, 08:36 PM
roncruiser's Avatar
If possible, anyone that has had there set opened please report the fan voltage. The fan voltage should be listed on the fan itself. (You can measure the fan voltage as well if you're properly set up to do so.) If any, note any information on the fan . Also, measure the outside dimensions of the fan. Length, width and height. If possible, measure the fan mounting holes: center to center.
With that information, a suitable fan replacement can be found.
I'd like to know more about the fan standoffs. What are they made of? Oscillations can occur if the fan mounts are not stiff enough.
Sammy2 likes this.
roncruiser is offline
post #497 of 1544 Old 10-26-2013, 08:49 PM
roncruiser's Avatar
Just noticed that the fans are only mounted at three points. Not good. If the fan standoffs are as soft as I suspect, oscillations are likely. It would have been better to have four mounting points rather than three. Especially, with soft rubber or silicone standoffs.
post #498 of 1544 Old 10-26-2013, 09:24 PM
Oppo Beta Group
RichB's Avatar
Quoted: 1273 Post(s)
Liked: 873
That is correct. The "sponges" stabilize the fan and remove the oscillation.
The fans are very quiet with the back off. The remaining noise seems to be coming from the air forced through the ventilation holes.
- Rich
Oppo UPD-205 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 | ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG 65C7 | Lumagen 2020
RichB is online now
post #499 of 1544 Old 10-26-2013, 09:27 PM
Oppo Beta Group
RichB's Avatar
Liked: 873
I'm entertaining the idea of doing the fix myself. How long did it take you to remove the back panel to access the fans?
Ron
It took about 10 minutes for the tech, you have to remove the stand, wireless, plug holder, and perhaps more. I do not recall.
Not a hove deal if you are comfortable with this type of thing.
- Rich
RichB is online now
post #500 of 1544 Old 10-26-2013, 10:07 PM
roncruiser's Avatar
Fan information:
post #501 of 1544 Old 10-26-2013, 11:10 PM
roncruiser's Avatar
Silicone sponge gasket in place of the foam strip "fix" should work as well or even better. I suspect, a full strip isn't even needed. Just a few well positioned small pieces to stabilize the fan should work well enough.
post #502 of 1544 Old 10-27-2013, 07:53 AM
NateTTU's Avatar
I have a tech coming this Friday to do the fan fix. My build date is July 2013 and based upon information in this thread it shouldn't have the fix already. Would they charge me if he came out and it already had the fan fix installed? I tried looking in, but like others mentioned I don't think it's possible to find out unless the back panel is removed and I don't really want to do that.
NateTTU is offline
post #503 of 1544 Old 10-27-2013, 07:59 AM
merccrazy's Avatar
Quoted: 13 Post(s)
Can somebody tell me if the back cover on the vt60 can be removed without removing it from the base stand? I know the vt50 can so I would think the vt60 should. Thanks
post #504 of 1544 Old 10-27-2013, 08:36 AM
Jeff_DML's Avatar
You told panasonic your serial number right? Their problem if so
Jeff_DML is offline
post #505 of 1544 Old 10-27-2013, 08:42 AM
NateTTU's Avatar
Yes
NateTTU is offline
post #506 of 1544 Old 10-27-2013, 03:41 PM
roncruiser's Avatar
Well, we are scheduled for an exchange this week. Crossing my fingers with the hope I get a relatively quiet TV. What a drag.
Received the replacement set this morning. No different than the last set in terms of noise. Same June build date as the previous one. Serial number is less than the previous one. Funny.
Well, if you can't beat them, join them. Something like that.
At least I tried. If I can't do the fix myself without voiding the warranty, I'll arrange for someone to come out and do the fix.
Ron
post #507 of 1544 Old 10-28-2013, 04:43 AM
hfc23's Avatar
I too have fan noise and decided to put tape over the vents leaving three rows of vent holes visible. Problem solved no noise. I still have ample air being pushed out of vents and have had set running for hours and is only warm on back cover.
hfc23 is offline
post #508 of 1544 Old 10-28-2013, 07:14 AM
Sammy2's Avatar
Quoted: 558 Post(s)
Liked: 264
The only time I have heard any noise is when the source is off. I think you guys are making more out of this than is really there. I have four fans cooling my equipment enclosure that make a little noise too. I much prefer a little bit noise than overheated expensive electronics.
Slowing down these fans could work though because they are of excessive CFM for the conditions so a lower RPM could go a long way to quite these things down. A resister in the positive lead could do the trick.
roncruiser likes this.
Sammy2 is offline
post #509 of 1544 Old 10-28-2013, 10:19 AM
ChuckAuger's Avatar
Fan information:
Thanks for the pic, looks like they are 4 wire fans, I thought I saw what looked like a 2-wire lead in one of the pics above.
post #510 of 1544 Old 10-28-2013, 10:28 AM
fmalczewski's Avatar
Quoted: 131 Post(s)
Liked: 50
Just the vents over the fans? Which three rows?
fmalczewski is offline
Panasonic , Panasonic Viera Tc P60zt60 60 Inch Plasma Tv , Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv , Panasonic Viera Tc P65zt60 65 Inch Plasma Hdtv
