Panasonic ZT60 and VT60 Fan/Fridge Noise Production Numbers - Page 47 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #1381 of 1544 Old 04-27-2014, 07:46 PM
pafalzon's Avatar
Originally Posted by pafalzon View Post
Just an update. The retailer was good enough to offer me a replacement unit today. Fingers crossed this one is not a dud. I take delivery of the replacement in 2 days time. Not looking forward to re-boxing the old one and having to setup the new one.
Received my replacement 55VT60A on the weekend. I have decided to run it or Normal mode when I am watching free to air TV and Foxtel and THX Cinema when I am using my PS3 for Movies and TV series.
After watching approx 6 hours of sports over the weekend I can confirm that there is no image retention or burn (phew). I also updated to the latest Viera Firmware last night
The fan noise is still present and just as loud as the previous unit I owned. The first unit was a October 2013 build and the replacement a July 2013. Both of them are identical from what I can see as there is no foam fix visible on either of them. The question I am asking my self now is do I proceed with the service technician fan foam fix or not? I am still using the cardboard vents I made which cut out approx 30% of the noise.
Panasonic P55VT60, PS3, Apple TV, ReadyNAS Ultra2+, Logitech Z5500, Sennheiser RS170
pafalzon is offline
post #1382 of 1544 Old 04-27-2014, 09:39 PM
myared's Avatar
Liked: 26
Originally Posted by vinnie97 View Post
My fans never changed in intensity or volume...the only determining factor as to their audibility is ambient noise in the room. I will probably have mine done this week.
Vinnie, I'll be eagerly awaiting your comments on the experience, and most importantly the result and if it was worth the risk to the TV. Thanks in advance and good luck with the fix.
myared is offline
post #1383 of 1544 Old 05-05-2014, 01:40 PM
S T I G's Avatar
I called Panasonic to have the fan noise fixed on my VT60. They gave me the local companies contact info who would do the work. Today I called the repair company and they said they only repair at their facility and would have to take my TV!
anyone else have this happen? I'm not letting them take my TV for a repair that takes a few minutes. They seemed to not even know what the repair procedure is when I asked them about it.
S T I G is offline
post #1384 of 1544 Old 05-05-2014, 01:49 PM
S T I G's Avatar
And whats this about causing hairline cracks?
S T I G is offline
post #1385 of 1544 Old 05-05-2014, 01:53 PM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
If it's a 42" then they will want to take it. That's been common for years, not sure if things have changed. Of course your tv is larger. It would take longer to load it up then fix it with potential for scratches:eek: That should have in home repair as far as I know, maybe you should call panasonic and have them forward the service bulletin.
S T I G likes this.
whipit is offline
post #1386 of 1544 Old 05-05-2014, 01:55 PM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
If the ZT's back panel is installed improperly it will crack the front glass. I think the bulletin was posted in this thread. That issue applies only to the ZT
S T I G likes this.
whipit is offline
post #1387 of 1544 Old 05-05-2014, 03:45 PM
Herman8or's Avatar
Quoted: 16 Post(s)
STIG: here's just my 2-cents on your comment. DO NOT LET A TV REPAIR COMPANY TAKE YOUR ZT PLASMA OUT FROM YOUR HOUSE! That fan noise repair and kit install can be done in house, safely, and with you keeping a careful eye on their work. I've ordered some parts & materials to complete a DIY fix I've been working on & designing, and will be posting it on this thread as soon as it's completely finished.
I hope you find a company that will do the work inside your own house. That is the only way I would do it,...but that's just my opinion.
Herman8or~
S T I G likes this.
Herman8or is offline
post #1388 of 1544 Old 05-05-2014, 04:23 PM
S T I G's Avatar
Going to call Panasonic back this week. I'll post here what I end up with.
S T I G is offline
post #1389 of 1544 Old 05-05-2014, 04:44 PM
Herman8or's Avatar
Quoted: 16 Post(s)
STIG: out of curiosity, do you know the Build Date in your Plasma? Forgive me, but I haven't read all your posts yet, but what exact Model of Panasonic Plasma do you own?
Herman8or~
post #1390 of 1544 Old 05-05-2014, 07:12 PM
S T I G's Avatar
May. 65VT60
S T I G is offline
post #1391 of 1544 Old 05-05-2014, 07:40 PM
Herman8or's Avatar
Quoted: 16 Post(s)
ZT FAN NOISE: as there are many people who have had issues with fan noise from ZT's as well as VT's, I, along with some others have made comments as to venting holes, and lack of them, causing both poor ventilation and possible noise due to fans pushing air out of the poorly designed back panel. Just in case your interested, Google "Pictures of Rear Panel of Panasonic VT, ST, S, models" from previous model years. If you look at those previous model years, you will notice a distinct difference in the location, but more importantly, the number of ventilation hole patterns on the rear panels and especially across the top of most rear panels. I mention this just as an observation I thought some of you may find both interesting and helpful? I will be having the fan kit installed in my ZT, and as promised, will post pictures of technicians work on those fans. After that, hopefully my fan noise will be reduced enough? If not, I will then post pictures of what I call, my Mini Acoustic Panel, that also reduces fan noise. Finally, no one likes having the rear panel removed from their Plasma. In the final scenario, I may use a special Dremmel tool and bit to drill out ventilation holes that match the patterns on previous generations of Panny Plasmas, 2012, 2011, etc. I just thought I'd post this observation and my opinion in case it's of any interest to some of you?
Herman8or~
post #1392 of 1544 Old 05-06-2014, 07:32 AM
eric3316's Avatar
Quoted: 841 Post(s)
Liked: 959
Herman8or~
There are no fans in anything below the VT series. I am not even sure the VT50 had fans built in and if it was new to 2013 models on the VT and ZT. The ST60 and S60 do not have any fans and that would be for earlier years as well.
eric3316 is offline
post #1393 of 1544 Old 05-06-2014, 08:45 AM
chunon's Avatar
Quoted: 2131 Post(s)
Liked: 1865
The 65" VT50 had fans, the 55" did not.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #1394 of 1544 Old 05-06-2014, 02:21 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Finally, at the 11th hour (month, more specifically) I had er' done! I will be intently watching for any signs of crackage over the next 3 weeks. I helped the tech, and I think we got her back in the groove successfully. As others have stated, there is maybe a 50% reduction in sound. Not sure it was worth all the trouble, and it doesn't leave me too exuberant about purchasing future Panasonic products when they take such a blatant engineering shortcut. Better than overheating but not very conducive to a home theater and the volume dynamics of movies.
vinnie97 is offline
post #1395 of 1544 Old 05-06-2014, 05:30 PM
eaayoung's Avatar
Quoted: 209 Post(s)
Liked: 134
50% reduction is not to shabby of a reduction.
eaayoung is offline
post #1396 of 1544 Old 05-06-2014, 06:16 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
soytainly, but the stress and fear of damaging the panel offsets the somewhat minor improvement, along with the fact that I had to help lift it off and back onto the TV stand (my tendinitis and trigger finger have made me considerably weaker, so it was no easy task) and cut my finger on the razor sharp metal of the back cover itself as we removed it. Finally, one of the screws near the bottom wouldn't even line up properly so as to be screwed back in, so it will be interesting to see what happens to the glass in the coming weeks.
vinnie97 is offline
post #1397 of 1544 Old 05-08-2014, 08:24 PM
pafalzon's Avatar
Getting my 55VT fan fix applied right now. The service technician is also adding the neoprene washers I supplied to reduce the play in the fans mounting. FYI he has replaced both Fans and added two strips to the SC fan only. Ill have a good listen once the job is done. Hopefully some improvement.
Seems like a pretty simple job. Getting the back cover off seemed fairly easy and I could not see any risk of damage etc.
pafalzon is offline
post #1398 of 1544 Old 05-09-2014, 12:26 AM
pafalzon's Avatar
Ok so its been a few hours and the first thing I will point out is that the noise is still there and not completely gone. What has changed is that the noise is reduced and not as noticeable as before. Im guessing about 30-40% noise reduction. Overall I'm pretty happy with the result.
pafalzon is offline
post #1399 of 1544 Old 05-09-2014, 06:17 PM
Calilife17's Avatar
Quoted: 21 Post(s)
So I got my ZT60 back in June 2013. I have been debating on if i should get the Kit or not before the Warranty runs out. Now about reading these stories about Cracked Glass, and knowing this TV isn't made anymore, i am starting to think that i wont get the fix, and avoid having anyone touch my TV. Maybe i will wait till the warranty is up, and create more holes in the back panel, or make them bigger.
I am in the Bay Area in Mountain View, let me know if anyone in the general area has had the Fix done to their TV as well. Gotta decide if i want to get it done or not.
Theater Room: 65ZT60, Denon AVR-X6300H, Oppo 103D, Apple TV4, Harmony Elite
Bedroom: 65VT50, Sony S790, Roku 4, Apple TV4, Harmony Ultimate
Man Cave: Vizio P75, Harmony Elite, Apple TV4, Shield, Roku Ultra, ChromeCast Ultra, Xbox One S, PS4 Pro, Wii U,Intel Skull Canyon & about 20 more game consoles
Calilife17 is offline
post #1400 of 1544 Old 05-09-2014, 11:11 PM
jlgoa's Avatar
Hi all,
I am new here. As a lot of you, my Tx-P55vtw60 has noisy fans. I found a lot interesting info from all of you and try to apply them. But before removing my tv from my wall and opening the back panel, I would to know if it is possible to see the build date from the menu of the tv? Or should I detached it from the wall? Thanks.
jlgoa is offline
post #1401 of 1544 Old 05-10-2014, 08:08 PM
eaayoung's Avatar
Quoted: 209 Post(s)
Liked: 134
Sets manufactured for the North American market have a sticker located on the back panel which has the build date printed on it.
eaayoung is offline
post #1402 of 1544 Old 05-10-2014, 08:44 PM
Jason626's Avatar
Quoted: 157 Post(s)
Liked: 152
In NA the first five digits on serial number will tell the year and day in numbers. Like #13254xxxx it would be the 254 day on year 2013.
Jason626 is offline
post #1403 of 1544 Old 05-10-2014, 08:56 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
The first four digits will give you the information. Like 3254xxxx would be the 254th day in year 2013.
Larry
LarryInRI is offline
post #1404 of 1544 Old 05-10-2014, 09:09 PM
Jason626's Avatar
Quoted: 157 Post(s)
Liked: 152
Larry
Thanks for the clarification Larry. I started writing the first four digits then I deleted it. I shoulda went with my first thought.
Jason626 is offline
post #1405 of 1544 Old 05-10-2014, 11:40 PM
jlgoa's Avatar
Thanks a lot, I will have look at it. But I doubt my tv has the fix cause I can here the fan in my entire living room which measure 9m long!
jlgoa is offline
post #1406 of 1544 Old 05-11-2014, 06:40 AM
TorinoCobra's Avatar
I don't think the build date is available in any menu. I was in the same situation as you. I had already mounted my TV on the wall, so I was unable to see the build date under the mount. Fortunately, my mount pulls out from the wall and pivoted enough that I was able to loosen one side/corner of the mount enough to pull it back and read the tag using a flashlight.
As stated in the last few posts, the fan noise will still be there even with the factory fix in place. Mine has the factory installed fix and it still annoys me almost every night. I'm following this thread in hopes that someone comes up with a miracle cure! smile.gif
TorinoCobra is offline
post #1407 of 1544 Old 05-11-2014, 03:48 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
jlgoa,
Check the very right hand rear of the unit about half way down. You may find a tiny black sticker there that has the serial number. (Right hand side looking at the screen.) If there is a sticker, you can calculate the date from s/n info described in the posts above.
Larry
post #1408 of 1544 Old 05-11-2014, 05:45 PM
fmalczewski's Avatar
Quoted: 102 Post(s)
Liked: 39
The serial number should be on the shipping box too. That said, swiss (european) sets use a different serial number scheme, so you may have to dig a bit further back (in this thread?) to find how theirs correspond to manufacture date. (Also, swiss sets may not have manufacture date on the backside sticker.)
Somebody not all that long ago (from Netherlands?) had the fix done, a month or two ago. May want to check the last few pages...
fmalczewski is offline
post #1409 of 1544 Old 05-11-2014, 06:01 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
Larry
post #1410 of 1544 Old 05-11-2014, 06:03 PM
eric3316's Avatar
Quoted: 841 Post(s)
Liked: 959
What was the volume measured at without the fix and after the fix. I have a projector that measures about 30db and sits right above my head. You can definitley hear it but it eventually just gets lost in the sound.
Just curious how loud these fans are compared to that.
eric3316 is offline
Panasonic , Panasonic Viera Tc P60zt60 60 Inch Plasma Tv , Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv , Panasonic Viera Tc P65zt60 65 Inch Plasma Hdtv
