Panasonic ZT60 and VT60 Fan/Fridge Noise Production Numbers - Page 51 - AVS | Home Theater Discussions And Reviews
post #1501 of 1523 Old 09-05-2014, 03:38 AM
fmalczewski's Avatar
Quoted: 42 Post(s)
Originally Posted by Tony1 View Post
I'm probably going to take the back cover off this weekend,, I'm just going to add the washers, and the foam, then before i hang it on the wall, I will probably tape a piece of felt on the wall right it,hoping it might deaden the sound a bit. At this point, that is all I can really do, and if all that reduces the oscillating and overall fan noise by 50% I'd be ok with that..
Just be sure to put the back on properly again (I'll leave digging up the memos on how to do this in this thread as an exercise to those not on the verge of going to bed.)
I need to do the same, been noticing my still pretty much off the shelf fan noise a bit recently again, so should just get it over with and done. (Have the official fan fix foam, and the washers.)
fmalczewski is online now
post #1502 of 1523 Old 09-06-2014, 12:35 AM
Tony1's Avatar
Quoted: 31 Post(s)
I will.. thanks.. Looks as if it won't be done this weekend, as i went to the home depot and they literally had almost no foam strips in stock, and the few that were, were a weird size,.. I don't know how that place stays in business. I may need to order the foam strips from panasonic as you did, or something similar online..
Panasonic GT50 55"
Pansaonic VT60 60"
Tony1 is offline
post #1503 of 1523 Old 09-12-2014, 11:28 PM
Tony1's Avatar
Quoted: 31 Post(s)
After installing the foam and washers, I would have to agree with what the majority on here are saying, in that it reduced the fan noise by about 50%.. The way it is now, you have to be listening for it to really notice it where as before you would just hear it right away. I feel its acceptable now.. The rear panel is very easy to remove, i believe there are 43 screws in total that need to come off.. I did it while it was on the stand, and by myself.. I don't feel that you need 2 people to do it.. I used a couple of strips of blue painters tape at the top, so just in case when i removed all the screws the panel wouldn't come loose and fall., you can also use the tape to secure it a bit as you reinstall the rear panel.
fmalczewski likes this.
Panasonic GT50 55"
Pansaonic VT60 60"
Tony1 is offline
post #1504 of 1523 Old 09-14-2014, 06:16 PM
jimshowalter's Avatar
Quoted: 38 Post(s)
Liked: 46
If anyone is interested in cooling the panel, and doesn't have access to an infrared camera (and boy, are they expensive, even to rent!), you could try what I tried.
Cole Parmer carries 25-packs of little thermal strips: "Reusable 7-Point Horizontal Adhesive Temperature Label, 86-140F; 25/Pk EW-90308-30".
You stick these on the back in columns in the areas known to be hot, and can see the heat map directly just by looking at the back of the panel.
My system? Google for: Martin Logan 420 CLX Descent Stage Summit
jimshowalter is offline
post #1505 of 1523 Old 09-15-2014, 01:11 AM
Tony1's Avatar
Quoted: 31 Post(s)
I can just feel which parts of the panel get the hottest with my hand, but how would you be able to cool it further?
Panasonic GT50 55"
Pansaonic VT60 60"
Tony1 is offline
post #1506 of 1523 Old 09-25-2014, 12:35 AM
texuspete00's Avatar
I must have really wanted to feel like it made a huge difference when I got the foam fix on my set 7 months ago... or forgotten how loud it was then. It has been driving me bonkers lately. I keep torturing myself by reading this thread every time I'm near smashing the stupid thing trying to figure out what I want to do.
texuspete00 is offline
post #1507 of 1523 Old 09-26-2014, 03:01 AM
Tony1's Avatar
Quoted: 31 Post(s)
some ppl here claim that covering a couple of rows of holes, make it quiet down..
Panasonic GT50 55"
Pansaonic VT60 60"
Tony1 is offline
post #1508 of 1523 Old 10-08-2014, 08:12 PM
hgutle's Avatar
Liked: 0
My ZT60 didn't have any of the fan noise or other issues listed in the thread - I was a happy camper until 3 weeks ago. We moved to a new house - my "baby" was carefully stowed in it's original packaging and moved carefully to the new location. Alas, this is when the problems started. The set begun to emit plasma buzzing to an extent where you can here it when watching TV shows with normal volume from 8 feet away - it obviously gets louder the brighter the screen is. It definitely didn't buzz in my old house. I tried unplugging my surge protector like other people have suggested and plug the TV directly into the outlet but to no effect. I called Panasonic and got a repair guy assigned to case who showed up 2 days later. He checked all the screws on the boards (which seemed to have been an issue in the past) but they were all tight. He also checked the boards and concluded that it's the panel itself that creates the buzzing. He took a dB measurement with his iPhone - apparently with an app that Panasonic has approved - and the reading was 32dB with Standard settings and 34dB with THX Cinema 3 feet away. Unfortunately, these readings are below Panasonic's threshold for a warranty claim so there is nothing to do. I will try and do my own dB reading since the buzzing is so annoying that 34dB seems low to me - although the dB scale is always tricky to judge by. That being said, does anyone have any other ideas for reducing the plasma buzzing or am I stuck with this?
hgutle is offline
post #1509 of 1523 Old 12-15-2014, 08:31 AM
Mean Gene's Avatar
Originally Posted by Calilife17 View Post
So I got my ZT60 back in June 2013. I have been debating on if i should get the Kit or not before the Warranty runs out. Now about reading these stories about Cracked Glass, and knowing this TV isn't made anymore, i am starting to think that i wont get the fix, and avoid having anyone touch my TV. Maybe i will wait till the warranty is up, and create more holes in the back panel, or make them bigger.
I am in the Bay Area in Mountain View, let me know if anyone in the general area has had the Fix done to their TV as well. Gotta decide if i want to get it done or not.
I am in the same boat, my 1 year is coming up and I have been putting the repair off because I don't want anybody touching my tv. I have the surround sound cranked 90% of the time so the "noise" is always drowned out. The fact that if anything happens to it and not being able to get a replacement is my driving factor in leaving it be...
Mean Gene is offline
post #1510 of 1523 Old 12-15-2014, 09:03 AM
Liked: 0
The PC enthusiasts I have have got function with comparatively low highest pace. If the TV might spin the actual fans to max pace this may not generate much more noise than the standard followers. The actual 11 flashesI can easily stay with. I wish to give it the try shortly.
aboveave is offline
post #1511 of 1523 Old 12-15-2014, 04:18 PM
merccrazy's Avatar
What he say????
merccrazy is offline
post #1512 of 1523 Old 12-22-2014, 09:58 AM
myared's Avatar
Liked: 26
I'm there with you guys too. My TV fans are really loud but I didn't want to get the fan fix until I had given myself the full year of factory warranty to see if I got used to the noise before I let anyone touch my TV. Well, after a whole year of owning the TV, I'm afraid I never got used to the noise. Of course it also doesn't help that we have the TV in our bedroom where I have to watch it sometimes at low volume which is pretty much impossible with the fan noise. So a few minutes ago, I bit the bullet and called Panasonic (on my last factory warranty day) and scheduled the repair for Tuesday.
Anyone in the Houston area who's had the repair done by Video Repair Place Ltd. has any comments about the service they received?
Also, I got the "prescribed" washers. Should I have the repair person install them; do they make a significant difference?
myared is offline
post #1513 of 1523 Old 12-22-2014, 11:42 AM
Quoted: 42 Post(s)
No reason not to. Even a little difference would be better than none, especially since you spent the money to get them.
Just make sure s/he gets the cover back on correctly.
post #1514 of 1523 Old 01-05-2015, 08:45 PM
icyykv's Avatar
Solution Found
Hello All,
I have found a solution to the fan noise. It has been ok for the past few days. The noise has been cut down by 95%. I had some vacuum filters around the house for my Kenmore canister. I took 2 and covered it over the 2 fans and taped all sides with tape without blocking the actual vent of the fans.
The part is Kenmore CF-1 Canister Secondary Filter. Attach the white fabric layer onto the TV and the filter faces out. The air will still flow through the filter thus not cause any heat issues.
Good luck.
MarkB432 likes this.
icyykv is offline
post #1515 of 1523 Old 01-05-2015, 09:56 PM
eaayoung's Avatar
Quoted: 101 Post(s)
Liked: 77
I'm sure they look better than the toilet plungers.
eaayoung is offline
post #1516 of 1523 Old 01-05-2015, 11:03 PM
Herman8or's Avatar
Originally Posted by icyykv View Post
Hello All,
Good luck.
Icy; sounds like you have a good idea...thinking outside of the box, so to speak! I was wondering if by chance you could post some pictures as to exactly how you have your filters set up and attached? It would be most helpful & greatly appreciated. I still have fan noise, but mine is still under warranty. I'm just very, VERY, learly about some 2nd party repair guy messing with my ZT60 and causing a problem far worse. If they were to screw it up, say "micro-fractures" then there are no high end Plasmas to replace it with. Thanks in advance for any help & photos. If you can't post pictures here, maybe a YouTube video titled "Panasonic Fan noise fix". I'm certain you'd get thousands of hits on it for sure!😃👍. Peace out.
Herman8or~
Herman8or is offline
post #1517 of 1523 Old 01-06-2015, 01:23 AM
Quoted: 42 Post(s)
Hello All,
Good luck.
Are these the ones that are white on the one side and black (foam?) on the other (filter?) side? (Looking at an ebay picture of one.)
Worth a try… worst case, I can use them in my vacuum cleaner.
post #1518 of 1523 Old 01-06-2015, 09:46 AM
icyykv's Avatar
Problem Resolved Pictures
Hello,
I have attached some pictures of the fix as requested.
The white side faces the TV..be sure to center the pads as to not
block the vent holes.
Hope this helps.
icyykv is offline
post #1519 of 1523 Old 02-01-2015, 09:06 PM
myared's Avatar
Liked: 26
OK, it's been a month now since I've had the fix done on my ZT. The result is similar to what has already been described here; about a 50% reduction in the fan noise. Also, there still is some fridge-like humming but it's definitely not as loud. I'm glad I had the knowledge of the experience of others on this forum to know what to expect. I would have expected a more significant decrease in the fan noise otherwise and I would have been disappointed... Anyway, I can now watch the TV at low volume in our bedroom and that's what I wanted achieved.
Needless to say, I was watching the repair guy like a hawk when he was putting the back of the TV on again. He was also familiar with the issue, so he went over the edge of the back of the TV several times to make sure it's tucked in appropriately with no bumps anywhere. So far so good, fingers crossed...
Thank you guys for the wonderful information on this forum. It sure made dealing with this issue much less stressful.
myared is offline
post #1520 of 1523 Old 02-08-2015, 06:26 PM
Quoted: 42 Post(s)
Hello,
Hope this helps.
Having just the other day swapped out hd-dvrs, it became painfully obvious just how much noise the old one had produced. It was certainly annoying, the spinning disk being the main, probably the only, culprit. And it seemed to be spinning most of the time -- regardless of its energy savings setting -- and generated quite a bit of heat as well.
Well it turns out the new one is dead quiet, I can't even tell it's running any more, except by looking at the front panel for any lights. (Also seems like my random audio/video dropouts may have gone away, but haven't given it quite a thorough workout just yet... the installer might have also swapped out the dish's lnb.) Why did I wait so long for my free equipment upgrade? If the next 2 years are anything like that last 2 days, I'll be a pretty happy camper (although the IR from the directv menus etc will probably continue to put a damper on that at least some).
But all of this made it painfully obvious that my (still official Panasonic noise-fix-free) 65ZT60, now the sole remaining noise generator of my home theater, needed to finally be addressed. So I just applied this filter mod and it's running quieter already. (Guestimate off the bat is maybe 60-70% quieter, but that's just at first "glance", could be more). I used black electrical tape around the perimeter of each, by the way.
So, so far, so good. Anything further to report, icyykv? Seems like it would be wise to check them every so often for signs of dust accumulation.
(Edit: Turns out my rarely used, or even plugged in, HD-DVD player (Toshiba HD-XA2) is pretty noisy even when it's just turned on and idle. Probably would drown out anybody's ZT60.)
post #1521 of 1523 Old Today, 08:55 AM
krismate's Avatar
Hello All,
Good luck.
Hello,
Hope this helps.
Hi,
I don't quite understand what you mean by not blocking the vent holes/vent of the fan? The pads are bigger than the fans and they go over the entire fan grill/vent holes. Also, do these not reduce air flow a bit? When I put a pad on my hand and press it up against where the fan is mounted, I can't feel any air moving through.
--Thanks
krismate is online now
post #1522 of 1523 Old Today, 08:57 AM
TornadoTJ's Avatar
Quoted: 208 Post(s)
Liked: 83
Has anyone tried blowing out the system with compressed air through the vent holes, so that the back of the TV doesn't have to be pulled off to resolve the noise?
TornadoTJ is online now
post #1523 of 1523 Old Today, 10:48 AM
Quoted: 42 Post(s)
Originally Posted by krismate View Post
Hi,
--Thanks
He means don't put tape over where the vent holes are, stick to the perimiter of the pads. And it does seem like you say with the air flow... at this point I just have some of the corners taped down... (furnace has been running a lot lately so hard to say how effective a fix it still is, but it still seems to be working, else I probably would have noticed at some point).
Panasonic , Panasonic Viera Tc P60zt60 60 Inch Plasma Tv , Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv , Panasonic Viera Tc P65zt60 65 Inch Plasma Hdtv
