Panasonic ZT60 and VT60 Fan/Fridge Noise Production Numbers - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #1 of 1544 Old 06-21-2013, 04:59 PM - Thread Starter
Lost!'s Avatar
Liked: 33
Some ZT60/VT60 owners are experiencing audible fan noise, which is like having a fridge working in your room. In this thread, we will post some production numbers, in case if someone from panny decides to investigate the problem. You can post your pr# here, and I will update the appropriate post with your info.
Update:
It is now confirmed that all VT and ZT units are affected with the so called fan/fridge noise to some extent. As confirmed by the AV UK thread, this noise is due to the design of the back panel and not the fans in particular. The air flow through the back panel makes the noise, and the units with back panels removed do not make any noise. However, it is worthy to mention that the noise depends heavily on the room dimensions and surrounding materials, and many did not experience ANY sort of noise with their fans.
The Fix:
Those who experienced the noise, never could get a healthy unit through exchanges and returns. Panasonic has a fix that is a set of foams to be installed between the fans and the back panel. According to those who went through Panasonic repair, the foams DO reduce the noise, but the updated units are no where near silent.
Latest Update:
As confirmed by a few members, now the foam fix is being done at the factory. Any built date after July 2013 should have the fix pre-installed. If you have an earlier build, you can call Panasonic, and they will send a technician to install the foam fix.
Marc Wielage likes this.
Lost! is offline
post #2 of 1544 Old 06-21-2013, 05:00 PM - Thread Starter
Lost!'s Avatar
Liked: 33
Some ZT60/VT60 owners are experiencing audible fan noise, which is like having a fridge working in your room. In this thread, we will post some production numbers, in case someone from panny decided to investigate the problem. You can post your pr# here, and I will update the first post with your info.
- AFFECTED UNITS
Pr# : Pr Date : User : exchanges : Issues
ZT60:
A00217 : April 2013 : Bigmoviegan : first unit : fan noise
A00269 : April 2013 : marcj9680 : first unit : cnst. whirring fan/fridge noise / buzzing
A00449 : April 2013 : Sensui : first unit : constant fan noise solved with diffuser
A00653 : April 2013 : Lost! : first unit : Fan / Fridge Noise
E00775 : n/a : Sverddrager : 1st unit : 60" fan/fridge noise
A01132 : May 2013 : vinnie97 : first unit : fan noise/whirring/pulsating when quiet.
A01283 : May 2013 : Dasanii19 : first unit : fan noise
A01387 : May 2013 : Goosedizzel : first unit : fan noise
A01925: May 2013 : Skoor : first unit: Audioble Fan/Fridge Noise
A02387 : May 2013 : TWD : second unit : Audioble Fan/Fridge Noise
A02488 : May 2013 : bradhs : first unit: Fan Noise
A02608 : May 2013 : iChristopher : 2nd unit : fan noise
A02732 : May 2013 : elambo : 1st unit : fan noise
A04763 : n/a : johnBoston123 : 1st unit : fan noise
A05340: June 2013 : Lost! : 4th unit : fan/fridge noise + hairline cracks
A05352: June 2013 : Lost! : 3rd unit : same fan/fridge noise + dented pedestal
A05354: June 2013 : Lost! : 2nd unit : same fan/fridge noise + V. Banding on Right!
A056xx : June 2013 : davoe : 1st unit : Fan Noise (whining)
A05692 : June 2013 : hdqboss : 1st unit : Fan Noise
VT60:
- n/a - : May 2013 : TWD : first unit : Audioble Fan/Fridge Noise
- n/a - : May 2013 : smurraybhm : first unit : Audioble Fan/Fridge Noise
MK30980102 : April 2013 : Ace_BB6 : first unit : Fan Noise
Lost! is offline
post #3 of 1544 Old 06-21-2013, 05:00 PM - Thread Starter
Lost!'s Avatar
Liked: 33
- UNITS WITHOUT SYMPTOMS
ZT60:
A00022 : April 2013 : Praktik : first unit : no issue
A00066 : April 2013 : Dogger1 : first unit : no issue
A00545 : April 2013 : Sammie2980 : first unit : no issue
A00918 : May 2013 : mattestarr : first unit : no issue
A01510 : May 2013 : repete66211: first unit : no issue
A02171 : May 2013 : Dr Harford : first unit : no fan noise, but banding on right
A02299 : May 2013 : Yaomizzle : first unit : no issue
n/a : May 2013 : sirh : first unit : no issue 60"
VT60:
n/a : n/a : mAdCapper : first unit : fan audible only on mute and 3' range
Lost! is offline
post #4 of 1544 Old 06-21-2013, 05:00 PM - Thread Starter
Lost!'s Avatar
Liked: 33
Reserved...
PaulDuBious likes this.
Lost! is offline
post #5 of 1544 Old 06-21-2013, 05:26 PM
TWD
TWD's Avatar
Quoted: 46 Post(s)
Liked: 36
You probably should make this a ZT/VT thread
hazel_wu likes this.
TWD
TWD is offline
post #6 of 1544 Old 06-21-2013, 06:17 PM
TWD
TWD's Avatar
Quoted: 46 Post(s)
Liked: 36
Unkn. May 2013. TWD First unit (VT60) Fan Noise
A002387 May 2013 TWD Second unit (ZT60) Fan Noise
TWD
TWD is offline
post #7 of 1544 Old 06-21-2013, 08:00 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
May 2013, #AO1132 (ZT60), does exhibit fan noise/whirring/pulsating when the surrounding environment is quiet.
vinnie97 is offline
post #8 of 1544 Old 06-21-2013, 09:22 PM
smurraybhm's Avatar
Quoted: 1469 Post(s)
Liked: 1760
60VT60 - no fan noise unless you place head behind display. No buzz no banding. Great picture. Not much to see at this home, move along.
RIP Cricket - my pug and little buddy Jan. 10, 2017
Panasonic 60VT60 (cal by DNice)
Ascend's with RAAL, Love my PSA v1800 and a 7.2.4 speaker config, Oppo 203 w/ 2500+ blu-rays and growing. Yes I still have HD-DVDs too.
smurraybhm is online now
post #9 of 1544 Old 06-21-2013, 09:44 PM - Thread Starter
Lost!'s Avatar
Liked: 33
Great! Good to hear not all units are bad. Unfortunately, we were not as lucky as you are.
Lost! is offline
post #10 of 1544 Old 06-21-2013, 09:48 PM
mattestarr's Avatar
ZT60:
A00918 : n/a. : mattestarr : first unit : no issue
VT60:
My build was May 2013
Panasonic 60ZT60 3DTV
Pioneer Elite VSX-70
Bowers & Wilkins 686 Fronts
Definitive Technology 8060HD Center
Definite Technology Pro Monitor 800 Sides
KLH bassbite 2 Sub (needs an upgrade)
PS3 for blu-rays
Xbox 360 for games
DirectTV & Netflix for content
mattestarr is offline
post #11 of 1544 Old 06-22-2013, 06:31 AM
CHASLS2's Avatar
Quoted: 354 Post(s)
Liked: 125
Same for my new 60vt60. No buzz and only hear a little fan hum on mute.
Panny 60VT60 Acurus 200x3
OPPO 83 &103
Pioneer Elite DV 59AVI
Paradigm 490cc B&W 685 S2's
Pioneer Elite SC61 SVS SB13Ultra
2 S-VHS VCR's B&W CM10 S2's
CHASLS2 is offline
post #12 of 1544 Old 06-24-2013, 11:13 PM
marcj9680's Avatar
A00269 (ZT60) : April 2013 : marcj9680 : first unit : constant whirring fan/fridge noise audible during quiet passages : buzzing is very noticeable during bright scenes
marcj9680 is offline
post #13 of 1544 Old 06-25-2013, 04:26 PM
TWD
TWD's Avatar
Quoted: 46 Post(s)
Liked: 36
- AFFECTED UNITS
ZT60:
VT60:
A002387 : May 2013 : TWD : second unit : Audioble Fan/Fridge Noise
Unit A002387 is a ZT60
TWD
TWD is offline
post #14 of 1544 Old 06-26-2013, 05:35 PM
praktik's Avatar
I'm April 2013
praktik is offline
post #15 of 1544 Old 06-26-2013, 06:36 PM - Thread Starter
Lost!'s Avatar
Liked: 33
Originally Posted by praktik View Post
I'm April 2013
You are one of the lucky ones too wink.gif You should buy a lottery ticket!
Lost! is offline
post #16 of 1544 Old 06-26-2013, 08:57 PM
defjamz's Avatar
Quoted: 43 Post(s)
Liked: 113
Dumb question - where do I find the production number?
I see the serial number on the back, and the production date, but I can't find the production number that begins with 'A'.
Rec Room: Sony 75X940C/Yamaha A1050/Oppo UDP203/Klipsch RP280F, RP450C, RP140 Atmos, Definitive SM350/SVS SB2000/PS4
Living Room: Sony 75X940D/Yamaha A730/Samsung K8500/Definitive BP8040, BP6/Martin Logan Dynamo1000/Xbox One S
Bedroom: Samsung 75HU8550
defjamz is offline
post #17 of 1544 Old 06-26-2013, 09:14 PM
praktik's Avatar
Striking out on the hospital lottery, maybe I used up my luck!
Lost! likes this.
praktik is offline
post #18 of 1544 Old 06-27-2013, 06:38 AM - Thread Starter
Lost!'s Avatar
Liked: 33
It is in the back of dark grey/brown folder that came in with your set under the empty card slot. Starts with A0xxxx.
defjamz likes this.
Lost! is offline
post #19 of 1544 Old 07-10-2013, 03:22 PM
Sverddrager's Avatar
E00775
Fan/fridge noise. Loud all the time
Sverddrager is offline
post #20 of 1544 Old 07-11-2013, 06:47 AM
S T I G's Avatar
65VT60 - don't have the production number in front of me but I know the build date was May.
Before wall mounting, I could hear a soft humming only with volume muted.
Now that it's wall mounted, I can hear even louder the humming/pulsing with the speakers on (during quiet scenes only). I didn't use any "super slim" wall mount either. The fans have a decent distance to the wall.
I really don't want to go through the hassle of an exchange only to possibly have the same problem. I may see how I get used to it. Thankfully I don't notice it during normal volume levels from the speakers.
S T I G is offline
post #21 of 1544 Old 07-11-2013, 09:28 AM
E00775
My Panasonic zt 60"
Fan sound is very loud.
Is hearable even up to volum 40
post #22 of 1544 Old 07-11-2013, 10:19 AM
maley's Avatar
Ugh, I see the great deals on VT60s and I want to get one and I see this thread. Why can't Panasonic just make a perfct TV ._.
maley is offline
post #23 of 1544 Old 07-11-2013, 10:42 AM
Latinoheat's Avatar
Quoted: 1076 Post(s)
Liked: 824
That's what happens when you come here and read these forums, some people will make other people feel paranoid about the stupidest things. Just remember that only a small percentage of owners are on this forum and they post problems most of the time, the thousands that are happy with their sets are owners not on these forums. Not saying that no tv has no problems but sometimes they are glorified too much. In other words, if you really want something go get it, not all sets are the same, just like women.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #24 of 1544 Old 07-11-2013, 11:32 AM
Auditor55's Avatar
Originally Posted by Sverddrager View Post
E00775
My Panasonic zt 60"
how you can live with loud fans is beyond me, that's unacceptable.
Auditor55 is offline
post #25 of 1544 Old 07-11-2013, 11:36 AM
S T I G's Avatar
I just watched cable for about an hour and no fan noise even when muted. Im not sure why it was so loud the other night. It was on for about 2 hours and streaming a movie from amazon over wifi.
S T I G is offline
post #26 of 1544 Old 07-12-2013, 01:17 PM - Thread Starter
Lost!'s Avatar
Liked: 33
The noise depends on the room and the hearing abilities of the person. VT and ZT are both great sets, however, if you have expensive speakers, and if you are remotely audiophile, you may not be able to bear with the fan sound.
There are some alternative solutions, like building the redirection dampers for the fans as stated by some members in the ZT thread. If you truly love the picture, the last resort is to build those magnetic cardboard dampers. Most of us complaining don't want to believe that the problem is general, but unfortunately the odds of getting a good set is very slim.
Lost! is offline
post #27 of 1544 Old 07-12-2013, 07:34 PM
johnBoston123's Avatar
I tried the dampers and I couldn't get them to work for me. One thing I'm thinking of doing is covering the wall behind the tv with felt. I put a blanket behind the tv for a few minutes to test it out and it seemed to cut down the noise from a howl high pitched noise to just the fan noise which would be completely acceptable to me.
johnBoston123 is offline
post #28 of 1544 Old 07-13-2013, 01:46 AM
Just got maybe a good tip about the fan noise in the Panasonic ZT 60"
There is a serviceport on the backside that can be used to more adjustments.
It's supposed to be fore tecnicions, but as i understand, they can adjust the fan speed.
Will talk to Panasonic monday and find out how to acsess the port.
post #29 of 1544 Old 07-13-2013, 07:00 AM
sooke's Avatar
Quoted: 99 Post(s)
Liked: 69
I think felt behind the TV is a good idea. Please let us know if it works out for you. I don't own a ZT60 yet, deciding whether to buy one today, actually. Since it would sit between two book shelves in my family room, I was worried about fan noise being amplified/concentrated. So I was planning the exact same thing: some kind of sound dampening material on wall behind the TV.
Although, I've been watching a DLP for 10 years that has an audible spinning color wheel, so I might not notice fan noise much anyways.
Good luck.
Panasonic TC-P60ZT60 plasma panel
Sony BDP-S5500 Blu-ray player
Arris DCX3600-M DVR
Yamaha RX-V650 AVR
XBox One
URC MX-780 remote control
sooke is offline
post #30 of 1544 Old 07-13-2013, 10:01 AM
mAdCapper's Avatar
I already have the tv on a slim mount in the wall so I can't get production number or date but I can only hear the fan when muted, the room silenced and I am within 3 feet of the tv. 60VT60.
mAdCapper is offline
Panasonic , Panasonic Viera Tc P60zt60 60 Inch Plasma Tv , Panasonic Tc P60vt60 60 Inch 3d Smart Plasma Hdtv , Panasonic Viera Tc P65zt60 65 Inch Plasma Hdtv
