Huge stripe of purple burned pixels on my Panasonic 50" plasma - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-22-2013, 11:15 AM - Thread Starter
kevo82's Avatar
I have this huge purple stripe on my 50VT20 plasma.
First it disappeared after i switched inputs, but now it's permanent?
My TV it's still in warranty, but do you think that this it's covered by the warranty?
kevo82 is offline
post #2 of 2 Old 06-23-2013, 05:31 AM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
Very common. Not burn in.
http://www.avsforum.com/t/1463226/panasonic-vt20-rectangle-top-left-issue
If you want to fix it yourself, go up there.
But try to get it repaired under warranty and argue since it goes away now and then, it is not burn in but a fault due to loose connector on the panel.
tom669 is offline
