Samsung F8500 Plasma Buzz and Buzzing, do they all? - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 116Likes
post #181 of 1139 Old 02-19-2014, 02:09 PM
Tandrin's Avatar
This "remote IR" buzz was loud and angry!
Tandrin is offline
post #182 of 1139 Old 02-19-2014, 02:17 PM
bullme109's Avatar
Originally Posted by Dougofthenorth View Post
On some, there seems to be 2 types of buzz - I from frame that have a chance of being fixed
However the "general screen buzz" very directional seems not to be solvable or able to be moderated, sadly in a lot of cases
like mine - frame solved, screen no
More 60" seem to be afflicted by the angry beehive issue
Sad, as it is a beautiful screen - I'm keeping it & accepting it (1st one was returned)
Exactly. I could definitely manipulate the frame buzz, but the loud directional buzz from the center of the screen would not go away. Kills me because again, great picture. But any movie with quiet dialogue drives me nuts.
bullme109 is offline
post #183 of 1139 Old 02-20-2014, 02:55 AM
Dougofthenorth's Avatar
Liked: 44
Sounds like it's like my 1st returned set.
This one is lower enough that it is liveable
Can you raise or lower it?
I took off the curved Sammy stand & mounted it ~8" higher - no way! - I'm going to be putting it back down.
Some have claimed moving it up or down solved almost all the issue - this screen buzz is VERY directional
Dougofthenorth
www.turtleshelltortue.org RIP
Dougofthenorth is offline
post #184 of 1139 Old 02-20-2014, 06:50 AM
bullme109's Avatar
Yea, I thought about it, but even mounting it wouldn't fix my issue. Just changing my position up or down, you still get that loud directional buzz from the center. I was literally sitting way off to the side to watch movies. Then I was like, wait, I spent almost $3 grand on this TV, haha, this is ridiculous. Decided to return it.
Now I'm just debating on waiting on the 2014 plasmas, or seeing how much better the new LCD's get. But blach, I hate even using the word LCD. Seems dirty. Then again, I haven't checked one out in years, so I'm sure they're much better than they were 5 years ago when I bought my last plasma.
post #185 of 1139 Old 02-20-2014, 08:00 AM
Liked: 44
Off to the side is one I haven't come across yet!! whoa that's terrible! Mine is so precise of a pinpoint direction just raising or lowering my head affects it.
I have a very costly 32" LCD monitor for gaming fantastic for TV or movies eech!!
EDIT 2nd LCD changed to LED
Dougofthenorth
post #186 of 1139 Old 02-22-2014, 03:08 PM
cyphron's Avatar
Liked: 31
I have a solution to my issue. I'm not sure if it applies to other, but I noticed that when I moved my power cable from an extension cord to the wall unit, the buzz decreased. The cable has a ferrite core on it. So what I did was purchase 10 ferrite cores from Amazon and put one on each cable that connects to the TV. Apparently, plasmas put out tons of RF signals and the cables seem to radiate these signals. My buzzing has significantly went down and I can now only hear it when I'm right next to the screen. I'm not sure if it will work for others, but it may be worth a try to disconnect all cables from the TV to see if your buzzing goes down.
Another issue is that ever since I switched over to Antenna only, the TV kills VHF channel 7 every time it turns on. I can watch channel 7 on my other TV, but the moment the F8500 turns on, it kills the channel on all TV's, without fail. So for some reason, this TV (or my particular TV) outputs a signal that kills VHF channel 7.
cyphron is offline
post #187 of 1139 Old 02-22-2014, 03:43 PM
Liked: 44
Glad you got good results!!
I go directly from the F8500 to the TV plug on my rack mount Monster power conditioner. I have the ferrite core on the TV power plug right at the plug at the TV.
No other cables except 1 HDMI to input 1 on TV.
The TV does not affect any other component or remote IR or RF
I don't use any U/VHF sources.
I would love to see what frequency the buzz is... I don't have equipment to measure it...
Dougofthenorth
post #188 of 1139 Old 02-22-2014, 03:46 PM
wxman's Avatar
Quoted: 4526 Post(s)
Liked: 3114
I had the same issue with vhf 7 on both my plasma tv's (Pionner and Samsung). A bit different though. Everytime someone would turn on a light, I would lose the channel for a split second. Just that channel via OTA amplified antenna. Once I got a better surge protector, that fixed the problem. I don't think it was the tv, but the amplifier on the antenna. Another issue is what type of speakers you have next to your tv. Not all are shielded, and that can also cause issues.
LG 65E6P FW 05.30.02
LG 65EF9500
wxman is offline
post #189 of 1139 Old 02-22-2014, 05:07 PM
cyphron's Avatar
Liked: 31
I moved the antenna to the roof from the attic and channel 7 is back. Unfortunately, I can still hear the buzz, but not as loud if I put position my body just right with total silence. Pushing on the back of the TV diminishes it somewhat so I suspect it's some sort of vibration from the high current that the plasma produces. I'm not going to worry about it any more because I usually watch TV with the sound volume up, at -20 DB from my AV receiver. I only hear it when the sound is muted with everyone silent. I'm not even going to worry about it any more and just enjoy the TV.
cyphron is offline
post #190 of 1139 Old 02-23-2014, 05:18 PM
newfmp3's Avatar
Quoted: 290 Post(s)
Liked: 266
mine buzzes as well. Certainly louder then my Panny's. Its lower right side, about 1/3 of the way in. If my head isn't in front of it, I don't hear it even in a dead silent room. But if my head is in the right spot in front of it, even dead center to tv, I can hear it quite clearly even over low tv volume. Its not enough for me to return it. I am very easily irritated by buzzes - so obviously it is not that bad. Seems to vary a bit too, with some days its just not that bad.
60" model, a few days old.
newfmp3 is offline
post #191 of 1139 Old 03-20-2014, 10:11 AM
Rekonn's Avatar
I bought the 51" F8500 a couple weeks ago, had it mounted on the wall, and noticed the buzzing right away. I'd describe my hearing as a little below average. I'm 36, used to go to heavy metal concerts, and have a hard time making out what people are saying in bars and other loud places.
Doesn't matter if I was directly in front or off to the side. The noise was noticeable and distracting from 9-10 feet away until volume on tv is set to 10. It's a constant noise, though it got a little worse when displaying bright video. It sounds just like that youtube vid in post #97 of this thread.
I called up Samsung tech support, they told me that all plasmas buzz, and that I could try lowering the brightness or contrast settings. I did, difference in noise was negligible, and certainly not worth it. I tried pressing fingers against the frame in various spots, no change.
I went to best buy, and they had a 64", same model set up in their home theater room. Nice salesguy turned it on, set volume 0, and shut the doors to the room. I know the ambient noise is still much higher in store, but I couldn't hear the buzzing even when standing 2 feet away. I hope that means I just had a bad one. I decided to do an exchange, had a new one delivered this morning, and can't wait to get back home to see if it's is better.
Rekonn is offline
post #192 of 1139 Old 03-20-2014, 10:28 AM
bullme109's Avatar
I went through 3 F8500's. Two were the 60", and had horrible buzz. It literally ruined any movies with quiet dialogue. Samsung also gave me the "all plasmas buzz" line, which really, is BS. I own two other older plasmas, one Panny and one Samsung. They both don't buzz, and you don't hear anything unless your head is pressed against the back of the TV. Totally silent. The two 60" F8500's sounded like a bee hive, it was ridiculous. Even from 8-10 feet away, coming from the center of the screen.
Last one I had was the 64", which definitely buzzed less than the 60"s I had, but was still loud enough to ruin quiet movies for me. I just couldn't justify keeping a TV that costs near 3 grand with those types of issues. Great picture though. For now I'm sticking with my 5 year old plasma. The buzzing on the F8500 made me fall back in love with it, so so quiet.
post #193 of 1139 Old 03-20-2014, 01:00 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
All plasmas do buzz, yes, but they don't buzz at the same frequency or decibel level. wink.gif
vinnie97 is offline
post #194 of 1139 Old 03-20-2014, 01:12 PM
fierce_gt's Avatar
Quoted: 1772 Post(s)
Liked: 1689
has ANYBODY returned a plasma and been happy with the replacement?
seems like there's only two options:
A) i bought my tv, it's awesome, can't hear any buzzing at viewing distance while watching content.
B) i returned 17 units and they all buzzed super loud, now i have a different model
i REALLY think buzzing is about personal sensitivity.
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is offline
post #195 of 1139 Old 03-20-2014, 01:21 PM
Liked: 44
I returned my 1st one & the replacement is much better (61db at screen (Xdb ?? I forget) 11-12 ft away)
- annoys me sometimes, but overall I can live with it. Now has thousands of hours on it
In some of the topics a few have done MANY replacements & finally got a good one.
Some just gave up & got another model... I got a better one with 1 exchange
As for "i REALLY think buzzing is about personal sensitivity"
Apparently for some sets, that doesn't hold true as an absolute.
- that 1st set is still in the store as a demo & a loaner
- over 30 people who sat down to view it (not walked by it) have remarked that the buzzing is totally unacceptable.
- that one is a directional screen buzzer, not rear metal mesh buzzing (81db at screen 41 11-12 ft away) thousands of hours on it
60" are the most problematic with regards to buzzing
Dougofthenorth
post #196 of 1139 Old 03-20-2014, 02:10 PM
bullme109's Avatar
Not really, like I said, I have two other plasmas that are almost silent. Only the F8500 drove me insane. The 64" was definitely quieter than the 60". If you're talking specific to that model, than maybe. But I returned the same model of my older Samsung years ago for the same model and the replacement was totally silent compared to the original. It just really seems to vary by set. My old Panny was quiet on the first try. It sucks, because I really don't like LCD. For now I'll just live with my older plasmas.
post #197 of 1139 Old 03-23-2014, 01:42 PM
Nazgul's Avatar
Ugh, so got my 60' F8500 on Friday from Amazon and it has the dreaded buzzing from like 7-8 feet away, but like most people's it's only if you sit in dead center (best spot ironically). It's AWFUL and is driving me totally nuts, seriously WTF is up with Samsung? I've been running the slides in a almost continuous loop since then but it hasn't dented the buzzing. Figure I have maybe 40 hours on it? Has anyone had this directional center buzzing and had it go away after a prolonged like 200+ hour break-in period? Other than the buzzing the TV is awesome, screen is flawless with no pixel, line or banding issues. I would rather not swap it out or have a technician come out if I can have it go away with 200 hours of break-in. Thoughts?
Nazgul is offline
post #198 of 1139 Old 03-23-2014, 03:25 PM
Liked: 44
Factually, I have NOT seen any 60" get better - as a matter of fact mine seems to be increasing in buzz lately & I have over 2,000 hours & adding 8-10 more a day
- NOT better
- my first one was even worse with 81db at screen
Sammy tech came out with an SPL meter, for the first one - I was told it is "within Samsung specs" - absolute nonsense mad.gif
60" are the worst of the 3 sizes - some 60" owners say they have no buzz or can't hear it - I need facts to believe that
Dougofthenorth
post #199 of 1139 Old 03-24-2014, 09:30 AM
Beefwahl's Avatar
I took delivery of a 60f8500 on Saturday. I've wall mounted it using a Monoprice slim mount.
Love the picture, smart hub, design, etc., but, it's a BUZZER. My centered, main viewing position is
on the couch roughly 12 feet away from the center of the TV and I am accutely aware of the buzz.
I move a foot to the left or right and the buzz more or less goes away. I can hear it over a
15 volume using built-in speakers. I can even hear it droning away when I listen to the surround sound system.
Thinking about the buzz while here at work is giving me a headache. It's a shame.
But, I was prepared for this after researching prior to ordering.
I've contacted Nebraska Furniture Mart here in KC and arranged a swap. New set will be delivered in two days.
Hope I hit the "No-buzz lottery" with the new set. I'll let you know...
Beefwahl is offline
post #200 of 1139 Old 03-24-2014, 12:29 PM
Nazgul's Avatar
Ugh WT* Samsung.... this is so easily replicatable I can't believe they are unable to fix it. I haven't poured over every post on the F8500 but has anyone given a reason behind the weird one directional buzzing? What is Samsung going to say, don't sit at the best spot in the room? lol
Nazgul is offline
post #201 of 1139 Old 03-26-2014, 01:09 PM
Beefwahl's Avatar
Got the exchange today. Exactly the same deal. No buzzing from sides or back. No audible buzz heard with ear near the screen.
Walk back to about 3 feet from center of screen and BBZZZZZ. Best seat in the house, dead center of screen, 11-12 feet back, BZZZZ.
Gonna let it marinate over the weekend. See if it gets better or if I start to become less aware of it.
If I can't stand it after 4 or 5 days, I'll return it and grab a 65F8000. /shrug
Beefwahl is offline
post #202 of 1139 Old 03-26-2014, 01:45 PM
hpp8140's Avatar
Quoted: 280 Post(s)
Liked: 87
What size? Hate to break it to you, but it won't get better. Since it's a plasma, the best seat in the house is not necessarily in the center.
LN55C630, PN64F8500, Definitive SSA-50, GE Supercinema 3D Array X, Paradigm Millenia CT
hpp8140 is offline
post #203 of 1139 Old 03-26-2014, 01:53 PM
Beefwahl's Avatar
It's a 60-inch. Not a problem to exchange it out in a week or so if I can't get over it.
I take comfort in knowing that anytime a bee buzzes towards me or I walk under a set of buzzing powerlines, memories of these precious inky-black days will come flooding back...
Beefwahl is offline
post #204 of 1139 Old 03-26-2014, 01:59 PM
Beefwahl's Avatar
Did you exchange your 60' for a 64"? If so, does it too have the front and center directional buzz? My zest for plasma is very low, but I would consider an exchange to 64" if I had a better chance of getting a "non-buzzer, although, an LED sounds like a nice safe bet at this time...
Beefwahl is offline
post #205 of 1139 Old 03-26-2014, 10:50 PM
hpp8140's Avatar
Quoted: 280 Post(s)
Liked: 87
Yes, I did exchange for the 64. It is much quieter than the 60" and not annoying in pitch....more like a humm.
hpp8140 is offline
post #206 of 1139 Old 03-27-2014, 12:39 AM
igreg's Avatar
Quoted: 270 Post(s)
Liked: 47
I have a Panasonic plasma.....no buzz at all. Zero.
ChadThunder likes this.
igreg is offline
post #207 of 1139 Old 03-27-2014, 07:56 AM
Rekonn's Avatar
Update, got my replacement set, also a 51" F8500, it's somewhat better. Sat on same spot on couch, watched same show. On mute, still very noticeable. At volume set to 7 I notice it slightly, and at volume 8 I can't hear it anymore. I was hoping for better, but I think this is good enough. I watched 3 episodes of Walking Dead last night at volume of 20 and didn't notice the buzzing at all during quieter scenes.
Maybe someday high end tvs will come with separate power supplies like computers have. Would love to put that noisemaker in the basement or in a closet, and would happily pay extra for that feature.
Rekonn is offline
post #208 of 1139 Old 03-27-2014, 07:58 AM
Beefwahl's Avatar
Exchanging the 60F8500 plasma for a 65F8000 LED tomorrow. My wife is tired of the TV stuff. My plasma experiment is over. Can't deny the great picture; can't ignore the BUZZZZZ.
Beefwahl is offline
post #209 of 1139 Old 03-27-2014, 08:47 AM
Nazgul's Avatar
Sometimes I think I can ignore it, then BAM it's there. I enjoy sitting front and center of my TV, sitting to the left or right is just bizarre (when it's just me). I'm tempted to open it up and see if there's anything I can do inside. The picture is just so nice, why oh why can't they just fix the issue? :-/ I've heard that the 64's don't really buzz, so maybe I can go to that....
Nazgul is offline
post #210 of 1139 Old 03-27-2014, 08:53 AM
chunon's Avatar
Quoted: 2494 Post(s)
Liked: 2231
I wouldn't put up with that if it was my set its to bad that particular size seems to be plagued with the buzzing.
Sony 75XBR940E
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv , Samsung Pn60f8500 60 Inch 1080p 600hz 3d Smart Plasma Hdtv
