Scrolling white bars almost every night...too much? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 06-27-2013, 04:41 AM - Thread Starter
garthy232's Avatar
So, I know this has probably been asked quite a bit already but I couldn't find anything on it particular. I have a panny VT series and I do watch shows and games that have static logos often, it seems like its inevitable and you just can't get away from them. Has over 1000 hours on it already, never had burn-in issues on it. Almost every night I am finding myself running the scrolling white bars to get rid of the IR which does its purpose with flying colors. I feel like I shouldn't be doing this every night or am I wrong?
garthy232 is offline
post #2 of 12 Old 06-27-2013, 05:41 AM
chunon's Avatar
Quoted: 2039 Post(s)
Liked: 1787
If you are gaming regularly doesn't seem excessive to me, if you aren't gaming then it is much more proactive than I would be. I never run the scrolling bar and have not had one single intstance of ir that I have noticed but I don;t game on my set so can't speak to that.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #3 of 12 Old 06-27-2013, 06:14 AM
Awenta's Avatar
Depends what you're watching. But either way it won't hurt it.
Sent from my SCH-I535 using Tapatalk 4 Beta
Awenta is offline
post #4 of 12 Old 06-27-2013, 06:25 AM - Thread Starter
garthy232's Avatar
Sorry I should've clarified, I don't game (xbox, ps3 etc.) but I watch games as in sports (football, tennis, baseball etc.) I do have high contrast on the TV around 98 which I'm sure doesn't help with the IR.
post #5 of 12 Old 06-27-2013, 06:32 AM
chunon's Avatar
Liked: 1787
My ISF Day mode contrast is 100 I never run the scrolling bar and never see IR, so yes in that case I see that as excessive. Have you ever not run the bar to see if your IR disappears on its own, I watch plenty of sports also and have had no issues thus far.
65C6 OLED
chunon is offline
post #6 of 12 Old 06-27-2013, 07:30 AM - Thread Starter
garthy232's Avatar
I think maybe once or twice I saw IR, but that was only with a completely white background. I assume it goes away after a while with regular content and with the TV off?
post #7 of 12 Old 06-27-2013, 07:47 AM
chunon's Avatar
Liked: 1787
Yes it will, if you want to be diligent run the scroll bar once a week or so beyond that I think it is overkill
65C6 OLED
chunon is offline
post #8 of 12 Old 06-27-2013, 08:29 AM - Thread Starter
garthy232's Avatar
Ok I'll give it a go. Thanks
post #9 of 12 Old 06-28-2013, 09:05 PM
Awenta's Avatar
I usually run it about 6 hours once a week. Just play music or something and let it go as long as I don't have to be in there.
But I also turn it on if I have a paused image on the screen and need to leave the room.
Awenta is offline
post #10 of 12 Old 06-29-2013, 12:20 AM
adone36's Avatar
Liked: 37
If it is not seen in normal playback, it does not have to be "fixed".
Tony
adone36 is offline
post #11 of 12 Old 06-29-2013, 06:32 AM - Thread Starter
garthy232's Avatar
Okay, that's what I figured. It is definitely not seen during normal content so we are not worried about it now.
post #12 of 12 Old 06-29-2013, 04:15 PM
k1ng617's Avatar
While playing GT5 I noticed the "now loading" indicator, the speedometer, and other static instrument images when a uniform screen pops up. I play the bars for a few seconds (5-10) and it disappears completely. So 6 hours might be a bit excessive IMO.
k1ng617 is offline
