Issue with Panasonic 58VT25 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 07-01-2013, 04:24 PM - Thread Starter
GMtheBest's Avatar
I turned on my tv today and noticed the new "feature" my tv developed over night. I have a rectangular area in the top right hand side of the TV that is pixelated\not displaying correctly. The TV is no longer under warranty, any idea what the issue could be and how I can fix it ?
vt25.JPG 1641k .JPG file
GMtheBest is offline
post #2 of 14 Old 07-01-2013, 04:50 PM
chunon's Avatar
Quoted: 2494 Post(s)
Liked: 2231
Pm tom669 he is very knowledgable about panny repairs
Sony 75XBR940E
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #3 of 14 Old 07-02-2013, 01:20 AM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
Loose connector is quite likely.
Take the back cover off and get pictures of inside the unit, then I will highlight the likely location of the fault, as simple as removing the connector and reinserting it.
tom669 is offline
post #4 of 14 Old 07-02-2013, 05:51 AM - Thread Starter
GMtheBest's Avatar
Thanks, I will work on it later today and post pictures. On a side note, I watched tv for about 2 hours last night and the issue resolved itself after about 1hr of being on. When I turned it on this morning, it was back.
post #5 of 14 Old 07-02-2013, 05:58 AM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
That's pretty typical for this kind of problem -- the connection becomes intermittent due to being incorrectly seated at the factory.
tom669 is offline
post #6 of 14 Old 07-02-2013, 02:14 PM - Thread Starter
GMtheBest's Avatar
Attached are the pictures (entire tv, left, center and right portions) Let me know if you need additional pictures or any closeups, etc. TV.jpg 795k .jpg file left.jpg 608k .jpg file center.jpg 817k .jpg file right.jpg 695k .jpg file
ID:	70476   Click image for larger version
ID:	70477   Click image for larger version
ID:	70478   Click image for larger version
post #7 of 14 Old 07-02-2013, 02:28 PM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
You should focus on this area.
Take a piece of tape or string from the exact middle of the fault area. Pull it over the TV frame; it will intersect one of the metal plates which connect to the panel itself.
You should then turn the TV off (unplug it) and leave it off for at least 5 minutes. Place one hand on the metal frame of the TV to ground yourself properly. Try to touch the frame while working on the set.
On the faulty part (if you are not sure do several in the same area) remove the screws holding the clamp down, unhinge the connector, bend the connector up, re-insert the connector, secure the latch (the cable should be completely parallel to the latch; no flex is permitted), screw the clamp down (very, very important, as if this is not done, the plasma panel driver will overheat after some time, which is a non-user-replaceable part) and power the TV back on.
This should hopefully fix the issue.
chunon likes this.
tom669 is offline
post #8 of 14 Old 07-02-2013, 02:49 PM - Thread Starter
GMtheBest's Avatar
Thanks, the problematic area is directly under the vertical part of the frame on the left side. I will remove that portion of the frame and let you know how it goes.
post #9 of 14 Old 07-02-2013, 03:03 PM - Thread Starter
GMtheBest's Avatar
Edit, removing the left vertical frame is problematic as there are screws at the bottom screwed in from the opposite direction. Any suggestions on how those should be removed ?
frame.jpg 939k .jpg file
post #10 of 14 Old 07-02-2013, 03:12 PM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
Not seen that before... You may have to take the stand off?
tom669 is offline
post #11 of 14 Old 07-02-2013, 06:42 PM - Thread Starter
GMtheBest's Avatar
I am having a heck of a time re-inserting the connector. Is there a specific technique?
post #12 of 14 Old 07-02-2013, 11:37 PM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
Just need to line it up in the slot then latch the connector down.
tom669 is offline
post #13 of 14 Old 07-03-2013, 07:24 AM - Thread Starter
GMtheBest's Avatar
I appreciate the help. Though I think in my frustration with removing-reinserting the ribbon cable I damaged it as a small corner of it is missing. I assume the other end is attached to the panel and cannot be replaced ?
post #14 of 14 Old 07-03-2013, 07:40 AM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
Not necessarily... that might be an alignment marker. Check the other ribbons to be sure. But if it is damage, yes, the panel would be scrap.
tom669 is offline
