question on dvi> hdmi sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-04-2013, 01:39 AM - Thread Starter
cinobyte's Avatar
I wanted to connect a pc to my Panasonic plasma tv through dvi to hdmi connection. the issue is getting sound to it. if i connect dvi to hdmi how can i get sound to pass through the tv since dvi will not pass sound? i THOUGHT i was going to be smooth and just connect speaker out on pc to one of the composite connections on the tv but it doesn't look like that will work. if i connect audio to a composite connection the tv expects the video signal to come from the same set of a/v connections.
any suggestions on this?
tia
cinobyte is offline
post #2 of 8 Old 07-04-2013, 05:33 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
What model plasma do you have? Most of my older generation Panasonic plasmas let you use the component audio in or front audio in for the HDMI audio, but you need to select the option in the menu to enable that.
tom669 is offline
post #3 of 8 Old 07-04-2013, 11:20 AM - Thread Starter
cinobyte's Avatar
its a p42c2. its not the end of the world if i cant i was setting up for the bedroom tv
cinobyte is offline
post #4 of 8 Old 07-04-2013, 11:36 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
Check the Sound menu, when on the correct HDMI source.
tom669 is offline
post #5 of 8 Old 07-05-2013, 03:08 PM - Thread Starter
cinobyte's Avatar
thanks ive owned the tv for years and never had any idea i could mix and match inputs
cinobyte is offline
post #6 of 8 Old 07-05-2013, 03:47 PM
slosvt's Avatar
Quoted: 59 Post(s)
Liked: 29
I have a DVI to HDMI cable hooking my HTPC to my Denon AVR and it will pass 1080P and DTS-HD with only one cable, so sound should not be an issue in your case?
slosvt is offline
post #7 of 8 Old 07-05-2013, 05:35 PM - Thread Starter
cinobyte's Avatar
its because i don't have an external amp like the denon. I do have that in my media room. but for the bedroom its pc straight to tv
cinobyte is offline
post #8 of 8 Old 07-06-2013, 03:15 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
Some graphics cards output sound over DVI, which is used if you have a DVI to HDMI cable. But not all of them do.
tom669 is offline
