Samsung ps50c550 Black area on screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-04-2013, 02:11 PM - Thread Starter
bradshawm's Avatar
Any ideas what's causing this? Started an hour ago and it's spreading the longer TV is switched on.
Any info would be gratefully appreciated
Attached picture shows patch as brown but it's really black and rest of picture is ok
STA70006.jpg 31k .jpg file
bradshawm is offline
post #2 of 4 Old 07-04-2013, 02:33 PM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
Minute crack in the plasma panel causing gas leakage. Not repairable. Call Samsung; known defect with these panels is sudden unexplained cracking, sometimes on the edge. Panel replacement required.
tom669 is offline
post #3 of 4 Old 07-04-2013, 02:47 PM - Thread Starter
bradshawm's Avatar
Thanks for your response
Black area now covering half screen and spreading
Set is 3 years old so at what point (age-wise) will Samsung say that it's not covered although it's as you say a known defect
post #4 of 4 Old 07-04-2013, 03:04 PM
tom669's Avatar
Quoted: 150 Post(s)
Liked: 140
I don't know if they'll replace it. Most panels had problems after around 6 to 18 months. If you get to Samsung Executive Support, you may get a discounted repair (pay labour only, around $200 to $300 for a panel swap is going to be typical.) You may even get a free repair, if you can argue the point well. But Samsung have never been great at after care. That being said, neither have Panasonic...
tom669 is offline
