LG 42PN4500 USB Video Playback possible? - AVS Forum | Home Theater Discussions And Reviews
Old 07-21-2013, 05:40 PM - Thread Starter
poocano's Avatar
Hi All,
A couple days ago my 2 year old Samsung PN43D490 died via "the click of death" so I decided instead of trying to fix to get the LG 42PN4500 which was on sale.
What I really liked about the Samsung was I was able to plug in a USB stick and play videos off of it. I tried on the LG and no luck. It seems to only support Audio/Pictures.
I've seen there is a hack to enable the video option but most of that seems to be geared older models. I was wondering if anyone had any info on the newer ones like mine?
Thanks for any help!
poocano is offline
Old 07-22-2013, 10:50 AM
myoda's Avatar
Liked: 57
Originally Posted by poocano View Post
Hi All,
What kind of video files are you trying to play?
These are the file formats the 43D490 supports:
Available video file
Maximum: 1920 x 1080 @30p (only Motion JPEG 640x480 @30p)
.asf, .wmvVC-1 Advanced Profile, VC-1 Simple and Main Profiles
[Audio] WMA Standard
.divx, .aviDivX3.11, DivX4, DivX5, DivX6, XViD, H.264/AVC, Motion JPEG
[Audio] MPEG-1 Layer I, II, Dolby Digital, MPEG-1 Layer III (MP3)
.mp4, .m4v, .movH.264/AVC, MPEG-4 Part 2, XViD
[Audio] AAC, MPEG-1 Layer III (MP3)
.mkvH.264/AVC, XViD, MPEG-4 Part2
[Audio] HE-AAC, Dolby Digital, MPEG-1 Layer III (MP3)
.ts, .trp, .tpH.264/AVC, MPEG-2
[Audio] MPEG-1 Layer I, II, MPEG-1 Layer III (MP3), Dolby Digital,
Dolby Digital Plus, AAC
.vobMPEG-1, MPEG-2
[Audio] Dolby Digital, MPEG-1 Layer I, II, DVD-LPCM
.mpg, .mpeg, .mpeMPEG-1
Available music file
File type : mp3
[Bit rate] 32 Kbps - 320 Kbps
[Sample freq.] 16 kHz - 48 kHz
[Support] MPEG1, MPEG2, Layer2, Layer3
Available photo file
Category : 2D(jpeg, jpg, jpe)
[Available file type] SOF0: baseline,
SOF1: Extend Sequential,
SOF2: Progressive
[Photo size] Minimum: 64 x 64
Maximum: Normal Type: 15360 (W) x 8640 (H)
Progressive Type: 1920 (W) x 1440 (H)
Items to note when playing videos
✎✎Some subtitles created by users may not work properly.
✎✎The video and subtitle files should be placed in the same folder. For subtitles
to display correctly, the video and subtitle files must have the same name.
✎✎We do not support any stream that contains GMC (Global Motion
Compensation) or Qpel (Quarterpel Motion Estimation).
✎✎Only H.264/AVC profile level 4.1 and lower is supported.
✎✎Video files that exceed 50 GB (gigabyte) are not supported for playback. The
file size limit is dependent on the encoding environment.
myoda is offline
Old 07-22-2013, 01:54 PM - Thread Starter
poocano's Avatar
Thanks for the reply. It's the LG i'm looking to be able to play the video files on. It's the Samsung I had no issues with.
I did figure out I can use my PS3 though and a USB stick with a quick conversion of the video file if necessary. Would like to just be able to plug the USB into the LG but this will work for now.
poocano is offline
Old 07-22-2013, 08:37 PM
myoda's Avatar
Liked: 57
What video file format were you trying to playback?
myoda is offline
Old 07-23-2013, 06:51 PM - Thread Starter
poocano's Avatar
Tried a couple, MP4/MKV, but the LG will only recognize pics/music
poocano is offline
Old 07-24-2013, 05:48 AM
myoda's Avatar
Liked: 57
I'd call LG about that..
myoda is offline
Lg 42lx6500
