Can you please Recc'd a HDTV Calibrator - AVS Forum | Home Theater Discussions And Reviews
Old 07-24-2013, 01:27 PM - Thread Starter
rimmi2002's Avatar
Quoted: 42 Post(s)
Hi after reading through so many settings it seems like its just best to get a calibrator and do this yourself for you ambient lighting and room. I'd like to buy a HDTV calibrator in the $150-200 range. Max $250 I guess if it is really good. Looking on amazon only thing I found is Datacolor Spyder4Pro or Spyder4elite. They are designed for Monitors which I'd like to use as well, but main reason for use will be HDTV. Says you can get a upgrade kit for TVs. Not sure how well this works. Can someone comment on this one or there something better that does the job.
The colors don't need to 100% right on accurate but if I can get in the 90~95% range I'll be very happy. Thanks!
rimmi2002 is offline
Old 07-24-2013, 01:33 PM
willieconway's Avatar
Quoted: 125 Post(s)
Liked: 135
I have the Calman 5 Tutorial + C3 combo and it's worked great for me. You may want to ask in the Display Calibration forum.
Adjusting settings according to personal preference is not calibration.
Epson 5030UB, 100" Carada Criterion with Classic Cinema White, Onkyo TX-NR818, NHT Classic 3s, Classic ThreeC, SuperZero 2.1s, Mirage Omni S10, Oppo 103D. Currently boxed up: Denon 1713, Klipsch SW-450,
NHT Absolute Center, Energy Veritas 5.1s, 5.2C, V-Mini-C.
willieconway is offline
