Panasonic TX-P42G20B Power Problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-25-2013, 08:41 AM - Thread Starter
Fishy1's Avatar
Hi,
I have a problem with my Panasonic Plasma TX-P42G20B TV which I hope somebody can advise me on?
The TV switches itself off and then the green led flashes 3 times and clicks 3 times as though you are trying to switch it on with the remote, it continues to do this repeatedly until you switch off at the mains, if you leave the TV off for a few hours it comes on again for about half an hour then switches itself off again repeating the same problem.
Would really appreciate some help with this
Thanks in anticipation.
Fishy1 is offline
post #2 of 3 Old 07-25-2013, 12:29 PM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
3 blinks is typically A or D board. PM me and I may be able to send you service documentation to help you fix it.
tom669 is offline
post #3 of 3 Old 02-05-2014, 02:05 PM
ezquerro's Avatar
Hi, Tom, maybe You know how to fix my Plasma TX-P42G20B ? it,s shows vertical bar in centre tv
http://www.1x2.talktalk.net/l3.jpg
ezquerro is offline
Panasonic Viera Tc P42g25 42 Inch 1080p Plasma Hdtv
