Horizontal Bars from Cable Box/Wii - AVS Forum | Home Theater Discussions And Reviews
Old 07-26-2013, 11:45 AM - Thread Starter
monkeymonkey35's Avatar
So, I'll just lay it all out:
The gear:
Panasonic Veira 50 inch Plasma
Denon AVR 3805 Receiver
Sony DVD player
Verizon Set Top Box
Verizon Modem/Wireless Router
Turntable plugged into receiver power outlet
Nintendo Wii
Very old house
Everything is plugged into one surge protector, on one outlet.
Upon installing the Verizon Cable TV, I noticed extremely faint horizontal bars. They only occured when the STB was connected and powered off. When you turned the STB on, they were gone completely (even if the image was very dark). So, I was convinced it was fine. At this time, the cable box was connected via component directly into the TV. Audio would output from the TV into the receiver via optical. Everything was fine.
Being as I have two other video outputting devices (the DVD and Wii), I decided to run them all through the receiver. Now, I get stronger horizontal bars that don't go away from video that goes through the receiver.
Cable TV: very strong horizontal bars
Wii: weaker horizontal bars
HDMI from computer to TV: no bars
TV apps (netflix): no bars
I tried turning the cable box off (and unplugging it), and the Wii still emits bars, so that might rule out a COAX grounding issue?
One other thing I tried was running the cable box to a different power outlet, and another time running the receiver from a different power outlet. This didn't fix it.
Any suggestions would be greatly appreciated! (please let me know if there's a specific product you use!)
monkeymonkey35 is offline
Old 07-26-2013, 03:50 PM
Latinoheat's Avatar
Quoted: 1088 Post(s)
Liked: 830
The gear:
Sony DVD player
Verizon Set Top Box
Nintendo Wii
Very old house
Post a picture of the problem.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
Old 07-26-2013, 04:12 PM - Thread Starter
I'm not going to be near the TV in question for a few hours. They're really just faint horizontal bars running up the screen. Bar Hum.
Old 07-27-2013, 09:39 AM - Thread Starter
Did I post this in the wrong forum?
Old 07-30-2013, 09:00 AM - Thread Starter
Anyone?? This is really frustrating. Attached is a photo of the issue.
Old 07-30-2013, 09:14 AM
Latinoheat's Avatar
Liked: 830
So you say this happened when you installed the Verizon cable box? And you can see them on cable and wii but not on computer? This would rule out the tv, if it was you would see them in every input or source. Have you tried an HDMI cable from cable to tv? Maybe your component inputs are no good.
Old 07-30-2013, 09:27 AM - Thread Starter
Hi,
It started when I connected the video components to my receiver. From the receiver they go to the TV.
The TV is fine, I'm sure of that.
Before I had things going through the receiver, there were very faint bars, but only from the cable box, and they were indiscernible while watching.
Old 07-30-2013, 09:41 AM
Latinoheat's Avatar
Liked: 830
Try an HDMI cable first from cable box straight to tv. And go from there.
Old 07-30-2013, 09:48 AM - Thread Starter
I will definitely try that to troubleshoot. There are a lot of benefits from running things through the receiver, so if possible, I will be shooting for that. Thanks.
Old 07-30-2013, 09:52 AM
Latinoheat's Avatar
Liked: 830
Yeah of course I have everything running through my receiver as well, we're just trying to find out the problem first.
Old 07-30-2013, 11:23 AM
njera's Avatar
How are you running audio from the computer to receiver... optical, coax, or analog RCA? PCs typically connect audio ground to case ground, which is usually ok but sometimes can create a ground loop.
njera is offline
Old 07-30-2013, 03:26 PM - Thread Starter
Verizon box to TV via HDMI works perfectly, no interference.
@njera, audio from Verizon Box and Wii goes into receiver via RCA.
I think there is a ground loop, but I don't know how to defeat it.
Old 07-30-2013, 03:49 PM
njera's Avatar
Actually, I was wondering about: "HDMI from computer to TV: no bars"
Do you have any audio running from the computer to your receiver? Just want to try to rule things out one by one.
njera is offline
Old 07-30-2013, 07:06 PM - Thread Starter
Oh, sorry, gotcha. It goes to the receiver via digital optical. (Computer HDMI->Tv->Optical->Receiver)
Panasonic 50 Inch Plasma Tcp50x5 , Denon Avr 3805s Home Theater Receiver
